Klipsch owner thread - Page 1888 - AVS Forum | Home Theater Discussions And Reviews
 23391Likes
post #56611 of 58048 Old 11-03-2018, 03:41 AM
Kain's Avatar
Quoted: 1932 Post(s)
Liked: 811
What is the max continuous SPL and the max peak SPL of the RF-7 III?
Kain is offline
post #56612 of 58048 Old 11-03-2018, 06:43 AM
Quoted: 106 Post(s)
Liked: 62
Originally Posted by ubhystry View Post
I tried searching old threads regarding the distance to wall for this center channel, so I'm sorry if I missed it.
I'm in the process of finishing my HT room build and getting ready for installing components and speakers. My component cabinet will not be ready for
another 6-7 months and I will be mounting the center channel under the TV on a pair of CC brackets or floating shelf of sorts to keep it clean as I can for now. What sort of space should I "try to keep" from the speaker and wall? or is this something that is personal preference and trial and error will tell me whats right?
Trial and error is best since all room acoustics are different. I would not think the center channel would have to be as far away from the wall as say a rear ported tower speaker since it's frequency range is likely higher in most cases. For what it's worth I have my 450c 10" inches from the wall to the back of the speaker. I hear no resonating sounds from the rear port of the 450c off the back wall, which is reflective drywall. This is not the case with my rp-280fa towers as they are 12" from the back wall. Any closer in my room and I hear the rear port resonating sound off the wall. One or two inches in placement really does MATTER!
Go Eagles! Go Sixers! Go Phillies! Go Flyers!
tingham is offline
post #56613 of 58048 Old 11-03-2018, 06:58 AM
Quoted: 12 Post(s)
Well, just a follow up to my previous posts. It looks as if I want my K’horns refinished, I’m going to have to do something myself. I’ve contacted one cabinet maker and one furniture refinisher. After looking at detailed photos neither one are interested in the job. I’m surprised how hard it is to find anyone interested in veneer jobs when veneer seems so common and readily available. I guess it’s mainly for OEMs. Oh well, have to figure out where I’m going.
LesLucid is offline
post #56614 of 58048 Old 11-03-2018, 07:07 AM
Liked: 0
Hi,
I need help to choose in celling surround speakers and subwoofer for my HT.
I bought PRO 250RPW for my LCR.
Which one will be better for surround?
CDT 5800C II
PRO 180RPC
or there is better option for celling speakers?
tripc is offline
post #56615 of 58048 Old 11-03-2018, 07:43 AM
ceptorman's Avatar
Quoted: 449 Post(s)
Liked: 709
There's probably info on the Klipsch forum about this. There are formulas on here also.
I will say they are world class speakers, and play above their price point.
gene4ht likes this.
650cc on the track
1000 cc on the street
800cc on the snow
ceptorman is online now
post #56616 of 58048 Old 11-03-2018, 07:47 AM
ceptorman's Avatar
Quoted: 449 Post(s)
Liked: 709
Make sure the front of your center speaker is close to the front edge of the shelf or cabinet. You don't want the shelf interfering with the sound waves. I keep my cabinet as close to the wall as I can, with the center out at the front edge, I have about 6" between speaker and wall....my center is pretty deep.
gene4ht likes this.
650cc on the track
800cc on the snow
post #56617 of 58048 Old 11-03-2018, 07:54 AM
ceptorman's Avatar
Quoted: 449 Post(s)
Liked: 709
I'll bet it would get expensive also to have a pro rebuild them. Are you fairly handy? You might try to repair and veneer them yourself. Maybe practice a lot on another project. It would be very rewarding knowing you rebuilt your own speakers.
I have been looking for a speaker rebuilding project, thought I found some cheap La Scalas, but it didn't work out.
gene4ht likes this.
650cc on the track
800cc on the snow
post #56618 of 58048 Old 11-03-2018, 07:59 AM
Quoted: 12 Post(s)
I’ve done a variety of projects around the homestead so I could probably do this. To be honest, the main problem with doing it myself is that I know I will go very slowly and I really don’t want to be without our main source of entertainment for long. I figured a professional would be able to do it fairly quickly. I have to think about this a bit.
LesLucid is offline
post #56619 of 58048 Old 11-03-2018, 08:06 AM
ceptorman's Avatar
Quoted: 449 Post(s)
Liked: 709
I can certainly understand that. Wonderful speakers.
650cc on the track
800cc on the snow
post #56620 of 58048 Old 11-03-2018, 03:15 PM
ereed's Avatar
Quoted: 2191 Post(s)
Liked: 1483
Its worth mentioning the xover point you are using. The lower the xover the more the port comes into play in lower frequencies. If you're using something such as 100hz xover you can put the speaker closer to the wall without issues.
TrueDis and BGLeduc like this.
