Klipsch owner thread - Page 1852 - AVS Forum | Home Theater Discussions And Reviews
 23535Likes
post #55531 of 58407 Old 04-22-2018, 01:22 PM
drh3b's Avatar
Quoted: 2032 Post(s)
Liked: 4033
Originally Posted by Chris B809 View Post
Would a move to RB 61ii be a good match to the RC 62ii over my current F3's?
The RB 61 II would be an exact match, same drivers. My experience between the two lines(Reference and RP) is that Reference is a little harsh, and RP is not. However, my experience is that the Audyssey Reference setting tamed the harshness of the Klipsch Reference line.
My World Beating System!
Spoiler!
drh3b is offline
post #55532 of 58407 Old 04-22-2018, 04:25 PM
Quoted: 61 Post(s)
Liked: 6
Originally Posted by retro124 View Post
Well done 👏, I Agree 100%.
Thanks for the well thought out advice. I have narrowed my choices down to either the RP-280F or RP-260F. Based on my research I understand the 280F are more powerful than the 260F, but is the difference worth the money? I will go with the center and rear to match them, but will probably get a SVS subwoofer. Thanks in advance for any suggestions.
Navyship is offline
post #55533 of 58407 Old 04-22-2018, 05:56 PM
drh3b's Avatar
Liked: 4033
Depends. If you plan to listen at ear splitting levels, the RP-280f are a must. If you plan on listening at human levels, the 260f will do just as well, at least with a subwoofer. Even with a subwoofer, the RP280f can play louder. But, like I said, we are talking excessively, dangerously loud.
Spoiler!
drh3b is offline
post #55534 of 58407 Old 04-22-2018, 07:52 PM
Liked: 5
I agree with the RP. I came from the wharfedale diamond line and supposedly got the klipsch expecting the worst. Surprisingly, I didnt find any harshness at all with the RP 160M/250C. Well, I kinda expected (and wanted) some. lol
Im also using Denon x1300 and it seems that when cinema EQ is off, I hear some exaggerated high frequencies (is this sibilance? or something like exaggerated hi-hats or SSSSS in words). Turning it ON seems to make the voice warmer.
Yeah, if I can have a movie only speakers, I will definitely have the Reference line. :-)
drh3b and Chris B809 like this.
addieboy is offline
post #55535 of 58407 Old 04-22-2018, 09:28 PM
Liked: 2
Thanks for the advice everyone. I have decided on RP250c/160m. That will help me declutter the living room a bit (WAF) factor and get a little cleaner sound overall. Both units are Open Box-Like New from authorized resellers with full warranty.
Anyone have a suggestion on speaker stands that can be weighted (add shot or sand to)? We have a 1 yr old that would just love to topple them on top of herself.
drh3b likes this.
SAMSUNG UN60KS8000, UBD-7500m. DENON x2300w. KLIPSCH: F3; KC-25; RS-41ii; RB-41ii. JAMO J112w. XBOX One S. NINTENDO Switch.
Chris B809 is offline
post #55536 of 58407 Old 04-23-2018, 06:21 PM
retro124's Avatar
Quoted: 1427 Post(s)
Liked: 1154
Well few question need to be asked. How much different it is in $$$ for you. For some it is huge for others no big deal.Each budget is different. Also get ready when you will buy RP-260F you will sooner or later looking for upgrade or ask question do it or not . RP-280F is better speaker then RP-260F no question but with good subs you will hardly know it unless you like to listen suer loud or like to listen 2 channel music without sub as I do. Then RP-280F will shine over RP-260F. No matter what you choice I will go for sure with center RP-450C over RP440C all day long!!!! For movies it is center of universe. So if you looking for towers what is going to stay for long time at your house I vote for 280F. I will bite $200 and go 8". Those bigger copper woofers also looked better if you are fan of those woofers as I'm.
gene4ht and drh3b like this.
