Klipsch owner thread - Page 1483 - AVS Forum | Home Theater Discussions And Reviews
 23397Likes
post #44461 of 58063 Old 04-30-2015, 08:31 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5935
So I finally tinkered with airplay last night on the marantz, and went thru the sound modes. I was utterly shocked, so much that when it was in "Pure" mode just running 2 channel, I had to go double check that my subs weren't running. At about -10db's on the volume, the bass was tight and kicking my chair, and the horns were clean.
I used to run the two fronts and two subs with music, but after hearing all modes, Ill be using 2 channel with these 7ii's.
Whats crazy, I put on a good song with clean bass, and the 10's weren't moving a lot, but they were thumping my chair. Ports in the back were moving a good bit of air though.
XBR65A9G / XBR65A8F
Oppo UDP-203 / Sony X800M2
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #44462 of 58063 Old 04-30-2015, 10:21 AM
mtfalen's Avatar
Liked: 0
Noob needs help!
Working on filling out my Klipsch setup for a new media room and picked up the RC-64II for the center. I have a control4 setup with all components in a central rack so will not have any furniture under the screen.
What are you 64 owners using as a speaker stand? Is there anything good out there that will hold this weight or am I looking at a DIY project. I'm not opposed, just want a sleek and modern look, and I am no carpenter!
Thanks in advance!
Mike
mtfalen is offline
post #44463 of 58063 Old 04-30-2015, 10:26 AM
evan1242's Avatar
Quoted: 215 Post(s)
Liked: 204
This is how I feel about my 5.5's.
That's why I'm kind of skeptical to upgrade to anything other than the rf-7 ii's.
Louis Bartay likes this.
LG 60LF6300 60"
Pioneer Elite VSX-70
Klipsch RF-82II / RC-62II / RS-35 / KG 3.5
Sub Full Marty Ultimax 18 Build
Sony PS4
Panamax MR4300
evan1242 is offline
post #44464 of 58063 Old 04-30-2015, 02:02 PM
bxbigpipi's Avatar
Quoted: 72 Post(s)
Liked: 46
Will the rs42ii match well with the rf62ii?
bxbigpipi is offline
post #44465 of 58063 Old 04-30-2015, 02:07 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5935
Well, got the XLR cables in and ran XT32 again. Center was still -12, fronts now became -11 and -11.5 (XLR connection made things 2db hotter).
So after everything was said and done, I level matched.
LF was -11 (made it -9)
C was -12 (77db at that setting)
RF was -11.5 (made it -9.5)
All were then 75db as they should be, with -2.0db volume setting. So, i boosted my subs from -6 to -4, and I noted my new "reference" volume as -2.0 and not 0.0.
Also got this up
Tom Riddle, retro124 and evan1242 like this.
XBR65A9G / XBR65A8F
post #44466 of 58063 Old 04-30-2015, 02:11 PM
evan1242's Avatar
Quoted: 215 Post(s)
Liked: 204
Klipsch puts the 52 ii in there rf-62 ii package, but im sure they would be fine considering they have the same size tweeter just 4" drivers in the 42 ii and 5.25" in the 52 ii.
LG 60LF6300 60"
Sony PS4
Panamax MR4300
evan1242 is offline
post #44467 of 58063 Old 04-30-2015, 04:11 PM
Quoted: 92 Post(s)
Liked: 38
So.....I finally have everything hooked up, ran Audyssey and love the sound! I'm curious though, what sound setting do you guys use when watching blu-ray's....dolby pro logic II, dts neo 6 or pure direct?
LG: C8 65in OLED | Denon: X2100W | Klipsch: R-28F L&R, RC-62II center | JL Audio: E-112 sub
OPPO: UDP-203 | Sony: PS4 Pro | Roku: Ultra | Apple: TV 4K | Logitech: Harmony One | APC: H15BLK Power Conditioner
TheDrkLord is offline
post #44468 of 58063 Old 04-30-2015, 04:30 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5935
I hve a 3.2 system and just use the red "Movie button". It's basically just getting the DTS Master and TrueHD lossless tracks from the Oppo and decoding them.
