Klipsch owner thread - Page 1849 - AVS Forum | Home Theater Discussions And Reviews
 23561Likes
post #55441 of 58486 Old 04-11-2018, 02:25 PM
pdasterly's Avatar
Quoted: 268 Post(s)
Liked: 93
Originally Posted by Louis Bartay View Post
It will hold the weight but you MUST LAG bolt into wall studs. I was going to use one too but.......
My wall studs did NOT line up where I wanted them mounted and not having a flat surface would NOT allow me to raise the rear of the speaker up.
I could have cut a 3/4" plywood and made a shelf to lay on the "L" brackets you are looking at. I did not want to wait on shipping so I spent less ten 10 bucks to DIY one. I had the 3/4" MDF so I needed rattle can paint and 4 lag bolts and large body washers and some sand paper and a hour of my time.
But if you are mounting under the TV go for it and don't worry if the two "L" braces are not evenly spaced under the RC-64.Most people won't notice they are watching the movie. :-)
I added a extra 3/4"X 6" wide back board to my shelf and drilled 3/4" holes every few inches so I could find two studs to mount in the center with after I measured with stud finder where the studs are in the wall. I can't see the shelf or the board against the wall.
stud is no problem
Louis Bartay likes this.
pdasterly is offline
post #55442 of 58486 Old 04-11-2018, 03:05 PM
gene4ht's Avatar
Quoted: 1988 Post(s)
Liked: 2691
Originally Posted by pdasterly View Post
got my rc-64iii today, this speaker is massive, anyone have an idea on how to wall mount it?
As @Louis Bartay indicated...a couple of brackets secured into studs and a shelf did the trick for me. Both brackets and black shelf (12"x36") are from Menards for about $18. I wanted a shelf vs just brackets alone to properly elevate the speaker using the screw foot. I lighted the area for the photo. Under normal lighting, the brackets and shelf blend into the black background and all but disappear.
Name:	RC-64II Mount.JPG
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is online now
post #55443 of 58486 Old 04-11-2018, 05:33 PM
coytee's Avatar
Quoted: 261 Post(s)
Liked: 433
Not knowing how handy you are....but if you need a stud somewhere, you can "always" (hahahahaha) open the wall up, insert one, close wall (replace drywall, tape/mud then paint) and have it where you want it.
Don't pooh pooh the idea too much as I know someone (cough....my wife....cough....) who's done just that on more than one occasion!
She happens to be very good fixing the drywall (after I reinstall it) so I understand it's an effort. But it can allow you to put exactly what you want, where you want it.
oops....gotta go.... I think I hear the wife removing the bathroom wall......
coytee is offline
post #55444 of 58486 Old 04-11-2018, 05:56 PM
gene4ht's Avatar
Liked: 2691
Excellent tip/suggestion!
I recall you posting in the past about your wife's excellent drywall skills. It's admirable and fortunate that someone in the household has both the interest and the desire to develop the skills. Over the years, after raising three kids and various remodeling projects, I too can repair drywall without too much effort. In reality, it's not too difficult to tape/mud/paint...just takes a little practice and it will become an art. Please pass on my commendations to your wife!
post #55445 of 58486 Old 04-11-2018, 06:33 PM
ereed's Avatar
Quoted: 2331 Post(s)
Liked: 1641
Attachment 2388778
I'm surprised as heavy that center is that one screw holds it well.
Theater room: Sony 45es | 120 inch screen | Panasonic BDT500 | Rotel RMB-1077 | Outlaw Audio 976 | Klipsch RP-280F/RP-450C/RP-160M (x4) | Funk Audio subs (x2) | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x2) | Monster Power Conditioner | GIK acoustic panels
TV Room: Panny 60 inch | Rotel RMB-1075 | Rotel RSP-1068 | Axiom Audio M60/VP150/QS8
ereed is online now
post #55446 of 58486 Old 04-11-2018, 06:41 PM
Louis Bartay's Avatar
Quoted: 403 Post(s)
Liked: 850
I read on the old Klipsch Forum a French Cleat is a option to think about for hanging a shelf for a 40 pound speaker. A lot of heavy kitchen cabinets are mounted with a French cleat.
