Monitor Audio Owners Thread - Page 421 - AVS Forum | Home Theater Discussions And Reviews
 440Likes
post #12601 of 12913 Old 02-11-2019, 08:30 PM
mkiv808's Avatar
Quoted: 87 Post(s)
OK, the FX speakers do look good. Would consider those.
mkiv808 is online now
post #12602 of 12913 Old 02-13-2019, 07:56 AM
Quoted: 1521 Post(s)
Liked: 301
Originally Posted by Shadowed View Post
Originally Posted by mkiv808 View Post
Who has the Controlled Performance in-wall/ceiling's?
Intrigued by them. Loved my old MA bookshelves, and want an enclosed speaker for sound proofing purposes (and not having to build boxes for an open speaker). These seem rather cost effective. I would be doing 8 speakers for surround (sides) and Atmos (ceiling).
If your concern is sound proofing, the in walls are not the way to go.
Any speakers in wall/ceiling cavities will leak sound to the rest of the home much easier. The most efficient/cost sound barrier is multiple layers of drywall on channel clips with green glue etc. with no holes cut in it.
So bookshelf speakers or towers are a better option to keep the sound in the room.
I have atmos speakers (CT-280 CRT) planning to go in ceiling that is sound proofed. Not much I can do about that. I’m sure the sound proofing is still better then nothing...
Sony 75Z9D, Samsung 65JS9500
Monitor Audio Gold 200(2), Gold 350, Gold 50(2), Gold CT280-IDC(4). SVS PC4000(2).
NAD 758, Anthem MCA-5
Apple TV 4K, Nvidea Shield. Mac Mini (2018). Samsung UHD BluRay and X-Box One X. 14 Sonos
Chirosamsung is online now
post #12603 of 12913 Old 02-13-2019, 10:02 AM
Quoted: 114 Post(s)
Liked: 87
I have a 7.1.4 atmos setup with ALL monitor audio CP speakers... Wt-380idc front 3, Wt-260s surrounds and ct-260 atmos. I think they're fantastic and I disagree with the other poster about sound leakage. I have them in the basement and the only sound traveling to the 1st floor is from the subwoofers. The back box on these speakers is extremely effective at controlling the sound to only go into the room where you want it.
Just my opinion, but I do actually own these speakers. When I was shopping I got a lot of negative comments about using in walls but they were all wrong. I don't think many people go this route, and I got a lot of comments from people that didn't actually own this type of speaker.
mkiv808 likes this.
ctsv510 is offline
post #12604 of 12913 Old 02-13-2019, 10:05 AM
Quoted: 114 Post(s)
Liked: 87
I disagree. I have all controlled performance in wall and in ceiling speakers and the only sound that leaks to the rest of the house is from subwoofers.
You may be confusing these with open back in wall speakers, which will leak sound very much.
mkiv808 likes this.
ctsv510 is offline
post #12605 of 12913 Old 02-14-2019, 06:21 PM
Liked: 2
Originally Posted by purplerain View Post
I've had the RX FX series for a few years. Was looking into the Monitor Audio Silver 500 (2), Monitor Audio Silver C350 (1), and Monitor Audio Silver FX (2) all in Rosenut. How much of an upgrade would this be and I'm looking at around $5K for this setup (unless you know of a place cheaper?)
Present system:
(2) Monitor Audio RX FX surrounds
(1) Monitor Audio RX center
(2) Monitor Audio RX6 towers
Hi @purplerain . I had the exact speaker setup as you. I switched to the silver 300, c350, rxfx and silver 50. While I dont think there is a huge difference in the rxfx, the front 3 were night and day better sounding. Quite a bit more bottom end and much more clear and accurate midrange. Very smooth and not bright. I running them with an anthem MRX 1120. The imaging is outstanding. Im using 2 PSA s1510 df subs so I didn't feel I needed the 500's. I am extremely happy with the upgrade. Hope this helps. Cheers
deane1098 is online now
post #12606 of 12913 Old 02-15-2019, 05:55 AM
purplerain's Avatar
Quoted: 233 Post(s)
Liked: 97
Question
Is it OK to mix silver towers and silver center with the RXFX surrounds?
