Klipsch owner thread - Page 1945 - AVS Forum | Home Theater Discussions And Reviews
 23534Likes
post #58321 of 58407 Old 09-18-2019, 12:31 PM
gene4ht's Avatar
Quoted: 1984 Post(s)
Liked: 2681
Originally Posted by evanft View Post
Anyone have thoughts on this?
Conventional wisdom has always suggested that three identical speakers should be used to ensure accurate timbre matching across the front stage...especially for movies.
Tom Riddle likes this.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is online now
post #58322 of 58407 Old 09-18-2019, 12:33 PM
evanft's Avatar
Quoted: 75 Post(s)
Liked: 35
There's already a mismatch due to the different size and design of the current center vs. the L/R. My thinking would be that the 280F probably isn't that different from the 8000f, and even if it was it would still be closer than the current 450C.
JVC RS-520, Elite Screens 100" AcousticPro UHD electric
Klipsch RP-8000F, RP-450C, 2xRP-240S, 2xRP-402S, 2xSVS PB-1000
Onkyo TX-NR585/HDFury Linker/MiniDSP 2x4 HD
Panasonic UB820/PC/PS3/PS4 Pro/Switch/WiiU/Xbox One X
Logitech Harmony Hub
evanft is offline
post #58323 of 58407 Old 09-18-2019, 12:43 PM
gene4ht's Avatar
Liked: 2681
That’s true. The only real test is actually trying the 280f which is likely to be fine. My previous comment refers to the ideal case.
post #58324 of 58407 Old 09-19-2019, 01:00 AM
LawCPA's Avatar
Quoted: 35 Post(s)
Liked: 35
Finally back in business! Top right sub amp had issues and had waited since 5/28/2019 and finally had my R-115SW amp arrive 8/16/2019 from Klipsch warranty. Great guys. I had the other 3 sub amps replaced a year ago and still going great. The first replacements for the 3 still had issues and failed. These are all good now. Calibrated to reference (75dB for each pair) which is great for headroom as each sub is only at 69dB each. Got both sub 1 & 2 to be -8.5 level in my Denon. Haven’t raised the level yet.
Also I finally have symmetry instead of an iPhone 11 pro max 3 camera array (which I will be owning lol). Next thing is seeing if a projector will fit in between the subs for a huge screen or if they’ll be in the way.
Denon AVR-X4200W (Auro-3D upgrade)
Parasound HCA-1206
Denon DCM-560
Sony UBP-X800
Sony PS4
Apple TV 4K
Samsung UN50KU6300FXZA
2 x Klipsch RP-280F
1 x Klipsch RP-450C
2 x Klipsch RP-250S
4 x Klipsch RP-500SA
4 x Klipsch R-115SW
wilfredent, drh3b and GatoGoat like this.
LawCPA is offline
post #58325 of 58407 Old 09-19-2019, 06:57 AM
whiteboy714's Avatar
Quoted: 1198 Post(s)
Liked: 435
Parasound HCA-1206
Denon DCM-560
Sony UBP-X800
Sony PS4
Apple TV 4K
2 x Klipsch RP-280F
1 x Klipsch RP-450C
2 x Klipsch RP-250S
4 x Klipsch R-115SW
Haha that's crazy. Makes the screen lol tiny!
TCL 65R625 -- Denon X1400h -- Klipsch RP600m -- RP450C -- Micca M-6S 6.5 -- Dual Klipsch RW-10
whiteboy714 is online now
post #58326 of 58407 Old 09-19-2019, 09:46 AM
LawCPA's Avatar
Quoted: 35 Post(s)
Liked: 35
Hahah I know it does. I’m pretty close so the 50in isn’t even that bad tbh. I got the tv a long time ago when it was $550 on a deal for the 4K-tv low end model. Need to dabble in projectors and 3D/4K. Never attempted it before.
LawCPA is offline
post #58327 of 58407 Old 09-19-2019, 10:23 AM
gene4ht's Avatar
Liked: 2681
You'll literally have an "eye opening" immersive experience when you get a chance to "dabble" in projectors...a leap to the next level. A 100+ inch projected image will bring the video in line with the audio you're now experiencing...for example, the visceral stomp of the T-Rex will finally "look" credible and realistic!
