Definitive Owners Thread - Page 1368 - AVS Forum | Home Theater Discussions And Reviews
 3814Likes
post #41011 of 41548 Old 03-01-2020, 05:04 AM
Quoted: 344 Post(s)
Liked: 468
Originally Posted by WOKNROX View Post
Nice...
I've completely moved away from DT....
Have a bunch of them sitting in the unused audio/storage room tho....humm..
I really need to clean it out..
like...whatcya got in that stoeage closet?
LG 55C8, Pioneer Elite VSX-LX503, Panamax M5400, Microsoft Xbox One X, Nvidia Shield Pro
Definitive Technology: BP9060 Front left/right/CS9040 center/A90 front Atmos/ProMonitor 800 rear Atmos/SR9040 surround left/right
Rythmik FVX15
MATTHEW PATIENT is online now
post #41012 of 41548 Old 03-01-2020, 05:28 AM
Quoted: 1983 Post(s)
Liked: 1270
Nice...
What did you move on to, I'm curious? I'm gonna look to move on in the best few years.
Hetfieldjames is offline
post #41013 of 41548 Old 03-01-2020, 06:55 AM
WOKNROX's Avatar
Quoted: 542 Post(s)
Liked: 441
@Hetfieldjames Its all in my signature at the bottom...
One of the many nice things about the SDA SRS-TL line of speakers is that they are designed to be against the wall(less then 17" from baffle to wall). So although they are huge and make massive sound they don't need to be 3' or more into the room like most all tower speakers.
Plus you can't bet the SDA TECHNOLOGY for their huge imaging. Polk just brought them back with the L800 this year.
Orotund Desert Theater;7.7.4,14'x20'x10',100amp service, JVC RS620,120" ATscreen, Carada Masquerade Masking, OPPO203 & Panny ub820, Anthem AVM60, Simaudio Moon Titan 7&5ch ,Crown xls2500, ACInfinity Fans, L&R Polk SDA SRStl Fully built, CC 2 Polk RTA15tl in Custom Cabinets Fully build, SS-BS Inwall Triad Silver LCR, 4 Atmos Core5, Subs-miniDSP-HD2x4, 4 HSU VTF-15H-MK2, 3 MBM, 2 Rows of 3 Seatcraft Excalibur Lx Seats & more.
WOKNROX is offline
post #41014 of 41548 Old 03-01-2020, 07:11 AM
WOKNROX's Avatar
Quoted: 542 Post(s)
Liked: 441
Oh...its not a closet...its a 20' x 15' room. Then there's one 3 car garage
MATTHEW PATIENT likes this.
WOKNROX is offline
post #41015 of 41548 Old 03-01-2020, 08:05 AM
Quoted: 14 Post(s)
Liked: 4
Hi everybody,
So i try what Matthew tell me, i connect the center wire to the BP9060 FRONT. So everything work fine with the BP9060, bass are fine and volume of bass works well with audissey or without.
Then I try what Laika tell me to do.
unhook all speakers and stop every process. try small and crossover at 60hz, no bass.... Try in large, no bass...
Again i think i have an issue with the speakers
Any other idea ?
Thanks for all your help
can you take the CS9080, disconnect it from the center channel and switch out one of the towers to test it? if you’re getting good reaponse from the towers but not the cs, that is what i would do to test it. if it works, at least you’d know it wasnt the speaker.
Originally Posted by Laika View Post
Same speaker same issue. Just try this, Don't overthink it.
Turn off all processing. Make sure the speakers are db balanced using a setup mike or db meter.
Unhook all speakers except the center (or turn them off in the amp/ receiver). If you can try a crossover at 50, 55 and 60 (don't use the LFE line). Find a movie with deep male voices, start with the crossover at 50, spend a bit of time listening to the male voices while raising or lowering the bass knob till you have good center bass. Repeat at 55, Repeat at 60) You need about 4 or more inches of open air above the center for this to work. Spend a good 10 minutes on each crossover. If you think you have it nailed spend another 10 minutes to make sure. (Mine knob rides around 11 Oclock)
If you can not set the crossovers in that range set the center to full and do the same.
