Klipsch owner thread - Page 1937 - AVS Forum | Home Theater Discussions And Reviews
 23499Likes
post #58081 of 58343 Old 07-25-2019, 02:48 PM
Renatto's Avatar
Quoted: 108 Post(s)
Liked: 63
Originally Posted by sddp View Post
the side surround is about 110 degrees, but if I lower the sides it would have to be way in front of the MLP maybe 80 degrees if I have it right at ear level.
If the surround speaker is too high, you can't feel the separation of the "floor" & "height" effects. It can be a bit higher than ear level, just not the "standard" 2-3 feet above. The side surround should be adjacent to the listening position or a bit behind, so 90'-110' and I'm afraid if it's a bit in front, then you will lose the back effects. A little further back or back wall? (I tried both - sides or back wall; On L/R side walls you will get better/stronger side effects, but less back - not as accurate; On back walls you get better/stronger back effects, but smaller sides - feels mostly L/R moves on the front. I like the side walls more, but now put them back to back wall.)
DOLBY ATMOS 5.2.4 - Yamaha RX-A2080 - Klipsch RP-280F - RP-450C - RP-250S - RP-140SA - R-112SW - LG OLED 55B7 - HiMedia Q30 - Xbox One X SE
Renatto is offline
post #58082 of 58343 Old 07-25-2019, 04:01 PM
sddp's Avatar
Quoted: 316 Post(s)
Liked: 126
I have 4 surrounds and 4 ATMOS. The 4 ATMOS are to dolby specs and I am good with that. 52degreen each one from the MLP.
The back surrounds I can bring down or up very easily of course. But the sides? I can build a fake wall and drop it about 1.5' OR it would not be in Dolby's specified 90-110 and in front of my MLP at 80 degrees and have been pondering this delimma for a year now. Attached pics for what I am up against. Any advice would be appreciated
ID:	2594648   Click image for larger version
EPSON 5040UBE | DENON X6400H | XBOX ONE X\PS4 | EMOTIVA XPA-7 GEN 2 |EMOTIVA XPA-3 GEN 3 | ELITE SCREEN 150" ZEREO EDGE W/LED KIT
9.3.4 SURROUND SYSTEM ALL KLIPSCH | L&R RF-7II | CENTER RC64II |FRONT HEIGHTS 2 x RB-81II | 4 SURROUNDS RS-62II | 4 ATMOS CDT-5800 | SUBS R112SW & 2 x R115SW
VEFXI 3D-BEE DIAMOND (2D TO 3D CONVERTER) | DARBE VISION DVP-5000S | LOGITECH HARMONY 800
sddp is offline
post #58083 of 58343 Old 07-26-2019, 01:37 AM
Renatto's Avatar
Quoted: 108 Post(s)
Liked: 63
I see, not easy. You should try to put them under 5 feet, so lowering them 1.5' from 9' won't be enough (if I understand right). Before build anything, first lower the backs, recalibrate and check the difference. After, lower the sides to the place you could put (80 degrees, in front). Just on boxes yet or else, so around 3-4 feet high. Recalibrate and check > mostly the "back sounds", so they coming from the back. Maybe you will hear everything great, because the rear surrounds, help You out and push the back, but you have to try this, I think.
Finally You can try on the recommended 90-100 to hear the recommended speaker sounding.
I usually used my Front speakers boxes to check placement, but finally I always put them on walls. However many of my friends uses speaker stands, because the "open room" problem, like Yours.
PS: Can't you move the MLP in front a bit to get 90 degrees on the side?
Renatto is offline
post #58084 of 58343 Old 07-26-2019, 03:03 PM
crazepharmacist's Avatar
Quoted: 96 Post(s)
The 4000 - with 4" woofers - is way small for front, I think. (My RP-140SA Atmos speakers have a 4" woofer.) So yes, I vote for the 5000.
RP-4000F: https://f072605def1c9a5ef179-a0bc3fb...-Sheet_v01.pdf
RP-5000F: https://f072605def1c9a5ef179-a0bc3fb...-Sheet_v01.pdf
For movies a subwoofer is a must have.