XBR65A9G / XBR65A8F
post #44469 of 58063 Old 04-30-2015, 04:38 PM
Quoted: 92 Post(s)
Liked: 38
@gadgtfreek
That's what I have done. When I press the red "movie button" it gives me options to use stereo, dolby pro logic II, dts neo 6 and a few others (can't pull it up right now....at work). The yellow "pure button" is the one I'm curious about. It seems to do the same as pro logic II, but without the options to adjust things. I was curious if anyone used this setting or to just get a take on what was best or what others use?
post #44470 of 58063 Old 04-30-2015, 05:13 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5935
IIRC PLII, basically will mix stereo into all your channels instead of outputting 2 channel, and when it gets DD, DD+, TrueHD and Master, that is what gets sent.
I think all pure does is bypass Audyssey.
XBR65A9G / XBR65A8F
post #44471 of 58063 Old 04-30-2015, 05:15 PM
Quoted: 92 Post(s)
Liked: 38
I found an answer for Pure Direct.
Pure Direct playback:
This mode is for playback with higher sound quality than in Direct playback mode.
This mode turns off the main unit display and analog video circuit. Doing so suppresses noise sources that affect sound quality.
Video signals are only output when HDMI signals are played in the Pure Direct mode.
When the Pure Direct mode has been selected, the display turns off after about 5 seconds.
In Direct and Pure Direct sound modes, the following items cannot be adjusted.
Tone
Restorer
MultEQ XT, XT32
Dynamic EQ
Dynamic Volume
Graphic EQ
post #44472 of 58063 Old 04-30-2015, 05:22 PM
mpirnat's Avatar
Quoted: 175 Post(s)
Liked: 141
I ran the RS42ii with RB81ii fronts and RC42ii (and later RC62ii) center. They blend perfectly well. I only upgraded to RS62ii surrounds to quell my "what ifs".
mpirnat is offline
post #44473 of 58063 Old 04-30-2015, 05:51 PM
Tasdom's Avatar
Quoted: 158 Post(s)
Liked: 585
Thanks in advance!
Mike
Welcome to the forums and the Klipsch family!
You might want to check out these guys. I've heard some good results from them and they will make custom sizes for a fair price.
http://www.gwizpro.com/stands/
Onkyo Pre/Pro PR-SC5508 & Emotiva XPA-5's x 2
Klipsch RF-7II's Mains RC64II Center RB75's Heights RS-7's Sides RS-52II's Rears
Klipsch RW-12D Subs x 2
Klipsch Belle's
OPPO BDP-105 with Roku Streaming Stick
Epson 6030UB / Vapex 120" Electric Tensioned Screen
Tasdom is offline
post #44474 of 58063 Old 04-30-2015, 06:00 PM
gigging's Avatar
Quoted: 16 Post(s)
Liked: 95
Hi guys,
I mounted 4 rb-61 ii on my ceiling for Atmos. I am now wondering if having the speakers facing downward will damage them. They are book shelf speakers so they were not designed to be hung from the ceiling.. Anyone have some insight to this?
gigging is offline
post #44475 of 58063 Old 04-30-2015, 06:02 PM
evan1242's Avatar
Quoted: 215 Post(s)
Liked: 204
Originally Posted by gigging View Post
Hi guys,
Shouldn't bother them at all.
LG 60LF6300 60"
Sony PS4
Panamax MR4300
evan1242 is offline
post #44476 of 58063 Old 04-30-2015, 07:17 PM
Robbiey60's Avatar
Quoted: 452 Post(s)
Liked: 559
Are you running 7ch? Pure turns all processing off like tone, eq and audessey. Dts hdma and true hd give 5.1(or 6.1 or 7.1 depending on the disc)with processing, and the other options generally are for matrixing the surround back/extra channels from a 5.1 mix. I change mine constantly but if I had to choose its probably dolby ex.