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses, Emotiva XPA-200
Sony XBR65X930E , Oppo 203
Apple 4K TV, Mac mini, Sony UBP-X800, PS3
retro124 is offline
post #55537 of 58407 Old 04-23-2018, 06:57 PM
bigbadbob's Avatar
Quoted: 64 Post(s)
Liked: 34
So I have my false wall at 3' from my basement wall covered with Sonic XP insulation. I have an opportunity to put Chorus IIs, Forte IIs and/or Quartets behind my AT screen. Question is: will the Sonic XP absorb too much from the passive radiators or do I need to build a false wall behind the passive radiators?
Klipsch Rocks!
bigbadbob is offline
post #55538 of 58407 Old 04-23-2018, 09:46 PM
apexgrin's Avatar
Quoted: 77 Post(s)
Liked: 43
If you're using them for cinema most of the time then it's probably not worth the money to upgrade. Seems like the 280's shine most with 2ch listening without subs or with a little backup. My 250F's sound great for movies (xover at 80hz anyways) and I use my subs for "2ch" listening. If I had a dedicated 2ch room I'd probably go with the 7III's.
Louis Bartay likes this.
LG OLED65C6P
Oppo 203 - PS4 Pro
Denon X4300H + Outlaw 2200 (Center)
Klipsch RP-250F, RP-450C - Dual PB-1000 Subs - Onkyo Satellites
apexgrin is offline
post #55539 of 58407 Old 04-25-2018, 03:30 AM
dropadred's Avatar
Quoted: 12 Post(s)
Liked: 0
For guys in EU, what plugs did you use to overcome EUinitsgreatestwisdomputtingplasticpintopreventyou usingusualbananaplugs issue? Did you find Z-type (Z-plug, BFA) fitting or not all fitting?
dropadred is offline
post #55540 of 58407 Old 04-25-2018, 01:40 PM
Quoted: 106 Post(s)
Liked: 62
They sure do. I just picked up a pair of RP-280FA's and I'm really impressed with how they sound using them 2 ch. I use Sting's album "Ten Summoner's Tales" for testing and I can't believe how good it sounds with these speakers. Crystal clear with really good dynamics. I can't be happier with them so far. They sound very good with HT as well. It's the best of both worlds for me.
Go Eagles! Go Sixers! Go Phillies! Go Flyers!
tingham is offline
post #55541 of 58407 Old 04-25-2018, 09:25 PM
Quoted: 29 Post(s)
Liked: 2
Finally getting around to replacing my LCR, currently running old school Synergy F-20s for LCR, then a 7.2.4 Atmos all the way around. CDT-5800 and R-5800wii for the sides and tears.
I’m torn between RF-7ii and RP-280F. I know the RF-7 is the top of the line option but would the RP-280F match my system better since it’d be 8 inch mids all around?
Use is 100% dedicated theater 14.5' x 24' x 10 room. I appreciate any input!!
gojazz is offline
post #55542 of 58407 Old 04-26-2018, 01:51 AM
Quoted: 50 Post(s)
Liked: 5
I'm interested in this question too! I'm considering the RP-280F but I'm not sure if I have any place to demo them locally. I've heard that there are occasional sales online, and crutchfield seems to have a small discount this week, but do Klipsch RP speakers have bigger sales occasionally?
bakerjin is offline
post #55543 of 58407 Old 04-26-2018, 05:48 AM
Quoted: 124 Post(s)
Liked: 185
If you have the space and the budget get the RF7s towers with the RF center. Larger tweets and woofers. Built in USA. Better sound dynamics all around. You cannot find much better speaker for the price IMO.
If I had a dedicated theater that's what I would have bought.
My theater is in the living room so I had to balance size, WAF and astetics. I ended up with the RP-260f's with RP-450c center. It sounds great since I have a SVS pb 16ultra for my lows. But I really want to upgrade to the RF7s. They are really to big for my living room though. I really like the size of the RP-260f's.
Sent from my SM-N950U using Tapatalk
gene4ht and malmstump like this.
lag1791 is offline
post #55544 of 58407 Old 04-26-2018, 01:53 PM
youthman's Avatar
Quoted: 162 Post(s)
Liked: 562
youthman is offline
post #55545 of 58407 Old 04-26-2018, 03:24 PM
apexgrin's Avatar
Quoted: 77 Post(s)
Liked: 43
Here's one for you guys...
