Klipsch owner thread - Page 1858 - AVS Forum | Home Theater Discussions And Reviews
 23535Likes
post #55711 of 58407 Old 06-10-2018, 01:13 PM
zinfella's Avatar
Quoted: 388 Post(s)
Liked: 289
Originally Posted by _Jim_ View Post
What about the VideoSecu MS08B DA8? 20lbs , adjustable, with keyhole screws. I dont have these stands so I cant speak to their definition of "keyhole screws". This sometimes means a bolt and a elongated nut. Sometimes you have to temporarily remove the keyhole mount from the speaker to feed the bolt from the back. In-lieu of an adapter , I've always used a bolt with a trio of nuts to secure keyholes to stands when necessary.
Those stands a possibility, but, removing the keyhole mount on those particular speakers is not gonna happen here. To be fair, that might not be necessary anyway.
zinfella is offline
post #55712 of 58407 Old 06-11-2018, 12:42 PM
tibimakai's Avatar
Quoted: 180 Post(s)
Liked: 50
Newbie question here.
I don't have to many options, to install a center speaker. Garage setup, with motorized screen in front of the garage door, very close to the ceiling(low ceiling), Benq pj, half into the ceiling(motorized lift).
I'm thinking to go with 450c or 440c, motorized opening from the ceiling.
The speaker's back port, will be venting into the attic. Would be installed in an angle (piano hinged shelf), and just the "face" would be poking out.
Good idea, or bad idea?
Living Room: Samsung UN65JS8500, Onkyo TX-NR656, Klipsch R-28F, Klipsch RC-62II, Klipsch R-14S, Polk Audio 80 FX/RT(Atmos)
Bedroom: Samsung UN55MU6290, Onkyo TX-RZ610, Onkyo & Fluance speakers
Garage: Benq HT2050A, Elite Screens 125" motorized screen, Klipsch RP-160M, Klipsch RP-150M, Klipsch RP-450C , 2 x Klipsch CDT-3800 II for Atmos, Klipsch RW10
tibimakai is offline
post #55713 of 58407 Old 06-12-2018, 04:21 PM
Quoted: 49 Post(s)
Does anyone have their TV on top of a RP-450c? I have a Sony 65" A8f OLED that I was going to wall mount but I now realize it would fit on top of the center channel. The TV weighs 60 pounds. Would there be concerns of the panel vibrating at high volumes? Surely it wont tip over at a high volume.
Living room: Sony 65" A8F OLED, Klipsch 5.1.2, Sony 1080 AVR, Sony X700 UHD Player, Nvidia Shield
Bedroom: Samsung 55" KS8000, Sony HT-ST5000 Dolby Atmos Soundbar
Kasfury is offline
post #55714 of 58407 Old 06-12-2018, 11:53 PM
Quoted: 27 Post(s)
Yes, mine has a TV on it, all 82 lbs of it. As I understand it, the RP-450C was designed to support up to ~100lbs.
https://community.klipsch.com/index....of-an-rp-450c/
Kasfury likes this.
_Jim_ is offline
post #55715 of 58407 Old 06-13-2018, 02:24 AM
Louis Bartay's Avatar
Quoted: 403 Post(s)
Liked: 850
I too wondered it this was OK. How long have you have the TV on the speaker?
Klipsch Cornwall I,C7,RS3-II, R-14M
Klipsch Heresy II, NAD C272/C162,PL-518X ATOC9ML/III
Klipsch KLF-20,ReVox A77 MK IV D, Nakamichi BX-300
Klipsch Synergy Sub 12" X 3, SVS PB 13 Ultra Sub
Yamaha RX-V1900 HD 7.1, CDC 697, PS4
Louis Bartay is offline
post #55716 of 58407 Old 06-13-2018, 08:38 AM
Quoted: 27 Post(s)
Not long..only 4 months or so. It’s a Panasonic gt55 and the base JUST fits front-to-back which is a good thing as this means a good portion of the weight is directly on the outside walls.
