Calling all Polkies:Official Polk thread - Page 1493 - AVS Forum | Home Theater Discussions And Reviews
 1810Likes
post #44761 of 45277 Old 05-08-2019, 05:10 PM
Geoff4RFC's Avatar
Quoted: 469 Post(s)
Liked: 1653
Originally Posted by Darren Chan View Post
https://www.adorama.com/pkalsim704c....ce=rflaid62905[/QUOTE
Thanks for the suggestion on the 704's. Are those prices at adorama for new or B stock? Before picking up the S60's, I was seriously thinking of four LSiM703's for front R/L and rear surrounds. It's priced really well at Polk's eBay store. $1500 USD for the four and a free 706 center. I never considered the 704 but It's definitely top of the list now.
Dude, if you can get your hands on two pairs of 703's and a 706, I'd be a jumpin on it!!!
To each his own with the 704, but after going through three different series of Polk speakers, as far as the center goes, the "big dog" of the series is the only CC I'll own in my set up i,e: CSII with the Monitors, CSiA6 with the RTiA's and now the 706. After all, for home theater, the dialogue is probably the most important link in the chain, why skimp on your center?? IMO of course
And to address your B stock question, I've gone with B stock amps more than once and now my 706 is B stock, no complaints and happy to have saved hundreds of dollars. The performance is as good as A stock and you still get a warranty.
I remember being skeptical in the beginning regarding B stock items, but once I dove into the pool, I found out that the water was just fine.
Set up:
Marantz AV8802A w/Pangea Premium XLR's-Source: Oppo 103-CD Player: Emotiva ERC 3 w/Pangea Premium XLR's
Display: Samsung QLED 65F-Amplification: Emotiva XPA-DR3, XPA-2 x 2
Mains: PolkAudio LSiM707, C 706, SS 702, RS RTiA9
Geoff4RFC is online now
post #44762 of 45277 Old 05-08-2019, 07:53 PM
axlemay's Avatar
Quoted: 60 Post(s)
UPS delivered my lsim 703 this afternoon and open and connect to my system. It doesnt fit on top of my cabinet so for now I put it on top of my subwoofer. It sounds very clean. My plan previously is to get lsim 703 for now and get 705 if $ allow. But for the size of 703 I couldnt hang this on the wall.
axlemay is offline
post #44763 of 45277 Old 05-08-2019, 08:34 PM
Geoff4RFC's Avatar
Quoted: 469 Post(s)
Liked: 1653
Congratulations! Yeah, the 703 is no wall hanger. Audiovisor has some nice Sanus steel stands in a few different heights that won't break the bank.
Set up:
post #44764 of 45277 Old 05-08-2019, 08:39 PM
Liked: 6
Where would you put the 705's? Everything looks pretty tight in there lol.
Darren Chan is offline
post #44765 of 45277 Old 05-08-2019, 08:50 PM
Liked: 2
Speaker placement
Matthew Newman is offline
post #44766 of 45277 Old 05-08-2019, 09:04 PM
axlemay's Avatar
Quoted: 60 Post(s)
Where my primus P363 placed previously between cabinet and subwoofer. Sub was close to the right and left wall previously. I just move it close to cabinet so i can put 703 on top. So now P363 will go to rear surround.
axlemay is offline
post #44767 of 45277 Old 05-08-2019, 09:07 PM
axlemay's Avatar
Quoted: 60 Post(s)
Thanks Geoff... Is it the link above? But seems out of my range for a speaker stand.
axlemay is offline
post #44768 of 45277 Old 05-08-2019, 09:10 PM
Liked: 2
Sorry about the post above, I was starting to write a message and hit the post button by accident. Still looking for a way to delete the post, but I'm new to posting here.
I was looking for some help on speaker placement. I have a set of Polk Audio 65RT in Wall speakers I wanted to add to my basement. The issues is that I have a perfect storm for where I thought would be the best place to install them.
I have framed the size the projected image would take up on my wall as well as where I was thinking of placing the FR and FL. I was planning on using a phantom centre and eventually adding another 65RT or a matching centre speaker when I get more budget to do so.
What I'm wondering is if I should expect to get decent sound from the fronts being so close to each other.
