Klipsch owner thread - Page 1710 - AVS Forum | Home Theater Discussions And Reviews
 23535Likes
post #51271 of 58407 Old 01-13-2017, 09:26 PM
Quoted: 115 Post(s)
Liked: 7
Torn...between RP-160 or 150's.
In that feeling of 160 is to big, but if you buy the 150, you will always wonder if you should have gone for the larger size.
Wish I could see both of them sitting next to each other to really see size difference.
Will these work if there is no wall behind them? as in open room?
Thx
sac130 is offline
post #51272 of 58407 Old 01-13-2017, 09:35 PM
MrDickerson's Avatar
Quoted: 28 Post(s)
Looking at purchasing 2 RP-260F's and 1 RP-440C for my new front left and rights and my center. Thoughts? Oh, and getting these for around $1,000 total.
MrDickerson is offline
post #51273 of 58407 Old 01-13-2017, 10:06 PM
ereed's Avatar
Quoted: 2304 Post(s)
Liked: 1625
Originally Posted by sac130 View Post
Anyone using the RP-160M for the sides of a 7.1 set-up?
Wondering how far from your ears they are. They look big, and mine would be about 2-3 feet from seats and don't want them to be to overbearing over the rest of the system.
Can go with the RP-150M instead, but like to go big and never look back?
Also, what stands (24") would fit the base of these speakers?
Thx
Originally Posted by Theriddler07sms View Post
I had Sierra 1's as side surrounds in a 10' wide area and they were fine for me. i was usually the only one in there watching movies and whatnot. Depends on the room layout I suppose.
Also, I have my 160s on these now https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I may remove the angled base but for now they work fine.
The top plate on those stands is small, ever worry about the 160's falling off if bumped?
Wish Klipsch had stands with exact same size top plate as the actual speaker.
Should the speaker be right at ear height , below or above it?
My seat height is right at 39"
THX
I don't have 7.1 but I do use the rp160s as my side surrounds in 5.2 setup. And they are on the exact same stands Theriddler07sms posted which is 26 inches and brings the tweeter about 2 inches higher than my ears. While the top plate is smaller than the speaker they have rubber which is on top of stand that holds the stand very well and doesn't slide.....its also a heavy stand and pretty stable. I have one of my speakers out in the hallway and I always make sure I don't walk into it or bump into it. But you can use blutack to hold it more securely if needed, I'm not using anything since I don't have kids or pets. I have my rp160s 6 feet away per side at 110 degrees from my MLP and have it firing in front of the room toward the coffee table. Here is pic showing them as my side surrounds. I measured from floor to tweeter with that sanus stand and its 38 inches. Also its worth mentioning that the speaker has small back tilt (Whole RP line has this except the center channel) so it slightly goes to your head or above it depending on how far away you sit.
Sony 45es | 120 inch screen | Panasonic BDT500 | Rotel RMB-1075 | Rotel RMB-1077 | Rotel RSP-1068 | Klipsch RP-280F/RP-450C/RP-160M (x4) | Funk Audio subs (x2) | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x2) | Monster Power Conditioner | GIK acoustic panels
ereed is online now
post #51274 of 58407 Old 01-14-2017, 02:21 AM
Alanlee's Avatar
Quoted: 439 Post(s)
Liked: 276
Thx
I have tried various ear height locations for side surrounds. What works for me is to push the speakers slightly ahead of the listening post (lp) as in the attached pictures. I built the speaker stands with wheels, so I can experiment and/or move the speakers if I move the couch.
Name:	01 sofa-surrounds.jpg
ID:	1894225   Click image for larger version
Name:	08 middle surround right.jpg
7.4.6 system with Denon 8500, Additional Amps: Emotiva (front and center) and NAD (wide), classic Klipsch speakers.
Alanlee is offline
post #51275 of 58407 Old 01-14-2017, 04:21 AM
loudog2's Avatar
Quoted: 266 Post(s)
Liked: 199
Originally Posted by ceptorman View Post
rb75?
Maybe a new bookshelf version will come out with the new RF 7III's coming out.
ceptorman likes this.
Sony 940C*Sony HX909*Samsung K8500*Yamaha 3050*klipsch front RP-280's*rear RF-3's*center RP-450C*Sides RP-280's*front heights RP-140's*overhead 5650cii's*SVS-PB2000x4*emotiva XPA-5*Yamaha YSP-1600 sound bar*Sony HT-CT370 sound bar
loudog2 is offline
post #51276 of 58407 Old 01-14-2017, 05:24 AM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
That would be nice. There is a new 15" RF7lll based sub.
