Calling all Polkies:Official Polk thread - Page 1357 - AVS Forum | Home Theater Discussions And Reviews
 1898Likes
post #40681 of 45489 Old 09-26-2015, 03:22 PM
chi_guy50's Avatar
Quoted: 2275 Post(s)
Liked: 2345
Originally Posted by dj7675 View Post
When you installed them, did you put any backing/backer box/ sound absorbing material behind them?
I am trying to decide between the 80 f/x rt or the 700 ls for my atmos ceiling speakers. Any thoughts on which would be better?
You don't mention whether budget is a concern, but I'm going to assume that "money is no object" does NOT apply.
Of those you mention (and bear in mind that there are a host of other suitable options available to you), I would recommend that you go with the 80F/X-RT, with their dual 3/4-inch aimable tweeters and 8-inch woofer. You can currently buy them at Polk Audio's eBay store for $216 a pair. They are listed as refurbished, but my extensive experience is that you will not see any difference between the new and refurb'ed speakers they sell other than that the refurbs carry a 2-yr warranty vs. 5 years for new.
FWIW, I originally purchased my first pair of 80F/X-RT for use as surrounds and chose them over the RC80i for their quality, versatility, and with an eye to upgrading my mains at some point from the Monitor series to the RTi series (which I have since accomplished). As surrounds they are fabulous; as heights they will see much more limited, less demanding service; but there's no substitute for quality and they're still a great deal at the discounted price of around $100 each.
I did make backer-boxes for my four in-ceiling speakers and would recommend that you do as well if feasible. I wanted to protect the speakers from heat and debris in the attic as well as to enhance their acoustical properties. I made my backer-boxes out of cheap rigid foam insulation boards that I had on hand and foil duct tape. Here are some pictures:
ID:	963321   Click image for larger version
ID:	963329   Click image for larger version
ID:	963337   Click image for larger version
Living Room: Sony XBR-65Z9D; Oppo UDP-203; Nvidia Shield TV; Roku Ultra; Denon AVR-X8500H (9.1.4/13.1); Polk Audio RTiA7 (Fl/r), CSiA6 (C), RTiA5 (Sl/r & FW), OWM5 (SB), 80F/X-RT (FH, RH); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929, DarbeeVision DVP 5000S, Amazon Fire TV 4K, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is online now
post #40682 of 45489 Old 09-26-2015, 04:18 PM
dj7675's Avatar
Quoted: 123 Post(s)
Liked: 57
Thank you for the detailed reply. In particular the home made backer boxes with common materials. The Polk eBay store is exactly where I was looking at the 80 f/x-rt. it is s great buy. I decided for the 700-LS. I may upgrade my fronts to the LSI Polk's at some point and this would match those. Tip ended up getting the 700-LS for $100 each which I just couldn't pass up. Here is a link to the LS-700. http://www.polkaudio.com/700ls/d/1065C2880
Thanks again.
climber07 likes this.
dj7675 is offline
post #40683 of 45489 Old 09-29-2015, 06:53 AM
asharma's Avatar
Quoted: 1879 Post(s)
Liked: 610
Help please Polk LSiM series issue
Hi folks....really need some help with this...I have the LSiM series speakers 705s,706, 703s...I am running a Denon 4100 as a pre amp into an Emotiva UPA-7 125 wpc 7 channel amp...I am streaming FLAC via a Sony BDP 6200 from a NAS...
When listening to 2 channel, I seem to be getting a certain underlying resonance with high pitched female vocals that follows the frequency of the vocal. 3 of my 5 speakers had the tweeters replaced as there was an obvious vibration coming from the tweeters when listening to certain material. I tested against that same material, after replacing the tweeters and it is not vibrating any more...
To test whether this was a room acoustics issue, I put the 706 mother center in the middle of the room and treated it as a left channel. Same resonance occurred during high pitch sound with certain material. This speaker is brand new and did not have the tweeter replaced.
Looking for advice folks...is this a speaker issue, room issue, equipment issue or source issue?
Thanks folks, really need your help as these speakers are not inexpensive...
asharma is offline
post #40684 of 45489 Old 09-29-2015, 08:21 AM
PretzelFisch's Avatar
Quoted: 491 Post(s)
Liked: 301
That sounds pretty much how my tweeter sounded when it started to go bad in my 705.
PretzelFisch is offline
post #40685 of 45489 Old 09-29-2015, 08:24 AM
asharma's Avatar
Liked: 610
Uggggg, I was afraid you were going to say that...did you replace the tweeter? Did it fix the issue? I have replaced both tweeters in the 705s...
zpatter1 likes this.
asharma is offline
post #40686 of 45489 Old 09-29-2015, 11:20 AM
asharma's Avatar
Liked: 610
Folks, just looking for any more input and your thoughts...thanks kindly
asharma is offline
post #40687 of 45489 Old 09-29-2015, 03:05 PM
Quoted: 394 Post(s)
Liked: 113
Hi everyone, i currently have a 7.1 setup (FR: Monitor 75T C: CS2 SR&SBR: TS110). i would like to upgrade to a 7.1.4 setup. Please what in-ceiling speakers would you recommend i get?
