Klipsch owner thread - Page 1917 - AVS Forum | Home Theater Discussions And Reviews
 23396Likes
post #57481 of 58063 Old 02-18-2019, 07:00 PM
gene4ht's Avatar
Quoted: 1970 Post(s)
Liked: 2661
Originally Posted by gene4ht View Post
Yes..however, for movie ambient effects found in side surrounds, any differences are likely negligible
Yep agree, I would likely do the same....
https://www.klipsch.com/products/pro...n-wall-speaker
Within the same "line," my assumption is there would be no technological differences...other than adapting the framework to the respective mounting locations.
Originally Posted by velocci View Post
those are expensive. do you think they are worth the money over the Polk Audio RC85i?
@velocci by way of this post, I have asked @darthray to provide a recommended Canadian Klipsch dealer who might be helpful to you. Good luck in your search!
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is online now
post #57482 of 58063 Old 02-18-2019, 07:16 PM
darthray's Avatar
Quoted: 2098 Post(s)
Liked: 2990
Finally found that speaker
Here's a link for the one I found;
https://www.electronicsforless.ca/kl...hite-8536.html
Hope this help a little.
Free shipping in Canada, and in CDN pesos.
Not sure if it is a big discount price, but you know what you pay in advance.
Ray
gene4ht and ceptorman like this.
darthray is offline
post #57483 of 58063 Old 02-18-2019, 07:18 PM
gene4ht's Avatar
Liked: 2661
Ray
Thanks Ray...very much appreciated!
darthray and ceptorman like this.
post #57484 of 58063 Old 02-18-2019, 07:24 PM
darthray's Avatar
Liked: 2990
More than welcome Gene, just hope it help the OP for reputable place to buy on line.
Ray
gene4ht likes this.
darthray is offline
post #57485 of 58063 Old 02-18-2019, 08:05 PM
ceptorman's Avatar
Quoted: 449 Post(s)
Liked: 709
It'a a real shame a US Klipsch dealer can't sell to Canada.
gene4ht likes this.
650cc on the track
1000 cc on the street
800cc on the snow
ceptorman is offline
post #57486 of 58063 Old 02-19-2019, 05:24 AM
velocci's Avatar
Quoted: 596 Post(s)
Liked: 42
Ray
Thanks Ray. I seen that site and bought my sub from there. Maybe I'll wait till it goes on sale. I was leaning towards the Polks, but if I can get the Pro180RPW for less, I'd prefer those. Not sure if they are overkill though. I agree that there isn't a lot of content coming from the surrounds and rears, but I do tend to raise their volume by alot and want speakers that can handle it. so I'd rather over spend than under spend and regret it.
gene4ht and darthray like this.
Family Room: Onkyo TX-NR 646 AVR, Polk Audio RtiA3 fronts, Polk Audio CSiA4 center, BIC America F12 sub, Polk Audio RC-65i rears
Basement: Denon AVR-X3400 AVR, Klipsch RP280f fronts, RP450c center, SVS PB-2000 sub, Polk Audio RC-85i rears & surrounds
Www.jvpix.com
velocci is offline
post #57487 of 58063 Old 02-19-2019, 03:02 PM
darthray's Avatar
Liked: 2990
While I would love to provide more help.
I cannot offer any good advise, since I do not follow any of those two brands.
However, since in my life did many upgrades, mostly by rushing into it.
I can say that often, you end-up regretting a purchase. Try to resell-it, and sometime end-up just collecting dust.
My suggestion would be to get the Pro180RPW. Even if it will take you a while longer to get, since these are the ones you really want.
Ray
gene4ht likes this.
darthray is offline
post #57488 of 58063 Old 02-19-2019, 05:49 PM
fa11en's Avatar
Hi All
Moving into a new house in the near future and have a room roughly 480sq feet with 9 foot ceilings. Looking to get new speakers for this area and have looked at the RP-6000F for LR, RP-404C for center and RP-500M for the 2 rears. I currently have a Denon AVR-S510BT that I was hoping to use with these. The receiver lists 70W output per channel. My questions are will this receiver be enough to adequately power these? Also will these selections be "overkill" for a room this size?
fa11en is offline
post #57489 of 58063 Old 02-19-2019, 06:31 PM
velocci's Avatar
Quoted: 596 Post(s)
Liked: 42
Ray
just cause I want them, it doesn't necessarily mean its a smart buy. not sure if the polks can handle the extra volume I will put on them and if it really makes a difference anyways since they only get ambient sounds.
