Klipsch owner thread - Page 1854 - AVS Forum | Home Theater Discussions And Reviews
 23499Likes
post #55591 of 58345 Old 05-03-2018, 11:21 AM
drh3b's Avatar
Quoted: 2010 Post(s)
Liked: 3913
Originally Posted by Navyship View Post
Thanks for all the help and suggestions. I am running Marantez 7011 for the AVR, so I am guessing that will be more than enough to push what I have, am I right?
If those are your only 3 speakers, then definitely yes. If you have a full on 9 or 11 speaker Atmos setup, AND you want to listen loudly, it gets a little more dicey. The Marantz should be able to push 125 watts, or close to it to 3 speakers. Those speakers are pretty efficient, so that's plenty. The more speakers you have, the less power you have to spread around.
gene4ht likes this.
My World Beating System!
Spoiler!
drh3b is offline
post #55592 of 58345 Old 05-03-2018, 11:22 AM
gene4ht's Avatar
Quoted: 1984 Post(s)
Liked: 2679
Rated at 125 watts/channel, the Marantz 7011 is more than adequate since typical demands on AVRs in general are under 20 watts most of the time and probably hardly exceed 50 or 60 watts. And given also that Klipsch speakers are more efficient than many brands, you're in good shape...no need to worry. You would only need more power if you listen at reference (very loud) all the time and in a very large room. Follow the suggestions given by the previous posters regarding initially setting the speakers to "small" and crossover to 80hz. These are the typical starting points and after reviewing mthomas's post...your newly acquired knowledge and your ears will guide you from there. Most of all...enjoy and have fun!
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is offline
post #55593 of 58345 Old 05-03-2018, 11:24 AM
drh3b's Avatar
Liked: 3913
Originally Posted by gene4ht View Post
Rated at 125 watts/channel, the Marantz 7011 is more than adequate since typical demands on AVRs in general are under 20 watts most of the time and probably hardly exceed 50 or 60 watts. And given also that Klipsch speakers are more efficient than many brands, you're in good shape...no need to worry. Follow the suggestions given by the previous posters regarding initially setting the speakers to "small" and crossover to 80hz. These are the typical starting points and after reviewing mthomas's post...your newly acquired knowledge and your ears will guide you from there. Most of all...enjoy and have fun!
Oh, yeah, I forgot about the crossover, that makes the Marantz's job even easier.
gene4ht likes this.
drh3b is offline
post #55594 of 58345 Old 05-03-2018, 02:59 PM
IMWhizzle's Avatar
Quoted: 929 Post(s)
Liked: 308
Originally Posted by ereed View Post
I used to listen to my RP280s full range without subs for music.....but now that has changed since I have moved my subs around and added a 3rd sub for a smooth flat bass response....now I keep subs on for music.
Also switching from 80hz to 100hz xover for movies fixed a lot of my nulls/dips I had in my bass response. Its funny how moving things around and changing few settings makes it sound like you got a huge system upgrade.
Truth. I’ve also settled with a 100hz crossover all around. It fixed a null in my room too. The sound is tremendous. I love these RP280F speakers. I have four of them and two R-115SW subs combined with a Marantz 7011 AVR.
ereed, Louis Bartay and ceptorman like this.
Klipsch Reference Premiere: 4 x RP-280's, 1 x RP 450C and dual R-115W's
Marantz 7011 AVR
LG OLED B6
Apple TV 4K
PlayStation Pro
IMWhizzle is offline
post #55595 of 58345 Old 05-03-2018, 05:42 PM
confinoj's Avatar
Quoted: 1243 Post(s)
Liked: 1060
Interesting. I’ve seen a few people in the sub forums also really liking higher crossovers. My setup is per my sig. I’ve experimented with crossovers between 60 and 90 as well as the sub distance tweak and even a little phase adjustments with the assistance of REW which helped smooth out crossover FR but still have some nulls that are just inherent to the room and my front speakers. My PC-4000 subs are obviously very capable but are both located behind me in rear corners as I get the best tactile response there. I may try bumping crossover to 100 and see how it sounds and what rew tells me. My main worry is that subs may become localizable but certainly worth trying.
