Klipsch owner thread - Page 1962 - AVS Forum | Home Theater Discussions And Reviews
 23936Likes
post #58831 of 59115 Old 03-22-2020, 03:20 PM
Jarrod2750's Avatar
Quoted: 47 Post(s)
Liked: 30
Originally Posted by itsmyforte View Post
Goop, E6000, or a variation made by that company. You need to rough up the edges with a razor blade where the two pieces meet up. It should last a lifetime if you get a good bond. Don't even attempt to remove the old except for any that may be on the backside of the dustcap.
Sent from my moto z4 using Tapatalk
Check out the glue that is used for woofer refoaming kits. I don’t remember the brand off hand, but have great success with it in the past
Tom Riddle likes this.
Marantz AV8805, Parasound Halo a21, (2)Parasound 2250, Parasound 275, Panamax 5400PM
Klipsch Epic CF3 V1, KV 4, (4) RP250S,(2)RP140S (2)CDT5650
LG Oled 65C8,Oppo 205, Pro-ject 2xperience Classic w/Music Hall speed Control
Cambridge Audio Azur 851N, Harmony Ultimate,(2) SVS SB 3000
Jarrod2750 is offline
post #58832 of 59115 Old 03-23-2020, 05:46 AM
Liked: 1
Thanks guys. Goop is not avaliable in Poland, but I found Zhanlida B6000 . I hope it will work just the same.
Wysłane z mojego CLT-L29 przy użyciu Tapatalka
Rafał Trynkus is offline
post #58833 of 59115 Old 03-29-2020, 02:36 PM
Drew1204's Avatar
Quoted: 110 Post(s)
Liked: 68
Hello everyone,
I am currently thinking about setting up a theater in a room off of the kitchen. It is 15 feet wide x 15 feet deep and 9 ft ceilings.
Planning on going with a 135 inch 16:9 screen.
The issue is I cant decide which speakers to go with.
So far I have decided between the following:
R-5502-W II LCR behind the screen
Klipsch R 5650 S II behind and above the sofa in the wall
VS
Klipsch RP 280F
Klipsch 440C / 450C
Klipsch 240S - surround on stands
How much better are the floor standing speakers listed above vs the in walls? Are there other in walls I should consider that are slightly more expensive but much better? or are the ones I selected really good?
I currently have 280F and 440C in my other room and like them a lot. Would I be happy with having the R-5502-W II in the other room behind the 135 inch screen or be disappointed?
Pricing is pretty similar, so it is more of an aesthetic and clean look vs floor standing towers...
Drew1204 is offline
post #58834 of 59115 Old 03-29-2020, 03:01 PM
Jim McC's Avatar
Quoted: 644 Post(s)
Liked: 181
Generally, how are the Klipsch bookshelf speakers if used for music and home theater ? Are there any good ones for about $300 or less ?
Jim McC is offline
post #58835 of 59115 Old 03-29-2020, 03:30 PM
drh3b's Avatar
Quoted: 2420 Post(s)
Liked: 5329
RP series are very good for both. You might be able to find used or open box RP-150m or the newer RP-500m for about that on ebay.
My Stuff.
Spoiler!
drh3b is offline
post #58836 of 59115 Old 03-29-2020, 07:16 PM
Jim McC's Avatar
Quoted: 644 Post(s)
Liked: 181
Jim McC is offline
post #58837 of 59115 Old 03-31-2020, 08:56 AM
schwock5's Avatar
Quoted: 232 Post(s)
Liked: 81
kind of in a pickle for my surrounds.
i'm building a dedicated theater in my basement (finally) but the width isn't great.
to fit as much seating as possible with room to walk to get to the seats, i can't have my surrounds stick out too far (this takes up the walking space and don't want people walking into them).
i had (still have) RS-35s. the depth is 7.5 inches.
i was considering using in walls to replace them, but don't want to compromise my soundproofing.
i can build backer boxes, but klipsch support said the infinite baffle in walls are really made to use the entire cavity inside the studs.
i also don't know if i'd want to use the RS-35s given atmos is more object oriented now.
any other suggestions? the new RP502 and 402 are really just as deep as the RS-35 (6.5 and 7.5 inches).
anyone have any ideas/thoughts? or is in-wall the only way to go, which preserves the space, and is also more directional instead of wide dispersion for atmos?
how much sound quality will i be losing by building a backer box to preserve the soundproofing?
klipsch said i'd lose low-end, but if using a subwoofer am i losing area that would be cutoff anyway to mid-base/midrange > 80hz?
was looking to use the 5800w-IIs in-wall to replace my surrounds.
the rear surrounds could then use the RS-35s or my old RF-35s depending on space/configuration
EYES: Sony 75z9d
EARS: Klipsch: Front - RF7 | Center - RC7 | Side Surround - RF35 | Rear Surround - RS35
BRAIN: Marantz 8012
FOOD: Oppo BDP 103D: HD and 3D, SACD/CD | Sony UBP‑X700: 4K | Marantz 1975 6300 Turntable (Grado Blue Cartridge)
schwock5 is online now
post #58838 of 59115 Old 03-31-2020, 12:04 PM
Jim McC's Avatar
Quoted: 644 Post(s)
Liked: 181
Has anyone compared the sound of the R-51M to the Sony Core bookshelf speakers ? They would be used for home theater and music.