Www.jvpix.com
velocci is offline
post #57490 of 58063 Old 02-19-2019, 06:59 PM
cindernat's Avatar
Quoted: 54 Post(s)
Hi all,
I posted a few pages back and everyone was helpful.
This is what was suggested for my room by the sales guys at the retailer I've been to:
1pr Klipsch RP-6000F Floorstanding Speakers (RRP $2499)
1 x Klipsch RP-504C Centre Speaker (RRP $1599)
1pr Klipsch RP-502S Surround Speakers (RRP $1999)
The installer came out to quote on install today (this is also for projector, cabling, screen, amp, etc).
He actually said that for my room size, shape and seating location, he would instead put floor standers at the back rather than the RP-502S on the side wall in line with seating, because a) it will give a better sound and b) can then angle/move the rear floor speakers if required.
My question is, what is the better match with my fronts?
Klipsch R-820F - earlier series
or
Klipsch RP-5000s which sticks with the same series
The R-820Fs are $200 cheaper (I am in Australia) but it's not a huge saving.
cindernat is offline
post #57491 of 58063 Old 02-19-2019, 07:52 PM
gene4ht's Avatar
Liked: 2661
Hi all, which Klipsch in-wall speakers would go best with my RP-280f? I need 4 of them, two for the surrounds and two for the rears to complete my 7.1 setup. See my signature for my basement HT which is where these would go in. my basement is big so I would be raising the volume on these in-walls so they can keep up with the fronts. I will be using these for mainly movies. Another question is that when I research the top in-wall speakers, the ones that seem to be at the top are using the Polk Audio RC85i. not sure why though. do you think they would be better than the klipsch?
I think you're under the impression that your side and rear surrounds need to "keep up" with the L,C,R's. For movies, this is just not the case as the demands for the side surrounds are significantly less and for the rear surrounds...substantially less. My basement HT is 4800cf and even when approaching reference volume, my inexpensive Atmos speakers rated at 100 watts have no problem "keeping up." I believe the Polk RC85i and the Klipsch R-5800-W II are both rated around 100 watts and more than capable of handling all the surround duties and content you throw at them. Unless you are OCD and/or don't mind spending the $$$, I personally would not even consider the Klipsch Pro-180RPW as it would be overkill and overpriced for the application. My unequivocal choice would be the Klipsch -5800-W II. Spend the extra $$$ elsewhere in your system where it will result in real audible/discernible improvement(s). Again, while engrossed in a movie, you will not be able to distinguish which speaker's surround effects you are listening to. Good luck with your decision!
darthray likes this.
post #57492 of 58063 Old 02-19-2019, 08:09 PM
ceptorman's Avatar
Quoted: 449 Post(s)
Liked: 709
Originally Posted by fa11en View Post
Hi All
That will be a very nice home theater speaker package, and it will definitely not be overkill. I noticed you didn't list any subwoofer. A sub (or two) would definitely help in a room that size. Depending on how loud you like the movies, that Denon should be ok.
650cc on the track
800cc on the snow
post #57493 of 58063 Old 02-20-2019, 09:44 AM
gene4ht's Avatar
Liked: 2661
Hi All
I'm in agreement with ceptorman...a very nice system! And because Klipsch is one of the more efficient speaker brands, the Denon 510 rated at 70wpc will have no problem driving your speakers...even in your very large 4300cf space. Generally speaking, the majority of the time, it only takes 10-20 continuous watts to drive most speakers to normal listening levels...any additional power requirements come into play only when there are large demand peaks or bursts...and these are only momentary.
There is an old adage or conventional wisdom shared in these threads: The greater portion of your budget should be allocated to speakers as speaker technology changes little and holds value very well over time. In contrast, electronics change constantly, often, and looses value quickly. It appears you've made an excellent choice/decisions with the RP-6000F, RP-404C, and RP-500M
Regarding your AVR: It is considered an entry level unit but more than adequate to drive your choosen speakers. There are, however, at least two reasons you may want to consider an upgrade in the future: (1) you decide to go beyond its 5 channel limit to 7, 9, 11, or more channels to accommodate additional speakers for 3D sound...i.e. Atmos/DTS:X/Auro or (2) you want to drive your speakers to "very" loud levels w/o distortion...but this is a different discussion for the appropriate thread.