If you find this works. Activate the front Left and Right. If they have active subs (sorry did not read that part) and start trying to blend. (Once again no processing) start with the bass knobs low, oddly in my room, turning them down from 12 actually increases tactile bass and perceived audio bass (standing wave issue I think). Mine are at around 11 O clock, a bit lower maybe. Repeat the male voice test. Once it sounds right watch a few bass heavy movies and keep playing with the knobs on LR mains. Once you think you have it (take some good time on this, I spent a week) If you like what you hear but it once in a while bass sounds muddy or you lose dialogue toe them in toward the listening position. If your LR mains seem to lack a bit of bass now toe them out away from your head.
If this all works hook up the rest and adjust the sub.
My room hates processing with active speakers, I do the final tuneup with a computer and L/R and sub placement and slight adjustments of the bass knobs again over weeks of listening but don't change them much. When you finish run the mike processing and if you like the sounds better without it just turn it off.
beastmaster1981 is offline
post #41016 of 41548 Old 03-01-2020, 02:13 PM
Mantis10's Avatar
Quoted: 72 Post(s)
Liked: 66
Anyone have any Mythos 10 or 9's they want to move. I'm looking for a pair.
Mantis10 is offline
post #41017 of 41548 Old 03-02-2020, 08:01 AM
Quoted: 30 Post(s)
Liked: 8
BP2006TL hum
I’ve got a pair of BP2006TL speakers and one morning I woke up to a hum coming from the right speaker when I entered my great room (quasi home theater). After verifying all connections and the hum remained, I simply unplugged the AC. After reaching out to DT technicians, I received instructions for a board removal and repair job. But the techs said I can use it and go on with it as is, since I have a subwoofer and the board is only used for subwoofer management.
The question is, should I get that board repaired? Will it be worth it? Is my system dysfunctional??? It sounds fine to my casual ear. We watch movies all the time and I really haven’t noticed anything different.
pikemike is offline
post #41018 of 41548 Old 03-02-2020, 08:45 AM
Laika's Avatar
Quoted: 53 Post(s)
Liked: 26
One of each in mint shape if that gets you anywhere.
Laika is offline
post #41019 of 41548 Old 03-02-2020, 08:59 AM
Laika's Avatar
Quoted: 53 Post(s)
Liked: 26
That is so odd, It's hard to believe you got two bad ones but I'm starting to think so. The only other thing I can think of is it's wired out of phase either externally or internally. Switch the wires. I don't think this will help but it sure is easy to try. I had mine wired backward after tweaking a few months back and had a ton of bass, I thought the soundtracks were not mixed well but cancellations were not that notifiable, the center just seemed a bit off, watched two movies that way before I determined something was really off, It was not in your face bad and bass was there,. Where you crank it up and there is heavy bass notes on the center can you feel so solid air pumping from the top of the center? I have the 9060 first and did not like it because of lack of bass. Was not bad but it actually had more issues pop up in soundtrack clarity and bass then the 80 wired backward. This is a stumper.
Originally Posted by beastmaster1981 View Post
Hi everybody,
Any other idea ?
Laika is offline
post #41020 of 41548 Old 03-02-2020, 10:58 AM
keeper's Avatar
Quoted: 658 Post(s)
Liked: 277
Without the use of the woofer in these towers the cutoff is much different of course. I have read my BP3000 cut off around 120. So as long as you make the adjustments in bass management you should be fine. Or run your receiver setup with towers unplugged and see what it sets them as.
pikemike likes this.
keeper is offline
post #41021 of 41548 Old 03-02-2020, 02:01 PM
Laika's Avatar
Quoted: 53 Post(s)
Liked: 26
It's not a ground fault is it, sometimes those happen overnight for reasons I don't know. If you are not sure, plug it into another outlet in another room (or at least not on the same circuit breaker) If it goes away there are some cheap ways to try and get rid of the ground fault where it is currently powered.
Laika is offline
post #41022 of 41548 Old 03-02-2020, 02:09 PM
inspector's Avatar
Quoted: 308 Post(s)
Liked: 201
Originally Posted by bnewt View Post
Have a bp7004 that the red light no longer comes on. Is that a sign of speaker failure? Speaker seems to still play fine
Did you ever find out what was wrong with it, maybe the amplifier?
...finally retired and spending time in my dedicated HT!!!
