New NHT Classic line to replace Super Audio - Page 395 - AVS Forum | Home Theater Discussions And Reviews
 248Likes
post #11821 of 11849 Old 09-04-2019, 11:47 AM
kombat's Avatar
Quoted: 37 Post(s)
Originally Posted by Lp85253 View Post
go with the c series instead .. on sale now .. this will save you from having to upgrade anytime soon..
The c-series is more than I want to spend.
kombat is offline
post #11822 of 11849 Old 09-04-2019, 03:12 PM
Quoted: 2137 Post(s)
Liked: 1807
check amazon,see if the current sale on the c1 fits your budget , if not the superones are said to be very good for the price..EDIT.. be advised , the price on c series is per speaker..
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is online now
post #11823 of 11849 Old 09-05-2019, 07:06 AM
kombat's Avatar
Quoted: 37 Post(s)
It is still.
My question was how do they compare to the Emotiva and HTD I am currently leaning towards, quality-wise and value. Emotiva B1+C1 is $478. HTD Level 2 would total $378, Level 3 $578. The NHT SuperOne + Center would be $333. Also, is the SuperCenter not well thought of? I see a lot of posts of people saying they use 3 SuperOnes across the front.
kombat is offline
post #11824 of 11849 Old 09-05-2019, 07:22 AM
Liked: 1807
It is still.
i have the b1's .. they are fine , the c1 is highly thought of , but i haven't heard it .. the super ones are probably a bit clearer but a bit brighter(treble emphasized).. if it was me with the 3 choices , i think i would get the nht's(super series) based on reported clarity but the emotiva's are pretty good and very smooth...
post #11825 of 11849 Old 09-24-2019, 12:29 PM
flyinrazrback's Avatar
Quoted: 154 Post(s)
Liked: 57
New to the group here. Just ordered 3 of the C-LCR speakers and 2 C3 bookshelves for my 5.1 system. Excited to see how they sound. Now just need a sub and a receiver. Leaning towards a Monoloth 15 or Rythmik FV18 for the sub and either a Yamaha 3080, Denon 6500 or Anthem MRX720 for the receiver. 100% Home theater use. Hope these speakers rock, kept going back and forth between these, RSL and SVS Ultras.
Lp85253 likes this.
flyinrazrback is offline
post #11826 of 11849 Old 09-24-2019, 02:42 PM
Liked: 1807
How well do th iC2, iC3 or iC4 work in ceiling for Atmos? Kicking around the idea of a 5.1.2 system with 2 speakers in the ceiling.
smart 1st choice , imo...my 2nd would have been rsl.. both good stuff though..
post #11827 of 11849 Old 09-24-2019, 03:24 PM
Quoted: 154 Post(s)
Liked: 57
Does anyone have experience with the iC3 or iC4 ceiling speakers? Looking at adding 4 atmos speakers to the NHT system I just bought but I can't find any good info about the iC4s except Amazon reviews.
post #11828 of 11849 Old 09-24-2019, 03:34 PM
Justins123's Avatar
Quoted: 12 Post(s)
I have a 5.2.2 system with 3.3s, AC-2, C-1s and iC4s. I have no complaints about the iC4s. Seems like you can occasionally find them pretty cheap on eBay. They might be overkill however if you're just using them for atmos. iC3s are probably fine.
Justins123 is offline
post #11829 of 11849 Old 09-24-2019, 04:03 PM
Quoted: 154 Post(s)
Liked: 57
Thanks for the info. The ic4 is actually cheaper than than the ic3, $182 for the iC4 vs $198 for the iC3 on Amazon. Best prices I have seen so far.
post #11830 of 11849 Old 09-24-2019, 07:44 PM
cwglideman's Avatar
Quoted: 71 Post(s)
Liked: 73
I've got 4 iC4's doing Atmos duty. Bought on ebay a few years ago...killer deal...all 4, brand new in box for $200.
7.2.4 surround system anchored by Classic 3s (w/ Classic3center) all around and Hsu subs.