Louis Bartay likes this.
_Jim_ is offline
post #55717 of 58407 Old 06-13-2018, 02:11 PM
Quoted: 61 Post(s)
Liked: 6
Does anyone have feedback on the Klipsch 250s bi polar rear speakers. I’m considering adding a set to my system.
Navyship is offline
post #55718 of 58407 Old 06-13-2018, 03:55 PM
Killroy's Avatar
Quoted: 529 Post(s)
Liked: 412
Bipoles are an acquired taste. Some people hate them. I fell in love with a set of Fluance bipoles and I bought them. Then when testing different speakers for my new HT I heard the 250s and I felt the same first-love I felt with the first time I heard the Fluances but the 250s are far better.
You need to find them installed somewhere and listen to them. If you are one of those that likes their unique sound then you will love them.
Killroy is online now
post #55719 of 58407 Old 06-15-2018, 06:50 AM
zinfella's Avatar
Quoted: 388 Post(s)
Liked: 289
I am going to be running exposed speaker wire to one of the new side surrounds in our living room. This isn't a matter of choice, it's either exposed or not at all. So, I'm going to run the lion's share of .it in the corner where the side wall meets the ceiling. What I want to know is there a staple gun that works for this task and that won't destroy the wire in the process? That approach seems ever so much better than using a hammer to install the tacks/staples/wire holders. But, folks here might have better suggestions, so let'er rip!
zinfella is offline
post #55720 of 58407 Old 06-15-2018, 06:54 AM
drh3b's Avatar
Quoted: 2032 Post(s)
Liked: 4029
Raceways.
https://www.amazon.com/Legrand-Wirem...wiremold&psc=1
drh3b is offline
post #55721 of 58407 Old 06-15-2018, 06:56 AM
Killroy's Avatar
Quoted: 529 Post(s)
Liked: 412
Two words.... Ghost Wire.
post #55722 of 58407 Old 06-15-2018, 12:19 PM
Quoted: 27 Post(s)
..if the other solutions proposed dont work for you there is this sort of staple gun:
https://www.amazon.com/Gardner-Bende...ner+bender+gun
https://www.amazon.com/Gardner-Bende...090052&sr=1-17
I've used this for speaker wire and xmas lights.
_Jim_ is offline
post #55723 of 58407 Old 06-16-2018, 04:27 AM
coytee's Avatar
Quoted: 261 Post(s)
Liked: 433
You state it's exposed or not at all....this infers to me you either can't dig into the wall or, don't want to. (ripping into the drywall would be my choice so you could bury the wire.... but, my wife is pretty adept at fixing those type things and you can't tell it was ever opened...)
I'd go the raceway ...way. Basically get some conduit on the wall so you can run whatever you need. I like the purported benefits of the ghost wire but personally, I think I can see some shortcomings with it when it comes time to turn corners and go around objects. Something that is wide and flat, doesn't like to make a sudden 90 degree turn without bunching up or some other issues. (I would personally want as few splices as possible)
So my vote, since you don't clarify why you can't do it
1. Rip into wall & bury the wire
2. Raceway
coytee is offline
post #55724 of 58407 Old 06-19-2018, 11:18 AM
tibimakai's Avatar
Quoted: 180 Post(s)
Liked: 50
Nobody can help?
It is a good, or bad idea, to place the center speaker, with the vent port, into the attic?
I have another question about two speakers, that I'm considering.
One is an old one, RB-35(8" speaker) and the other, is a RP-160M(6.5" speaker)
The BR-35, I can have it for $75/pair, with one bad tweeter(replacement would be $39), and I could replace that myself.
The RP-160M, is around $300 as an open box.
I'm considering the RP-450C, as the center channel.
post #55725 of 58407 Old 06-20-2018, 04:21 PM
Liked: 0
Hey guys, long time lurker with a few questions.
I have the following Klipsch speakers:
2 - RF-82
4 - RS-42
1 - RC-42
(These are not the II)
I will be moving soon and selling my Denon X2000 to get something with HDCP 2.2. I also need to buy a new subwoofer. I plan to go with the Denon X3400 and likely a PB-1000.