650cc on the track
1000 cc on the street
800cc on the snow
ceptorman is offline
post #51277 of 58407 Old 01-14-2017, 06:01 AM
Quoted: 115 Post(s)
Liked: 7
Do those stands hide the wire, or is it visible on the outside?
sac130 is offline
post #51278 of 58407 Old 01-14-2017, 08:01 AM
sb1
sb1's Avatar
Quoted: 445 Post(s)
Liked: 390
Picked up some 160's yesterday for a small music only system. For gits and shiggles I hooked them up to my main system. Wasn't expecting them to sound as good as they do. Highly impressed.
ereed and dmb12679 like this.
Stephen.
Chances are very good that I was drinking when I posted the above.
sb1 is offline
post #51279 of 58407 Old 01-14-2017, 09:05 AM
mpirnat's Avatar
Quoted: 175 Post(s)
Liked: 141
Thx
Go big and don't look back.
To me, volume is what becomes overwhelming. I have an RS-62II a couple feet from my side of the couch and it's not overwhelming at all. For my space, I run most movies between -30 dB and -20 at the extreme loudest and am quite content. What you'll get with the larger woofer and (I think) larger horn on the 160 is more fullness, depth, and detail. I went from RS-42II to RS-62II and they could both play at the same level, but the RS-62II was just better.
As long as you get all your levels balanced (either automatically with help from your AVR or manually with an SPL meter or approximated with a phone app) it will be no more overwhelming than any other speaker.
mpirnat is offline
post #51280 of 58407 Old 01-14-2017, 09:13 AM
ereed's Avatar
Liked: 1625
Yes the wire is visible from the outside. Its not hidden wire management system. I used black loom (speaker wire is white) for the run from the speaker to the floor so you don't see it. They come with small hole holding system at the top and bottom base to keep wire from moving, but its not hidden. I will take a pic of it later to show how I made mine look less noticeable, but its behind the column so can't really see it unless looking for it.
sac130 likes this.
ereed is online now
post #51281 of 58407 Old 01-14-2017, 09:41 AM
Quoted: 115 Post(s)
Liked: 7
Quick question on my rears. Looking at the pic I have them set in dipole mode with the back wall behind them.
If I drop them down about 18" just below the wall so they hang freely, would this be better for the sound or make it worse since they no longer have a back wall to bounce off?
sac130 is offline
post #51282 of 58407 Old 01-14-2017, 10:06 AM
dmb12679's Avatar
Quoted: 596 Post(s)
Liked: 298
I would leave them where they are if I were you. It would look very odd with them hanging, for a minimal gain
Marantz SR6010 -- Marantz MM7025 -- Marantz UD5007
Klipsch RF-7ii's - RC-64ii - RB-51ii's - RS-42ii's - R-112sw(x2)
HK990 -- HD990 -- Klipsch RF-7ii's
dmb12679 is offline
post #51283 of 58407 Old 01-14-2017, 10:11 AM
ereed's Avatar
Liked: 1625
Question is....do they sound good to you currently? Is this 5.1 or 7.1 setup you have? Are you planning on going to atmos?
ereed is online now
post #51284 of 58407 Old 01-14-2017, 10:13 AM
Quoted: 115 Post(s)
Liked: 7
Currently only 5.1, and I hear them when watching movies, but wasn't sure if they would perform better at a lower height to the sitting area (currently at 8').
Can't do Atmos, have large vaulted ceiling.
sac130 is offline
post #51285 of 58407 Old 01-14-2017, 10:26 AM
dmb12679's Avatar
Quoted: 596 Post(s)
Liked: 298
So speaker on the right in the picture would just be dangling in the air, the one on the left would be dropped down the support beam? Ideally you would want them lower, but I think the minimal gain of 18" closer is not worth the eye sore imo
sac130 likes this.
dmb12679 is offline
post #51286 of 58407 Old 01-14-2017, 12:42 PM
heron25's Avatar
Ok, just pulled the trigger on my first Klipsch speakers. Going with a 5.2.2 setup for HT use primarily. Went with Pro-6504-l-thx for LCR, 6502 for rear surrounds and CDT-5650-c-II for in-ceiling ATMOS. Compared them to MartonLogan Edge in-walls. Edge's were warmer sounding for music, but for HT use, the Klipsch won! Can't wait to install these in my new home theater.
ereed, ceptorman and retro124 like this.
heron25 is offline
post #51287 of 58407 Old 01-14-2017, 02:09 PM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
Very nice....I'm sure you'll like those....congrats.
