7.1 placement question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-18-2006, 07:52 AM - Thread Starter
Gates's Avatar
Quoted: 255 Post(s)
Liked: 109
Hi guys, I'm building my HT room and want some advice. I have a 7.1 setup with Dipoles for sides and regular speakers for the back. I know they say to put surrounds above ear level, but how high is too high ? And do the side and back have to be at the same height, or do the dipoles have to be higher ? On another note, the HT room will be constructed in the basement and I was wondering if french doors is a good idea in an HT room. Anyone have any ? Do they vibrate ? I know they are probably not the best to keep sound out, but if I want to split the two sides of the basement, it might be the best way to not close it off completely. The basement is a little on the small side. Thanks in advance.
JVC DLA-RS400, Elunevision 120" 2:35 Cinemascope AT screen, Marantz AV8802a Pre/Pro, OPPO UDP-203, Anthem MCA 525, Anthem MCA 225, Anthem PVA-4, 4x Paradigm CI Elite E80-R ceiling speakers, Paradigm Prestige 95F, Paradigm Prestige 15B x4, Paradigm Prestige 55c, Paradigm Signature Sub 1, Richard Gray 1200c Custom power conditioner.
Gates is offline
post #2 of 3 Old 05-18-2006, 08:32 AM
SethH's Avatar
How many rows of seating do you have? One of the reasons that side speakers should be well above head-level is so that the sound isn't blocked by the person sitting next to you on the couch. If you only have one row of seating then this shouldn't really be an issue with the rear speakers.
SethH is offline
post #3 of 3 Old 05-18-2006, 08:39 AM - Thread Starter
Gates's Avatar
Quoted: 255 Post(s)
Liked: 109
Well the room isn't very big (approx 10 1/2 by 21 feet, so my couch is along the side wall and my loveseat is across the room facing the TV, wih my sofa chair being between them.
Gates is offline
Closed Thread Speakers