Dry wall repair is doable but matching the finish and color of paint can be a challenge most of us avoid.I wish my wife had that talent/skill to finish after I tape and bed the seams my garage would be father along for my music room. I can't match the wall finish it look perfect without doing a whole section.
gene4ht likes this.
Klipsch Cornwall I,C7,RS3-II, R-14M
Klipsch Heresy II, NAD C272/C162,PL-518X ATOC9ML/III
Klipsch KLF-20,ReVox A77 MK IV D, Nakamichi BX-300
Klipsch Synergy Sub 12" X 3, SVS PB 13 Ultra Sub
Yamaha RX-V1900 HD 7.1, CDC 697, PS4
Louis Bartay is offline
post #55447 of 58486 Old 04-11-2018, 06:46 PM
Quoted: 403 Post(s)
Liked: 850
I used four, two 4" apart on each stud thru the back board or in your case I would use two screws on each L bracket. I did not look to see how many were on that link.
ceptorman likes this.
post #55448 of 58486 Old 04-11-2018, 06:53 PM
gene4ht's Avatar
Liked: 2691
Agreed...and offset at that...no one more surprised than me. It hasn't move so much as a mm in two years. Klipsch apparently knew the capability of their design.
Edit: I assumed you were referring to the adjustment screw on the speaker. If you were referring to the "L" brackets, there are two screws in each bracket securing it to the stud behind.
ereed, Louis Bartay and ceptorman like this.
post #55449 of 58486 Old 04-11-2018, 06:54 PM
ereed's Avatar
Liked: 1641
I have my RP450 center on sanus speaker stand. It has 2 screws on the ends of the stands for angling....works quite well.
ereed is online now
post #55450 of 58486 Old 04-12-2018, 01:16 AM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
Lots of great advice from everyone. Those brackets would work fine, and are adjustable so you can hit the studs. I think I would install a wood shelf on the brackets. It will lock everything together, give you more adjustability, and still look good. Is your center going below your TV, and aiming pretty straight forward? I assume the 64lll has adjustable spikes? That's an awesome speaker. Curious....what are your mains?
650cc on the track
1000 cc on the street
800cc on the snow
ceptorman is offline
post #55451 of 58486 Old 04-12-2018, 01:18 AM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
I think sanding down the drywall mud is the key to getting a good match.
650cc on the track
800cc on the snow
post #55452 of 58486 Old 04-12-2018, 09:23 AM
pdasterly's Avatar
Quoted: 268 Post(s)
Liked: 93
will get some shelf brackets and some plywood, going to place under tv so i will have to angle speaker upward. rf-7iii coming next
post #55453 of 58486 Old 04-12-2018, 09:33 AM
gene4ht's Avatar
Liked: 2691
The speaker should have a built-in screw type foot/feet for adjusting the angle. Rather than plywood, I would suggest pre-finished shelving...comes in all sizes and colors and is relatively inexpensive. I believe my 5/8"x 12"x36" shelf was under $10 from Menards...but these can be found at Home Depot, Lowes, etc. And congrats on your RF-7III's. Be sure to post pictures of your finished project!
Louis Bartay and pdasterly like this.
post #55454 of 58486 Old 04-12-2018, 09:34 AM
PonzLL's Avatar
Quoted: 38 Post(s)
Liked: 75
I officially joined the club today!
I sent back my Fluance Signature fronts and bought set of RP-150m's and an RP-250C. Considered going with the 450C but I think it's too much in my room.
Pretty excited though, they arrive Saturday!
Sony 75" X900E | Yamaha RX-V383 | Samsung UBD-M8500
Klipsch RP-150M - RP-250C F/C/R | Fluance SX6 Rear | SVS PC-2000
PonzLL is offline
post #55455 of 58486 Old 04-12-2018, 09:46 AM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
You will love those RF7llls....congrats to a world class front stage.
650cc on the track
800cc on the snow
post #55456 of 58486 Old 04-12-2018, 09:47 AM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
Congrats....now you have to playing the waiting game....anticipation!
Louis Bartay and PonzLL like this.
650cc on the track
800cc on the snow
post #55457 of 58486 Old 04-12-2018, 09:48 AM
pdasterly's Avatar
Quoted: 268 Post(s)
Liked: 93
what are your thoughts on thx surrounds?
post #55458 of 58486 Old 04-12-2018, 10:32 AM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
I think THX surrounds would blend ok with most speakers. Are the THX and your front three the same brand of speakers?