650cc on the track
800cc on the snow
post #51288 of 58407 Old 01-14-2017, 06:16 PM
Alanlee's Avatar
Quoted: 439 Post(s)
Liked: 276
If those are your rear surrounds, drop them down as close to ear level as possible. Few of us have the perfect environment, so do the best you can.
At some point you may want ceiling speakers, and then your rear surrounds where they are will be a problem. Better to start solving that problem now.
Alanlee is offline
post #51289 of 58407 Old 01-15-2017, 07:30 AM
Quoted: 496 Post(s)
Liked: 187
Looking for advice here. Better to do 7.1.2 in a small 1500cu ft room or 5.1.4?
Theriddler07sms is offline
post #51290 of 58407 Old 01-15-2017, 07:33 AM
ereed's Avatar
Liked: 1625
Here is a pic as promised. Noticed I have white speaker wire that is ran along the baseboard? So I used black wire loom at speaker stand side so it looks flush.
ereed is online now
post #51291 of 58407 Old 01-15-2017, 07:40 AM
ereed's Avatar
Liked: 1625
The only difference depending if you have room for the 2 rear speakers behind you. Keep in mind the 5.1 and 7.1 layout is the exact same but with 2 extra speakers behind you. You need few feet at least which should be the same as side surrounds. I have 5.2 setup cause my mlp is up against the wall. I don't have enough room behind me to do 7.2. Also pics showing the layout will help as well.
ereed is online now
post #51292 of 58407 Old 01-15-2017, 07:44 AM
airborn007's Avatar
Quoted: 238 Post(s)
Liked: 86
Never owned Klipsch but I'm interested in the fr & center Premiere Series. Is it best to stick w/ their subwoofers or I can get something else I like and still blends well. Mainly it would be for watching movies 3/4 of the time.
LG C9 & UB9000
LG C8 & UB820
Denon AVR, SVS Prime Elevation & Ultra Series, HSU Subwoofer, Emotiva
airborn007 is offline
post #51293 of 58407 Old 01-15-2017, 07:48 AM
Quoted: 496 Post(s)
Liked: 187
My room is so dark its almost impossible to take good pictures. The room is 15x10ft and the couch sits probably 2' from rear wall and ears are about 3' from rear wall (my sub and electronics are behind the couch).
post #51294 of 58407 Old 01-15-2017, 07:54 AM
dmb12679's Avatar
Quoted: 596 Post(s)
Liked: 298
Subs do not need to match. I matched mine as I liked the copper cones matching with my regular speakers. Although I recently saw a deal for $399 for the r-115sw at fry's electronics, which I would find price for pop almost unbeatable. There are better subs out there than Klipsch at their regular retail price point imo.
dmb12679 is offline
post #51295 of 58407 Old 01-15-2017, 08:10 AM
airborn007's Avatar
Quoted: 238 Post(s)
Liked: 86
Thanks. I agree with the latter statement.
LG C9 & UB9000
LG C8 & UB820
post #51296 of 58407 Old 01-15-2017, 08:13 AM
Quoted: 496 Post(s)
Liked: 187
Take a look at PSA, HSU, SVS, and Rythmik sub offererings. Theres currently a Rythmik F12 (Sealed) in the classifieds for $750, just about $200 off retail
post #51297 of 58407 Old 01-15-2017, 08:15 AM
ereed's Avatar
Liked: 1625
Stick with 5.1 layout. You need more room behind you for 7.1. Remember the speaker is 12 inches so if you have it behind you it will be 2 feet to your ears. LOL I'd just do 5.1.4 or 5.1.2. If you really want 7.1 and can move your couch 3 more feet out then go for it.
ereed is online now
post #51298 of 58407 Old 01-15-2017, 08:17 AM
airborn007's Avatar
Quoted: 238 Post(s)
Liked: 86
I will but leaning towards HSU for price and value otherwise might just use might current sub and go from there
LG C9 & UB9000
LG C8 & UB820
post #51299 of 58407 Old 01-15-2017, 08:36 AM
Quoted: 496 Post(s)
Liked: 187
Yeah i dont think I can move my couch even more forward. than i'd have to get a smaller screen haha. 5.1.4 sounds good to me.. thank you
ereed likes this.
post #51300 of 58407 Old 01-15-2017, 03:20 PM
troyh4's Avatar
Quoted: 73 Post(s)
Anyone have the RP-440c CENTER CHANNEL ? If you own this one, where did you buy your stand for this speaker ? or , did you make one diy?
thanks,
troyh4 is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