Louis Bartay likes this.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | Tivo Roamio OTA | Nvidia Shield | ATV 4K | Oppo UDP-203 | Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is online now
post #55596 of 58345 Old 05-03-2018, 09:37 PM
IMWhizzle's Avatar
Quoted: 929 Post(s)
Liked: 308
You should try one sub in the front and one in the back. One on the left side in the back and one on the right side in the front.
Marantz 7011 AVR
LG OLED B6
Apple TV 4K
PlayStation Pro
post #55597 of 58345 Old 05-04-2018, 03:45 AM
confinoj's Avatar
Liked: 1060
I have had them there. They sound good but I get more impact/tactile response when both in rear corners. They still measure well in rear. Added bonus is aesthetically they look better there and my wife is happier not to see them when watching TV.
ID:	2398824   Click image for larger version
post #55598 of 58345 Old 05-06-2018, 08:52 AM
Ladeback's Avatar
Quoted: 1366 Post(s)
Liked: 497
Send a message via MSN to Ladeback
I have a question about ported tower speakers. I am using a pair of Klipsch R-26F's for my front left and right speakers and they are are currently at the sides of my 104" wide screen with a RC-7 flour a center. I am thinking of going to a AT screen and wonder how close I can have the towers to the wall? I am am trying to keep about 6" from for f of speaker to screen.
What are your thoughts?
Edit: I am using one 12" down firing sub with a ported front of that helps. I hope to get more subs later to help balance the room.
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #55599 of 58345 Old 05-07-2018, 08:19 AM
cchunter's Avatar
Quoted: 583 Post(s)
Liked: 853
I run a 7011 with 7II's, 64II, and 62II's. It's more than capable. I can run it at reference with little to no distortion and its ear bloody loud. An external amp might help a bit at high volumes but I haven't bought one yet because I haven't felt the need. I listen to movies between -5 to -15 and music 0 to -10. My room is 20x13x8.
Sony 75X900E 4K
Marantz SR7011 Parasound Halo A52+
Klipsch RF7II's, RC-64II, RS-62II's, RP500SAs Atmos
SVS Dual SB13 Ultra's
Oppo UDP-203 4K Sony PS4 Pro Panamax 5300PM
cchunter is offline
post #55600 of 58345 Old 05-07-2018, 08:22 AM
cchunter's Avatar
Quoted: 583 Post(s)
Liked: 853
I bet that chess table can play itself with dual 4000's inches away
ceptorman likes this.
Sony 75X900E 4K
cchunter is offline
post #55601 of 58345 Old 05-07-2018, 08:42 AM
confinoj's Avatar
Liked: 1060
So far no broken windows or flying chess pieces but I do wonder if I pushed the system to reference what may happen. I tend to listen at more moderate levels.
post #55602 of 58345 Old 05-11-2018, 05:23 PM
Teremei's Avatar
Quoted: 804 Post(s)
Liked: 408
so how do I mount the RS-42 II to the wall? I had it nail mounted and it fell and pulled the nail with it. I have 2 RS-41 II on the wall for 3 years with no problems. This is a different wall of course. It seems after 3 " there is cement so I can't go any deeper into the wall. Maybe 4". Bc when I hammer I hear a "ting".
Upstairs - Sony 75x940e: soundbar - Klipsch R-20B
Basement - BenQ HT3050: screen - Elite 125" motorized ATS: speakers - RF-7IIx2, RC-64II, RS-41IIx2, RS-42IIx2, AVR Denon x4000 -- subs PC-12NSD + RW12D
Bedroom - LG 65eg9600: soundbar - LG SH3K
Teremei is offline
post #55603 of 58345 Old 05-11-2018, 06:50 PM
gene4ht's Avatar
Liked: 2679
You’ll need to determine exactly what material is behind the wall. If it is indeed cement/concrete, there are appropriate wall anchors available. Home Depot or Lowe’s should be able to assist with the correct anchors for literally any material. As you didn’t mention if the wall is drywall on framing with space between it and the cement, all that may be necessary are appropriate drywall anchors...nails are not appropriate for this purpose. HD should be able to help with these as well. Good luck!
gene4ht is offline
post #55604 of 58345 Old 05-11-2018, 06:54 PM
retro124's Avatar
Quoted: 1427 Post(s)
Liked: 1154
I have mine RS-62II's on wall with single 2.5" screw in to stud and never had any issues. So if you used nail and works I will stick with it or try 1/4" or 5/16 blue concrete screws. I believe 1/4" will fit perfect.