650cc on the track
800cc on the snow
post #55459 of 58486 Old 04-12-2018, 10:46 AM
pdasterly's Avatar
Quoted: 268 Post(s)
Liked: 93
i have rc-64iii and rf-7iii up front, klipsch thx or rp for rears?
post #55460 of 58486 Old 04-12-2018, 11:47 AM
Quoted: 59 Post(s)
I flipped my L brackets so the speakers itself is hiding them, as opposed to the bracket brace being below. I’ll upload a pic later. But it looks like a floating shelf at that point.
Your 64 is wide enough to pick up a couple of studs. I hit two for my 62 and it’s plenty sturdy.
gene4ht likes this.
Sony XBR65X900E
Xbox X
Denon X4300H
5.1.4- Klipsch RC-62 ii, R-26F, R-15M, R-10SW, Monoprice 8" Black Back Ceiling Speakers
mons0160 is offline
post #55461 of 58486 Old 04-12-2018, 12:03 PM
gene4ht's Avatar
Liked: 2691
I personally don't have any first hand experience with the THX series. I can only comment that I can't recall much discussion of the THX's in this thread...perhaps a visit in the Klipsch forum would yield more input. I would also say that the RP series surrounds would be more than capable and would match up perfectly to your RF-7III 's and the RC-64III. To better understand what real world gains the THX series offers, I would definitely post the same question in the Klipsch forum.
post #55462 of 58486 Old 04-12-2018, 12:37 PM
drh3b's Avatar
Quoted: 2073 Post(s)
Liked: 4189
Somehow, I read that as II, but yeah, the RP series would be more closely voice matched to the III series than the THX surrounds, and probably cost less, too.
gene4ht and pdasterly like this.
My World Beating System!
Spoiler!
drh3b is offline
post #55463 of 58486 Old 04-12-2018, 02:30 PM
Carbo's Avatar
Quoted: 306 Post(s)
Liked: 188
Originally Posted by Jerry SHen View Post
Just finished my media room with Klipsch Reference Premier set. Very happy with the results!
Running 7.2.4 dual-sub setup through a Marantz 6012.
2x RP-280F
RP-450C
2x RP-250S
2x RP-160M
4x CDT-5800-II
2x R-115SW
Put in buttkickers on the seats for good measure ;-)
Jerry,
Nice Theater. I like the grey color. What color is that and from who?
1) JVC RS540, Yamaha CX-A5100, Outlaw Audio 7700 & 7140, Wharfedale Jade 7's series speakers, RSL C34e(Atmos)
2) LG OLED65B6, Integra DRC-R1, Emotiva XPA9, Klipsch RP8000F, Klipsch RP404C, Klipsch RP500SA, Klipsch RP140D
Carbo is offline
post #55464 of 58486 Old 04-12-2018, 02:44 PM
vipervick's Avatar
Quoted: 144 Post(s)
Liked: 51
Who do I have to kill to get a room like that?
JohnnytheSkin and PonzLL like this.
The accumulated filth of all their sex and murder will foam up about their waists and all the whores and politicians will look up and shout "Save us!"... and I'll whisper "no."
Samsung 65KS800D - Denon AVR X4200W - Oppo UDP-203 - PS4 Pro - Apple TV 4K - Aperion Intimus 6T - Aperion Intimus 6C - Aperion Intimus 4BP - SVS PC-13 Ultra
vipervick is offline
post #55465 of 58486 Old 04-12-2018, 03:06 PM
jbnpaul's Avatar
Quoted: 116 Post(s)
Liked: 38
I don't think the room that you get comes with klipsch speakers
Sevastos and drh3b like this.
jbnpaul is offline
post #55466 of 58486 Old 04-12-2018, 04:08 PM
Quoted: 403 Post(s)
Liked: 850
Wireless kits
HELP
My neighbor that has 4 Klipsch KLF20/C7 HT and wants to move the system. The rears will need a wireless conversion kit. There are so many different ones, anyone have info??. They have a 2016 Yamaha Advantage 130X7 AVR, as I see some kits have small amps.