I'm looking at $3400 shipped for the 2 towers and center
*ENTERTAINMENT PURPOSES ONLY*
*TV: Sony XBR65Z9D* - *BD Player: Pioneer UDP-LX 500* - *AVR: Yamaha RX-A3070* - *Audio System: (2) Funk Audio 6.1P’s towers - (2) Funk Audio 3.4D’s surrounds - (1) Funk 18.0C sub*
purplerain is offline
post #12607 of 12913 Old 02-16-2019, 09:14 AM
Liked: 2
I'm looking at $2900 shipped for the 2 towers and center
Hi @purplerain . I have the Silver FX to match everything else, I mistyped RXFX in my earlier post. I don't think sound wise there would be a huge difference if you kept your RXFX with the new Silvers. I replaced mine due to different colours. Walnut to black. That is a great price! I'm in Canada, I paid a lot more than that. Cheers
post #12608 of 12913 Old 02-16-2019, 04:17 PM
Superman07's Avatar
Quoted: 185 Post(s)
Liked: 46
Found a dealer selling a C350 which I was able to get a good deal on (although now feel like I could have gotten more off ). Should be here end of next week!
purplerain likes this.
Superman07 is online now
post #12609 of 12913 Old 02-19-2019, 05:55 PM
vantage78's Avatar
Quoted: 166 Post(s)
Liked: 43
Originally Posted by Mors78 View Post
What are good subwoofers to pair up with the Gold 300s? I was looking at 2 of the SVS SB-3000 but I am concerned with sound quality not being on par with the gold speakers. thanks
I have dual PB-4000s with the Gold front stage (Gold 300s, Gold C350) They work fantastic, athough probably overkill lol.
vantage78 is offline
post #12610 of 12913 Old 02-21-2019, 03:50 PM
Liked: 301
CT280-IDC grilles come come off easily?
I just had MA CT280-IDC in ceilings installed for atmos by an installer and I’ve noticed that when trying to take the speaker grill off to change the tweeter direction it seems pretty firm. Are they supposed to come off easily or would they be somehow stuck on there in properly?
post #12611 of 12913 Old 02-21-2019, 03:53 PM
Liked: 301
I have just purchased Duel SVS PC4000s (same strength as the PB4000) for the Gold 200 and gold 350 centre...,
post #12612 of 12913 Old 02-21-2019, 04:25 PM
Quoted: 114 Post(s)
Liked: 87
They're just magnetic. If you slide something between the grill and the drywall they'll pop off. Because of the angle of the edge of the grill it can be a little difficult with your fingers.
ctsv510 is offline
post #12613 of 12913 Old 02-21-2019, 04:28 PM
Liked: 301
Thanks so much for the helpful response-that would explain why I can’t get it off with my hands...I’ll try a butter knife 🙂
post #12614 of 12913 Old 02-22-2019, 02:54 PM
Liked: 301
Another question about the in ceiling CT280-IDC. I couldn’t see anywhere instructing how to change the angle of the speaker (tweeter or woofer?) in the 280.
I don’t want to just pull on it and maybe breeak something...is there a way to safely angle it to MLP?
post #12615 of 12913 Old 02-22-2019, 04:28 PM
Quoted: 114 Post(s)
Liked: 87
It looks like they're similar to my wt380-idc...you should be able to push on the entire center section. Try pushing on one of the indents. That whole center section tilts.
ctsv510 is offline
post #12616 of 12913 Old 02-22-2019, 05:54 PM
sb01gt's Avatar
Quoted: 210 Post(s)
Liked: 75
Just want to get some opinions on how these speakers perform for home theater usage. I was specifically looking at the Silver 100's with Silver C350 (~$2450 CND) for front LCR, but the gold series from 2014-18 has also caught my eye since they're now on sale everywhere due to the new 2019 version being released. I would probably do the Gold 100's + C150 (~$2700 CND), obviously there's a big difference between the two series with the tweeters, and those prices are with no negotiating.
Currently running Focal Chorus 807V and CC 800V for my fronts, would the MA's be a noticeable upgrade? How would they compare to something like the MartinLogan Motion 35XT + 50XT center? Unfortunately I wouldn't be able to listen to those two brands pre-purchase.
Panasonic EZ1000 65" OLED / Panasonic DMP UB400 / NAD T758v3 / Nvidia Shield TV
5.1.2 speaker setup - KEF R300 / R600c / Q50a / Focal Chorus SR800V / HSU ULS-15 mk2
sb01gt is offline
post #12617 of 12913 Old 02-24-2019, 10:01 AM
Liked: 301
I’ve got all gold series in 5.1.4 and it’s great. Mine are gold 200 and 350 with 50s as surrounds.