Ugh, the RP4000's came today. Did a listening to test for an hour with various types of music. They sound incredible, don't get me wrong, but without a subwoofer the low end seems lacking. These are my only real pair of speakers so it's hard to compare but just from watching youtube videos of sound tests from the rp5000f's with headphones, the bass response seems much greater than my 4000's.
May return them to amazon and get the 5000's. I feel bad since I first started out with the r625fa's and returned those after being disappointed. the 4000's are miles better but I think I may trade them in for the 5000's and forgo getting a sub. Am I dick for doing that? I wonder if they are able to just repackage and resell as refurbished. Still must be taking a loss.
And again don't get me wrong. The 4" woofers looks incredibly dinky but they really do pack a punch for their size. I think I'm still left wanting a little though.
crazepharmacist is offline
post #58085 of 58343 Old 07-26-2019, 03:16 PM
HYPURR DBL NKL's Avatar
Quoted: 391 Post(s)
Liked: 449
A good sub would still be recommended. Even the 5000's probably aren't going to dig very deep. I have the older RF-62II's, and while the bass is good on them, they are no match for my sub in the lower frequency range. 👍
gene4ht likes this.
HYPURR DBL NKL is offline
post #58086 of 58343 Old 07-26-2019, 03:45 PM
gene4ht's Avatar
Quoted: 1984 Post(s)
Liked: 2679
IMO and experience, until you have at least 8”-10” drivers, a sub is necessary for music and an absolute must for movies. And no need to feel bad for returning product. Consumers have the right to get the product performance they expect and paid for. Retailers have both the means and margin for reselling/disposing of returned goods.
crazepharmacist likes this.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is online now
post #58087 of 58343 Old 07-26-2019, 10:17 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6027
Cmon man. I had RF7iis and that still couldn’t hang with a sub. Buy a sub.
XBR65A9G / XBR65A8F / 55R615
ATV4K (3) / PS Vue
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #58088 of 58343 Old 07-26-2019, 11:13 PM
Quoted: 96 Post(s)
So now the question is get a sub or get the 5000's and a sub? Would I notice a difference assuming I have a sub if I upgraded to the 5000's or would that sub cancel out any benefit? For both movies and music.
Sent from my Pixel 2 using Tapatalk
post #58089 of 58343 Old 07-27-2019, 12:42 AM
toy4x's Avatar
Quoted: 53 Post(s)
Liked: 38
Recommendations for side surrounds for atmos?
My L shaped couch is located against the side wall. This causes the right side surround to be extremely close. The left side ends up being up being much further..
Would it be better to go with the 500sa above the MLP? Or go with the 402s? (502s are too wide for my placement)
Sent from my SM-N950U using Tapatalk
toy4x is offline
post #58090 of 58343 Old 07-27-2019, 12:45 AM
drh3b's Avatar
Quoted: 2009 Post(s)
Liked: 3913
Get a sub, no matter what speakers you end up with. Towers just can't do justice to blockbuster movies, and while the bigger Klipsch towers will handle most music just fine, a good sub will handle the bottom two octaves even better. I listen mostly to music, and my subs just add a little presence the towers don't have by themselves.
My World Beating System!
Spoiler!
drh3b is offline
post #58091 of 58343 Old 07-27-2019, 01:06 AM
Renatto's Avatar
Quoted: 108 Post(s)
Liked: 63
First get a subwoofer. Maybe you wouldn't notice difference between 4000 & 5000. For music I don't use sub
Renatto is offline
post #58092 of 58343 Old 07-27-2019, 01:13 AM
Renatto's Avatar
Quoted: 108 Post(s)
Liked: 63
Because the close range a WDST speaker like 402 would be better, otherwise the sound/speaker can be localizable (too direct).
toy4x likes this.
Renatto is offline
post #58093 of 58343 Old 07-27-2019, 09:53 PM
Canuck31's Avatar
Quoted: 314 Post(s)
Liked: 53
So I'm looking at a few different brands in my search for a 3.1 setup. I've never owned Klipsch speakers before but I'm wondering if the R-15M bookshelf and the R-25C centre would be a good set for a 3.1 setup. This will be in a bedroom that is 12'x13'x8' in size.