Lastly, I will once again as I often do, agree with ceptorman! If you're primarily a movie person, a subwoofer is an absolute must and should be your next priority! And if you continue to visit this forum, your future funds are already allocated...you just don't know it yet! Good luck moving forward!
post #57494 of 58063 Old 02-20-2019, 10:39 AM
gene4ht's Avatar
Liked: 2661
Originally Posted by cindernat View Post
Hi all,
or
Firstly, everyone is entitled to an opinion. Your installer may be speaking from a music (multi or all channel) rather than an HT perspective. IMO from an HT perspective, (1) side surrounds have a far greater performance importance than do rear surrounds - it would be a mistake to install rear surrounds in lieu of side surrounds (2) floorstanders "for HT" rear surrounds are an "extreme" overkill (from a performance as well as expense perspective) as there is, relatively speaking, very little content directed to the rears (2) why take up floor real estate for rears when wall speakers will perform equally well (3) no need to reposition rears - they're there just for some subtle ambience cues (4) if floorstanding rears outperformed wall mounted rears, the majority of enthusiasts would have them - I don't recall HToTM or $50,000+ HT's with floorstanding rears. Although I have seen floorstanding rears, most were for bragging rights or just because...because of unlimited budgets...not for performance reasons. Lastly, if funds are unlimited, the funds would be better spent on something that would return more value/performance...i.e.possibly upgrading the PB-2000's to PB-3000's or PB-4000's. As always, YMMV and this is just my .02. Good luck moving forward with your decision!
post #57495 of 58063 Old 02-20-2019, 11:12 AM
Liked: 0
Ultra 2
I've read in posts elsewhere that you can get these substantially discounted. Is there a go to dealer here on the forum people use? Thanks.
n.yoshi is offline
post #57496 of 58063 Old 02-20-2019, 04:12 PM
cindernat's Avatar
Quoted: 54 Post(s)
No - he said this is what he has at home in his home theatre and it 'sounds amazing'.
Real estate is not an issue now that we have the couch 1m from the rear, there's a bunch of empty space back there. We have 9ft ceilings so I think the distance to rear Atmos is ok.
Funds are not unlimited, they are the same price as the RP-502Ss.
Anyway I do appreciate your comments and will have to weigh everything up.
post #57497 of 58063 Old 02-21-2019, 01:56 PM
dbphelps's Avatar
Quoted: 27 Post(s)
Liked: 27
I will add that I completely disagree with gene4ht.
I have RF-82s for the fronts and the rear surrounds (custom setup, not wanting to get into it, but it has NOTHING to do with bragging or overkill, as it "has" to be this way for my setup) and on certain movies (Battleship for example) the rears are very much just as important as any other "floor-level" speaker in a surround setup. I say "floor-level" since it is obvious that ATMOS or "top" speakers are not the same, in that they are very much "ambiance" speakers more than main-content.
I have a pair of RS-42s as side surrounds and I am seriously considering using an extra pair of RF-62s I have for side surrounds. I may just set it up that way to experiment a bit. (I am "stuck" with the RS-42s for now since I have all Ref-IV speakers and I have yet to find a decent pair of Ref-IV RS-52s or RS-62s for a decent price, but I have on hand Ref-IV RB-51s and RB-61s as well so I can experiment a bit). But, honestly, I have not found the RS-42s "lacking" in that they sound great, so experimenting with the RF-62s should be quite interesting.
In certain movies there is an amazing amount of "full-bodied" content in the rear surrounds. John Wick is another such title.
dbphelps is offline
post #57498 of 58063 Old 02-21-2019, 02:16 PM
cindernat's Avatar
Quoted: 54 Post(s)
Thanks for this. So you have a 7.1 (with Atmos) - I will only have 5.1.4 -> do you think it's still ok to have rear floorstanders in that scenario, ie: where there are then no sides at all? Keeping in mind I can place the rear floorstanders anywhere - in the corner, back sides, completely at the back, etc.
