Klipsch owner thread - Page 1886 - AVS Forum | Home Theater Discussions And Reviews
 23568Likes
post #56551 of 58525 Old 10-18-2018, 12:49 PM
gajCA's Avatar
Quoted: 9386 Post(s)
Liked: 6468
Not a Klipsch owner but am interested if anyone has compared the new RP to the old RP lines and whether the improvements can be heard.
This was the original press release:
"Featuring a new, vented proprietary Linear Travel Suspension titanium tweeter and our exclusive Tractrix® horn loaded technology, the new Reference Premiere series speakers deliver improved high-frequency response, better extension, enhanced imaging, and reduce unwanted harmonics for incredible detail and clarity."
Geoff A. J., California
gajCA is offline
post #56552 of 58525 Old 10-18-2018, 01:04 PM
drh3b's Avatar
Quoted: 2110 Post(s)
Liked: 4263
Originally Posted by jbalder19 View Post
They should play decently well to 80hz though right? I'll be crossing everything over to a sub. I'm just wondering because I know 4 inch woofers probably don't play as well to 80hz, but I was wondering if the large cabinet size and 4 woofers vs 2 helps it in this regard.
I believe they are designed to go a little below 60 Hz, so they should be fine. Like I said, everyone who has commented on them in the past has liked them. The relatively large cabinet and the ports are presumably what makes it work so well.
jbalder19 likes this.
drh3b is offline
post #56553 of 58525 Old 10-18-2018, 02:34 PM
Quoted: 67 Post(s)
Liked: 4
Originally Posted by gene4ht View Post
I've installed the 5502's in my daughter's home under a 65" flat panel. They are excellent performers. The installation is very simple for the DIY'er...just cut the appropriate size opening in the drywall, insert the entire speaker assembly, twist and screw/secure the holding tabs, and done...oh and the "paintable" magnetic grill is a nice touch. Depending on your home's construction type and installation location, the most challenging part could be running and fishing the speaker wire. Beyond this, keep in mind that in wall speakers can result in sound transmission to other parts of the home (more so if mounted in interior walls vs exterior walls). As others have mentioned, a backer box is helpful for improving sound quality and limiting sound transmission. Also, it's a good ideal to surround the speaker with or without a backer box with perhaps blanket insulation to further dampen sound transmission. Lastly, these speakers are widely available through many authorized on line retailers at substantial discounts. Good luck with your project!
Thank you.
Are we able to disclose what dealer(s) have these at a substantial discount? All the ones I have been able to find so far that are less than MSRP are non-authorized dealers.
matpal is offline
post #56554 of 58525 Old 10-18-2018, 02:43 PM
gene4ht's Avatar
Quoted: 1996 Post(s)
Liked: 2723
Originally Posted by matpal View Post
Thank you.
PM sent...
matpal likes this.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is online now
post #56555 of 58525 Old 10-18-2018, 04:59 PM
thetman's Avatar
Quoted: 533 Post(s)
Liked: 286
from everything I read and heard its not a big difference. tweaked the tweeter- but mostly cosmetic it seems, base style- different finishes.
thetman is offline
post #56556 of 58525 Old 10-19-2018, 03:04 PM
jokerrn's Avatar
Klipsch set up
Hey, guys. Building a new house with a dedicated media room and am narrowing down my choices. Haven't owned Klipsch before, but have heard some and loved the sound of them. Room is ~13x18 with 10' ceilings. One row of seats. Haven't picked screen yet. Room use will be 75% movies, 25% gaming (kids).
Here is the 7.1.4 in-wall (don't even get me started...) Klipsch set up I am considering based on performance and budget. Would love to know if I am missing something.
R-5800W-II as FL, FR, SL, SR, SBL, SBR.
R-5502W-II as center
R-115SW x1
For the heights, my understanding is that I don't really need to feel the need to match them with the other speakers or spend a bunch of money on them. I am considering something like the JBL SP8Cs that go on sale a few times a year or similar.
Looking for a Marantz SR7012 and an Emotiva A-500 to drive it all.
Wide open to feedback. Thanks.
jokerrn is offline
post #56557 of 58525 Old 10-20-2018, 08:03 AM
jokerrn's Avatar
R-115SW x1
So I actually found some CS-18C speakers for a good deal to use as the heights. I recognize that just matching the brand doesn't necessarily mean anything sound-wise, but I'm far from an audiophile and just want everything to be clear and loud.
Anybody have an issue with this grouping?
jokerrn is offline
post #56558 of 58525 Old 10-21-2018, 07:19 AM
Tom Riddle's Avatar
Quoted: 819 Post(s)
Liked: 736
I got my Klipsch CDT 5650 II's in on Friday!!!! Should have them installed in the next week and a half or so - they finished framing my dedicated HT yesterday. I posted pictures over in my thread, if anyone is interested.