Tapcon concrete screws from Lowes will be perfect.
gene4ht and ceptorman like this.
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses, Emotiva XPA-200
Sony XBR65X930E , Oppo 203
Apple 4K TV, Mac mini, Sony UBP-X800, PS3
retro124 is offline
post #55605 of 58345 Old 05-11-2018, 07:08 PM
gene4ht's Avatar
Liked: 2679
Retro124 is correct...screws will be fine if secured into a stud. If the speakers are not mounted directly over a stud, the appropriate type anchor is necessary for security.
gene4ht is offline
post #55606 of 58345 Old 05-11-2018, 07:14 PM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
It sounds like you have a standard wood framed wall over a concrete wall, is this in a basement? You need to locate the world framing (structure) behind the drywall. You can knock on the drywall and listen for the difference in sound when you knock where the wood is, or you can probably see some of the drywall nail spots in the surface of the drywall. Another good way to locate the wood, wherever there is an electrical outlet, one side of that outlet is against the wood framing. Or a studfinder will locate the wood also. Even if I use a stud finder to locate the stud, I always poke a couple holes in the drywall with a nail to locate the center of the wood. A screw can hit the edge of the wood and fail. I would use screws instead of nails.
gene4ht, Louis Bartay and retro124 like this.
650cc on the track
1000 cc on the street
800cc on the snow
ceptorman is offline
post #55607 of 58345 Old 05-11-2018, 07:44 PM
retro124's Avatar
Liked: 1154
I always overdue all those do it yourself project, why? just because I want to make sure. If you tell me my DVD shelf will be fine with 2 screws I know I will use 4 just to add more holding capacity for more movies
Denon X6200W
retro124 is offline
post #55608 of 58345 Old 05-11-2018, 08:15 PM
gene4ht's Avatar
Liked: 2679
That’s exactly what responsible architects and engineers do...design for a rated working capacity and then over spec materials by 50% or more for extra margin and safety.
gene4ht is offline
post #55609 of 58345 Old 05-12-2018, 06:52 AM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
Those "EZ" drywall anchors work well also, if you want to mount something but can't hit the wood behind the drywall.
gene4ht likes this.
650cc on the track
800cc on the snow
post #55610 of 58345 Old 05-12-2018, 07:25 AM
gene4ht's Avatar
Liked: 2679
The 75lb capacity EZ Anchors are exactly what's holding my RS-62II's.
https://www.lowes.com/pd/E-Z-Ancor-6...iABEgK2tPD_BwE
gene4ht is offline
post #55611 of 58345 Old 05-12-2018, 09:50 AM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
When you see them in the package they aren't very impressive, but when they're installed properly, they can hold quite a bit.
650cc on the track
800cc on the snow
post #55612 of 58345 Old 05-14-2018, 07:59 AM
Quoted: 60 Post(s)
I was hoping someone could help I purchased a pair of aw650’s in the cheap and one of the woofers is seized and was hoping someone could point me to where I could find a replacement or comparable woofer to replace the bad one
Chase_Monkey is offline
post #55613 of 58345 Old 05-14-2018, 08:26 AM
Louis Bartay's Avatar
Quoted: 403 Post(s)
Liked: 850
I looked on Ebay and found this. https://www.ebay.com/itm/Klipsch-Spe...EAAOSwTPBa9Rom
Klipsch Cornwall I,C7,RS3-II, R-14M
Klipsch Heresy II, NAD C272/C162,PL-518X ATOC9ML/III
Klipsch KLF-20,ReVox A77 MK IV D, Nakamichi BX-300
Klipsch Synergy Sub 12" X 3, SVS PB 13 Ultra Sub
Yamaha RX-V1900 HD 7.1, CDC 697, PS4
Louis Bartay is offline
post #55614 of 58345 Old 05-14-2018, 01:23 PM
Quoted: 59 Post(s)
L brackets ‘upside down’. I built a shelf around it, but the brackets themselves could work to for a more hidden approach.
