Klipsch owner thread - Page 1933 - AVS Forum | Home Theater Discussions And Reviews
 23535Likes
post #57961 of 58407 Old 06-23-2019, 01:34 AM
drh3b's Avatar
Quoted: 2032 Post(s)
Liked: 4030
Originally Posted by Aqua Man View Post
RP-504C or RP-600C ?
I have RP-280FA fronts and RP-150M Rears
They will both be excellent. Whatever fits your space better.
My World Beating System!
Spoiler!
drh3b is offline
post #57962 of 58407 Old 06-23-2019, 11:10 AM
Quoted: 12 Post(s)
Liked: 6
Which one sounds better though ?
I actually owned a 600C, but returned it and bought a 504C.
I couldn't explain it, but I heard sounds on the 600C that I don't on the 504C. Example, in Bumblebee chapter 2, when the robot dropped Bee on the mountain and he rolled, I heard sounds on the 600C but I don't on the 504C... I wish I kept the 600C longer and compared them ...
I think I need a 604C (if that even exists)
Aqua Man is offline
post #57963 of 58407 Old 06-23-2019, 11:53 AM
sjm817's Avatar
Quoted: 764 Post(s)
Liked: 307
It does...sort of....
https://www.klipsch.com/products/rc-...hannel-speaker
sjm817 is online now
post #57964 of 58407 Old 06-24-2019, 05:29 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6047
HT room is about finished, just have to get wire to the RP502S's.
gene4ht, LennS, jeff1967 and 6 others like this.
XBR65A9G / XBR65A8F / 55R615
DP-UB420 / ATV4K (3) / PS Vue
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #57965 of 58407 Old 06-26-2019, 01:48 PM
eLKuRLy's Avatar
Hello,
I need a center channel recommendation for my bookshelf speakers, RB-5 ii. I did not realize how many options of center channels Klipsch has, but looking for something that will pair with the RB-5's.
I've done a bit a research and seen that people recommend:
r-25c
rp-250c
rc-62ii
Rc-35 (used $100)
I was going to get a used B&W CM Centre but I read about "timbre match" so what do you guys recommend or think.
Receiver is a Marantz NR1506.
eLKuRLy is offline
post #57966 of 58407 Old 06-26-2019, 01:53 PM
drh3b's Avatar
Liked: 4030
Originally Posted by eLKuRLy View Post
Hello,
r-25c
rp-250c
rc-62ii
Don't know for sure, but I would guess the RC-62 II would be the closest match. It's a newer speaker in the same line as yours. With the RP series, the Klipsch sound became a bit mellower, and probably doesn't match particularly well with your speakers.
gene4ht likes this.
Spoiler!
drh3b is offline
post #57967 of 58407 Old 06-26-2019, 07:00 PM
gene4ht's Avatar
Quoted: 1984 Post(s)
Liked: 2681
Hello,
r-25c
rp-250c
rc-62ii
Rc-35 (used $100)
I’m also in agreement with the RC-62. You may want to check out the current sale at Frys for $169.
http://images.frys.com/art/email/062...firmation#set3
drh3b likes this.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is online now
post #57968 of 58407 Old 06-27-2019, 05:47 PM
Warmacblu's Avatar
Quoted: 180 Post(s)
Liked: 85
Hey guys, I am looking for a little bit of advice. I have decided to purchase either:
Klipsch The Sixes
or
Klipsch R-51PM
I was wondering if anyone could give some pros and cons to each. I plan to use them in an office setting and also plan on adding a sub down the line (undecided on 10 inch Klipsch or SVS sub).
Please feel free to ask me any more questions if it would help in your recommendation.
Warmacblu is offline
post #57969 of 58407 Old 06-27-2019, 05:51 PM
mzs22's Avatar
Quoted: 230 Post(s)
Liked: 91
Klipsch The Sixes
or
Klipsch R-51PM
Can't help you with the speaker choice but I would get the svs sub over the klipsch !
CaptinCrunch likes this.
mzs22 is offline
post #57970 of 58407 Old 06-27-2019, 06:30 PM
drh3b's Avatar
Liked: 4030
Klipsch The Sixes
or
Klipsch R-51PM
This is just a guess, but it looks like the Sixes are based on the RP line, and the other is the R line. Without buying both, and sending back the loser, I would get the Sixes. I would also take SVS over Klipsch for the sub, and throw in the RSL Speedwoofer for consideration. It trades in a smaller size over less extension over the SVS which may or may not be important to you in an office situation.