I think you're gonna like the iC4's (or 3's). They have excellent dispertion with the tweeter array and blend/timbre match w/ the base speakers seamlessly. My receiver is the Denon 4300 but i'm using it in preamp mode w/ 7channels of amplification from Emotiva XPA 5 and a UPA 2, Receiver is powering the ceiling speakers. You will probably be fine though with just an 11 channel receiver (ie: Denon 6x00), if your room size isn't too massive.
I see NHT speakers on ebay frequently, so you should be able to find a pretty good deal on the iC4's or 3's if your patient.
cwglideman is offline
post #11831 of 11849 Old 09-25-2019, 07:03 AM
rmplum's Avatar
Boy I still love my Classic 3s so much. I have them in nowhere near an ideal room situation and they still have such a big, clean sound. Plus, considering how little they are worth 2nd hand I'll probably have them forever. The looks and design still knock me out.
Ryan
rmplum is offline
post #11832 of 11849 Old 09-25-2019, 09:23 AM
ace54's Avatar
Quoted: 93 Post(s)
wondering if anyone else finds dialogue from the TWOC too bright and harsh or maybe I just have sensitive ears iv'e compared it to my Superone and C1 the tweeter on the TWOC is harsh and loud it's definitely more clear and detailed but that comes at a cost the Superone and C1 tweeters have softer, toned down sound compared to the TWOC I guess all of NHT three way speakers are like this
ace54 is offline
post #11833 of 11849 Old 09-25-2019, 09:51 AM
Liked: 1807
that's a shame that your still having the issue.. have you called nht CS?( i assume you may have).. maybe do a return and use a c1 or super one as center?
post #11834 of 11849 Old 09-25-2019, 10:37 AM
ace54's Avatar
Quoted: 93 Post(s)
yeah I have the Superone as my center now I really wanted to keep the TWOC because it looks really nice and expensive but its not for my ears like someone on here said I bought the speaker to listen not to look at
ID:	2619802   Click image for larger version
Lp85253 likes this.
ace54 is offline
post #11835 of 11849 Old 09-25-2019, 10:40 AM
Liked: 1807
exactly .. do what sounds good to you , in the long run it isn't about $$'s spent .. it's about what you like..
post #11836 of 11849 Old 09-25-2019, 08:41 PM
cwglideman's Avatar
Quoted: 71 Post(s)
Liked: 73
I'm curious what source is powering your 2C2? I have 2C2 in my bedroom system and it sounds great. I used to have a Supercenter2 (w/ Superone's) and the 2C2 sounds way better to my ears. Much more dynamic and forward with way better dispersion (but not harsh at all) than the SC2. I'm using a Denon receiver to power them and they sound great.
post #11837 of 11849 Old 09-26-2019, 08:48 AM
ace54's Avatar
Quoted: 93 Post(s)
I'm using a Yamaha RX-S600 receiver MSRP: $649.95 Slim and compact 5.1-channel network AV receiver, with high-quality audio and convenient functions including AirPlay,AV Controller app and MHL support.
"Much more dynamic and forward with way better dispersion" Agreed the TWOC does sound better to my ears it also sounds too bright and high pitched
ace54 is offline
post #11838 of 11849 Old 09-26-2019, 12:06 PM
cwglideman's Avatar
Quoted: 71 Post(s)
Liked: 73
Ok. I’m not familiar with that particular receiver but I have had Yamaha receivers before and from recollection, I do remember it being a bit brighter than the next receiver I brought, which was a Denon. Maybe it was the Audyssey xt32 in that receiver that tamed the brightness in my speakers to the room that it is in. Have you done any room calibration with the Yamaha or have absorbing elements in the room that could possibly tame the harshness, ie: carpets, drapes, furniture, sound absorbing panels, etc.?
