Definitive Owners Thread - Page 1282 - AVS Forum | Home Theater Discussions And Reviews
 3820Likes
post #38431 of 41569 Old 02-13-2018, 04:08 PM
Falconsfan71's Avatar
Quoted: 1656 Post(s)
Liked: 595
Originally Posted by Hetfieldjames View Post
Hey guys got a kinda odd question for ya. Would putting a TV on the CLR2002 hurt it? I have the Sony 55X900E that I might want to take off the wall and put it on its stand. I mean I'm not sure yet but I may. The TV is only 38 pounds but do you think it would hurt the CLR2002? The base I think would fit perfectly on it, and it would give the TV the perfect height. By the way the X900E is an insanely gorgeous display. Its surpassed what I thought it would be and way past what I thought an LED/LCD could do.
Why take the tv down?
in4maous likes this.
Denon X4300H * Def Tech BP8080st front L/R * Def Tech CLR2002 center * Def Tech ProMonitor 800 surrounds (x4) * Hsu VTF-3 MK5 HP sub * Outlaw OAW4 wireless sub kit * Vizio 60" 4K HDRtv * Sony UBP-X800 Bluray * PS4 * AC Infinity S9 AVR fan
Falconsfan71 is offline
post #38432 of 41569 Old 02-13-2018, 04:16 PM
Quoted: 1988 Post(s)
Liked: 1277
Well it's just a thought. Long story is I had a 52 inch LCD before your on a full motion mount so it was off the wall 10 inches or so. The new 55 inch I have on a slim fixed mount so it's right against the wall, so it's 10 inches back. Now I bought a full motion mount that can be extended 14 inches off the wall. This will of course bring the TV closer to the seating area. I will also be able to tilt the TV. I think this will solve my issues but just in case my last resort is to put in on it's stand and bring in as close as I need it to be. That's the whole story. What do you think?
Sent from my Pixel using Tapatalk
Hetfieldjames is online now
post #38433 of 41569 Old 02-13-2018, 04:29 PM
Liked: 595
I’m just not sure about sitting on top of the center. It may be fine as far as the weight.. but I wouldn’t like it.
post #38434 of 41569 Old 02-13-2018, 04:37 PM
Liked: 1277
Thanks and I agree. I really think putting it on the full motion mount will solve all these issues. I'm actually not skimping and I'm having a home theater guy come in to do it. I want his input on the exact height, and position it should be at.
post #38435 of 41569 Old 02-13-2018, 05:00 PM
Liked: 595
As far as tv height, I think it just depends on how far back you are from it, how low you sit, and pretty much just what you want.
post #38436 of 41569 Old 02-13-2018, 05:15 PM
Liked: 1277
And all those variables that is why I'm having a home theater guy come in and do it.
post #38437 of 41569 Old 02-14-2018, 01:31 PM
Liked: 595
Valentine’s Day??? There has been no action on the Forum today.. not in Speakers or Subwoofers! I guess all the men are too busy running around getting that sweetheart crap today to try to make up for the rest of the year…? I bet no men are out buying speakers today!
eaayoung likes this.
post #38438 of 41569 Old 02-14-2018, 01:34 PM
josh6113's Avatar
Quoted: 450 Post(s)
Liked: 181
Lol...yea I bought a Chromecast audio today....with my woman......it's audio related at least....sounds great.
Sent from my MHA-L29 using Tapatalk
Falconsfan71 likes this.
Doing what I do best...LIVIN!
josh6113 is offline
post #38439 of 41569 Old 02-15-2018, 09:02 AM
weekendtoy's Avatar
Quoted: 624 Post(s)
Liked: 1893
Originally Posted by pbz06 View Post
Finally got a chance to clean up the cables. Love the speakers Do you guys toe in for movies?
That is a nice clean set-up. My wife would be jealous!
I reject your reality and substitute my own.
weekendtoy is offline
post #38440 of 41569 Old 02-15-2018, 10:50 AM
Liked: 595
Ok..so has anyone ever had any issues with their towers? ..7000 or 8000 series? ..a squeaky squealing noise near a bass radiator like air escaping maybe? I’ve been communicating with Def Tech and have tried a couple of things.. replaced the bass radiator and even tried another amp (process of elimination).. it’s still there. It’s only when the bass gets low or there’s some low LFE. I have both towers set identical and the other one doesn’t do it. It’s done it since I got them. I’ve just kept the bass turned down. You all know the journey I’ve had over the last two years and how many DT speakers I’ve bought. I’m sending it to them for them to check it. I hope it can be fixed.. “might” be a bad enclosure. They don’t make the BP8080 anymore so not sure what would be a resolution. FedEx has already picked it up and it’s...