Jim McC is offline
post #58839 of 59115 Old 03-31-2020, 12:19 PM
Tom Riddle's Avatar
Quoted: 1057 Post(s)
Liked: 1237
You can use bipole of monopole speakers with Atmos - I'm using the RS-62 II's as side surrounds and RS-52 II's as back surrounds (both bipole) that work well. If you have plenty of space to the sides and back where your surrounds will be placed, monopoles would be find (the in wall speakers). If you are closer or you are doing multiple rows of seats, then the bipoles would be better, which you RS-35's are.
Good luck with the build - it's definitely worth it, even though the build process is stressful with all these decisions.
gene4ht likes this.
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7705 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is online now
post #58840 of 59115 Old 04-01-2020, 06:42 AM
WhiskeyJ's Avatar
Quoted: 22 Post(s)
Liked: 24
Have you considered something from the Klipsch THX Ultra2 line. The earlier model was KS-7800 THX and a newer one is PRO-7800S-THX. There also seems to be THX-8000-S. All of thse are 8" woofer and two 1" tweeters for in wall surround use. These are all somewhat more expensive than the Klipsch RP line but may be what you were looking for.
Jack
Pioneer Elite SC-95 / Audiosource 6.2 Tripath (Wide Amp) 9.2.2/11.2 system
JBL 590 (Front), / JBL 590 (Drivers & XO) Center in Klipsch RC-7 Cabinet
Klipsch RS-42 (Side & Rear), Klipsch RVX-42 (Wide), Klipsch RS-25 (Height)
(2) Klipsch RW-10D Subwoofers, Klipsch RP-140SA (Atmos Enabled)
Pioneer Elite BDP-62FD (Blu Ray/SACD/DVD-Audio
WhiskeyJ is offline
post #58841 of 59115 Old 04-01-2020, 07:32 AM
schwock5's Avatar
Quoted: 232 Post(s)
Liked: 81
the problem i have is i DON'T have space tot he sides. to maximize seating and leave area to walk as of irght now i need in-wall, or if i do on-wall then it may compromise seating area.
Also where the wall is that these would be on compared to the lsitening position, i feel like the RS-35 / any RS / RP surround series with a 45 degree angle has the tweeter fiiring too far in front and behind of the listening position. only the woofer would be in line with the listeners since the couch would be slightly in front of where these would go.
in wall 5800 i can angle at the listeners or leave right behind, but both tweeter and woofer would at least be aimed correctly.
Name:	updated layout.JPG
EYES: Sony 75z9d
BRAIN: Marantz 8012
post #58842 of 59115 Old 04-01-2020, 07:33 AM
schwock5's Avatar
Quoted: 232 Post(s)
Liked: 81
Jack
let me check these out!
EYES: Sony 75z9d
BRAIN: Marantz 8012
post #58843 of 59115 Old 04-01-2020, 07:41 AM
schwock5's Avatar
Quoted: 232 Post(s)
Liked: 81
Jack
The THX 8000 L may be what i need?
Seems like these are sealed rather than infinite baffle.
the S line which is dispersion would be the same as my RS-35s and point tweeters away from the listeners, so L would be better if aimable.
Or the regular 5800w II if a backer box doesn't cut off too much low end where the subwoofer would pick it up could be fine but i won't know until it's installed and measured...
EYES: Sony 75z9d
BRAIN: Marantz 8012
post #58844 of 59115 Old 04-01-2020, 08:54 AM
MrKyle's Avatar
Quoted: 180 Post(s)
Liked: 87
I know it doesn't help you right this second but I am just about to have a set of 5800 W IIs installed as my side surrounds and I have a similar non ideal setup where wall mounted side surrounds would be hard to place/have a chance to be run into
Living Room - XBR77A9G / X800M2 / X4500H / ATV4K
Klipsch RF-7 iii - RP-504C - 4x CDT 5650 II - 2x R-5800 W II
2x HSU VTF-15H Mk2 / miniDSP 2x4HD
Bedroom - 65VT30
MrKyle is offline
post #58845 of 59115 Old 04-01-2020, 09:18 AM
schwock5's Avatar
Quoted: 232 Post(s)
Liked: 81
are you building backer boxes for soundproofing?
EYES: Sony 75z9d
BRAIN: Marantz 8012
post #58846 of 59115 Old 04-01-2020, 10:14 AM
MrKyle's Avatar
Quoted: 180 Post(s)
Liked: 87
No backer boxes, one side is an external wall and the other is my home office so I decided not to do them.