Louis
post #55467 of 58486 Old 04-12-2018, 08:22 PM
dbjunction's Avatar
Quoted: 27 Post(s)
Liked: 4
What size wire is the builder running thru the walls? We used #12 for speaker wire and RG6U coax with RCA ends for the sub.
He is putting 16 gauge - maximum length would be 20ft.
dibs
dbjunction is offline
post #55468 of 58486 Old 04-12-2018, 08:35 PM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
I agree.....Unless you could get a deal on the THX, I'd save money and get the RP series for the rears.
gene4ht and drh3b like this.
650cc on the track
800cc on the snow
post #55469 of 58486 Old 04-12-2018, 08:43 PM
dbjunction's Avatar
Quoted: 27 Post(s)
Liked: 4
And that's the key...a resource on staff. This is normally the exception rather than the rule. It's likely that high end homebuilders would retain specialized resources first and hopefully in time with greater demand, all builders will have such resources. This is no different than automotive options that are first seen/included in high end cars and then eventually seen in mid range cars as these options become more commonplace. The demand for immersive surround sound systems from the general public just isn't commonplace...yet.
Originally Posted by Ladeback View Post
Like I said above, our builder had an A/V guy that new about home theater and other A/V things to put in the home they were building. Our A/V guy also wired and set up our alarm system and ran speaker wires to our outside wall to our patio for speakers a future time. When I tried to talk to our Builders representative about type of coax a d Cat wife, he had now clue and to talk to their A/V guy. He also ran coax for future subs for my living room. I haven't used them yet. I guess builders care about LV and A/V and others don't.
The builder might regret that when it's time to get a good reference from the homeowner. Word of mouth is a pretty powerful type of advertising.
I'm in agreement and commend you and your company for going above and beyond...the Nordstrom of your industry! However, its been my experience that most industries don't venture much beyond what they normally do...it incurs additional costs and disrupts time lines. In this case, ceiling background speakers for music...yes...accurate surround and 3D speaker placement for home theaters...no. This level of understanding of audio, acoustics, and codecs requires far more expertise and planning...beyond a builder's ROI. Lastly, unlike the members and visitors of these forums, most builder's customers have no knowledge or desire to incorporate much beyond a "big screen" TV and maybe a soundbar. It's unfortunate but it's the reality.
I can't believe this either. When we built our house almost 11 years ago my build sub for AV had no problem pulling wire where ever I wanted it run. I have towers and ceiling speakers for surrounds and center wired in my living room that run to my basement where I have equipment. I also had him run speaker wire in the walls where the TV is in case I ever went with in-wall speakers. I agree, you are the customer and should get what you want. You are paying the bill.
Originally Posted by Losifanatic View Post
Wow I can't believe that a builder won't work with you on getting you the setup you want. I am the senior electrician for an electrical and technology company and its always about giving the customer what they want. Just surprises me that contractors aren't willing to work or listen to their customers.
After a lot of persuasion, the builder agreed to make it custom. Their rationale is that if someone makes it custom and then backs-off of buying the house, they will be left with something nobody wants.
In any case, they will still charge be for 7 holes in the ceiling even if I don't use them. I am planning to use atleast 4 - 2 slightly forward of seating position for Atmos and two behind of the wall for surrounds.
The fronts and center speaker will be on a wooden frame next to the tv (custom frame).
Should I ask him for the ceiling wire anyways for the other 3 spots that I am going to anyways pay for? I was going for a 5.1.2 configuration but I can theoretically plan for 7.1.2 OR 5.1.4 configuration in the future. Which one would you recommend? And where should i put the remaining two slots (the seventh one will be wasted for sure) - for 7.1.2 OR 5.1.4?
Dibs
post #55470 of 58486 Old 04-12-2018, 08:55 PM
brian6751's Avatar
Quoted: 1707 Post(s)
Liked: 1704
Dibs
Wait, the builder wants to charge you for the ceiling wiring AND the wall wiring? Thats BS. Its not Custom. I bet they dont consider adding extra cable jacks in the walls custom do they? How about wiring for ceiling fans in every room that you wont use, is that custom?
They could patch up the holes very easily. Its not like you are asking for yellow kitchen cabinets and orange shag carpet.....
You are paying A LOT of money for your house. They need to build it the way YOU want, not the way THEY want. Are they going to pay part of your mortgage?!!
I hate builders..........
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