LG 49" UHDTV 49UJ6300; Yamaha RX-V481; Sony UBP-X800 BD Player; Fluance SXHTB speaker set, SVS SB-1000
Canuck31 is offline
post #58094 of 58343 Old 07-28-2019, 06:13 AM
whiteboy714's Avatar
Quoted: 1076 Post(s)
Liked: 335
Who's got the RP600m's and how do you like them. I am considering them against some B&W 606s that I loved because the Klipsch are quite a bit cheaper and the sound was close. But they were tested on two different days so wasn't a side by side.
Samsung 55MU6290 -- Denon X1400h -- Klipsch RP600m -- RP450C -- Micca M-6S 6.5 -- Dual Klipsch RW-10
whiteboy714 is offline
post #58095 of 58343 Old 07-28-2019, 02:31 PM
drh3b's Avatar
Liked: 3913
Buy from Crutchfield, $10 returns if you don't like them.
Spoiler!
drh3b is offline
post #58096 of 58343 Old 07-28-2019, 02:45 PM
Liked: 335
Yeah thats my plan for sure. Love the 60 day period too, plenty of time to really see if they are for me. Just need to keep my two year old away!
drh3b likes this.
post #58097 of 58343 Old 07-28-2019, 04:10 PM
cchunter's Avatar
Quoted: 583 Post(s)
Liked: 853
Don't bother with the 5000s either. The 6000s are best bang for buck and have much more bass.
Sony 75X900E 4K
Marantz SR7011 Parasound Halo A52+
Klipsch RF7II's, RC-64II, RS-62II's, RP500SAs Atmos
SVS Dual SB13 Ultra's
Oppo UDP-203 4K Sony PS4 Pro Panamax 5300PM
cchunter is offline
post #58098 of 58343 Old 07-28-2019, 05:33 PM
gene4ht's Avatar
Liked: 2679
Ugh, the RP4000's came today. Did a listening to test for an hour with various types of music. They sound incredible, don't get me wrong, but without a subwoofer the low end seems lacking.....The 4" woofers looks incredibly dinky but they really do pack a punch for their size. I think I'm still left wanting a little though.
As overwhelmingly noted, experienced enthusiasts all recommend the addition of a sub...regardless of tower driver size. Keep in mind that the larger the tower's drivers, the better the bass performance. However, as also stated, even towers with large drivers are no match/substitute for a true subwoofer to optimize both music and especially movie performance. There is a reason the majority of enthusiasts have subwoofers in their systems. Bottom line...let your budget determine the largest affordable tower + subwoofer.
Renatto and drh3b like this.
post #58099 of 58343 Old 07-28-2019, 08:59 PM
mike1sc's Avatar
Location: SC-GA border & neighbors are just far enough away!
Quoted: 21 Post(s)
You need to add a sub to your layout.....period!
Vizio M70-D3 TV, Denon X4300H AVR w/AC Infinity Fan, Emotiva XPA-3 Gen3 Amp, LG UBK90 4K w/DV, Samsung K8500 4K, Klipsch RP280F (2), RP450C Center, RP250 Surrounds (4), Atmos RP140SA (2), R12SW Subs (2), S-10 Surrounds (using as rear heights) (2), Apple TV 4K, Nvidia Shield 4K, Roku Ultra 4K, Amazon Fire TV Box. Currently running a 9.2.2 setup.
mike1sc is offline
post #58100 of 58343 Old 07-28-2019, 09:06 PM
juanej's Avatar
Quoted: 12 Post(s)
8 got the 6000 and by the price 8m thinking i should've go for the 8000
juanej is offline
post #58101 of 58343 Old 07-28-2019, 10:13 PM
wajeeh2009's Avatar
Appreciate it if anyone could advise me with wall mounts that would fit the RP160M for back surrounds.