Sony XBR65X900E
Xbox X
Denon X4300H
5.1.4- Klipsch RC-62 ii, R-26F, R-15M, R-10SW, Monoprice 8" Black Back Ceiling Speakers
mons0160 is offline
post #55615 of 58345 Old 05-14-2018, 01:26 PM
Ladeback's Avatar
Liked: 497
That should be ok for that as long as you don't overload it. The bracket was ment to go down to give you more support above. Another option is to screw a 2x2 onto the wall and then build a box shelf with it open on the back and screw through the box and into the 2x2 from the bottom.
Ladeback is offline
post #55616 of 58345 Old 05-14-2018, 04:24 PM
Quoted: 49 Post(s)
Hey guys, looking at doing my first Atmos setup in my living room. I am going for budget route but still want quality sound. I have an open concept living room so traditional surrounds wont be possible. My rears will have to be in the ceiling. My ceiling height is 8 feet. I sit about 14 feet away from my TV and about where the front speakers and subwoofer will be placed.
This is the setup I am leaning towards.
Sony STRDN1080 receiver ($300 my cost)
Rp-250f x2
Rp-250c
R-110sw
CDT-2650 C II x2 (ceiling rear surround)
R-2650 C II (ceiling atmos)
My understanding of the CDT 2650 in ceiling speaker is that it can be angled down towards me with its swivel option.
Living room: Sony 65" A8F OLED, Klipsch 5.1.2, Sony 1080 AVR, Sony X700 UHD Player, Nvidia Shield
Bedroom: Samsung 55" KS8000, Sony HT-ST5000 Dolby Atmos Soundbar
Kasfury is offline
post #55617 of 58345 Old 05-14-2018, 05:57 PM
gene4ht's Avatar
Liked: 2679
Rp-250f x2
Rp-250c
R-110sw
If your personal tastes or room constraints are dictating ceiling mounted rear surrounds, it would be best to forego the rear surrounds. Proper Atmos configuration require vertical separation between the bed speakers (rear surrounds) and the overhead speakers (ceiling Atmos). Having both in the ceiling will destroy the accuracy of the intended immersive Atmos effects. As a suggestion, you may want to visit the Atmos Installation Guide on Dolby's website.
https://www.dolby.com/us/en/guide/do...tup/index.html
From Dolby's installation guidelines....
You'll get the best sound when the front and surround speakers are at or slightly above your ear level when you're seated. Wall-mounted surrounds can be higher, but no speakers should be higher than half the height of your wall.
As an alternative or option, is there a possibility you could place bookshelf rear surrounds on stands behind your seating at or slightly above ear level?
I could be mistaken but I believe only the Klipsch CDT 3000 and 5000 series have swiveling horn tweeters.
gene4ht is offline
post #55618 of 58345 Old 05-15-2018, 09:33 PM
mpirnat's Avatar
Quoted: 175 Post(s)
Liked: 141
Text messages I received from my wife today while I was out at a conference:
“Black panther on our set up. The audio is crazy!!!”
“The waterfall scene... I’m looking around like wtf“
I felt really good about things at this point as she had been skeptical about the RF7IIs at first. Then...
“I feel like our tv is too small”
gene4ht, shivaji, kevyh and 2 others like this.
mpirnat is offline
post #55619 of 58345 Old 05-16-2018, 02:47 AM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
Awesome.....congrats!
Someone will be searching for a new TV or a projector/screen.
gene4ht likes this.
650cc on the track
800cc on the snow
post #55620 of 58345 Old 05-16-2018, 05:46 AM
kevyh's Avatar
Quoted: 41 Post(s)
It's a good sign to upgrade after she suggests it!
Sent from my SM-T810 using Tapatalk
gene4ht likes this.
kevyh is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