I would definetly get the better 350 driver as it is 3 way vs 2 way of 150 and the center is the most important in home theater
post #12618 of 12913 Old 02-24-2019, 10:06 AM
Liked: 301
Another question about the CT-280 or 380 IDC.
When I was rotating the driver I noticed a switch for room gain on/off. It was set to off on all 4. What does this mean and should I leave off?
Also, it had another switch for 0 or +3 or -3.
It is set to 0. Same question..,
post #12619 of 12913 Old 02-24-2019, 12:27 PM
sb01gt's Avatar
Quoted: 210 Post(s)
Liked: 75
I was originally looking at the silver 100's with matching C350 before I saw that the golds were on closeout sale due to being updated. Will the bigger center speaker work fine with the smaller bookshelves, or is there a possibility that it could overpower them a little?
sb01gt is offline
post #12620 of 12913 Old 02-24-2019, 01:34 PM
Liked: 301
350 Doesn’t overpower 200s...
Get the golds-BOG STEP UP over silvers
post #12621 of 12913 Old 03-01-2019, 10:51 AM
Liked: 301
Bump
post #12622 of 12913 Old 03-01-2019, 02:45 PM
mkiv808's Avatar
Quoted: 87 Post(s)
Has anyone bought from bestdealav on eBay? They have very good prices on in-walls. Just wary that they're legit/genuine, as I haven't seen them that cheap anywhere else.
post #12623 of 12913 Old 03-04-2019, 11:51 AM
Mors78's Avatar
Thanks for the reply. How big is your room?
Mors78 is offline
post #12624 of 12913 Old 03-04-2019, 11:55 AM
Mors78's Avatar
Please let me know how that goes. Also have big is the room?
Mors78 is offline
post #12625 of 12913 Old 03-04-2019, 12:09 PM
Mors78's Avatar
Has anyone used CP-CT260 in a bathroom? Any issues with humidity? thanks!
Mors78 is offline
post #12626 of 12913 Old 03-04-2019, 12:56 PM
vantage78's Avatar
Quoted: 166 Post(s)
Liked: 43
23’x14’
post #12627 of 12913 Old 03-06-2019, 04:55 AM
Liked: 301
17.5x12x7.25
About 1500sq ft
post #12628 of 12913 Old 03-10-2019, 04:47 PM
AllanMarcus's Avatar
Quoted: 96 Post(s)
Liked: 41
wow, just noticed the Gold line (4th gen, or 4G) has been discontinued in favor of a new Gold line. Looks like MA is giving up on the ribbon tweeter and switching to a "Micro Pleated Diaphragm" (MPD) tweeter, which basically looks like an Air Motion Tweeter. I think this tweeter slides down from the Platinum line.
At any rate, there are some great prices from Parts_Connexion on Audiogon for Gold 4G speakers, if anyone is interested.
Anyone heard the MPD based speakers, either gold or Platinum?
Yamaha RX-A3080 | LG OLED77C8PUA | Monitor Audio Gold GX100 mains
Monitor Audio Gold C350 | Orb ModX surrounds and Atmos overheads | SVS SB13Ultra sub | 7.1.4
Plus a bunch of high-end headphones (Utopia, TH-900mk2, Audio Zenith, and more)
AllanMarcus is offline
post #12629 of 12913 Old 03-11-2019, 12:58 PM
purplerain's Avatar
Quoted: 233 Post(s)
Liked: 97
Question Sell together or split
I will be getting rid of my speakers, should I split these up or sell all together?
Mint 10/10
(2) Monitor Audio RX FX (surrounds) Black
(1) Monitor Audio RX (center) Rosenut
(2) Monitor Audio RX6 (towers) Rosenut
post #12630 of 12913 Old 03-15-2019, 02:12 AM
Mors78's Avatar
Mint 10/10
I would try and sell together and if that doesn't work then split.
Mors78 is offline
Reply Speakers
cp-wt380idc , Denon Avr 3806 Av Receiver , Denon Blu Ray Dvd Cd Player , Jl Audio Brand , Monitor Audio , Nad , Parasound , Receivers Amplifiers , Sunfire , Toshiba , tube amp , tubes