SPARKSPLEX HT - Epson 6040 3D/4K UB Projector; 110" .09 16x9 Dalite HD Progressive Screen; Sammy 3D/4K K8500 (r-free); Panny ub420; 7.2.4. Def Tech speakers, Earthquake P12v2 Subs; Auto Source 100vs Amp; Denon 4300H; MX990 Remote; .
inspector is offline
post #41023 of 41548 Old 03-04-2020, 01:45 PM
Maddmaster's Avatar
Quoted: 152 Post(s)
Liked: 79
The red LED is the Subwoofer indicator. Check to see if the subwoofer part of the speaker works.
Definitive Technology:Front Height - Mythos Gem XL
Front - Mythos ST-L & ST Towers, Center - Mythos 10 & 8
Side & Back Surround - Gem XL
Ceiling - 4 DI 8R
Sub - Supercube Ref, SVS SB13 Ultra, SVS SB16 Ultra
Maddmaster is offline
post #41024 of 41548 Old 03-04-2020, 01:46 PM
bnewt's Avatar
Quoted: 133 Post(s)
Originally Posted by derekmoore View Post
^ what is your crossover set to on the CLR2500?
the crossover in the receiver is set at 80
can you set the individual crossover for each speaker?
Remembering Dad's passing 01/16/2017
May God Guide and Guard the USA!
bnewt is offline
post #41025 of 41548 Old 03-04-2020, 01:48 PM
bnewt's Avatar
Quoted: 133 Post(s)
guess the subwoofer portion is out
have ordered a replacement amp, so will see if that takes care of the issue
derekmoore likes this.
bnewt is offline
post #41026 of 41548 Old 03-05-2020, 05:38 AM
Quoted: 487 Post(s)
Liked: 387
That depends upon the brand. Denon/Marantz you can set each channel separately, but I understand some other models that is not the case.
5.1: Power - Denon 4308ci, Fronts - Def Tech BP9040's, Center - Def Tech CLR 2000, Surrounds - Def Tech PM1000's, Sub's - Rythmik E15HP x2, Display - Panasonic TC-55AS530U, TT - Rega Planar 2 w/ Dynavector 10x5
derekmoore is offline
post #41027 of 41548 Old 03-06-2020, 07:54 PM
BiggShooter's Avatar
Quoted: 379 Post(s)
Liked: 130
I've been noticing an issue with my DT CS9060 Center Channel Speaker. The 'illuminated D' is not turning off, and stays 'illuminated' long after my Denon AVR-X4300H is powered off. The light on the back is blue, which I'm assuming indicates the subwoofer is active. Any ideas / suggestions? I've unplugged it for 10+ minutes, and upon plugging it back in, it did not come on. Even after turning up the volume, it stayed off. I had to unplug the speaker, and plug it back in to get the 'D' to illuminate. I haven't noticed any issues with dialogue or sound coming from the center channel speaker. Everything sounds just like it did before the described issue.
I haven't had good luck with my DT speakers (BP9060's), and now the CS9060. I ended up replacing both powered subs in my BP9060's.
Thanks for the replies.
Hetfieldjames likes this.
BiggShooter is offline
post #41028 of 41548 Old 03-07-2020, 09:07 AM
Quoted: 344 Post(s)
Liked: 468
it is supposed to go off 15 minutes after it no longer detects a signal. if it stays on longer than that after the signal shuts off, i would venture to say you have some king of signal interference that is keeping that going.
i would send an email to DT support....thats pretty much the only way you can get ahold of anyone (took them 4 days to respond to my email).
sorry for your troubles.
Rythmik FVX15
post #41029 of 41548 Old 03-07-2020, 10:31 AM
Quoted: 105 Post(s)
Liked: 60
I just bought 2 of the BP9060, 2 of the BP9040 and a CS9060. I know forums tend to highlight the problems, but sounds like a few people are having reliability issues with the amp going out, etc...
Should I be concerned? Anyone have any long term reviews on these for reliability?
SD1290 is offline
post #41030 of 41548 Old 03-08-2020, 10:13 AM
maddog510's Avatar
Quoted: 468 Post(s)
Liked: 97
Been having an issue as of late with my Supercube 2000. When I turn on my AVR, the subwoofer won't turn on. I have to unplug the LFE cable from the woofer then the power comes on & then all is well until I turn off the receiver. Could it be an issue with the cable or the amp itself?