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7704 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #56559 of 58525 Old 10-21-2018, 09:50 AM
nap2422's Avatar
Liked: 26
Originally Posted by jcwilkerson View Post
Hello Everyone!! I just recently replaced a Velodyne CHT-12 with a Klipsch R-112SW because the Velodyne had a bad board internally. I decided to re-run the AccuEQ calibration on my Onkyo RZ-810 and I got some very strange suggested settings that I wanted to run by everyone here. My setup is as follows: (2) RP-280FA (for my L Front and R Front both with up firing Atmos Height Speaker), RP-450C (center), RP-250S (L Surround and R Surround placed in back), and finally the R-112SW. I have a Rotel 225 x 5CH AMP powering only the LCR and all through the Onkyo RZ-810. For the Sub I set crossover knob to it's highest setting and have the gain knob a little below mid. The suggested Crossover settings after calibration are as follows:
FRONTS = 200Hz
CENTER = 100Hz
SURROUND = 100Hz
HEIGHT (ATMOST) = 40Hz
I assume the LFE on the Onkyo is still set to 80Hz. This suggested setting is complete opposite of what I would have assumed and what I previously had. Mainly because of the size of the RP-280FA and RP-450C speakers I am using. What are everyone's thoughts about this? Does anyone have any suggestions for tweaks? The sound is very clear and punchy so I don't have many complaints but I do feel that some sounds are getting lost but not sure. Thank you in advance for anyone's knowledge or advice.
JW
I had this same issue when using accuEQ on my RP series with an rz-610. At first I would just lower the crossover to 80hz but lost a lot of LFE and things did not sound correct, then I disabled EQ and things seemed out of control. Without the knowledge or equipment to calibrate on my own I dedicated hours to messing with speaker and mic placement. I was able to get all speakers at 40hz (changing to 80hz afterword) with accuEQ by putting the mic well below the tweeter, this meant raising the speakers on platforms so I could place the mic at listening level when calibrating. I know you posted this a while ago, but I looked around so much for people having the same issue. Let me know if this helps or if you've found a solution since then.
Samsung 65Q8FN | Denon AVR-X4400H (5.1.4) | Klipsch RP-260F, RP-450C, RP160M, MICCA M-8C x 4 | PSA V1811 | Samsung UBD-M7500
nap2422 is offline
post #56560 of 58525 Old 10-21-2018, 09:57 AM
gene4ht's Avatar
Liked: 2723
Looking good! Great progress! As a suggestion, a link to your build thread in your signature would be helpful.
post #56561 of 58525 Old 10-21-2018, 11:58 AM
Tom Riddle's Avatar
Quoted: 819 Post(s)
Liked: 736
I'm trying to paste the link into my signature, but can't seem to figure out how to just paste the link title and not the whole hyperlink. I can change it in an email or in office, but for the life of me can't figure out how to do it in google chrome. Anyone know how - would love to have it in there as @gene4ht stated.
post #56562 of 58525 Old 10-21-2018, 03:52 PM
Quoted: 723 Post(s)
Liked: 238
Try the following without the spaces in the brackets, and replace "url here" with your url
[ url="url here" ]link title[ /url ]
Tom Riddle likes this.
dkfan9 is offline
post #56563 of 58525 Old 10-21-2018, 06:16 PM
Liked: 0
Surrounds speakers/book shelf speakers.
I'm currently building a HT in my basement and I am at a crossroad due to budget, the room is 13' by 21' and has 8' suspended ceiling. 90% of the listening in the room will be movies or sports. I'm running a Denon arv4400 with recently purchased RP280f mains and a RP440 centre a R112sw and a psb 12"
from my old system. eventually I intend to purchase a separate amp to run the front stage and add 4 ceiling atmos speakers but thats a year away. so long story short I can not use my old Bose surrounds for obvious reasons and I need to purchase surrounds so can I get away with book shelf speakers and be happy or do I need to spend the extra cash and buy surround speakers?
ripyaone is offline
post #56564 of 58525 Old 10-21-2018, 09:43 PM
Alanlee's Avatar
Quoted: 440 Post(s)
Liked: 276
Go with what you have for now. Wait a few months, let your cash build up, and then buy the next piece. If you have a tight budget, and you try to do it all at once, you will never be happy with what you have. The future is bright and full of opportunities.
Louis Bartay and IMWhizzle like this.
7.4.6 system with Denon 8500, Additional Amps: Emotiva (front and center) and NAD (wide), classic Klipsch speakers.
Alanlee is offline
post #56565 of 58525 Old 10-22-2018, 09:08 AM
doubleH's Avatar
Klipsch In-Wall Comparison
Hello,
Apologies if I didn't post this correctly, but I didn't have the option to start a new thread once inside the Klipsch Owner Thread. Looking at two models for in-wall LCR's. I am having trouble finding if they are 2-way or 3-way. Anyone know?
  • PRO-250RPW LCR (2017)
  • R-5502-W II (2012)
If you have comments around these two models feel free to add those as well.
Thank you.
doubleH is offline
post #56566 of 58525 Old 10-22-2018, 01:06 PM
Tom Riddle's Avatar
Quoted: 819 Post(s)
Liked: 736
That's the ticket!!!! Thanks, it's now listed as the Routh Family Theater in my signature. Now if I can just figure out how to change the Forum name!