“Going back to Cali”
post #38441 of 41569 Old 02-15-2018, 11:29 AM
josh6113's Avatar
Quoted: 450 Post(s)
Liked: 181
This is bad luck...not sure what might cause that.I know you got your 8080 towers used and I'm hoping that the seller didn't have this issue before selling them to you.I know definitive will treat you right.
Keep us posted on the problem.
josh6113 is offline
post #38442 of 41569 Old 02-15-2018, 11:41 AM
SAVholic's Avatar
Liked: 30
Finally got my A-90 modules on my 9060's hooked up and watched some movies.
Due to restriction (not a dedicated theater and concrete ceiling) all I can say is that these give awesome another notch
Atmos native films sound incredible and non atmos movies sound almost as good with neural-x enabled in my AVR.
I know down firing or height speakers will work even better but I can't complain on how they look and perform.
Will post pics later!
"My English is not very good looking" - Celia Cruz
SAVholic is offline
post #38443 of 41569 Old 02-15-2018, 01:42 PM
nithinmuktesh83's Avatar
Quoted: 80 Post(s)
Friends - can you suggest a good place to buy def tech "cheaper" in Florida :-) Am near Miami area.
nithinmuktesh83 is offline
post #38444 of 41569 Old 02-15-2018, 04:44 PM
Audioguy509's Avatar
Quoted: 31 Post(s)
Liked: 120
I have a chance to pick up 2 DT BP 7002, CLR 2500 and 2 BP 2x on the cheap. How will this sound being run off a Yamaha rx-a 820 with a SVS sb-13 ultra. In a 26 x 17 x 8high room.
7.3.4 Avr: Pioneer SC-95 elite LR: Klipch RF-3 C: RC 52ii Surrounds: Klipch SF-1 and def tech B6p SUBS: 2 UM22-18 Full martys on INuke 6K dsp Atmos: 4 monoprice 8"
Audioguy509 is offline
post #38445 of 41569 Old 02-15-2018, 09:35 PM
ALtlOff's Avatar
Quoted: 1449 Post(s)
Liked: 816
The Yamaha shouldn't make that much of a difference, while not super powerful it should be just fine. That setup in general, is a good, quality, 5.25" matched system, should sound pretty "full" in that size room.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
https://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
post #38446 of 41569 Old 02-15-2018, 09:51 PM
ALtlOff's Avatar
Liked: 816
Bought one of those Sony x-800 referb's, arrived last night, reality looking forward to see what the UHD discs look like on my 1080p setup, hopefully it's a nice step up until I can get the 4k projector, but if nothing else I'll finally be able to have Atmos soundtracks again, on my newer discs (the upmixer is fine, but really..... No Atmos mix on standard BR is a real bummer). Also got a BB gift card for Valentine's Day, so went crazy with a bunch of New and Reissued UHD discs to give everything a good workout for the weekend, time to pull some things off the walls to keep them from falling off....
My Build Thread:
ALtlOff is offline
post #38447 of 41569 Old 02-16-2018, 09:15 AM
AlexanderDelarg's Avatar
Quoted: 229 Post(s)
Liked: 288
Baja Waverunner sells Def Tech refurbished units for a very respectable price.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | Hulu | Roku Ultra | Monoprice 12AWG |
AlexanderDelarg is offline
post #38448 of 41569 Old 02-16-2018, 10:24 AM
weekendtoy's Avatar
Quoted: 624 Post(s)
Liked: 1893
I rent movies through Netflix's DVD program. There are some Blu-Rays that come with Atmos. I never know which ones, but every once and a while I'm surprised when I go to play the movie and it has ATMOS.
I'm switching my rental account to 3d-blurayrental.com so I can take advantage of UHD & 4K(Oppo 203 and Vizio P65). However, not all UDH disc have ATMOS (which I thought they did). I bought the Martian on UHD during Black Friday for like $10 and was disappointed to find it only had 5.1.
To keep the DT themed. I recently set up a 7.1.4 ATMOS system with SVS Elevation height speakers in the rear, and up-firing Def Tech A-60 speakers up front. Will post my impressions...
post #38449 of 41569 Old 02-16-2018, 10:41 AM
mksumpter205's Avatar
Liked: 3
I'll be picking up a pair of BP8060's tomorrow and want to know where I may find the A60 atmos modules at a decent price. Or does anyone have a pair for sale. Thanks
mksumpter205 is offline
post #38450 of 41569 Old 02-16-2018, 11:14 AM
Liked: 595
It’s not Bajawaverunner anymore.. It’s actually Definitive Technology!
post #38451 of 41569 Old 02-16-2018, 11:14 PM
Jmouse007's Avatar
Quoted: 247 Post(s)
Liked: 201
I encountered the same kind of issue with my 7100sc. It turned out to be vibration coming from a loose internal speaker wire that wasn't secured/insolated/tacked down (I believe it was the wire to the 12" bass subwoofer) that was vibrating against the inside of the speaker cabinet when the sub played at low frequencies. Drove me crazy trying to find the source of the problem. Thought it was coming from the sub power amp... nope; defective 12" sub bass speaker... nope. Turned out to be an unsecured wire. Def Tech sent me a ball of the black sticky tack they use around the speakers. I found the offending loose wire, up behind the 12" sub speaker, secured it with the sticky tack and voila the vibration buzzing, whining sound totally disappeared.
