Calling all Polkies:Official Polk thread - Page 1500 - AVS Forum | Home Theater Discussions And Reviews
 1700Likes
post #44971 of 44999 Old 07-09-2019, 05:44 PM
Divine_Madcat's Avatar
Quoted: 20 Post(s)
Originally Posted by Geoff4RFC View Post
Fine score indeed!!
I would place the A5's to the side, facing the couch, and slightly to the rear of it.
I would pull the A9's away from the wall as your bass will not be quite so bloated. Gives the A9 some breathing room.
Do you plan on using a center? Do you have one? Or just do a phantom center?!
Fair enough, ill wrestle the speakers into a slightly different position.
Right now, I have a MartinLogan Motion 8 (also a thrifty buy for $40), but have been STRONLY advised to ditch it due to how it is so unmatched to my polks. I hooked it up, but it didn't sound bad, so I am torn. I would love an A6 center, but I am also debating getting a better AVR to support the output to my existing speakers. Admittedly, I don't plan on using many of the features of an AVR (I don't have any separate HDMI devices, so no pass through needed - audio will go through optical out from the TV), but its not to say I wont use them if I have them (I have never owned a dedicated AVR before, so I am not used to what such a system can do for me). So far, I have found a few candidates (but these are really budget stretching:
Denon -980H ($259)
780H ($208)
X2200W ($200 or less - might be able to negotiate this one a bit).
If I got even more expensive, I might be able to get a Yamaha RX-A870 for $260, or A880 ($320) (but these require some negotiation).
Divine_Madcat is offline
post #44972 of 44999 Old 07-09-2019, 06:13 PM
Geoff4RFC's Avatar
Quoted: 433 Post(s)
Liked: 1628
If you're happy with your current center, I'd use it till you feel the need to upgrade. Check out accessories 4 less, lots of options for avr. They are returns but I've bought my last three from there. All in new shape.
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Marantz AV8802A W/M.P. Monolith XLR's-Oppo 103-65" 4K Sammy-Emotiva: XPA-DR3, XPA-3, XPA-2 x 2-PolkAudio: RTiA9 x 4-LiSM706-FXiA6 x 4-LiSM703-Furez 10awg homemade cables
Geoff4RFC is offline
post #44973 of 44999 Old 07-09-2019, 06:14 PM
Geoff4RFC's Avatar
Quoted: 433 Post(s)
Liked: 1628
Oops, ferurbs, not returns lol
Set up:
post #44974 of 44999 Old 07-09-2019, 06:15 PM
Geoff4RFC's Avatar
Quoted: 433 Post(s)
Liked: 1628
Sheesh.....REFURB
Set up:
post #44975 of 44999 Old 07-09-2019, 06:42 PM
Quoted: 20 Post(s)
I guess the question is - should I look at any ferubs () or anything else in the first place? I mean, to my very untrained ears, my A9s sounded amazing, but I am sure I can get more out of them. Problem is, I am not sure if what is in my price range is worth it for the speakers (since I haven't even had my A5s and A9s singing together yet...).
post #44976 of 44999 Old 07-10-2019, 12:36 AM
Geoff4RFC's Avatar
Quoted: 433 Post(s)
Liked: 1628
Not knowing what your price range is, I still refer to you to AC4L. You might stumble across a smoking deal like I did when I snagged my Integra Pre.
Set up:
post #44977 of 44999 Old 07-10-2019, 11:51 AM
Quoted: 20 Post(s)
Sounds good, I'll check it out for sure.
BTW: i found the thread that originally made me worry about damage:
https://forum.polkaudio.com/discussi...e-60-vs-rti-a9
https://forum.polkaudio.com/discussi...rtia9-receiver
The people in the threads sound so dire about it too. Ant idea why they are so over the top there?
post #44978 of 44999 Old 07-10-2019, 12:20 PM
Geoff4RFC's Avatar
Quoted: 433 Post(s)
Liked: 1628
You mean regarding power to the A9'?
If so, the A9's three woofers suck up a ton power with todays audio tracks with LFE. If you're setting them to full or large, they will demand power for LFE.
Getting an AVR with high power will help. Any AVR with pre-outs to add an external amp will be even better. For the time being, just don't listen too loud You should be okay.
Set up:
post #44979 of 44999 Old 07-10-2019, 12:25 PM
Geoff4RFC's Avatar
Quoted: 433 Post(s)
Liked: 1628
Another consideration is to set the A9's to 40hz in your AVR so you are not using the woofers to full capacity. You could even set them to like 60 or 80hz and be totally safe. Now your AVR will only be powering the top section of the cabinet: the midrange and tweeter section. You will be safe from all harm
Divine_Madcat and climber07 like this.