My only concern is for when we choose a lounge suite the rear tweeters will need to be above the back of the couch, depending on how high the couch is which is TBA. For a normal couch they definitely would buy for a set of 4 recliners, if they weren't 'reclined' - might be pushing it. Guess I need to take some measurements (I have 2 lounge suites in mind).
Cheers.
post #57499 of 58063 Old 02-21-2019, 03:57 PM
dbphelps's Avatar
Quoted: 27 Post(s)
Liked: 27
Yeah, my setup is a 7.2.4 configuration with 4 ATMOS speakers in-ceiling configured as "top front" and "top rear".
For your config the big issue is blocking the sound coming from the tweeters. That is why for those setups a "non-traditional" setup putting the speakers up higher (which isn't as much of a crime as many make it out to be) would be better. Just don't plan on putting them all the way up at the ceiling. I think that is where a lot of people get less than optimal results, in that they try to hide all the speakers in-ceiling, or they put certain locations up far too high for aesthetic purposes.
Basically, my view is that for a dedicated "space" you try to make it look as "nice" as possible, but it is all function over form for the most part. For a location that is "shared use" such as a high-traffic family room, then it is all about compromises.
For me, mine is a dedicated "space" so it is all about how good it can perform.
cindernat likes this.
dbphelps is offline
post #57500 of 58063 Old 02-21-2019, 06:56 PM
retro124's Avatar
Quoted: 1427 Post(s)
Liked: 1154
What you using as center?
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses, Emotiva XPA-200
Sony XBR65X930E , Oppo 203
Apple 4K TV, Mac mini, Sony UBP-X800, PS3
retro124 is offline
post #57501 of 58063 Old 02-21-2019, 07:24 PM
dbphelps's Avatar
Quoted: 27 Post(s)
Liked: 27
I have a Ref-IV RC-62 as center. The in-ceiling speakers are Monoprice Caliber 8" coaxes. I had a friend bring over a RC-64 and didn't feel the tweeter matched well enough with the RF-82s. If I had RF-7s or RF-83s I would opt for the RC-64 to match them.
The receiver is a Pioneer VSX-LX503 11.2 channel with an Onkyo M-282 2-channel to drive the rear channels. Front left, center, front right, left/right surround and all 4 ATMOS in-ceiling speakers are driven off the VSX-LX503. Wiring is all 14-gauge in-wall Monoprice CL2 wire, with Monster wire for all jumpers between the receiver and wall mounted banana jacks.
I will start a thread for my build, which is pretty unique as I had to build some equipment to make it all happen, but I figure a bunch of pictures really aren't what this thread needs.
dbphelps is offline
post #57502 of 58063 Old 02-22-2019, 11:07 AM
p3trol_h3ad's Avatar
Quoted: 291 Post(s)
Liked: 90
@cindernat - I would definitely go with the towers for the *side* surrounds. They will technically be a little behind you but they're still side surrounds in 5.x.x setup. Since you have the floor space, they'll be easier to position rather than fiddling with angling wall mounts. Also, today's surround sound technology is more aimed at discrete channels, whereas the "surround" bi-pole speakers (which the Klipsch essentially are) are a carry-over from past tech. Especially if you're going for Atmos, I wouldn't use a bi-pole speaker... but it's not like it would ruin anything. Just less ideal.
And to answer your question, you definitely don't want the R-820F.. those are the lower line of speakers. Stick with Reference Premiere. I'd go with the smallest tower possible.. the RP-4000F. Slightly smaller footprint so it won't attract as much attention and they'll be plenty sufficient for surround duty.
cindernat and drh3b like this.
Sony MASTER Series | harman/kardon AVR | Klipsch Reference Premiere | KEF UniQ | PlayStation | Mohu Leaf | Hue Play | MediaLight | logitech Harmony | CyberPower PFC UPS
p3trol_h3ad is offline
post #57503 of 58063 Old 02-22-2019, 01:58 PM
Liked: 0
Surround Upgrade
I am more than ready to upgrade my Klipsch surrounds. I knew the Synergys were my weakest link when I bought them but finance dictated more than I would like to admit. I would like to find 4 RS62's but that is appearing harder than anticipated which leaves RP-250S or RP-502S. The questions are, Would any of these choices not work well with what I got? Should I continue to wait for some RS-62's to appear? A different route altogether?