After I bought my LCR I noticed the center popping at loud volume. It sounded kind of like the tweeter was blown, and I came to the forums looking for suggestions. Replaced the tweeter, same issue. Thought maybe the receiver was clipping, so I bought an Outlaw 2200 for the center channel. Same issue. Ignored it for quite a while then a couple weeks ago decided to take a closer look.
I feel dumb for not doing it before but I held my ear close to each speaker while repeating a scene that wasn't screaming loud but still produced the problem. Turns out, it was the left woofer clearly making the popping sound.
Here's the real dumb part, I ordered a replacement before removing the original to inspect (out of warranty). When the replacement got here I pulled the woofer out and found a piece of hot glue dangling from inside the cab, with the solid blob resting on the back of the woofer.
Dropping the blob onto the woofer produced a virtually identical sound, just quieter. I'm guessing certain frequencies would bounce/strike it and make the sound. Everything sounds awesome now.
Hey at least I have a spare tweeter and woofer now, and an Outlaw. Can't imagine this happens often..
LG OLED65C6P
Oppo 203 - PS4 Pro
apexgrin is offline
post #55546 of 58407 Old 04-27-2018, 12:23 AM
Hercules's Avatar
Quoted: 32 Post(s)
Thoughts on a 7.1.4, or 7.2.4 Atmos setup? I am going to use 2 or 4 ceiling speakers (probably the Polks RC80is but i'm open to suggestions here) to round out the Atmos overheads, but what speakers would you recommend (with sub) on a ~$2000-$2500 budget? I like the Klipsch brand generally, have had great results with it in the past but I'm not sure given how many choices of speakers there are. My family room is about 17x22', if that is any help, and the TV will be mounted over my fireplace. I don't want any floorstanding speakers, I want wall mounted ones preferably (wife won't go for the standing ones). Being used 95% for movies and surround sound for them.
Appreciate any thoughts -- please quote me so I know I got a reply Thanks!
Hercules is offline
post #55547 of 58407 Old 04-27-2018, 05:22 AM
Quoted: 124 Post(s)
Liked: 185
I am assuming you mean 7.1.2 or 7.1.4 system. The last number designates overhead speakers and the middle number is subwoofers. And of course this is AVS forum so we all are going to tell you to get the most speakers possible.
Overhead speakers are less critical to be voiced matched with fronts and center so go with what your budget and tastes dictate. Your auto EQ on you AV will level match everything anyway. I am assuming you have a 11channel AV to process 7.1.4? To bad about the floor standing speakers though. Limits you quality wise. Will the wife go with large bookshelf at least?
lag1791 is offline
post #55548 of 58407 Old 04-27-2018, 10:24 AM
Hercules's Avatar
Quoted: 32 Post(s)
Large bookshelf speakers are fine, so long as they can be wall mounted. I'm also open to suggestions on the receiver. I have a Yamaha TSR 7810 right now, not sure if that will fit the bill as it's in a box so I can't really play with it right now
Hercules is offline
post #55549 of 58407 Old 04-27-2018, 10:56 AM
Ladeback's Avatar
Quoted: 1380 Post(s)
Liked: 506
Send a message via MSN to Ladeback
Looks like the Yamaha TSR 7810 will only do up to 7.x.2 from what I have seen online. I would still wire for at least 7.x.4 if you ever upgrade.
Klipsch does make in-wall and on-wall speakers. If you go with in-walls I would build backer boxes for them in the wall. They could be behind a AT screen and you wife would never see them.
http://www.klipsch.com/in-wall-speakers
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is online now
post #55550 of 58407 Old 04-27-2018, 02:11 PM
ereed's Avatar
Quoted: 2304 Post(s)
Liked: 1625
Originally Posted by youthman View Post
I finally had the opportunity to compare my Klipsch RSW-15's with the SVS SB-16 Ultra subs. Both subs sound fantastic but one stood out above the other.
https://youtu.be/tGkwumFdk7s
Good review but you may want to invest in REW to see how the frequency response is to see where or why you're not feeling the pressurization of the svs subs. Not all subwoofers will have same frequency response in the same exact spot. What I mean is, the Klipsch sub may sound good where you normally have it....but if you put svs sub or another sub for that matter in exact same spot, it could have different freq response and would require to move it forward, back, etc., or possibly in different part of the room for it to sound its best. Just my experience with different brand subs that it takes trial and error. Would be so nice to simply swap subs if they all perform best in exact same location but of course the room will have an effect on that.