They are here installing the surround and projector pre-wire now. 12 guage all the way!
ceptorman likes this.
post #56567 of 58525 Old 10-22-2018, 01:59 PM
c627627's Avatar
Quoted: 29 Post(s)
What would be a disadvantage of buying a more powerful speaker than what you have for front speakers?
In my example I was told by Klipsch to get the R-34C center for my R-26F speakers.
Since their used price is similar to a used RC-62, I was thinking why not go with the more powerful RC-62 for the same price?
What are the advantages of the new 2018 RC-34C center speaker when compared to the old RC-62, if being paired with regular R-26F speakers?
What would you do?
c627627 is offline
post #56568 of 58525 Old 10-22-2018, 04:23 PM
bertk's Avatar
Quoted: 74 Post(s)
Liked: 68
Hey Tom, the sig link is broken. Click Edit and then the A/A (switch editor mode) icon at the top right of this message window. This will show you the full link within "Routh Family Theater" below. Copy and Paste it into your sig and click Preview Post to check.
To change the Title of the thread contact a moderator.
Denon X3400H | Klipsch RP-280F | RP-450C | RP-240S | RP-500SA | Monolith 12" THX Subwoofer X2
Panasonic UB-820 Player | LG OLED65C8 TV | DirecTV HR54/200 | AppleTV 4K l Monoprice Certified HDMI Cables
bertk is online now
post #56569 of 58525 Old 10-22-2018, 04:29 PM
Kini62's Avatar
Quoted: 2760 Post(s)
Liked: 2613
What would you do?
Get the RC-62. New at Amazon for $255.
https://www.amazon.com/Klipsch-RC-62...=klipsch+rc-62
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #56570 of 58525 Old 10-22-2018, 06:23 PM
c627627's Avatar
Quoted: 29 Post(s)
I thought there would be zero advantage in getting the RC-34C for my setup, but have not bought speakers in twenty years and didn't get a chance to look at the models.
I happened to score the R-26F fronts unrelated to any choice, so now I am looking to get a center for them but with Klipsch support telling me to get RC-34C because RC-62 would be overkill for them... I figure I would ask you guys....
Thank you for clarifying that I should get the RC-62s.
c627627 is offline
post #56571 of 58525 Old 10-23-2018, 06:10 AM
Tom Riddle's Avatar
Quoted: 819 Post(s)
Liked: 736
Thanks, @bertk ! It is working now. I will contact a Moderator, too. Thanks for all the help!
post #56572 of 58525 Old 10-23-2018, 07:36 AM
bertk's Avatar
Quoted: 74 Post(s)
Liked: 68
The room is coming along nicely Tom!
bertk is online now
post #56573 of 58525 Old 10-23-2018, 01:23 PM
Tin_Can's Avatar
Quoted: 290 Post(s)
Liked: 68
Does anyone know where to find off axis measurements of the klipschorn?
Tin_Can is offline
post #56574 of 58525 Old 10-23-2018, 01:51 PM
ceptorman's Avatar
Quoted: 450 Post(s)
Liked: 710
You might try the Klipsch Forum, lots of info there....https://community.klipsch.com
650cc on the track
1000 cc on the street
800cc on the snow
ceptorman is offline
post #56575 of 58525 Old 10-23-2018, 05:59 PM
Tom Riddle's Avatar
Quoted: 819 Post(s)
Liked: 736
Hit my first stall today - the audio installer put in 16 awg wires instead of 12 awg. I didn't even catch it - asked the guy yesterday and he said 12 awg was going in. Luckily the company I hired caught the mistake and the owner called this morning to let me know - he is sending them back out tomorrow to fix it.
post #56576 of 58525 Old 10-24-2018, 02:41 PM
Desmond7's Avatar
Quoted: 52 Post(s)
Liked: 0
Is there any difference between these center speakers Klipsch RP-450C and Klipsch Reference RP-450CA I can get the other for 160 less.
Desmond7 is offline
post #56577 of 58525 Old 10-24-2018, 03:11 PM
Quoted: 106 Post(s)
Liked: 64
RP-450CA is real wood veneer. RP-450C is wood looking vinyl wrapped. All internal components are the same.
ereed and drh3b like this.
Go Eagles! Go Sixers! Go Phillies! Go Flyers!
tingham is offline
post #56578 of 58525 Old 10-26-2018, 10:55 AM
thetman's Avatar
Quoted: 533 Post(s)
Liked: 286
new 5.1 set up for music in my home office. Piano black RP-250F x 4 and RP-250C. Really like the look of the piano Black. So far played a lot of blu-ray audio and SACD's. they sound great, just enough for the room.
ID:	2474010   Click image for larger version
ID:	2474012   Click image for larger version
ID:	2474014   Click image for larger version
tbass2k, DesertDog, Kini62 and 3 others like this.
thetman is offline
post #56579 of 58525 Old 10-26-2018, 11:04 AM
drh3b's Avatar
Liked: 4263
What's the subwoofer?
My World Beating System!
Spoiler!
drh3b is offline
post #56580 of 58525 Old 10-26-2018, 11:21 AM
thetman's Avatar
Quoted: 533 Post(s)
Liked: 286
its a HSU VTF-1 MK2 in maple finish.
Louis Bartay and drh3b like this.
thetman is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