Sony 45es | 120 inch screen | Panasonic BDT500 | Rotel RMB-1075 | Rotel RMB-1077 | Rotel RSP-1068 | Klipsch RP-280F/RP-450C/RP-160M (x4) | Funk Audio subs (x2) | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x2) | Monster Power Conditioner | GIK acoustic panels
ereed is online now
post #56621 of 58048 Old 11-04-2018, 04:47 AM
Quoted: 106 Post(s)
Liked: 62
It certainly is, good point! My experience is with the towers set to full range as I'm mostly 2ch music. When movie watching the center is set to 80hz.
tingham is offline
post #56622 of 58048 Old 11-04-2018, 11:12 AM
aztony's Avatar
Quoted: 47 Post(s)
Just wondering if anyone has their speaker wiring running along the floor and if they use some type of conduit to hide it.
aztony is offline
post #56623 of 58048 Old 11-05-2018, 03:56 AM
jeff1967's Avatar
Quoted: 60 Post(s)
Liked: 846
I have used 2 methods for this. In places where it will not be in plain sight i haves used plain gray plastic conduit available from the big home improvement stores. Pretty inexpensive, and I have sanded and painted it in some instances to have it blend into the wall color. Same goes for the hardware to attach to the wall/baseboard.
Also at the home improvement stores, there are fake baseboards that look like the real thing, but they snap open and you can run several wires through them. A bit more expensive, but looks PERFECT when finished. And again, you can paint them any color you need.
Louis Bartay and ceptorman like this.
Panasonic TC-P55ST50 Plasma 55"
Oppo BDP-203 Blu Ray, Toshiba A30 HD DVD
Onkyo RZ-900 Receiver (7.1 Config)
Klipsch R28F, RC64ii, RS400, RB600, R-12SW Sub
Mac Mini/PS3/Wii, Harmony Smart Control
jeff1967 is offline
post #56624 of 58048 Old 11-13-2018, 11:36 AM
Quoted: 75 Post(s)
Do the horn speakers of the rp line have a wide soundstage or is it localizable? Ill be sitting about 6ft from most likely a rp 440c with a tv on top and wondering if it'll sound like the sound is coming from the tv or the speaker. I've never dealt with horn speakers before but have heard they're very directional. If I want the illusion that sound is coming from the tv and not localized to the center, would a horn or dome tweeter be better, or its about the same?
jbalder19 is offline
post #56625 of 58048 Old 11-13-2018, 01:58 PM
Quoted: 81 Post(s)
Liked: 146
It's a 90 X 90 horn. You be should be fine. My center is also horn loaded and it's right on top of the TV. I don't find it distracting at all.
jbalder19 likes this.
garygreyh is offline
post #56626 of 58048 Old 11-13-2018, 02:52 PM
Quoted: 75 Post(s)
thanks
post #56627 of 58048 Old 11-16-2018, 09:10 AM
Carbo's Avatar
Quoted: 291 Post(s)
Liked: 158
Just wondering how well a RP404c or RP440c will match a pair of Klipsch RF-5's. I can't use any other Klipsch centers. I need something that will fit in my center rack space and the 404 or 440 are about it. I was thinking about getting RP8000f, RP440c and RP500SA's and selling the RF-5's but large speakers are a pain to sell and ship. So I was wondering if anyone has any thoughts of just matching the RF-5 with RP404c and RP140SA to save some money.
1) JVC RS540, Yamaha CX-A5100, Outlaw Audio 7700 & 7140, Wharfedale Jade 7's series speakers, RSL C34e(Atmos)
2) LG OLED65B6, Integra DRC-R1, Emotiva XPA9, Klipsch RP8000F, Klipsch RP404C, Klipsch RP500SA, Klipsch RP140D
Carbo is online now
post #56628 of 58048 Old 11-16-2018, 11:45 AM
Liked: 0
Howdy, I'm new to the forum but I have quite a few questions. Top start of im trying to decide how the klipsch r-820f compare top the 280f. The specs seem extremely similar but im not familiar enough to know if im missing something. Im asking because the r820fs are on sale 2 for $450 and im leaning towards upgrading to these from the r26f. Any advice?
Man-o-Vertigo is offline
post #56629 of 58048 Old 11-16-2018, 12:02 PM
Quoted: 370 Post(s)
Liked: 308
The RP series has less fatiguing high end and you will enjoy listening to them for longer periods of time. The RP-280F is on sale too but it is more expensive at $383 each. If you have a subwoofer then you could go with the RP-250F for $238 each so real close to price as the r-280f. Let your sub handle the low end. The RP-250F actually has the same low end specs as the r-280f at 35Hz at 3db down so a win win going with the RP-250F
Check it at Amazon or Klipsch site.
https://www.amazon.com/Klipsch-RP-25...lipsch+rp-250f
https://www.klipsch.com/products/ref...&model=rp-250f
cocrh is online now
post #56630 of 58048 Old 11-16-2018, 03:12 PM
ceptorman's Avatar
Quoted: 449 Post(s)
Liked: 709
I think you'll be ok. It might not be a perfect match, but after running some type of Audyssey, I think it will tame down any major imperfections. If you update your towers later, you'll be all set with a match. Let us know how it worked out.
gene4ht and Louis Bartay like this.