Tom Riddle and LawCPA like this.
post #58328 of 58407 Old 09-19-2019, 11:29 AM
LNEWoLF's Avatar
Quoted: 476 Post(s)
Liked: 291
Parasound HCA-1206
Denon DCM-560
Sony UBP-X800
Sony PS4
Apple TV 4K
2 x Klipsch RP-280F
1 x Klipsch RP-450C
2 x Klipsch RP-250S
4 x Klipsch R-115SW
Nice, [email protected]@ks like you may have outgrown your space a little
Twin Pioneer AVR Locomotives-Elite SC 97, SC 1222 7.2.4, DOLBY Atmos and DTS X, (Front Pre Out,) JBL Pro Synthesis LS Series Speakers, F L R-LS80, Cen-LS, S L R-LS60, SB L R-LS60, 4 Dolby Atmos Enabled Klipsch R41SA, Twin Klipsch R120SW. Mitz 73740 DLP, Sony UBP-X800, ATV G4, Yamaha ATS 1060 Sound Bar, True Depth Firestorm 2.0 3D Glasses, Harmony Hub with Utlimate 1 Remote, Broadlink RM Pro2, EYE Pad Air, Winegard FL6550A
LNEWoLF is offline
post #58329 of 58407 Old 09-19-2019, 12:39 PM
LawCPA's Avatar
Quoted: 35 Post(s)
Liked: 35
Oh no it’s not blocking the doorway at all. It’s not evident in that pic. I guess you probably mean the entire wall of speakers lol before pic attached.
Parasound HCA-1206
Denon DCM-560
Sony UBP-X800
Sony PS4
Apple TV 4K
2 x Klipsch RP-280F
1 x Klipsch RP-450C
2 x Klipsch RP-250S
4 x Klipsch R-115SW
GatoGoat likes this.
LawCPA is offline
post #58330 of 58407 Old 09-19-2019, 01:07 PM
Liked: 435
Oh no it’s not blocking the doorway at all. It’s not evident in that pic. I guess you probably mean the entire wall of speakers lol before pic attached. *SNIP*
Parasound HCA-1206
Denon DCM-560
Sony UBP-X800
Sony PS4
Apple TV 4K
2 x Klipsch RP-280F
1 x Klipsch RP-450C
2 x Klipsch RP-250S
4 x Klipsch R-115SW
Do those 250s' blow you away? Or does audessy turn them way down? Seems like they could easily drown out the fronts.
post #58331 of 58407 Old 09-20-2019, 12:01 AM
LawCPA's Avatar
Quoted: 35 Post(s)
Liked: 35
Yes, I love them. Sometimes, depending on the mix, I hear sounds directly behind me which is most impressive imaging since I have no speakers behind the couch. That or it is the reflection off the back wall to me! They blend really well even when I crank it up towards reference. I guess I never thought about it since they’re wide dispersion monopoles and are adjusted really well. I use Audyssey flat (I want to keep the highs unless it is too hardcore like Mad Max!) no dynamic EQ, no other EQ or bass boost. If I want more bass I simply move sub 1+2 in level (pic below) from -8.5 to say -7 for total of 3dB boost or -5.5 for a 6 dB boost.
Since we are speaker geeks, I’ve attached a picture of my level calibration.
LawCPA is offline
post #58332 of 58407 Old 09-20-2019, 02:54 AM
Quoted: 59 Post(s)
Liked: 2
is moving from rp500C to rp504C a worth center upgrade ?
siting 2.5m from a TV
Ahmadss is online now
post #58333 of 58407 Old 09-20-2019, 05:34 AM
Tom Riddle's Avatar
Quoted: 781 Post(s)
Liked: 686
I’m sure it would gain some benefit. The overall tweeter design looks to be identical, so it will sound very similar. With the added woofers, you would have a fuller sound, but it’s hard to say if you would be blown away.
gene4ht likes this.
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7704 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #58334 of 58407 Old 09-20-2019, 05:49 AM
mattg3's Avatar
Quoted: 887 Post(s)
Liked: 309
So I was going to ask if buying an RP8000F for fronts for a room 21 by 11 with seating about 10 ft from the screen and speakers would be overkill and then I see LawCPA and his setup. Still wonder if my condo on the second floor can handle the 8000 even with low to moderate volume? I love the piano black but no other option but the 8000 in this glossy look.
Matt
mattg3 is offline
post #58335 of 58407 Old 09-20-2019, 09:42 AM
Quoted: 59 Post(s)
Liked: 2
so a better upgrade in my case is rp600c or rp504c ?
post #58336 of 58407 Old 09-20-2019, 09:49 AM
Tom Riddle's Avatar
Quoted: 781 Post(s)
Liked: 686
Looks like the same tweeter design in the 600c. My personal opinion is the rp504c would be more of an upgrade.
post #58337 of 58407 Old 09-20-2019, 09:53 AM
Tom Riddle's Avatar
Quoted: 781 Post(s)
Liked: 686
In my opinion, there is no such thing as overkill when it comes to the size of the speaker. It’s really up to your personal preference and how much you want to spend.
gene4ht, mattg3 and LawCPA like this.
post #58338 of 58407 Old 09-20-2019, 10:06 AM
Quoted: 59 Post(s)
Liked: 2
600c has Woofers 6.5 inch compared to to 5.25 inch in 500c
looks i will go with 504c
post #58339 of 58407 Old 09-20-2019, 09:03 PM
LawCPA's Avatar
Quoted: 35 Post(s)
Liked: 35
Judging by my picture in the living room, where would you recommend mounting a projector screen? My concern is me not wanting to have to block the front heights or having to move them as they’re attached to the wall stud. Also, I don’t want the screen to block them even if it is acoustically transparent. Love the look of the attached, but want 4K + 1080p 3D in one.