Sent from my SM-G960F using Tapatalk
wajeeh2009 is offline
post #58102 of 58343 Old 07-29-2019, 12:56 AM
gene4ht's Avatar
Liked: 2679
This and other similar mounts of this type can be found on Amazon...just ensure the mount is able to extend the RP 160M out from the wall so as not to block the rear port.
https://www.amazon.com/dp/B01N2TM8BQ...xpY2s9dHJ1ZQ==
post #58103 of 58343 Old 07-29-2019, 02:04 AM
Renatto's Avatar
Quoted: 108 Post(s)
Liked: 63
And 1 more thing to use subwoofer: to reproduce the deep frequencies requires high energy from the receiver, so you spare it that way. There is more power left over for the rest, for a more dynamic sound. And that is really needed.
The RP-280F has 2 x 8" and sound quite good, but not as good and as deep as a subwoofer.
gene4ht likes this.
Renatto is offline
post #58104 of 58343 Old 07-29-2019, 04:14 AM
wajeeh2009's Avatar
Rp160m are 12.86" deep..... most of the stands in amazon are less than 11".
Not sure how it will fit & how much it will be able to rotate for adjustment (left/right) without them over hanging alot from the base.
post #58105 of 58343 Old 07-29-2019, 10:52 AM
Shadow5606's Avatar
Building out a dedicated basement home theatre. It's a very small room... 11' wide and maybe 18' deep... Was originally looking @ 8000Fs for the fronts and the 504C as my center. I also have a nice SVS sub with 2 down firing 12s to handle the low end.
I was talking with a friend of mine who works for Klipsch and he suggested with the small room I might actually be ok with the RP-600M as my fronts because the 504C and the SVS sub would be doing so much of the work in a home theatre.
I demoed the 600Ms vs the 8000Fs and the difference was marginal... the 8000Fs seemed more present but I believe to properly A/B test this setup you'd probably have to adjust some other values on the receiver which we could not do in the AV demo room.
On music I was surprised how closely the 600Ms came to the 8000Fs and with a sub thrown in I could barely tell the difference.
What do you guys think about the 600Ms as L/R channels in a small home theater if supported by a very nice sub and center?
Shadow5606 is offline
post #58106 of 58343 Old 07-29-2019, 12:31 PM
Renatto's Avatar
Quoted: 108 Post(s)
Liked: 63
I'm pretty sure the are really good. My room is not much bigger than Yours 13x23, but I picked the "big front", the 280F, the successor of the 8000, simply, because it's a beauty! I love to look at them!
ceptorman likes this.
Renatto is offline
post #58107 of 58343 Old 07-29-2019, 12:38 PM
Liked: 335
Excellent fit on that center!
post #58108 of 58343 Old 07-29-2019, 12:51 PM
Renatto's Avatar
Quoted: 108 Post(s)
Liked: 63
Made for order.
Renatto is offline
post #58109 of 58343 Old 07-30-2019, 01:35 PM
Quoted: 16 Post(s)
Liked: 0
Hello,
I recently grabbed some R-620F towers and love them... but I need some help matching a center channel.
I got an R-52C to match my R-620f and it just sounds so thin and tinny. It matches well on the high end, and upper mids, but there is NOTHING on the lower spectrum.
I tried an RP-400C and that matched beautifully on the lows and mids, but the upper end loses its sharpness and clarity, and leaves a hole in the high end.
I got fed up and put in my R-51M bookshelf as a center. This sort of has the best of both, matches lows, mids, and highs... however, it can't keep up with my R-620f towers, and gets messier at higher volumes and doesn't hold up with the towers, and brings the system down a bit as a whole.
What the heck am I supposed to do to match a decent center with this system? It is supposed to be the R-52C but I don't understand how anyone can use that, it is so flat and tinny that you lose the entire low end, but it seems there are no other good options to match with? The RP sounds great, but I think the tweeter aren't timbre matching or something as it leaves a hole in the high end.
I just ordered an RC-62 II to try... do you think I will run into timbre issues with this?
What else do you recommend? At this point I am almost giving up and just running stereo with phantom center...
(I am also running a BiC PL-200 II sub if that matters...)
calidus is offline
post #58110 of 58343 Old 07-30-2019, 01:48 PM
Liked: 335
Originally Posted by calidus View Post
Hello,
Curious what source material this is with? Isn't the center mostly just dialogue? Or are you doing something like "all channel stereo" or multi channel audio?
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
