Ascend SE Owner's Thread - Page 142 - AVS Forum | Home Theater Discussions And Reviews
 128Likes
post #4231 of 4285 Old 03-10-2019, 11:03 AM
xpostal's Avatar
Quoted: 99 Post(s)
Liked: 127
Originally Posted by tonybradley View Post
I'm in the market for some new speakers. I've narrowed down some of my choices, but based on reviews, I'm really leaning towards the CMT-340s for my LCR. I do NOT like Harsh or overly bright speakers and these appear to fit that bill. Many years ago, I had them in my cart and was about to order them and then was deflected to a brand many were raving about. Hindsight is 20/20, but I made the wrong decision and purchased Elemental Design towers and Center. I've never been too happy with them. The only good thing is they aren't harsh. But they are just missing something. I was recently told they had a bad mid range crossover and the tweeters were very poor. So about 12 years later, here I am back to Ascend CMT-340s.
My dedicated budget theater room is 13x19x7.5. I have two 12" SVS Subs. My main listening position is about 12' from the screen, or about 10' from the speakers (not sure how far from the wall they should be). This is 99% BluRay movies (maybe 4K in the future) and 1% Streaming Netflix. No Music in this room. I do have 4" of Bass Traps in the front corners, some broadband absorption Panels at first reflection points, and Velvet Panels with Drywall behind it for the Non first order reflection points up to about 5' from screen one on both sides. My center channel is definitely not in an good position. It sits low to the ground. Tweeter would be about 18.5" off the ground where my Ear in the first row would be 36". I have my current center speaker angled upwards towards the main listening area using rubber door stops.
Few questions:
1- Should I hear a noticeable improvement with the CMT-340s compared to my Elemental Design Speakers? I can't remember the model numbers off the top of my head, but they were their larger mains and center. Company went out of business several years ago for some shady practices.
2- I like to listen fairly loud using my Denon X3400H receiver. Not quite Reference level, but still quite loud. Will these do well at loud volumes for movies?
3- I hate to spend almost as much for their speaker stands as a pair of speakers. Does anyone have any recommendations for a non Ascend Speaker Stand that would work well? I do like the looks of their stands as it makes the speaker appear seamless and like a Tower, but they are pricey. Would something like this Monolith by Monoprice work well....or do most people purchase Ascend's stands?
https://www.monoprice.com/product?p_id=24794
4- Given my center will be located lower than ideal, and angled towards the listener, do you feel the CMT-340 Center Channel will still perform well? I know it won't be great for the second row, but it is what it is....unless I can figure out a way to mount it above the screen and aim it downward. I've been recommended KEF to work better with the center being so low. I have not contacted Ascend yet, but Chane and Elac have both told me I'd have no problem with their speakers lower and angled to the listener.
You have a couple difficult questions to answer, I will do my best. I am running a 7.4.1 setup (will get a second sub eventually). I have 3 CMT-340 SE speakers up front 4 HTM-200 SE's for surround duty and 4 RSL C34E speakers for the ATMOS heights.
1. I don't know anything about the Elemental Design speakers, so I cannot compare them and would not know if the Ascends will improve your experience. I did initially compere mine to some Klipsch speakers. I thought the Ascends sound was a bit cleaner, but not as bright with no harshness. It sounded just right to my ears. Make a decision and don't second guess yourself. Unless you have money burning a hole in your pocket. Buy them and enjoy them.
2. I have the Denon X4400H and can power my Ascend setup to uncomfortably loud levels without distortion. My room is far, very far from ideal. I fill the space without any trouble. I added a second amp for 2 of the heights, and it works great.
3. As for the stands both those options look nice. I was feeling creative so I built my own stands. I had built a shelving unit for my Xbox and matched the three fronts with the same design. Eventually it will all be hidden behind a false wall, but for now they look nice. And when the lights are down and I am watching a move, you can't see them anyway.