The room I will be using is mostly a box, about 14 x 12 x 10. My main question is should I or can I use two of the RS-42s for height speakers to make a 5.1.2 system? Or should I stick with 7.1 with the speakers I have? I also have a pair of R-15Ms if anyone has a creative idea for those.
Ben Treanor is offline
post #55726 of 58407 Old 06-21-2018, 10:06 AM
zinfella's Avatar
Quoted: 388 Post(s)
Liked: 289
Okay, this is not as easy as I had imagined it to be. First, let me say that _jim_ was right, removing the keyhole mount was necessary in using the Sanus EFSATB stands that I bought because I thought that they had the right hardware for keyhole mount speakers. However, they do NOT, and I had to scrounge around for parts (of course scrounging around included the obligatory trip to the BORG) that I could force into service for mounting the R-14S's on these stands. I did make it all work, ugly as it is, but it is not the best situation, and I will be looking for a better solution as far as stands go.
By the time I got the wiring done and the Frankenstein mounts fabricated it was too late to go hunting for content to show off my new surrounds, and rejoice in my return from a 3.1 setup after our move, back to a 5.1 setup such as we had before the move. I streamed episode 1 of Marvel's Daredevil thinking a Marvel choice would be a good demo, but that choice was mild to say the least. While trying to recall the not too distant content that made me want to go back to 5.1, I drew a blank, but at least that matched my brain at that point, so I went to bed.
zinfella is offline
post #55727 of 58407 Old 06-21-2018, 12:38 PM
Quoted: 32 Post(s)
Liked: 34
Trying to patiently wait for a sale on the Reference Premiere line. I am expecting there will be a sale in the not too distance future on the current line, since the RP refresh should be released in the fall.
I am want to replace my LCR with RP-160Ms & RP-450C. I am currently using a pair of KG4s with a B&W LCR6s2.
LG OLED65C7P, Denon X3400H, Chane A2.4 (LCR), Infinity RS5 (Surrounds), Klipsch Quintet (Heights)
r160dB is offline
post #55728 of 58407 Old 06-21-2018, 03:06 PM
Kini62's Avatar
Quoted: 2721 Post(s)
Liked: 2536
2 - RF-82
4 - RS-42
1 - RC-42
You could try the RS-42 as front height/Atmos speakers but they are not really designed for that. They're designed to be side surround speakers. The R-14SA or the RP equivalent would be what you should use.
I'd take 5.1.2 over 7.1 any day, especially in your small room.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is online now
post #55729 of 58407 Old 06-21-2018, 03:55 PM
Killroy's Avatar
Quoted: 529 Post(s)
Liked: 412
You missed a good sale about two weeks ago. I picked up a RP-450c, 2x RP-280F, and 4x RP-250S, and also 2x R-115SW (good price but not on sale).
post #55730 of 58407 Old 06-21-2018, 04:08 PM
Quoted: 32 Post(s)
Liked: 34
Where was the sale? Was it a online retailer? I've been watching klipsch.com, Amazon, Fry's Electronics. I want to go through a authorized retailer.
r160dB is offline
post #55731 of 58407 Old 06-21-2018, 04:14 PM
Killroy's Avatar
Quoted: 529 Post(s)
Liked: 412
Amazon. I think it was a one day sale. I was hoping that they would lower the price on the subs but nope. Speaking of Fry's... they sometimes have a sale of the lower end towers and speakers but include the R-115SW at a lower price point than the sub alone on Amazon.
post #55732 of 58407 Old 06-21-2018, 04:52 PM
Liked: 0
Are these preferred to something that mounts in the ceiling?
post #55733 of 58407 Old 06-21-2018, 04:58 PM
Kini62's Avatar
Liked: 2536
In ceiling is the best option, but is not always available depending on the situation.