Set up:
post #44980 of 44999 Old 07-10-2019, 04:20 PM
Quoted: 95 Post(s)
Can anyone tell me what the actual frequency response of the RTi A1 speaker is? A lot of places seem to indicate that it's 60hz - 26Khz, I've seen BestBuy list it as 50hz - 27Khz. Polk lists two frequency responses:
  • Total Frequency Response 50 Hz → 27,000 Hz
  • Lower and Upper -3dB Limits 60 Hz → 26 Hz
Ryan Statz is offline
post #44981 of 44999 Old 07-10-2019, 06:15 PM
PretzelFisch's Avatar
Quoted: 459 Post(s)
Liked: 284
If you have the rtia9 I wouldn't worry about it. Typically no one level matches the stuff when they rerun calibration so they play louder which translates into better sounding or woke up.
It will also depend how far you sit from them how your room treats base. sometimes you might have calibration able to deal with a room mode when more power is available.
PretzelFisch is offline
post #44982 of 44999 Old 07-10-2019, 11:47 PM
Geoff4RFC's Avatar
Quoted: 433 Post(s)
Liked: 1628
An interesting little WOW...for me that is
@climber07 , Dave, the other day my daughter and I were watching a movie, can't quite remember which one, but....I saw a little blue light spark up on one of my stereo amps, you know, the 'ol XPA-2. I backed up the movie and replayed and sure enough, the blue light make it's appearance again. I had to check to see which speaker was linked to that channel.
It was the left Surround, FXiA6. The left one is a little further away then the right. I haven't seen any blue, much less red lights in quite some time.
I miss my systems potential One day amigo, one day, I'll even have my subs involved again
climber07 likes this.
Set up:
post #44983 of 44999 Old 07-11-2019, 04:17 PM
Quoted: 20 Post(s)
So, following up on the suggestions, I managed to trade some other equipment for a "Sonance The Sub" Thx Subwoofer " - https://www.cnet.com/products/sonanc...sub-subwoofer/
I know it's an older unit, and not as powerful as others. But given my living location, i am hoping it will be useful at least. And if it takes load off my A9s, even better. I also found a smoking deal on an RX-730, and so returned my RX-A710. Not a huge change, but at least slightly newer.
Geoff4RFC likes this.
post #44984 of 44999 Old 07-11-2019, 04:38 PM
AlphaPie's Avatar
Quoted: 228 Post(s)
Liked: 419
A4L has had polk speakers in the past for deeply discounted pricing. I check the site every month. If you keep an eye out you might find a great deal on more than just avrs.
Pioneer Elite SC-85 | RBH R-515 LCR | Morel Surrounds | DIY 12" Infinity Subs w/ Inuke 3000
2 CH - Realistic STA-2100D | Realistic Optimus 5-B (restored) | Marantz AT 6 | Sony CDP-CE375
AlphaPie is offline
post #44985 of 44999 Old 07-11-2019, 11:34 PM
Geoff4RFC's Avatar
Quoted: 433 Post(s)
Liked: 1628
Nicely done!
Set up:
post #44986 of 44999 Old 07-11-2019, 11:35 PM
Geoff4RFC's Avatar
Quoted: 433 Post(s)
Liked: 1628
Thanks for the heads up!! Yeah, I lurk there occasionally looking at pretty much everything they have to offer.
Set up:
post #44987 of 44999 Old 07-12-2019, 08:41 AM
climber07's Avatar
Quoted: 795 Post(s)
Liked: 2570
I hear ya @Geoff4RFC . I was rewatching X-Men Apocalypse last night with my son at around -18dB MV and the house was rockin'. My son was like "wow daddy, rewind that and play it again"! I, of course, had to oblige.
Power Sound Audio S7201 Quad 18" 4000W Sealed Subwoofer - Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Epson 5030UB Projector - Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - - XBox One S - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #44988 of 44999 Old 07-12-2019, 09:16 AM
Quoted: 459 Post(s)
Liked: 284
Both of you, freaking cut it out. My movie room is the wife's junk drawer and your making me cry.
Geoff4RFC and climber07 like this.
post #44989 of 44999 Old 07-12-2019, 09:20 AM
climber07's Avatar
Quoted: 795 Post(s)
Liked: 2570
You can call the "junk" acoustic treatments and turn off the lights. LOL
post #44990 of 44999 Old 07-12-2019, 11:00 AM
Geoff4RFC's Avatar
Quoted: 433 Post(s)
Liked: 1628
I haven't spit my coffee on the monitor in a long time
Get'cher man card back...carefully
Set up:
post #44991 of 44999 Old 07-15-2019, 04:57 PM
EndersShadow's Avatar
Quoted: 1186 Post(s)
Liked: 1454
Does this help you feel better?