Den: Sony XBR75x950g, Marantz sr8012, ATV4k, Oppo bdp105, Emotiva XPR-5/UPA-2, NHT ClassicThree+C3C/iC4x4, Hsu,7.2.4
Bedroom: Samsung 64f8500, Denon 4311, ATVHD, Oppo bdp93, NHT Absolute Towers x2, Classic2Center, Classic2 Surround, M&K sub 5.1
Headbanging: MacMini/Roon/Tidal HA-1, ProJect PreBox s2 PM-1, Senheisser 6xx
post #11839 of 11849 Old 09-26-2019, 03:46 PM
ace54's Avatar
Quoted: 93 Post(s)
I had a Denon receiver before the Yamaha I remember it wasn't as bright or neutral sounding as the Yamaha so It could be that the receiver and speaker are both bright neutral sounding producing extra bright, neutral sound I already did the auto calibration with mic when I first set up the speaker also turned the center speaker level to -3
I don't mind the neutral sound of the Yamaha receiver over the stereo sounding Denon The TWOC center sounds good with movies its only high pitched and too bright with Youtube videos and music
ace54 is offline
post #11840 of 11849 Old 09-28-2019, 06:24 AM
Quoted: 154 Post(s)
Liked: 57
I received my speakers today from Amazon, these are super nice looking! Decided to buy a second set of C3 bookshelves for a 7.1 system instead of 5.1.
Lp85253 likes this.
post #11841 of 11849 Old 10-30-2019, 04:20 PM
jhumur's Avatar
Quoted: 103 Post(s)
Liked: 37
Hey people. I'm currently (home) auditioning a set of C3 bookshelves with one LCR center channel. I just ran an Audyssey room cal, and Audyssey set the crossovers to 60 Hz for the bookshelves and 80 Hz for the center. I manually upped the crossover for the bookshelves to 80. My question is, does anyone have any recommendation to where I should set them? My sub is a RSL Speedwoofer 10s. (Just so happens I'm also auditioning a RSL setup at the same time. I switching back and forth but keeping the sub the same.)
jhumur is offline
post #11842 of 11849 Old 10-30-2019, 04:29 PM
SnellKrell's Avatar
Quoted: 217 Post(s)
Liked: 72
That's like asking how high is up?
There are so many variables - room size, furnishings, etc.
Listen, listen, listen!
Try various recordings that feature substantial bass and go back and forth.
It's what sounds better for you.
Lp85253 likes this.
SnellKrell is offline
post #11843 of 11849 Old 10-30-2019, 06:16 PM
jhumur's Avatar
Quoted: 103 Post(s)
Liked: 37
Yes, I understand that. In the end, it's what sounds best to one's ear. I've run the gamut of frequencies from 40 to 200 and haven't heard much of a difference. That's why I decided to reach out to the community to see if there was a general consensus of sorts.
jhumur is offline
post #11844 of 11849 Old 11-02-2019, 08:58 AM
adam2434's Avatar
Quoted: 343 Post(s)
Liked: 167
Have you compared the NHTs to the RSLs yet? Just curious on your impressions.
Regarding crossover for mains and center, I generally experiment in the 60 to 100 Hz range to find the best balance of blend and slam. Having multiple subs helps with this.
FYI, a lot of folks bump sub level several dB post Audyssey.
What version of Audyssey do you have?
With XT32 and the MultEQ Editor App, many folks prefer to limit equalization to below 200-400 Hz to help with room resonance, but not alter the midrange and up.
5.1 and 2.0 ch: Marantz AV7704/Emotiva DC-1/Rotel RB-1582 MKII/Audiosource Amp Three x 2/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage and Dayton IO655 on patio. 2.1 ch: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2. 2.0 ch: Outlaw 975/Outlaw M2200 x 2/Klipsch RF-7 III/Sony ES BDP/LG 65" LED. 2.0 ch: Klipsch Powergate/NHT SB3. Kitchen: Sonos Play5.
adam2434 is offline
post #11845 of 11849 Old 11-02-2019, 07:09 PM
jhumur's Avatar
Quoted: 103 Post(s)
Liked: 37
Yes, I have had an opportunity to listen to both of them, at first without any calibration then with. I'm not a seasoned audiophile so I probably won't be able to give you truly meaningful insights, but here are my observations, through untrained eyes. Hope it helps.