4. If you are fine with your center the way it is now then don't worry, the matched center will sound great. I believe Ascend is using a wide dispersion tweeter and it is set for the horizontal position, unless you specify differently. I have an AT screen so I have all three CMT-340's upright behind the screen and had to ask for the tweeter to be rotated on my center. Ascend lived up to their reputation of top notch customer service and were wonderful to deal with and answered all my questions.
xpostal is offline
post #4232 of 4285 Old 03-10-2019, 01:39 PM
tonybradley's Avatar
Quoted: 567 Post(s)
Liked: 236
Thanks for the reply. That's great news that you can crank it loud and they still play well. Also good to know about the wide dispersion. I was wondering about that as their site stated that for the Mains, but not the center. I didn't know if there was a Physics thing that prevented the wide dispersion for the Center with the tweeter rotated since it wasn't listed.
Does the Center seem to have some "Umph" to it?
tonybradley is offline
post #4233 of 4285 Old 03-11-2019, 08:08 AM
xpostal's Avatar
Quoted: 99 Post(s)
Liked: 127
It looks like the center is the same speaker, just with the tweeter rotated and a different crossover. I am not the most knowledgeable in that area. From their website.
"The heart of our new 340 SE center is its advanced bi-wireable crossover featuring EXBAC. EXBAC is our coined term for Extended Baffle Compensation, resulting in natural and full sounding vocals free of typical honkiness and thinness." It goes on in detail after that.
xpostal is offline
post #4234 of 4285 Old 03-11-2019, 08:24 AM
bcg27's Avatar
Quoted: 24 Post(s)
I would recommend calling Ascend if you have questions about the physics specifics. There's a good chance you'll be able to talk to Dave or at least arrange a call back and get everything answered straight from the source.
bcg27 is offline
post #4235 of 4285 Old 03-11-2019, 10:04 AM
Quoted: 567 Post(s)
Liked: 236
Contacted them late last week. Hope they are able to get back to me this week.
post #4236 of 4285 Old 03-12-2019, 04:44 PM
Quoted: 567 Post(s)
Liked: 236
Dave responded to my email. Given that the Tweeters have a wide dispersion, he stated that the center would work out well being mounted low. He does not recommend mounting above the screen. I also asked about any Toe-In. He said that's more of a personal preference and to try it out. I did ask a follow up question. I asked, with the wide dispersion, if I still need to angle the center speaker towards the MLP.
post #4237 of 4285 Old 03-14-2019, 04:27 PM
Quoted: 567 Post(s)
Liked: 236
Originally Posted by postrokfan View Post
Ascend's prices for stands aren't unreasonable IMHO. Pangea makes some economical stands but they're still around $100.
I'm very ignorant on Speaker stands as I really am having a hard time pulling the trigger on $180 per Stand from Ascends (although they have a sell for $140 per stand which is still a lot I think). I've always had Tower Front speakers and Surrounds have always been mounted on walls. I did a lot of searching on AVS about Stands for the CMT-340 SEs. Several were very old posts, and the stands can't be found. However, I did read some posts recommending the Monolith by Monoprice for $55 a piece and the Sanus on Amazon (which I found the Sanus Steel Series SF22-B1) for $110 a piece.
I'm clueless about knowing what stands will fit the CMT-340s. The ones from ascend state the speakers lock into the base. How do others, such as Sanus or Monolith work....do they just Sit and balance, or is there a method to lock? I am also not sure if the base of the stand has to be the same size as the Speaker, smaller, bigger, etc.
Any help would be appreciated.
post #4238 of 4285 Old 03-14-2019, 08:46 PM
Ascend's Avatar
Quoted: 233 Post(s)
Liked: 699
Hi Tony,
Our TP-24 stands are $180 per pair, not per each stand - and that price drops to $140 for the pair when purchased with the speakers...
Considering how much these actually cost us to manufacture, we should actually be selling them for quite a bit higher.
Be careful with choosing stands for the 340's if you don't wish to go with ours, the 340's are big and heavy speakers.
Please feel free to contact us directly.
postrokfan, xpostal and Vg247 like this.