Robbiey60 is online now
post #44477 of 58063 Old 04-30-2015, 07:37 PM
Quoted: 92 Post(s)
Liked: 38
@Robbiey60
My R-28F's are bi-amped, I'm running a 3.1 set up. I have all my components listed at the bottom. I was playing with the different settings before I came to work, I was curious what everyone on here used or if they preferred one thing over the other. The "pure direct" thing threw me off but I understand it now, thanks for the input.
post #44478 of 58063 Old 05-01-2015, 06:09 AM
mtfalen's Avatar
Liked: 0
[quote=Tasdom;33903474]Welcome to the forums and the Klipsch family!
Thank you! I will start there!
mtfalen is offline
post #44479 of 58063 Old 05-01-2015, 11:16 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5935
I am finding, even though both were calibrated with XT32 to 75db's with the test tones, I cannot be as liberal with the volume and 7ii's as I was with the 82ii's.
They sound great with blu-ray movies too.
XBR65A9G / XBR65A8F
post #44480 of 58063 Old 05-01-2015, 03:25 PM
cchunter's Avatar
Quoted: 582 Post(s)
Liked: 865
The RB61II's arrived a few weeks ago. I got everything set up now for my daughters. Sony 48 inch Tv with Sony bluray player and Denon 3312. It's all set up in the basement. I was listening to some music the other day and was floored how well these small bookshelves sound. Feeding them 125 w/ch and really had the drivers moving. Very impressed.
Sony 75X900E 4K
Marantz SR7011 Parasound Halo A52+
Klipsch RF7II's, RC-64II, RS-62II's, RP500SAs Atmos
SVS Dual SB13 Ultra's
Oppo UDP-203 4K Sony PS4 Pro Panamax 5300PM
cchunter is online now
post #44481 of 58063 Old 05-01-2015, 03:29 PM
ceptorman's Avatar
Quoted: 449 Post(s)
Liked: 709
I told you that you would like them more than you would realize…pretty nice speakers
gadgtfreek likes this.
650cc on the track
1000 cc on the street
800cc on the snow
ceptorman is offline
post #44482 of 58063 Old 05-01-2015, 03:48 PM
evan1242's Avatar
Quoted: 215 Post(s)
Liked: 204
What's a pair of mint KLF-20's worth? Found some local but he wants 1k for them.
LG 60LF6300 60"
Sony PS4
Panamax MR4300
evan1242 is offline
post #44483 of 58063 Old 05-01-2015, 04:00 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
There's a pair FS on the Klipsch forum for $400...
malmstump and Louis Bartay like this.
SanchoPanza is offline
post #44484 of 58063 Old 05-01-2015, 04:03 PM
evan1242's Avatar
Quoted: 215 Post(s)
Liked: 204
Wow ok. I'm going to see what he will take. Hard to find locally. Shipping would be a ton for those big boys!
LG 60LF6300 60"
Sony PS4
Panamax MR4300
evan1242 is offline
post #44485 of 58063 Old 05-01-2015, 04:20 PM
Quoted: 197 Post(s)
Liked: 511
^^^ surely not $600, by freight...ymmv...
post #44486 of 58063 Old 05-01-2015, 04:21 PM
evan1242's Avatar
Quoted: 215 Post(s)
Liked: 204
Oh no there local. Less than 20 minutes away. I was just saying I'd rather get them locally then pay extra for shipping. He wants 1000 with local pick up. Lol.
LG 60LF6300 60"
Sony PS4
Panamax MR4300
evan1242 is offline
post #44487 of 58063 Old 05-01-2015, 05:54 PM
Tom Riddle's Avatar
Quoted: 682 Post(s)
Liked: 548
Also got this up
Love the sign. I know it's been mentioned before, but I can't find it - where did you buy that beauty?
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7704 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #44488 of 58063 Old 05-01-2015, 05:56 PM
Mongo171's Avatar
Quoted: 995 Post(s)
Liked: 1428
https://klipsch.cwshops.com/en/klipsch-collage-poster
Nexgen76 and Louis Bartay like this.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #44489 of 58063 Old 05-01-2015, 06:26 PM
Tom Riddle's Avatar
Quoted: 682 Post(s)
Liked: 548
Originally Posted by Mongo171 View Post
Mongo171 likes this.
post #44490 of 58063 Old 05-01-2015, 06:41 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5935
Yep, thats it!
XBR65A9G / XBR65A8F
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