Spoiler!
drh3b is offline
post #57971 of 58407 Old 06-28-2019, 05:03 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6047
Got the speaker cable ran to my new rear surrounds. Was able to fire up Netflix and watch a little Avengers in DD 5.1, gives a more surrounded feeling, like you are in the middle. Can't wait to try it out on some Ultra HD Blu-rays.
drh3b likes this.
post #57972 of 58407 Old 06-28-2019, 10:50 AM
CrossCameron's Avatar
Liked: 0
Hello all,
I am currently using a Yamaha RX-A780 receiver and switched center channels and am having issues hearing dialogue as loudly as I'd like.
My old center channel was a Polk Audio CS20 and I didn't have to turn it up quite as loud to hear dialogue clearly. I switched to a Klipsch RP-504C center and love everything about it except the soft dialogue during 4k blu ray movies.
My question is, someone told me to use Adaptive DRC and it might help so I don't have to crank the volume just to hear the dialogue more clearly? Currently it is set at MAX but someone said to try Minimum/Auto?
Thoughts?
CrossCameron is offline
post #57973 of 58407 Old 06-29-2019, 04:40 AM
Liquid$team's Avatar
Quoted: 222 Post(s)
Liked: 110
Got some ATMOS speakers to install!!!
hollisesco, gadgtfreek and Renatto like this.
Projector:Epson 6050ub Screen:Elite screens manual SRM Pro series 120" TV: Vizio P75f Pre/Pro:Marantz AV7705 Amplifier:Monolith 7x and Emotiva A-700 for ATMOSSpeakers:Klipsch THX8000-L (LCR) R5800 side surrounds, 5650-S rear surrounds Klipsch 5800-C for ATMOSSubwoofers:PSA v1811x2 Bluray Player:Panasonic ub820 Media Streamer:Fire TV cube
Liquid$team is online now
post #57974 of 58407 Old 06-29-2019, 05:55 AM
altpensacola's Avatar
Quoted: 256 Post(s)
Liked: 156
Originally Posted by CrossCameron View Post
Hello all,
Thoughts?
Assuming you have recalibrated everything after the switch?
Music, more music.
altpensacola is offline
post #57975 of 58407 Old 06-29-2019, 10:03 AM
ericuf's Avatar
Quoted: 121 Post(s)
Hi all!
I’m looking at the 402s for side surrounds. Does anyone else use these? Should I use them for back surrounds as well?
ericuf is offline
post #57976 of 58407 Old 06-29-2019, 01:02 PM
Renatto's Avatar
Quoted: 118 Post(s)
Liked: 68
Originally Posted by ericuf View Post
Hi all!
I use the previous bigger model the RP-250S on the side walls. (Earlier used them on the back wall.) On the sides, you can feel much more immersive side moves/sounds, while slightly less back sounds (not so concrete/accurate). When they were on the back wall, the side moves - L/R - wasn't so powerful, while the back sound was good (but not much better than the side wall use). So I prefer the side walls, but it depends your room. I recommend to try both, if you can, but maybe the back wall is not possible for you. (Put them on - the front speakers - boxes, calibrate with the avr, try and then put them to the other position and re-calibrate...)
DOLBY ATMOS 5.2.4 - Yamaha RX-A2080 - Klipsch RP-280F - RP-450C - RP-250S - RP-140SA - R-112SW - LG OLED 55B7 - HiMedia Q30 - Xbox One X SE
Renatto is offline
post #57977 of 58407 Old 06-29-2019, 02:43 PM
ericuf's Avatar
Quoted: 121 Post(s)
Thanks! It’ll be a 7.1 setup. Right now my rear surrounds are the bookshelf Klipsch. But I’m wondering if it would be better to get 4 of the 502s, two for side and two for back. If I read your post correctly, you suggest sticking with monopoles for rear?
ericuf is offline
post #57978 of 58407 Old 06-29-2019, 02:48 PM
ericuf's Avatar
Quoted: 121 Post(s)
And one more - what stands should I get with side speakers like these?
ericuf is offline
post #57979 of 58407 Old 06-29-2019, 03:41 PM
kee68's Avatar
Quoted: 31 Post(s)
Liked: 25
Originally Posted by gadgtfreek View Post
Anyone have a stand recommend (going on HW floors) for the 600M's I am going to use as rear/side surrounds with 500SA's on top?
gadgtfreek I bought 4 stands for my Klipsch RB-75's and did not use the pointed carpet spikes on our hard floors. They are heavy for a speaker stand and not easy to tip over. Here is a link to them. http://www.amazon.com/gp/product/B01...?ie=UTF8&psc=1
Here is the name to search if you wish
Pangea Audio LS300 Speaker Stand - Pair (36 Inch)
gadgtfreek likes this.
kee68 is online now
post #57980 of 58407 Old 06-30-2019, 05:44 AM
Renatto's Avatar
Quoted: 118 Post(s)
Liked: 68
I used only Klipsch WDST speakers - R-14S and now RP-250S - so I don't have monopoles. Most people (and Dolby) recommend monopoles for Atmos systems, while others use bipoles, like the Klipsch WDST speakers. Just to inform You, if you want to upgrade later. These are sealed (402S/502S), so can be wall mounted, like mines (the top is 5 feet high from floor). The monopoles has a reflex port on the back, so you can not wall mounted them, need space between the wall and the speaker. Other thing if a monopole is not enough far from the listener, you will get a direct sound exactly from the speaker, even the sound should come from the side or back... The WDST is dispersed, so this can't be a problem.