Sent from my SM-N975U using Tapatalk
maddog510 is offline
post #41031 of 41548 Old 03-08-2020, 01:46 PM
Quoted: 344 Post(s)
Liked: 468
may not be detecting a signal from the receiver. could be a short in the cable (happened to me). could be settings on your receiver arent strong in the lfe area.
what is your sub level set to? what source material are you listening to?
there’s a lot of variables that go with your issue.
Rythmik FVX15
post #41032 of 41548 Old 03-08-2020, 01:49 PM
Quoted: 344 Post(s)
Liked: 468
seems to be hit or miss.
i have a pair if the bo9060. they are working so far, but i havent had them for very long.
Rythmik FVX15
post #41033 of 41548 Old 03-08-2020, 01:54 PM
maddog510's Avatar
Quoted: 468 Post(s)
Liked: 97
I wasn't having this issue up until about a week ago. My trim level is set @ -6.0 DB in the AVR so I know it's not too low. I'm kind of thinking it could be the cable because like I said when I disconnect it from the woofer the power come on.
post #41034 of 41548 Old 03-08-2020, 02:24 PM
Quoted: 344 Post(s)
Liked: 468
next time it happens, instead of unplugging the cable, try wiggling the cable or tapping the connection. if you do that and it kicks on, you probably have a short. thats what i did when i hd the same issue. but my cable was a monster one that was 20 uears old and went through 5 moves in the military....so.....
or you can go get a new cable, hook it up and turn it on. if it works, its the cable. if it doesnt, return the cable and start looking at either the sub terminal or the receiver.
Rythmik FVX15
post #41035 of 41548 Old 03-08-2020, 02:29 PM
maddog510's Avatar
Quoted: 468 Post(s)
Liked: 97
I just wiggled the cable & it didn't come on so does that mean that's the culprit?
post #41036 of 41548 Old 03-08-2020, 03:12 PM
Wiho1975's Avatar
I've had my pair of BP9060 and a single CS9060 since Q4/2017 without any issues thus far (knock on wood). I drive them daily for at least a couple of hours as part of a 5.1.4 setup using an RX-A3070.
Sent from my ONEPLUS A6013 using Tapatalk
josh6113 and MATTHEW PATIENT like this.
Wiho1975 is offline
post #41037 of 41548 Old 03-08-2020, 03:34 PM
Quoted: 344 Post(s)
Liked: 468
wiggle not just the terminals, but the cable itself from end to end.
if it doesnt come on, i would venture to say it isnt the cable.
Rythmik FVX15
post #41038 of 41548 Old 03-09-2020, 08:12 AM
bnewt's Avatar
Quoted: 133 Post(s)
I changed out the amp & everything seems to be back to normal
Another question...…...I have the BP7004 as fronts & also as surronds.
I was hoping that this set up would give me more bass, but apparently there isn't
much bass sent to the surronds?
Is that correct?
bnewt is offline
post #41039 of 41548 Old 03-09-2020, 09:44 AM
Bonzo17's Avatar
Quoted: 46 Post(s)
Liked: 47
Is that correct?
Do you have them set to large in your processor/receiver?
Sent from my moto g(7) play using Tapatalk
Bonzo17 is offline
post #41040 of 41548 Old 03-09-2020, 10:12 AM
Quoted: 14 Post(s)
Liked: 4
Hi everybody,
Thanks Laika for answers.
Bigshooter, i Think we have the same issue
My problem is still the same. I contact again my dealer who wants me to test with LFE.
So i buy a long cable to connect the CS9080 to the LFE Marantz SR7013. And after a lot of test, still the same issue, NO BASS !
I think the unluck time is here
Hope the dealers will do something
Thanks again
Reply Speakers
Definitive Technology , Definitive Technology Bp2x Speakers , Definitive Technology Bp7004 , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Bpx Speaker Single Black , Definitive Technology Mythos 6 Aluminum Stand , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Supercube Trinity , Marantz Sr7002 Surround Receiver , Parasound , Receivers Amplifiers , Speaker Systems