A: 7.2.2 Yamaha 2070, Klipsch RF-63, RC-64, 4 RB-61, RP-500SA, R-115, RW-12D, RT10D
V: Sony XBR85X900F, Xbox One X
Hempinfool is offline
post #57504 of 58063 Old 02-22-2019, 02:30 PM
Liked: 0
Anyone have a pair of RB-41 II for sale?
Freeagent79 is offline
post #57505 of 58063 Old 02-22-2019, 05:23 PM
Liked: 0
I posted earlier looking for dealer leads. I understand from previous threads Klipsch speakers are priced pretty aggressively. Im getting ready to build a new HT in my new home and leaning heavily towards Klipsch Ultra. If anybody knows dealers who price aggressively shoot me a message. Thanks.
n.yoshi is offline
post #57506 of 58063 Old 02-22-2019, 06:14 PM
cindernat's Avatar
Quoted: 54 Post(s)
Mine is also a dedicated space and fully darkened. The space behind the couch, no one would (or should!) be walking behind there so floor standers should be no issue. I'm with you, function over form, but I'd prefer not to have exposed wiring (and won't in this scenario - wall mounted is a little more tricky as this room is on bottom floor - we have access under house to run wires).
Totally agree. I think the decision is made. I chose the RF-5000s, only because I am hoping the height will be enough to reach over back of couches (need to do some measurements to confirm).
Just need to decide on correct placement of them, should they be at rear or on side toward rear? I'm getting told elsewhere that in a 5.1 system, you have SIDE surrounds and you don't have rear, and rear cannot replace sides.
Thanks for everyone's help.
post #57507 of 58063 Old 02-22-2019, 07:06 PM
Quoted: 97 Post(s)
Liked: 35
I've got RP-260F as surrounds. Great choice to go with towers u 2
asabrag is online now
post #57508 of 58063 Old 02-22-2019, 10:21 PM
Quoted: 46 Post(s)
Hi guys, just got a pair of RP-280FA and RP-250S recently with denon 3300.
Looking for a good center to go with this combination. Initially was planning to go with RP-450C but it is either out of stock or at a similar price to RP-504c. Avoiding the subwoofer as I live in a townhouse. Maybe I will get a small one eventually.
My concern is that I have been reading a lot about the importance of a matching center. So if I go with the updated RP-504C, will that be okay? Or should I stick to finding a 450c, maybe used.
Tanmay Garg is offline
post #57509 of 58063 Old 02-23-2019, 04:41 AM
Liked: 4
Hi,
I recently bought a pair of RP-160M Premier 1 as front speakers in my 5.1 setup. My center and surround speakers are Dali Concept 1. AVR is an old NAD T744.
I am really happy with the new fronts but i noticed my center now is very low compared to the sound effects coming from the fronts. The sound is very unbalanced. I have calibrated all speaker levels to 75db with my SPL and speaker distance, but it still does not sound good.
Could the problem be that my Dali center have a db sensitivity at 91db and the new Klipsch fronts have 96db? Would a new Klipsch center with 96db sensitivity solve this unbalance between fronts and center? Or can I just increase the speaker level on my Dali center with 5db?
I hope someone can help me out. Thanks.
kiddiboy1980 is offline
post #57510 of 58063 Old 02-23-2019, 06:21 AM
LNEWoLF's Avatar
Quoted: 466 Post(s)
Liked: 282
https://www.dolby.com/us/en/guide/su...5-1-setup.html
p3trol_h3ad likes this.
Twin Pioneer AVR Locomotives-Elite SC 97, SC 1222 7.2.4, DOLBY Atmos and DTS X, (Front Pre Out,) JBL Pro Synthesis LS Series Speakers, F L R-LS80, Cen-LS, S L R-LS60, SB L R-LS60, 4 Dolby Atmos Enabled Klipsch R41SA, Twin Klipsch R120SW. Mitz 73740 DLP, Sony UBP-X800, ATV G4, Yamaha ATS 1060 Sound Bar, True Depth Firestorm 2.0 3D Glasses, Harmony Hub with Utlimate 1 Remote, Broadlink RM Pro2, EYE Pad Air, Winegard FL6550A
LNEWoLF is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