Not sure if you are familiar with REW....its free and only need to buy a mic. Great $100 investment if you really want to know whats going on other than judging by feel or ear.
Keep the reviews coming....love watching your videos!
Sony 45es | 120 inch screen | Panasonic BDT500 | Rotel RMB-1075 | Rotel RMB-1077 | Rotel RSP-1068 | Klipsch RP-280F/RP-450C/RP-160M (x4) | Funk Audio subs (x2) | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x2) | Monster Power Conditioner | GIK acoustic panels
ereed is offline
post #55551 of 58407 Old 04-27-2018, 05:10 PM
IMWhizzle's Avatar
Quoted: 966 Post(s)
Liked: 327
Guys, is it safe to use a 60hz crossover on the 450C center?
Klipsch Reference Premiere: 4 x RP-280's, 1 x RP 450C and dual R-115W's
Marantz 7011 AVR
LG OLED B6
Apple TV 4K
PlayStation Pro
IMWhizzle is online now
post #55552 of 58407 Old 04-27-2018, 06:13 PM
brian6751's Avatar
Quoted: 1705 Post(s)
Liked: 1701
its -3db point is 58Hz. I would keep the crossover at 80
ceptorman likes this.
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is online now
post #55553 of 58407 Old 04-27-2018, 06:44 PM
itsmyforte's Avatar
Quoted: 325 Post(s)
Liked: 199
Yes it's safe up to it's rated power handling.
Sent from my XT1575 using Tapatalk
itsmyforte is offline
post #55554 of 58407 Old 04-27-2018, 07:07 PM
brian6751's Avatar
Liked: 1701
Safe? sure. Optimal? not really. You dont normally want to cross that close to the tuning frequency.
FOR SALE:
post #55555 of 58407 Old 04-27-2018, 08:15 PM
itsmyforte's Avatar
Quoted: 325 Post(s)
Liked: 199
It won't hurt anything. A typical AVR will be using a second order hi-pass filter. Anything from 40Hz on up as a crossover will be just fine up to the speakers rated power handling.
post #55556 of 58407 Old 04-27-2018, 08:21 PM
brian6751's Avatar
Liked: 1701
Right, I’m speaking purely from a performance standpoint. You usually want to be a good 10Hz or more above a speakers -3db point for a better crossover blend and to avoid any phase issues with port tuning.
FOR SALE:
post #55557 of 58407 Old 04-27-2018, 08:32 PM
itsmyforte's Avatar
Quoted: 325 Post(s)
Liked: 199
Phase issues with what port? One from another speaker?
In a room the location will change the response of a speaker. It will also affect the low end roll off of every speaker in there.
I understand where you are coming from, but it isn't as simple as "good practice".
post #55558 of 58407 Old 04-27-2018, 08:46 PM
brian6751's Avatar
Liked: 1701
the 450C is ported. the phase issue would be with the center channels port tuning. Anyway, the question was "is it safe?" the answer is SURE its SAFE buts its not GOOD PRACTICE
FOR SALE:
post #55559 of 58407 Old 04-27-2018, 08:49 PM
ereed's Avatar
Liked: 1625
Just cause the speaker can go that low doesn't mean you have to use very low xover. I'm using 100hz xover on my RP speakers and they perform better than 80hz or 60hz in my room. The room itself will determine the best crossover settings, not how low the speaker can actually play.
ereed is offline
post #55560 of 58407 Old 04-27-2018, 08:51 PM
itsmyforte's Avatar
Quoted: 325 Post(s)
Liked: 199
word
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