650cc on the track
800cc on the snow
post #56631 of 58048 Old 11-16-2018, 08:53 PM
sjm817's Avatar
Quoted: 747 Post(s)
Liked: 298
R-820F is the lower end Best Buy model. The RP280F is the Reference Premier. The mainstream Klipsch enthusiasts line.
https://www.klipsch.com/blog/referen...the-difference
sjm817 is offline
post #56632 of 58048 Old 11-17-2018, 06:55 AM
Liked: 0
280fs it is! I have another questions that touches on a concern I have with klipsch speakers. Now keep in mind, I'm not the most experienced klipsch owner. Stop I could be wrong in my assumption.
In July I upgraded my fluance bookshelves to the R-26Fs which were half off. After testing the speakers on a variety of movies and music I began noticing something. I've never had issues with high volumes in my theater room. But after, sometimes during, sessions with certain parts of movies I get this weird feeling. Not painful, but fairly uncomfortable. Like chewing foil almost, or the feeling after someone scratches a chalk board. It's tiresome...
Is this a klipsch thing? Never experienced this before getting these towers and would hate top purchase the rp280fs only to get more of that. Can anyone help me understand what's going on?
post #56633 of 58048 Old 11-17-2018, 08:38 AM
Carbo's Avatar
Quoted: 291 Post(s)
Liked: 158
Anyone go from a old pair of RF-5 towers to a newer RP8000? How's the difference in sound? Do the newer speakers sound better?
Carbo is online now
post #56634 of 58048 Old 11-17-2018, 08:38 AM
Quoted: 81 Post(s)
Liked: 146
This would be referred to as listening fatigue. It effects some more readily than others and is an issue many folks have with horn loaded speakers. Because horns increase the efficiency of the HF driver as well as narrow the dispersion (compared to a standard dome tweeter) of that driver, they are putting more direct acoustic energy into the listening area while reducing the reflected energy in the listening area. As such they exhibit what some call a "forward" or "aggressive" sound signature. Klipsch have supposedly refined the horns and drivers in the new RP series, but not having heard them, I can't speak to the end result.
If you have manual control of your EQ settings, I'd recommend starting with some 3dB cuts between 1.6 kHz and 4-5 kHz to see if you can pinpoint the frequencies that you find most offensive. Once you find the offending frequency or frequencies, you should be able to tame some of that. YMMV. Not knowing what EQ capability you have at your disposal, this could be quite simple to do, or become a bit of a PITA. It's not necessarily a Klipsch thing, but a horn thing. There's no free lunch in audio. Horns provide high efficiency, pattern control and good transients, but that comes with compromises in timbre and voicing. Some horns are better then others. It'll be interesting to see what the new RPs have to offer once they've been on the market for a while and folks start posting opinions on them.
post #56635 of 58048 Old 11-17-2018, 07:23 PM
Mike Ratledge's Avatar
Quoted: 63 Post(s)
Liked: 52
Damn! RP280F's on sale for $383? That is a steal, and I wish I had a spare $766 for another pair...
ceptorman likes this.
Mike Ratledge is offline
post #56636 of 58048 Old 11-18-2018, 04:24 AM
Liked: 1
I found the RP-280FAs for $1000 Pair, what are your guy's thought on this.I'm really considering pulling the trigger on 4x of them for 2k.
Daniel Villegas is offline
post #56637 of 58048 Old 11-18-2018, 08:39 AM
Giak's Avatar
Quoted: 27 Post(s)
Could anyone please tell me what's the difference in terms of sound between RP-260f and the new RP-6000f?
Giak is offline
post #56638 of 58048 Old 11-18-2018, 10:47 AM
mikeSKYsd's Avatar
Liked: 4
Looking to add a center channel speaker with RP-8000F towers (on order). I think this would normally mean go with the RP-504C. I have some decisions to make as far as install and setup. Would the RP-404C be fine with the towers?
The 404 would be about 5 in less in width than the 504, reducing the required width of the center console (not yet on order). However, understand the 404 has less performance than the 504 so looking for more information to help drive the trade off. Thoughts?
mikeSKYsd is offline
post #56639 of 58048 Old 11-20-2018, 09:54 AM
DekPM19's Avatar
Quoted: 187 Post(s)
Liked: 56
Joining the klipsch owners in a few days. I ordered a pair of RP250s for my sides and staying with the 5” driver I ordered a pair of RP-150Ms for my rears. Should by in this Saturday.
Allen
DekPM19 is online now
post #56640 of 58048 Old 11-20-2018, 10:40 AM
vpn75's Avatar
Quoted: 30 Post(s)
Liked: 31
Allen
Nice! I just upgraded from Polk to the RP-250F/RP-250C and have the RP-150Ms on order as well. Also ordered the SVS PB12 NSD sub from the Black Friday sale. Rounding things out with another pair of SVS prime elevations to go to 5.2.4 setup. My HT has never sounded better
AV equipment: Sony XBR65X930E, Denon X4400H, Sony UBP-X800 UHD, ATV 4K, PS4 Pro
5.1.4 Atmos setup: Klipsch RP-250C | RP-250F | RP-150M surrounds |SVS Prime Elevations (x4)
Subwoofers: SVS PB12-NSD |Outlaw LFM1-Plus
Gaming PC: i7 3770K OC 4.2Ghz, 16GB RAM, MSI GTX 1080 Ti Gaming X
vpn75 is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