Oops wrong pic.... this is the one I meant to post tehehehehehehe
It’s my new addition to my other enclosure (also 4 12s)......
And oh wait I haven’t got the sonotubes built yet .... so I can’t post those
But speaker wise, I’m slumming it with a pair of Polk SDA 2As for now... Cohesive 893 L\R\C w Concentric 8 or Angled Volt 8s planned by Christmas....
Anyway dropped by to say hi. I don’t pop in here (this section of the forum) much as Ive said all I need to about Polk speakers and my time with them is mostly done.....
Anyway see you punks around
Find me in the DIY Subwoofer section if you need me.
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #44992 of 44999 Old 07-16-2019, 12:31 AM
Geoff4RFC's Avatar
Quoted: 433 Post(s)
Liked: 1628
C'mon Danny, just because you have a house leveler subwoofer doesn't mean you can snob us
Pop in more often!!!!
Set up:
post #44993 of 44999 Old 07-16-2019, 12:58 PM
mknecht01's Avatar
Quoted: 95 Post(s)
Liked: 50
Speaking of deeply discounted prices, I just saw a few minutes ago that Polk eBay Direct has RTiA series at 40% off and LSiM series at 50% off right now. And Adorama on eBay is selling the LSiM 706c more than 60% off @ $460. All brand new, not factory refurb. I’m not in the market right now as I just bought a house 8 months ago but I may buy one of those centers from Adorama anyway, at that price!
Fronts: LSi7
Center: LSiM 706C
Surround: LSiF/X
Sub: Infinity BU-2 - Don't judge me, it was free.
AVR: Denon X3100W, Adcom GFA-7000 5-channel amplifier
mknecht01 is offline
post #44994 of 44999 Old 07-16-2019, 01:27 PM
mknecht01's Avatar
Quoted: 95 Post(s)
Liked: 50
RE: the Yammie receiver... I currently run a Denon but liked my RX-A720 a lot. I had to upgrade when I upgraded to LSi speakers, which are 4 ohm and can’t properly be run without extra amplification... so be aware that the Aventage 700 series does NOT have pre-outs for connecting additional outboard amplification. The 800 series is the minimum you can get that will give you that capability. And judging by what Geoff and many others have said about their RTiA9s, you’re eventually very much going to want to get an amp for those beasts in order for them to meet their potential.
I would think that you should be able to find an early model RX-A800 series for not that much more than the 700s you’re using now.
Fronts: LSi7
Center: LSiM 706C
Surround: LSiF/X
post #44995 of 44999 Old 07-16-2019, 02:15 PM
mknecht01's Avatar
Quoted: 95 Post(s)
Liked: 50
Originally Posted by mknecht01 View Post
Speaking of deeply discounted prices... Adorama on eBay is selling the LSiM 706c more than 60% off @ $460. I’m not in the market right now as I just bought a house 8 months ago but I may buy one of those centers from Adorama anyway, at that price!
A visit to the actual Adorama home page shows all the LSiMs more than 50% discounted... close to 60% on the 705s and 707s, 52% on the 703s. Plus that brilliant price for the centers.
Fronts: LSi7
Center: LSiM 706C
Surround: LSiF/X
post #44996 of 44999 Old 07-16-2019, 04:25 PM
Quoted: 20 Post(s)
For what its worth, I ended up getting an A880 that was refurbed for $320. As it is right now, I love my setup, and it gets plenty loud for the condo I am in. Maybe in a few years, when I have a house, I will look for a separate amp to drive them harder.. but for now, I am plenty happy.
post #44997 of 44999 Old 07-16-2019, 04:37 PM
mknecht01's Avatar
Quoted: 95 Post(s)
Liked: 50
I wish I had your magic. The 880 refurbs I was just looking at are $550 and 870s for $430. $320 is a really amazing price.
Fronts: LSi7
Center: LSiM 706C
Surround: LSiF/X
post #44998 of 44999 Old 07-16-2019, 05:23 PM
Quoted: 20 Post(s)
If you think that is magic, I probably shouldn't tell you about the Vienna Acoustics Bachs that I found for $50, or the Panamax MR4000 for $25 (Bach's at salvation army, MR4k at a pawn shop in the back)...
ID:	2591596   Click image for larger version
ID:	2591598   Click image for larger version
post #44999 of 44999 Old 07-18-2019, 05:22 PM
AlphaPie's Avatar
Quoted: 228 Post(s)
Liked: 419
holy crap this is a sweet build!
AlphaPie is offline
Reply Speakers
Polk Audio , Polk Audio Csi5 High Performance Center Channel Speaker , polk audio lsim , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Psw108 10 100w Psw Series Powered Subwoofer