David Fabrikant
audio professional and soft spoken representative of www.AscendAcoustics.com
Ascend is offline
post #4239 of 4285 Old 03-15-2019, 06:46 AM
Quoted: 567 Post(s)
Liked: 236
Originally Posted by Ascend View Post
Hi Tony,
Thanks David. At that price for a Pair, that's a great deal. I apologize as I thought that was Per Stand!!!
post #4240 of 4285 Old 03-15-2019, 10:55 AM
Quoted: 326 Post(s)
Liked: 328
I have the Sanus SF stands and they work well for me. Granted, I do not have the CMT speakers but have used 4 different sets of speakers. They provide different pieces of hardware you can use on the top plate corners to place the speakers on. I use the rubber ones which are placed in each corner. The speakers just sit on top of these and certainly could be knocked off. If you have kids or animals they certainly could knock the speakers off! Some people use products such as Blu Tack as an adhesive to attach the speakers to the stands and keep them from falling off. It all depends on your situation, home environment, and preferences. You ideally want the tweeter of your speakers to be around ear level of your listening position, so that might be something you consider on what size of the stand you buy.
Hope that helps.
BTW...the Sanus SF stands are by pair and not each as you stated. It isn't really clear on Amazon I see.
D33vious is offline
post #4241 of 4285 Old 03-15-2019, 11:14 AM
Quoted: 567 Post(s)
Liked: 236
Hope that helps.
I looked at the Q&A and it was the last question on the list. It didn't say on Amazon, so I assumed it was one.
post #4242 of 4285 Old 03-15-2019, 08:02 PM
postrokfan's Avatar
Quoted: 893 Post(s)
Liked: 6995
It looks like Dave from Ascend already answered your question. Their stands will lock the speakers into the base and that's ideal. The other stands will simply provide a base for the speakers to sit on (with some rubber pads to protect the finish). You can use Blu-tak on the bottom of speakers to prevent sliding. This material won't damage the speakers.
2-channel: PSB Imagine T, Music Fidelity M2si, SVS SB-1000, Rega RP1, Pro-Ject Phono Box, Marantz ND8006
Living Room: Deftech Demand D9, Deftech CS9040, B&W ASW610, Yamaha Aventage RX-A2030
Desktop: KEF LS50, Nuforce DDA-120, MacBook Air
BR: MA Silver 2 (5th Gen), B&W ASW608, NAD 326BEE, Zen Blue, Marantz CD5004
postrokfan is online now
post #4243 of 4285 Old 03-16-2019, 06:59 AM
Quoted: 567 Post(s)
Liked: 236
Now that I realize the Stands from Ascends are a Pair, even with shipping, I'd only be paying about $70 more than if I went with a good stand on Amazon. I'd pay $70 more to make sure I have stands made for it, and they make the speakers look more like conventional towers. My speakers will be in a dedicated room. My kids are older and there is no horse playing in the theater, so I wouldn't have worried about them getting knocked off....just that they were secure enough to look good.
xpostal likes this.
post #4244 of 4285 Old 03-16-2019, 11:30 AM
postrokfan's Avatar
Quoted: 893 Post(s)
Liked: 6995
The Ascend stands are definitely the sensible choice.
post #4245 of 4285 Old 03-18-2019, 04:04 PM
Quoted: 567 Post(s)
Liked: 236
Several posts back, I asked if the 340 Center has some "OOMPH" to it. Meaning, when watching a movie with a deep voice, does it sound deep? If the actor has a deep and gravely voice, does this center give that oomph with the deep and gravely feel? If a pistol is fired, does it pack a punch? I will be running a Sub, but I think many of the frequencies I'm talking about are above the 80Hz I have set for crossover as my current center doesn't give that that oomph I want.