Thanks in advance for your help.
post #44769 of 45277 Old 05-08-2019, 09:11 PM
Geoff4RFC's Avatar
Quoted: 469 Post(s)
Liked: 1653
Here you go:
https://www.audioadvisor.com/prodinfo.asp?number=SASF
Set up:
post #44770 of 45277 Old 05-08-2019, 10:04 PM
Liked: 6
I'm no pro but from what I see, you're gonna have reflection problems with that right wall, visually and audibly. Once the screen is lit up, light will spill onto that wall and reflect back and wash out your blacks. Your FR will have reflections as well being that close. As for your FL, can't it be placed closer to the corner near the door?
post #44771 of 45277 Old 05-08-2019, 11:02 PM
Geoff4RFC's Avatar
Quoted: 469 Post(s)
Liked: 1653
More separation would be ideal. And Darren has a point about 1st order reflections. And they do seem to be a bit too close to the floor.
If....your screen is an acoustic screen, you could mount them behind and space them accordingly.
As far as the right wall, you could paint it flat black and ideally, place some acoustic foam to handle the reflections.
Set up:
post #44772 of 45277 Old 05-08-2019, 11:29 PM
Geoff4RFC's Avatar
Quoted: 469 Post(s)
Liked: 1653
Here are some shots of 703's on the Sanus Steel stands:
ID:	2564434   Click image for larger version
ID:	2564436   Click image for larger version
ID:	2564438   Click image for larger version
ID:	2564440   Click image for larger version
Set up:
post #44773 of 45277 Old 05-09-2019, 04:01 AM
Liked: 2
Thanks for the responses Darren and Geoff.
Unfortunately there’s not enough room to move the FL closer to the door with the 65rt. The only other option would be to change the front speakers to a pair of 70rt so I can shift the pair over to the other wall some. I wasn’t sure I would get the same sound out of those though. Anyone have experience with those speakers? Also how much clearance would I need to give between the side wall and the FR speaker do you think?
I believe I can move the speakers up a little so the top would be about 40” from the floor.
The screen isn’t acoustic. Just a basic framed screen.
I’ll have to see about painting it black. I honestly didn’t think about the reflections for the projector before.
post #44774 of 45277 Old 05-09-2019, 04:33 AM
m0j0's Avatar
Quoted: 601 Post(s)
Liked: 602
It's not easy, but you may be able to wall mount the 703's in certain circumstances. I have mine wall mounted on my rear walls and angled in toward the MLP. On one side, I was able to put the wall mount into studs, but on the other side, I only had drywall, so I had to buy some WingIts drywall anchors. Here's the links to the mounts and the anchors if you're interested.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
ID:	2564464   Click image for larger version
Geoff4RFC likes this.
m0j0 is online now
post #44775 of 45277 Old 05-09-2019, 06:11 AM
Todd G.'s Avatar
Quoted: 164 Post(s)
Liked: 378
I have 70RT speakers in the living room ceiling for rear surround and four of them in the basement theater ceiling for Atmos. They’re not designed for much response below (probably) 60Hz, but I really like the way they sound—full and detailed. Plus your sub will fill in the gaps.
Best of luck getting your project sorted.
Basement bat cave: JVC RS2000, 100" 16:9 Stewart StudioTek 130, Denon AVR-X4400H, Oppo UDP-203, Polk RTi A7 towers/CSi A6 center/65RT in-wall side surrounds (2)/70RT in-ceiling Atmos (4), dual PSA V1811 subwoofers
Todd G. is offline
post #44776 of 45277 Old 05-09-2019, 06:34 AM
burntreality's Avatar
Quoted: 12 Post(s)
Awesome amigo!! Is there any reason why you can't move the sub next to the cabinet and place the stand to the outside? Then maybe, if there's room, pull them forward just enough to toe them in some.
I moved the subwoofer and the right speaker. It looks much better now and sounds great.
burntreality is offline
post #44777 of 45277 Old 05-09-2019, 09:25 AM
Geoff4RFC's Avatar
Quoted: 469 Post(s)
Liked: 1653
Nicely done! Working with limited space can be a challenge for sure, I'm there myself
But you're right, it does look better and it's good to hear that the change improved the sound as well!!
burntreality likes this.
Set up:
post #44778 of 45277 Old 05-09-2019, 09:44 AM
Liked: 2
Thanks Todd. I will measure up the space again to make sure I can fit them and try to go listen to them today. Since they are quite a bit smaller I should be able to place one on the left side and higher on the wall then move the one in the corner over some. I assume they sound similar to the 65RT being the same series.
Todd G. likes this.
post #44779 of 45277 Old 05-09-2019, 09:50 AM
Todd G.'s Avatar
Quoted: 164 Post(s)
Liked: 378
FYI, the 70RT speakers are extremely deep—I just remembered. You’ll need at least 8” from the finished side of the drywall to the back of the speaker enclosure. Polk’s website should give you mounted depth.
Sorry if I got your hopes up if you don’t have the room.