I also wanted to ask if there's a noticeable upgrade (night and day) in sound quality upgrading my Fronts to the RTIA7. Unfortunately i dont live in a country where i can demo the speakers.
Thanks for your advice and insights.
shyyour is offline
post #40688 of 45489 Old 09-29-2015, 03:10 PM
Quoted: 394 Post(s)
Liked: 113
i would like to upgrade to a 7.1.4 setup. Please what in-ceiling speakers would you recommend i get (room size is 29 x 14)?
Unfortunately i don't live in a country where i can demo the speakers for myself, hence why i am asking your reviw
shyyour is offline
post #40689 of 45489 Old 09-29-2015, 05:46 PM
RobLee's Avatar
Quoted: 294 Post(s)
Liked: 301
Yes, definitely!
Denon AVR-x3400H, Polk LsiM703's, 704c, 702f/x's, some Klipsch subs. Bedroom: Lsi9's, AVR-S930H
I once cried because I had no Atmos, until I met a man who had no stereo
RobLee is offline
post #40690 of 45489 Old 09-30-2015, 02:08 AM
Quoted: 394 Post(s)
Liked: 113
Originally Posted by RobLee View Post
Yes, definitely!
Thanks RobLee, if i do upgrade the Fronts to the RTIA7, would the timbre difference be off much from my current surrounds (TSX110) or do i have to change those also?
I would also appreciate any recommendations for in-ceiling speakers
Thanks again.
shyyour is offline
post #40691 of 45489 Old 09-30-2015, 08:46 AM
Quoted: 491 Post(s)
Liked: 301
Thanks again.
monitor 75 -> RITA 9
monitor 65 -> RTIA 7
just so that you know there will be some difference in the base response if you move from a 75 to a RTIA 7 without using a sub. You'll want to update the center when you have the chance.
post #40692 of 45489 Old 09-30-2015, 08:56 AM
enricoclaudio's Avatar
Quoted: 3870 Post(s)
Liked: 4758
Call Polk Audio and ask them to send you a new tweeter. My 706 had the same problem and after replace the tweeter with a new one the problem was solved. I also had same problem with one of my 703s tweeter but I took the tweeter out, disassemble it, assemble it back and the problem is gone.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #40693 of 45489 Old 09-30-2015, 09:35 AM
asharma's Avatar
Liked: 610
Thanks my 705s both have new tweeters from Polk but still getting resonance. Are you able to tell me what was involved with disassembling the tweeter. Are you suggesting you took the casing off the actual tweeter and looked at the guts of it...was there anything obviously wrong?
asharma is offline
post #40694 of 45489 Old 09-30-2015, 09:41 AM
Liked: 0
gift from younger brother SDA-2s, Denon AVR3300, a M & K subwoofer number inaccessible at this point. Vintage like me.
MobsTTa is offline
post #40695 of 45489 Old 09-30-2015, 09:47 AM
Liked: 4758
What do you mean by resonance? My issue was more like distortion or RF sound coming out of the tweeter itself at certain frequencies. Resonance is more related to the interaction between the tweeter assembling (case) and the speaker cabinet. I never had resonance issues with my LSiM speakers.
post #40696 of 45489 Old 09-30-2015, 09:51 AM
asharma's Avatar
Liked: 610
Thanks, it's hard to describe...during certain high pitch vocals, if I put my ear up to the tweeter, I can hear a resonance or vibration from the tweeter that follows the pitch of the vocal...I hear it in my seating position so to verify I put my ear up to the tweeter and that is where it is coming from...not sure if I am calling it resonance and u r calling it distortion...RF sound might describe it though...does Polk have an issue with their tweeters in the LSiM series? Also can you help me better understand the disassembly of the tweeter? Thanks again...
asharma is offline
post #40697 of 45489 Old 09-30-2015, 10:08 AM
Liked: 4758
Take the three screws out, pull out the tweeter coil just a little bit (be careful with the coil wires) and put everything back.
ID:	968577   Click image for larger version
ID:	968585   Click image for larger version
post #40698 of 45489 Old 09-30-2015, 10:24 AM
RobLee's Avatar
Quoted: 294 Post(s)
Liked: 301
Thanks RobLee, if i do upgrade the Fronts to the RTIA7, would the timbre difference be off much from my current surrounds (TSX110) or do i have to change those also? Thanks again.
Your surrounds should be fine for a while. It is not nearly as important that the surrounds match as do the front three. As Pretzelfisch mentioned, you will definitely want the center to match your Rti mains. You can usually find Csi5's online for under $200.