post #4246 of 4285 Old 03-18-2019, 05:16 PM
Quoted: 2094 Post(s)
Liked: 1719
A gun shot is mostly covered by the subwoofer but vocals are very full and highs are extended. Easily one of the best speakers out there for the money.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #4247 of 4285 Old 03-18-2019, 05:51 PM
Quoted: 567 Post(s)
Liked: 236
That's fair with the gunshots. I knew larger caliber guns came more from the Sub, such as Shotguns or Automatic Weapons, but wasn't sure about those from a pistol. I'm still trying to decide if I want to go with the Emotiva T1 Towers and C2 Center or the Ascends. Ascends is what I wanted to go with many years ago, before I went with another manufacturer, so I keep coming back to them. I also like the Wide Dispersion as Dave told me it would work great given my center is lower than I'd like. The Emotiva are cheaper with the T1 Closeout Price and $0 Shipping. Given you need Stands for the Ascends and Shipping, the CMT-340 SEs are about $200 more for LCR than the Emotiva's, but I won't have the risk of my amp not handling the Ascends properly or shutting down (although I think I'd be fine with Emotiva, but still concerned). If shipping was only $50, I'd order both and try them out, and send the ones I didn't want back. With Ascends, it's like $104 to have them shipped to me. I assume that if I don't like them and return them, not only do I pay shipping back (probably ~$100), I will not get the Shipping Costs back from my order, although I haven't checked on that. If that's the case, it's like $200 to try the speakers. $100 to try them out for 30 days is a little much, but I could almost do that. I'm very tight with my money, so thinking of wasting $100 or $200 to listen to some speakers hurts just a bit
post #4248 of 4285 Old 08-29-2019, 11:09 AM
Thunder240's Avatar
It’s been a few years, but I used to run a 2.1 setup with Ascend CMT-340SEs and an Outlaw LFM-1 EX. My recollection is that I settled on 65 Hz for the crossover point in my room after initially starting at 80. The Ascends packed plenty of midbass oomph. Deep voices sounded deep. I only ever needed the sub to cover the true subbass freqs, e.g the stuff that’s present in jet engines and explosions and such.
Re pistols, it depends on the mixing. There is a scene in Ronin where one of the guys is firing a .45 from an overpass. The Ascends didn’t quite handle the rumble from those gunshots on their own, but they are mixed with gobs of subbass. In others, like Band of Brothers, the Ascends seemed to handle pretty much the entire freq band of the gunshots (45s and 30-06s on the American side).
I hope that is helpful. I haven’t heard the Emotivas, so no point of comparison.
Vg247 likes this.
Thunder240 is offline
post #4249 of 4285 Old 02-07-2020, 12:51 PM
Brent M. Wagner's Avatar
I tried searching but there was conflicting info about rotating the tweeters on 340SEs for vertical vs horizontal use. Is it necessary or not? Emailed tech support, but no response for a few days.
Brent M. Wagner is offline
post #4250 of 4285 Old 02-07-2020, 04:05 PM
Quoted: 17 Post(s)
Liked: 9
Post 4064 in this thread says "No" for SE. Hopefully tech support confirms for you.
bac2040 is offline
post #4251 of 4285 Old 02-07-2020, 05:25 PM
jsb75's Avatar
Quoted: 434 Post(s)
Liked: 128
I know there is a toggle switch on the crossover . So depending on how the speaker was ordered, as a center or left and right, the switch is flipped one way or the other. It’s a circuit that is supposed to compensate for the center channel being in a cabinet or on top of something that will reflect the sound. Supposed to help with dialogue clarity. It’s easy to get to. If you unscrew one of the woofers, it’s right behind it. It wasn’t meant to be user adjustable. But it’s easy to do.
jsb75 is online now
post #4252 of 4285 Old 03-01-2020, 06:24 AM
Quoted: 110 Post(s)
Liked: 66
Some measurements for CMT 340 SE center channel is now out. Not really suprising findings as 2-way horizontal model with known caveats when laying. Horizontally +-10 degrees good response, then it falls apart. Vertically upright much better! Few other nags aswell, check it out:
https://www.audiosciencereview.com/f...-review.11797/
Vg247 and raistlin65 like this.
Mr_Hifi is offline
post #4253 of 4285 Old 03-13-2020, 08:39 PM
Ryan Statz's Avatar
Quoted: 1295 Post(s)
Liked: 1088
Does anyone know whether Ascend will do a different finish on their CMT-340 SE speakers, such as their satin dark cherry?