I'm currently using some NHT SuperZeros angled at 20 degrees on the top of my front towers, 9 ft drywall ceiling and I can hardly tell they're on, even boosted by 8-9db. Watched the first 10 minutes of BR2049 and got about zero overhead effects.
I don't want to go in ceiling so my next step is the SVS Prime elevation speakers mounted as front height or to the sides of the listing position but at ceiling height.
Def Tech SC8000
Onkyo RZ820
post #55734 of 58407 Old 06-21-2018, 05:18 PM
gene4ht's Avatar
Quoted: 1984 Post(s)
Liked: 2681
No need to wait for sales. Give Sound Distributors or Acoustic Sound Design (both authorized online retail dealers) a call for competitive pricing...you must call for best price quotes.
explorz and Louis Bartay like this.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is online now
post #55735 of 58407 Old 06-21-2018, 08:33 PM
Quoted: 32 Post(s)
Liked: 34
Thank Gene, I'll give them a call.
r160dB is offline
post #55736 of 58407 Old 06-21-2018, 08:48 PM
drh3b's Avatar
Liked: 4029
I wouldn't worry too much. Just stay vigilant, easiest way is to check Amazon, as several authorized dealers sell through them. Crutchfield will also put them on clearance as soon as Klipsch authorizes it, I'm sure. The previous generation was mostly widely available for a year or so.
You will enjoy them, they are great speakers, as long as you aren't a crazy loud listener like I am, then you need to accept no less than the RP280f.
I've owned the RP-150m, the RP250c, and currently the 450c, 280f and the 260f. I won't say they are the best speakers for the price in the world, as there are thousands to listen to, but they are damn good.
r160dB likes this.
My World Beating System!
Spoiler!
drh3b is offline
post #55737 of 58407 Old 06-22-2018, 08:22 AM
malmstump's Avatar
Quoted: 176 Post(s)
Liked: 369
hi guys ,thought to post pic of my klf c4 lol
Name:	c 7 x2.jpg
klipsch klf-30 s Vizio p65
klipsch klf c-7 x 2
klipsch klf-20 s
onkyo tx Nr-818 soon denonx4500
3 crown xls 2502 1 xls 1502, HSU vtf-15 Mk 2
malmstump is offline
post #55738 of 58407 Old 06-22-2018, 05:02 PM
explorz's Avatar
Quoted: 25 Post(s)
I'm thinking the same thing. I just purchased a set of Atmos enabled speakers from Klipsch at a great discount and that sent me down the rabbit hole. Now I'm looking to get a pair of RP-160M front speakers and a center RP-250C. But right now prices aren't really budging.
I imagine that as August approaches when the new line may become available, we're going to see a fair amount of clearance opportunities. I wonder if the deals will start before right before the new line comes out or after it is released.
explorz is offline
post #55739 of 58407 Old 06-22-2018, 05:05 PM
explorz's Avatar
Quoted: 25 Post(s)
I also prefer the look of the current RP line over the new look with the anodized ring. Although the new bases with the feet look good.
drh3b and r160dB like this.
explorz is offline
post #55740 of 58407 Old 06-27-2018, 12:26 AM
tibimakai's Avatar
Quoted: 180 Post(s)
Liked: 50
I have ended up getting the RP-450C Walnut, that has just arrived today.
I was listening to it, and to me, it sounds like the left inner speaker, sounds more muffled, then the right inner speaker. The right one has highs, but the left one not at all.
Almost like, each speaker has different frequency ranges. It could be, that all five speakers reproduce different frequency ranges?
The outer ones, barely make any sound, but I'm guessing those will make sound, only when the frequencies get low enough.
I would like to find out this info, as soon as possible, to be able to contact the seller, in case that it is not normal.
Any input would be appreciated.
P.S. Found this image on Youtube (Techno Dad). It could be possible, that the two inner speakers cover the 500-1500Hz range, but not as both reproduce the same frequencies, rather one reproduces, let's say 500-750Hz and the other, from 750-1500Hz range(split the range)? Maybe the same goes, for the two outer ones as well?
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