Since the repair over 3 years ago I have turned my bass up very loud on numerous occasions and have never experienced a single problem since. A real bass vibration torture test to make sure the problem is solved is the very beginning scene of LIVE, DIE, REPEAT/Edge of Tomorrow and many scenes from Mad Max Fury Road... my speakers are now dead silent.
Your problem is possibly just an internal wire that happens to be vibrating against the inside of your speaker cabinet. I hope this helps.
QUOTE=Falconsfan71;55698108]Ok..so has anyone ever had any issues with their towers? ..7000 or 8000 series? ..a squeaky squealing noise near a bass radiator like air escaping maybe? I’ve been communicating with Def Tech and have tried a couple of things.. replaced the bass radiator and even tried another amp (process of elimination).. it’s still there. It’s only when the bass gets low or there’s some low LFE. I have both towers set identical and the other one doesn’t do it. It’s done it since I got them. I’ve just kept the bass turned down. You all know the journey I’ve had over the last two years and how many DT speakers I’ve bought. I’m sending it to them for them to check it. I hope it can be fixed.. “might” be a bad enclosure. They don’t make the BP8080 anymore so not sure what would be a resolution. FedEx has already picked it up and it’s...
Sent from my iPhone using Tapatalk[/QUOTE]
Jmouse007 is offline
post #38452 of 41569 Old 02-17-2018, 03:55 AM
Liked: 595
[/QUOTE]
Well.. this isn’t a vibration or rattle. It’s a squealing squeaky whistling air “fluttering” noise.. like air escaping. I can’t really describe it.
post #38453 of 41569 Old 02-17-2018, 04:03 AM
Liked: 1277
Sent from my iPhone using Tapatalk[/QUOTE]Maybe a fan belt?
post #38454 of 41569 Old 02-17-2018, 04:12 AM
Liked: 595
@Hetfieldjames ??? lol
post #38455 of 41569 Old 02-17-2018, 04:22 AM
Liked: 1277
Just joking of course. Really sucks your going through this. Sounds like the enclosure or speaker cabinet? If so that is trouble.
post #38456 of 41569 Old 02-17-2018, 04:26 AM
Liked: 595
I didn’t see your comment.. now I do. You quoted in the wrong place. lol. A fan belt? That’s almost what it sounds like!
post #38457 of 41569 Old 02-17-2018, 04:27 AM
Liked: 1277
Yeah my phone did something wierd. Don't know why though.
post #38458 of 41569 Old 02-17-2018, 04:49 AM
Liked: 595
Maybe they can fix it.. if not, then what? They can’t replace it because they don’t make them anymore..
It’s made the noise since I got them but I just haven’t said anything in hopes with talking to DT it could’ve been resolved.. tried a couple of things but that was a no-go. You only hear it when the bass gets low or during an explosion or low LFE. I had to turn the bass way down on the towers so it wouldn’t make the noise. The VTF3.5 has plenty of bass but I want the best sound & bass out of the towers also.
post #38459 of 41569 Old 02-17-2018, 04:55 AM
Liked: 1277
Yeah you want the bass from the subs and the towers, that's why you bought powered towers with built in subs. You sent them to Def Tech right? I'm sure they can fix them. Otherwise your gonna have to lower the bass to where you can't hear it, ruining the purpose of towers with subs or bite the bullet and buy new speakers. That would suck.
post #38460 of 41569 Old 02-17-2018, 05:39 AM
Liked: 595
Yes I sent that one back. Thank goodness I have original boxes and packaging. I boxed it up and taped it very well so I hope it’s taken care of during shipping there and back. It has to go from Georgia to California and will take a week to get there and then a week to come back after it’s fixed.. If it can be fixed. So I will be without it for at least 3 to 4 weeks.
Reply Speakers
Definitive Technology , Definitive Technology Bp2x Speakers , Definitive Technology Bp7004 , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Bpx Speaker Single Black , Definitive Technology Mythos 6 Aluminum Stand , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Supercube Trinity , Marantz Sr7002 Surround Receiver , Parasound , Receivers Amplifiers , Speaker Systems