Home Theatre: Marantz SR6014 | KEF Q750 | KEF Q650c | KEF Q150 | HSU ULS-15 MK2 | Sony XBR55X900E | PS4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Fluance RT85 | Ortofon 2M Blue | Cambridge Audio AXC35 | Neat Motive 3
Ryan Statz is online now
post #4254 of 4285 Old 03-14-2020, 07:10 AM
doni01's Avatar
Quoted: 175 Post(s)
Liked: 141
Not as far as I know but best info will come from them. Shoot them an e-mail or call. They are great to deal with!!
Let's just boost this thread with a pic or two of my SE340's
Billy p, goldark and Wade. like this.
doni01 is offline
post #4255 of 4285 Old 03-14-2020, 08:04 AM
Quoted: 2543 Post(s)
Liked: 2364
i know you are probably thinking HT (where the 340's would be great), but the sierra 1 may be a better option...
YAMAHA TSR 5790.. front l/r Dennis Murphy modded emotiva b1's ..BIC v1220.....Emotiva basx10.... infinity alpha 20 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. ascend cbm 170 se... kef q100 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #4256 of 4285 Old 03-14-2020, 09:32 AM
Ryan Statz's Avatar
Liked: 1088
End game (in the very distant future, mind you... nowhere near being affordable right now unless you have $6k CAD to donate?) right now is Sierras all around, but if they were flexible with the finish on the CMT-340 SE centre, I'd for sure consider it over the Horizon just for space reasons.
Lp85253 likes this.
post #4257 of 4285 Old 03-14-2020, 10:20 AM
Billy p's Avatar
Quoted: 480 Post(s)
Liked: 930
Hi Ryan...yes they do. I had my htm 200s for surround done in espresso finish to match my mains. Its not the ideal situation because the stain application on my 200se(or 170s+340) the cabinet will not be precise due to the seams and nature of the material itself being mdf.
Dave advised me but to be honest they look very nice looking as surrounds but you can notice some very minor imperfections based on what I described. For main speakers... Id go with the Sierra's....just saying.
Here are my 200se
ID:	2697660   Click image for larger version
xpostal and Lp85253 like this.
Ascend Acoustics: Towers, STC w RAAL & 200 SE in espresso,
65" LG OLED B9, Marantz 1710 & Oppo 103D,
Sub: Funk Audio 18: (Santos Rosewood)
Indian proverb: We don't inherit the earth from our ancestors but we borrow it from our children!
Billy p is online now
post #4258 of 4285 Old 03-14-2020, 10:25 AM
Ryan Statz's Avatar
Liked: 1088
Originally Posted by Billy p View Post
Hi Ryan...yes they do. I had my htm 200s for surround done in espresso finish to match my mains. Its not the ideal situation because to the stain application on my 200se(or 170s+340) the cabinet will not be precise due to the seams and nature of the material itself being mdf.
Here are my 200se
That's good to know!
Oh, if anything, the CMT-340 SE would be a centre channel. And even then it would only be because the Horizon is too tall - mains would definitely either be Sierra 2s or 2EXs. With any luck, Sierra towers.
Billy p and Lp85253 like this.
post #4259 of 4285 Old 03-14-2020, 12:31 PM
Quoted: 40 Post(s)
I bet that rocks the house for movies!! Nice setup
doni01 likes this.
Ascend Sierra-2 LCR | Ascend HTM-200 Surrounds | Rythmic E15HP | Yamaha RX-A780 | Samsung HU8550
Wade. is online now
post #4260 of 4285 Old 03-14-2020, 12:33 PM
Quoted: 40 Post(s)
Ascend does a lot of custom work, I’m sure you’d have no problem having them do that, maybe a veneer covering would look better.
Wade. is online now
Reply Speakers
Ascend Acoustics , Pioneer Vsx 1014txk Thx Select Av Receiver , Receivers Amplifiers , Velodyne Impact 10 10 Subwoofer