LawCPA is offline
post #58340 of 58407 Old 09-20-2019, 09:16 PM
LawCPA's Avatar
Quoted: 35 Post(s)
Liked: 35
Hi Matt, I think my room dimensions are about that. I’ve got tons of headroom. I’m not normal, they don’t have medicine that works for me :P I actually had the top left sub in the door way in the corner because of the ridiculous room gain but it wasn’t practical and an eyesore. Two subs were amazing for me but I got good deals over a couple years on those subs and think they’re beautiful. With regards to towers-In a different post I read year or two back, someone regretted not going for the 8 inch woofer. He had crossed over his 6in 260F at 80 Hz, but he still heard distortion for mid range/mid bass when played “loudly”.
Home Theater Gear:
Spoiler!
LawCPA is offline
post #58341 of 58407 Old 09-21-2019, 04:23 AM
rosstg's Avatar
Quoted: 227 Post(s)
Liked: 149
Well I finally put in the effort and mounted my 140sa’s on my ceiling as top middle. What a difference compared to up firing. I reran Audyssey using the app, limited MultiEQ to 300hz, I don’t want EQ messing with midrange and HF. Turned DEQ OFF. Im in audio bliss. I’ll be adding another pair of 140sa behind my sectional.
wilfredent, Renatto and drh3b like this.
OLED65B7P/ OPPO UDP-203/ DENON X4300H/ Klipsch RP 440c/ Klipsch RP 250f/ Klipsch RP 240s x4/ Klipsch RP 140sa/ Dual SVS PB-1000/ SVS SoundPath Isolation System/ Auralex Mopad riser for center channel/
rosstg is offline
post #58342 of 58407 Old 09-21-2019, 07:50 AM
Tom Riddle's Avatar
Quoted: 781 Post(s)
Liked: 686
Home Theater Gear:
Spoiler!
Just one thing to add. If there is distortion in the midrange at high volumes on a 6” woofer, then there certainly would be more on an 8” woofer. Most likely the person who originally posted that did not have the headroom to play at the higher volumes the wanted to achieve. Although Klipsch speakers are highly efficient, driving them towards reference can still be very taxing and distortion can come into play.
post #58343 of 58407 Old 09-21-2019, 08:08 AM
Tom Riddle's Avatar
Quoted: 781 Post(s)
Liked: 686
You could fit a projection screen in there, but it would be on the smaller side - maybe 75 to 80”s max. That’s unless there is another way to configure your room, but I understand how much of a task that is. OLED televisions are becoming cheaper at larger sizes and will provide hdr highlights without the blooming effects that LED does. Of course, they have a significantly lower peak brightness, however, in my experience that doesn’t matter all that much. If you prefer LED, I would look for one that has as many dimming zones possible. The Vizio P series is a great option. If you want to spend more, Sony’s Bravia series is hard to beat - I love mine.
With that said, I prefer the HDR my JVC projector provides over my television any day of the week. Sure, it doesn’t have the peak brightness, but I find it more aesthetically appeasing to my eyes.
gene4ht and LawCPA like this.
post #58344 of 58407 Old 09-21-2019, 03:37 PM
drh3b's Avatar
Quoted: 2032 Post(s)
Liked: 4027
If he was referring to me a coupla years ago, I was powering them with 300 wpc emo amps. The distortion was from being overpowered, we're talking BRRRRAPPP type distortion. It was incredibly loud, and not a shot at the RP-260f, for most people, they would be more than fine. I moved them to the rear, and use RP-280f for both front and side surround. The song that really toasted them was "Rocky Mountain Way" by Joe Walsh.
My World Beating System!