NHT C-3+C-LCR+Speedwoofer 10S: They sounded a bit harsh, especially with Audyssey room calibration, so much so that I had to do most of my listening with MultEQ X32 off. The clarity you get from these speakers is amazing and they image beautifully. All in all, they're fantastic speakers. I just wish they weren't so bright at the top end. I contacted Jonathan Sun, NHT's GM. He volunteered the fact that the speakers are a little harsh out of the box, but also said they'd mellow out with some break-in time. I simply haven’t had enough time on them at a decent listening levels to do them justice. I got them from Amazon for an amazing price: $275 for each of the C-3s, and $278 for the C-LCR. But I'm planning to return them for two primary reasons: One is that I still have a few more speakers that I want to listen to before making a final choice. The other is that the two C-3s that Amazon sent me are pretty mismatched, by 2 dB according to Audyssey. I know it's not room placement or poor mic positioning. I've swapped the position of the two speakers, and taken great care to line everything up perfectly with a tape measure and a level when making calibration runs. That 2 dB difference in sensitivity between the two C-3s is real.
RSL CG5+CG25+Speedwoofer 10S: I’ve only had a few hours of listening on them but so far I like them a great deal. They sound more well-rounded, not as stark as the NHTs, go lower and give you plenty of detail. They don’t image the way the NHTs did but that may be because I haven’t found the ideal amount of toe-in. Subjectively speaking, I get the sense that they’re of a higher quality. I’ll give you more update in a few more days.
Regarding crossover, I settled on 80 Hz for NHTs and 60 for the RSLs. That’s where they sounded the best. Regarding Audyssey, what I’ve learned from this experience is exactly what you alluded to: that it sucks for the mid-to-high frequency range. I’m using a Denon X3500H so it’s MultEQ X32 for me. The MultEQ Editor App sounds like it might be life saver but 20 bucks?
Finally, Audyssey trimmied the sub (I’m using just one) to –4 dB. Should it bump it up to 0? (EDIT: I did some reading about subwoofer calibrating and came to the conclusion that would be a bad idea. I should rather turn up the subwoofer gain enough that Audyssey gives me a negative trim of 9 or 10. Then set the "Subwoofer Level Adjust" in the setup menu to -5 or -6...thereabouts.)
jhumur is offline
post #11846 of 11849 Old 11-03-2019, 08:05 AM
adam2434's Avatar
Quoted: 343 Post(s)
Liked: 167
[/LEFT]
A 2 dB difference in the C3s would make be believe that one of them is defective, so I understand why you are returning the NHTs.
I feel the MultEQ Editor App is worth the 20 bucks because it allows you to limit the correction range an make other tweaks/experiments.
Regarding sub level, yes, keeping the sub level in the "-" even after post-Audyssey boost is a common recommendation. Personally, I don't boost with the "Subwoofer Level Adjust" feature. I boost in the source-specific channel level adjustment, where I increase both of my subs 5-7 dB depending on source material, while still keeping the sub levels in the "-".
If/when money and space allow, I have found that adding a second sub (with same design) is a nice upgrade in bass headroom and smoothness. Just an upgrade path to consider for the future, regardless of the main speakers chosen...
jhumur likes this.
adam2434 is offline
post #11847 of 11849 Old 11-08-2019, 11:17 AM
helier's Avatar
I currently have an NHT system consisting of Classic 2 FLR a classic 2 center and classic ones at rear plus Atmos speakers also from NHT. This is all being powered by a Yamaha Aventage RX1060.
I have now placed an order for C3 to use in the front LR instead of the 2s. My question is, am I going to be OK power wise?
The room is not big and I do not listen very loud, however I know speakers do not sound their best if not properly powered.
What say you folks?.
The yammie is rated at 110 watts/2 channels driven.
helier is offline
post #11848 of 11849 Old 11-08-2019, 04:19 PM
afrogt's Avatar
Quoted: 2214 Post(s)
Liked: 1461
^^ Both the NHT Classic 2 and C3 have a sensitivity of 86db. Actually the C3 is 87db so if your Yamaha RX-A1060 has no problem with the current speakers, it'll have no problem with the C3 either.
Lp85253 likes this.
Afro GT
afrogt is offline
post #11849 of 11849 Old 11-09-2019, 05:37 AM
helier's Avatar
Thanks a lot, I feel more at ease right now.
helier is offline
Reply Speakers