You can get 4 of the same (4x 502s/402s or 4x Booshelf), but if you would like to use the 2 bookshelf, I think put them on the rear surrounds, and the new 502/402 on the sides. If the room is not big the 402 should be enough. If the money is not the consern go with the big.
Do You have big space behind the listening position?! Just wondering why you go to 7.1 and not 5.1.2. I never wanted 7.1, so I went to 5.1.2 from 5.1 and then 5.1.4... and I did not regret it.
Renatto is offline
post #57981 of 58407 Old 06-30-2019, 05:47 AM
ericuf's Avatar
Quoted: 121 Post(s)
It will eventually be 7.1.4
Now I’m worried I should have gotten the 402s instead of the bookshelves for the rear surrounds, I have the 600m
ericuf is offline
post #57982 of 58407 Old 06-30-2019, 05:55 AM
Renatto's Avatar
Quoted: 118 Post(s)
Liked: 68
Ohh, I see! I think that's not problem. You can get 4 monopoles or 4 bipoles or 2-2 of them. The more speakers you have the more accurate sound you will get. I don't have space for bookshelfs - 1 feet the speaker and 1 feet away the wall and need a shelf. Wall mounting a speaker is the easiest for me and I don't care/mind if I lose (but maybe not) some accuracy with it. The Atmos/DTS:X is truly amazing.
Renatto is offline
post #57983 of 58407 Old 06-30-2019, 05:58 AM
ericuf's Avatar
Quoted: 121 Post(s)
To be clear, I have two 8000 as fronts, 504c as center and two 600 as rears (for now). Was thinking about 402s as sides.
But if it would be better to return the 600 and get the four 402s, I will, I just don’t know. Once I have the 7.1, the rears will only be about 2-3 ft behind me
ericuf is offline
post #57984 of 58407 Old 06-30-2019, 07:58 AM
Renatto's Avatar
Quoted: 118 Post(s)
Liked: 68
I would go with the 402s to the sides and keep the 600 for rears (and later you can change the places, if you want to try). But if you feel you can get better with 4 same 402s - and have doubts with the 2-2 -, then go for them, can't go wrong. Both will be great, the difference not much and maybe not noticeable.
Renatto is offline
post #57985 of 58407 Old 06-30-2019, 08:03 AM
ericuf's Avatar
Quoted: 121 Post(s)
Perfect. That’s what I’ll do, ordering it all very shortly. Last question - what size speaker stands would you recommend for sides and rears? Thanks so much!
ericuf is offline
post #57986 of 58407 Old 06-30-2019, 08:35 AM
Renatto's Avatar
Quoted: 118 Post(s)
Liked: 68
Sorry, but I can't help, because I don't use stands. I hope someone else can help You. The speakers must between 5-7 feet from floor. Mine is a bit under - the bottom is at 4 feet & the top is at 5 feet - but still good.
Renatto is offline
post #57987 of 58407 Old 06-30-2019, 09:24 AM
sjm817's Avatar
Quoted: 764 Post(s)
Liked: 307
For Atmos (and in general), center of tweeter should be ~ ear height while seated. You want separation from the base and height speakers. Do the math and get stands that would get you close to that. I would do monopoles for sides and rears. In your case, 600 for sides and get another set for the backs. Maybe smaller models since they are so close.
post #57988 of 58407 Old 06-30-2019, 10:31 AM
kee68's Avatar
Quoted: 31 Post(s)
Liked: 25
Look at my post 57979 for a suggestion for stands. I bought these and are made very good and heavy so not easy to tip over.
ericuf likes this.
kee68 is online now
post #57989 of 58407 Old 06-30-2019, 11:21 AM
ericuf's Avatar
Quoted: 121 Post(s)
Thanks! Even though I’ll be sitting super close to sides, you’d say monopole still?
Speakers at ear height or above?
ericuf is offline
post #57990 of 58407 Old 06-30-2019, 11:22 AM
ericuf's Avatar
Quoted: 121 Post(s)
These look great. They seem a bit high though for ear level, no?
ericuf is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