Todd G. is offline
post #44780 of 45277 Old 05-09-2019, 09:55 AM
Liked: 2
Wow! 8 3/8", you're not kidding when you say they're extremely deep. lol
That's quite a bit of space. I do have storage behind that wall, so it's mostly open, but I will need to measure the places I would thinking to put them to make sure. There are pipes etc. behind the wall. Thanks for the heads up.
Todd G. likes this.
post #44781 of 45277 Old 05-09-2019, 04:51 PM
axlemay's Avatar
Quoted: 60 Post(s)
M0j0.. I had the p152 on my rear surround but i will try if the mount can handle the weight of 703.
axlemay is offline
post #44782 of 45277 Old 05-09-2019, 08:02 PM
Geoff4RFC's Avatar
Quoted: 469 Post(s)
Liked: 1653
Very intuitive!
m0j0 likes this.
Set up:
post #44783 of 45277 Old 05-10-2019, 05:00 AM
m0j0's Avatar
Quoted: 601 Post(s)
Liked: 602
The BT77's are rated for like 50 lbs, and the 703's are 30+ lbs, so I felt confident going that route. There weren't many other mounts I could find that were rated to hold that kind of weight.
m0j0 is online now
post #44784 of 45277 Old 05-10-2019, 06:45 AM
DD/DTS's Avatar
Quoted: 77 Post(s)
Liked: 673
Anyone own one of these?
Polk Atrium Sub10
Outdoor subwoofer with 10-inch woofer.
https://www.polkaudio.com/products/atrium-sub10
Do you like it? Does it have decent bass?
Looking for a sub for out on my patio
Main:🎭Denon AVR-S740H/Sony UBP-X800/Sanyo 55" 4K UHD HDR/Paradigm Cinema 100 x6/Cinema Center 1/Cinema Sub x2/CM-4228/7778/7600/LTE filter/RG-6 Quad Shield coax. Bedroom:📺Samsung 42" plasma/Samsung HT-J4500/Aluratek ADTB01F HD DVR. PC:🖥Dell Optiplex 780/intel Q9650/16gb DDR3/GT710/SB Audigy FX/Logitech X-530/RCA 32" HDTV. GamingConsoles:🎮 PSone/PS2/PS3/PS4/Xbox/Xbox360/Xbox OneX / *Jerry Austin*
DD/DTS is offline
post #44785 of 45277 Old 05-11-2019, 04:31 AM
67jason's Avatar
Quoted: 85 Post(s)
Liked: 803
yo yo yo whats up in polk-landia!??
some of you may remember me for a ways back (geoff, climber, others ). love me some polks, but have moved on for my main systems to things very different. just thought i'd check in here since its been a bit since i showed my mug 'round these parts.
here is a glimpse of things ive been playing with these days.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #44786 of 45277 Old 05-11-2019, 11:16 AM
Geoff4RFC's Avatar
Quoted: 469 Post(s)
Liked: 1653
Nice nice, I see a Pangea gear rack, Emo gear, Emo speakers and what is that beautiful Integra piece you have there????
Set up:
post #44787 of 45277 Old 05-11-2019, 11:30 AM
67jason's Avatar
Quoted: 85 Post(s)
Liked: 803
Geoff, its nothing fancy, just an old dhc-83 pre/pro
67jason is offline
post #44788 of 45277 Old 05-11-2019, 11:31 AM
67jason's Avatar
Quoted: 85 Post(s)
Liked: 803
80.3 that is...
Never tried avs on my phone til now...and well it sux lol
67jason is offline
post #44789 of 45277 Old 05-11-2019, 11:36 AM
67jason's Avatar
Quoted: 85 Post(s)
Liked: 803
some of you may remember me for a ways back (geoff, climber, others [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG]). love me some polks, but have moved on for my main systems to things very different. just thought i'd check in here since its been a bit since i showed my mug 'round these parts.
Aha...figuring this out now with the phone...still hate it though lol
67jason is offline
post #44790 of 45277 Old 05-11-2019, 11:42 AM
Geoff4RFC's Avatar
Quoted: 469 Post(s)
Liked: 1653
Lol, I can dig it, I hate it too!!
Nice on the 80.3, I upgraded my 70.4 to an 80.2 so we're essentially using the same unit. I'm liking the balanced connections over the "un" so far. But, having to use the split HDMI outs on the Blu-ray to see any 4K
Set up:
Reply Speakers
Polk Audio , Polk Audio Csi5 High Performance Center Channel Speaker , polk audio lsim , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Psw108 10 100w Psw Series Powered Subwoofer