Spoiler!
drh3b is offline
post #58345 of 58407 Old 09-21-2019, 03:52 PM
Tom Riddle's Avatar
Quoted: 781 Post(s)
Liked: 686
Interesting. I’m surprised they were overpowered, honestly. You must have really been putting it to them!
post #58346 of 58407 Old 09-22-2019, 01:28 AM
drh3b's Avatar
Liked: 4027
Oh, I was. I'm pretty sure it was well beyond their specs. Like I said, not a shot at the RP-260f, we're talking stupid loud, and with certain kinds of material. That said, I've never gotten that horrible BRAP sound out of the RP-280f. Distortion, yeah, but again, playing beyond their specs. A normal person in a normal home situation is unlikely to reach their limits. I've had my RP speakers paired up with Rythmik subwoofers, and it's great for both stereo and multi channel music. I rarely watch movies, but they've done great, for those as well.
Spoiler!
drh3b is offline
post #58347 of 58407 Old 09-22-2019, 01:48 AM
LawCPA's Avatar
Quoted: 35 Post(s)
Liked: 35
Hey! Congrats!! I remember us talking about this. Looks great. You get so much more out of front/rear heights. After I played the helicopter demo (Atmos demo disc) I felt the same and was itching for 2 more rear height. I wish the industry would push this placement and alternative. I wouldn’t have known about this or to recommend to anyone if it weren’t for this forum. We automatically think carve up ceiling or upfiring with Atmos but I want to keep my heights and not do in ceiling anymore. If I could just hide my wires! Also, I love Auro-3D and its upmixer and don’t want to lose it. I could keep the AVR at FH/RH instead of TF/TR but I’ll pass. Enjoy, check out 4K Rambo (2008) for lots of height info!
Edit:
What keyhole mounts did you use? Are they in studs?
Edit 2: you just gave me a great idea on how to get large projector screen on my wall....for me use the height middle placement like you (keep front height in AVR for Auro)
Home Theater Gear:
Spoiler!
LawCPA is offline
post #58348 of 58407 Old 09-22-2019, 06:09 AM
rosstg's Avatar
Quoted: 227 Post(s)
Liked: 149
Edit:
Home Theater Gear:
Spoiler!
Thanks! Yeah I’m very happy. I was watching movies all day yesterday. They work so well. I watched Rambo the week before with them upfiring lol. Didn’t sound that good so I popped it on for a minute. Wow! I also watched Daybreakers. Great as well. I’ll have to revisit a lot of titles.
They are actually in the top middle position. I was going to place them right above my head but since I’m adding another pair for the rear I followed Dolby’s guideline.
I used the Omnimount 10.0 from Amazon. They are in my studs and they have a keyhole option.
LawCPA likes this.
rosstg is offline
post #58349 of 58407 Old 09-22-2019, 09:05 AM
Tom Riddle's Avatar
Quoted: 781 Post(s)
Liked: 686
Well, I had surgery this past Wednesday - I’m sure everyone noticed more posts lol. I was finally feeling like getting out of bed and popping in a movie today - I picked Alien UHD! I was so excited, then I hit “Watch a Movie” and everything comes on except my 7704 and my amps. I go to check it and, XPA-5 is good but, the Marantz 7704 and Emotiva XPA-7 have no power. Check every component in the room; A/C, power recline seats, projector, masking screen, subwoofer, other amps, UHD player, TV receiver, XBOX One, and everything is good. So, one of the two components, either the Marantz or Emotiva, must have shorted out the other. I’m guessing the Emotiva, but who knows. I briefly thought it may have been a lightning strike - I live in the greater Houston area and we have had nearly 23”s of rain since last Tuesday, plus my neighbor had his house struck and a lot of stuff fried. But, since everything else is working and there doesn’t seem to be any damage to the house, it couldn’t be that.
I’m sure my speakers are all good but, I have no way to test them! Now I get to have fun with warranty repairs for 2 devices. I’m certainly hoping it doesn’t take too long, but I’ve heard all the stories before. Wish me luck!
post #58350 of 58407 Old 09-22-2019, 11:17 AM
LawCPA's Avatar
Quoted: 35 Post(s)
Liked: 35
That ending scene was insane and the lightning was awesome and LOUD in the top channels. Thanks for that, Klipsch says not to keyhole mount them to ceiling so it deterred me from it but it may be a legal liability thing. I’d like to angle my rears at MLP instead of shooting over my head maybe even do surround rear height (Auro) instead of rear height. I’m currently watching the last two of the four newly Atmos mixed 4K Tim Burton movies (Keaton/Kilmer/Clooney) and they use the heights rather well with an overall good mix.
Well, I had surgery this past Wednesday..... the Marantz 7704 and Emotiva XPA-7 have no power. Check every component in the room;
Hope you have a speedy recovery. Wow terrible luck. I have all my subs and my Parasound into the wall outlets the rest of gear is in a surge protector. I have some battery backups given to me but am worried using them could effect sound quality e.g. if amps can’t pull enough current? I haven’t studied the subject enough.
LawCPA is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