In my case, I upgraded the center first, from a CS2 to a CS20, and finally to a Csi5. The difference was literally "night and day". My Monitor 70's sounded so muffled compared to the Csi5. From there it was a natural progression up to RtiA7's and eventually A9's, then I replaced the Csi5 with a CsiA6 center just so the cabinets would match.
RobLee is offline
post #40699 of 45489 Old 09-30-2015, 10:40 AM
asharma's Avatar
Liked: 610
Wholly crap, wow, thanks...what do u think the actual issue is?
Also, if I pull out the tweeter coil just a little bit, will the 3 screws go back in correctly...?
asharma is offline
post #40700 of 45489 Old 09-30-2015, 12:29 PM
Quoted: 394 Post(s)
Liked: 113
Thanks that is my plan; upgrade each section one after the other (fronts, center and then surrounds). i have been reading a lot of reviews here and the LSIM series (705) has really piqued my interest. Its way beyond my budget for speakers. I was thinking since i have to ship the speakers in to my country why not just get it now than get the A7 and have buyers remorse. My only fear is that it might be overkill for my needs, my current setup is 95% movies and 5% music.
Is the A7 better/ more suited for movies than the 705?
Thanks again.
shyyour is offline
post #40701 of 45489 Old 09-30-2015, 12:34 PM
Quoted: 394 Post(s)
Liked: 113
Thanks again. If you've heard the LSIM 705 i would really appreciate your thoughts comparing it to the A7 for Home theatre use.
shyyour is offline
post #40702 of 45489 Old 09-30-2015, 01:57 PM
alwaller's Avatar
Quoted: 109 Post(s)
Liked: 72
Old vs New
Hi All
I have lsi9 mains with a lsi center, has anyone compared them with some of the cheaper options from Hsu (HB/ H-1), Ascends (CMT 340 & CBM-170), EMP-R6Bi or the SVS Prime bookshelf and center.
Would any of theses brands be a up-grade from the Polks? My Polks are 10 years old.
alwaller is offline
post #40703 of 45489 Old 09-30-2015, 02:35 PM
asharma's Avatar
Liked: 610
When I pull the tweeter coil out just a bit and put the 3 screws back in, the coil goes back to close to its initial position and sounds the same...what am I doing wrong?
asharma is offline
post #40704 of 45489 Old 09-30-2015, 04:02 PM
Quoted: 491 Post(s)
Liked: 301
I have both the LSIM is better, It's had to say if for the money it's better enough to buy them.
post #40705 of 45489 Old 09-30-2015, 05:47 PM
RobLee's Avatar
Quoted: 294 Post(s)
Liked: 301
I have never heard any of the LsiM line, though I own a pair of Lis9's which I use in the bedroom for music only. I tried them in our living room for HT and was somewhat disappointed. Furthermore they sounded terrible for TV viewing. They are great speakers for music and I'm sure they are decent for HT use, but at their price point I could not justify replacing a room full of Rti's with Lsi's.
RobLee is offline
post #40706 of 45489 Old 09-30-2015, 06:28 PM
Quoted: 394 Post(s)
Liked: 113
Thanks a lot for that. It really cleared things up.
shyyour is offline
post #40707 of 45489 Old 09-30-2015, 06:52 PM
Quoted: 394 Post(s)
Liked: 113
Thanks i'll definitely go for the A7 then, wish i could get the A9 but i don't have the height space for them. Thanks again
shyyour is offline
post #40708 of 45489 Old 09-30-2015, 09:00 PM
RobLee's Avatar
Quoted: 294 Post(s)
Liked: 301
I used the A7's for a while until I found the A9's on sale at 50% off. Then I had to buy an external amp because for the A9's to sound great they really do need more power than an AVR can deliver. So there is a price to be paid for the A9's and the A7's are essentially the best deal for most people who cannot justify paying that premium.
RobLee is offline
post #40709 of 45489 Old 10-16-2015, 12:37 AM
aircasper's Avatar
RC80i versus 70RT?
Hey guys, I'm in the middle of a kitchen remodel and would like to install a pair of ceiling speakers in the kitchen, plus an additional pair in the adjacent dining room and another pair in the adjacent family room. I originally thought I would just with the RC80i based on the positive reviews on Amazon and value pricing, but am now considering the 70RT because I prefer the visual appearance of the 70RT. Aside from the appearance, however, I was wondering if people think there is a noticeable difference in sound quality between the two speakers, considering the 70RT is double the price. Thanks for your help!
aircasper is offline
post #40710 of 45489 Old 10-18-2015, 07:06 AM
RobLee's Avatar
Quoted: 294 Post(s)
Liked: 301
Rti12's for $300 each!! NewEgg shellshocker starts at 6PM PDT/9PM EDT, cherry only. Unbelievable!
azz7686 likes this.
RobLee is offline
Reply Speakers
Polk Audio , Polk Audio Csi5 High Performance Center Channel Speaker , polk audio lsim , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Psw108 10 100w Psw Series Powered Subwoofer