Bedroom - 65VT30
MrKyle is offline
post #58847 of 59115 Old 04-01-2020, 10:30 AM
schwock5's Avatar
Quoted: 232 Post(s)
Liked: 81
i ordered the green installation kit to atleast have that in the wall to plan spacing to ensure if i do need it i have it, gonna be a bit before we close it though.
i'm curious after you get it in if you can advise how much sound it's letting through to the next room.
EYES: Sony 75z9d
BRAIN: Marantz 8012
post #58848 of 59115 Old 04-01-2020, 11:15 AM
MrKyle's Avatar
Quoted: 180 Post(s)
Liked: 87
I will let you know! i think I am going to do backer boxes for my in ceiling atmos that I am putting in (CDT 5650)
Bedroom - 65VT30
MrKyle is offline
post #58849 of 59115 Old 04-01-2020, 12:18 PM
schwock5's Avatar
Quoted: 232 Post(s)
Liked: 81
i bought the metal pre-fab ones for the 5800 in-cieling. not sure how well they work, but we'll see when the times comes
MrKyle likes this.
EYES: Sony 75z9d
BRAIN: Marantz 8012
post #58850 of 59115 Old 04-01-2020, 12:42 PM
bigbadbob's Avatar
Quoted: 68 Post(s)
Liked: 35
I used the backer boxes from Klipsch for my 4 - 5800s in-ceiling for my 5800s. Easy installation and soundproofing.
schwock5 likes this.
Klipsch Rocks!
bigbadbob is offline
post #58851 of 59115 Old 04-01-2020, 01:29 PM
schwock5's Avatar
Quoted: 232 Post(s)
Liked: 81
any reason they never made these for the regular in-walls?
EYES: Sony 75z9d
BRAIN: Marantz 8012
post #58852 of 59115 Old 04-01-2020, 03:09 PM
MrKyle's Avatar
Quoted: 180 Post(s)
Liked: 87
was looking at those but we've already done most of the drywall work so I was looking at the Dynamat ones as they can fit into just the cutout for the speaker itself - http://www.dynamat.com/architectural...-home-dynabox/
Bedroom - 65VT30
MrKyle is offline
post #58853 of 59115 Old 04-01-2020, 03:12 PM
Jim McC's Avatar
Quoted: 644 Post(s)
Liked: 181
What do you guys think of the R-51M bookshelf speaker ? I'm wondering how it compares to the Sony Core bookshelf speaker. Any advice would be great.
Jim McC is offline
post #58854 of 59115 Old 04-01-2020, 04:42 PM
Cichlid109's Avatar
Quoted: 332 Post(s)
Liked: 178
Any thoughts good or bad on the Klipsch F-300? I am aware the RP is better its also priced much higher. I just bought the F-300's for 300 while they may not be the latest and greatest I will be using them to replace the Acoustech Pl-89's. I am not worried about bass response since that is well taken care of. So any comments good or bad??
Marantz SR-6013, Klipsch F-300 w/Samson SX-2400's Rear Surrounds: Klipsch F-300 w/Behringer EPX-2800, Atmos: 2 pairs DIYSG Volt 6's w/Behringer Nuke 3000 and EP-2000
SUBS:SI HST-18's 8cuft Dual Opposed cabinet w/ Bossobass A14K, 2 SI DS4's each in 7cuft Sealed cabinet w/ Bossobass IT-8000, 4 Infinity 1262's BOSS mini riser w/ nu6000
Cichlid109 is offline
post #58855 of 59115 Old 04-01-2020, 06:25 PM
Tom Riddle's Avatar
Liked: 1237
Haven’t heard them, but a quick google search reveals some good customer reviews, with most citing that the brightness of previous Synergy speakers has been toned down. You got a good deal on them, so it sounds like you are ready to rock and roll mi wouldn’t give it a second thought if you like the way they sound.
post #58856 of 59115 Old 04-02-2020, 07:48 AM
DAG6371's Avatar
Liked: 0
Hi all, could someone please explain to me the difference between adding front and rear height speakers verses in ceiling Atmos speakers. Will I get the same effect from height speakers?
Sent from my Pixel 4 XL using Tapatalk
Sony Bravia XBR75X940D, XBR65X930D, XBR554X850D
Denon AVR-X7200WA, Klipsch 5.1; R-28F Floorstanding, RP-450C Center, RP-250S Surrounds, R-115SW Subwoofer
Xbox One S, Chromecast Ultra, PlayStation 3, Harmony Elite
DAG6371 is offline
post #58857 of 59115 Old 04-02-2020, 07:56 AM
MrKyle's Avatar
Quoted: 180 Post(s)
Liked: 87
In Ceiling Atmos speakers should give the best feeling of being in the sound "bubble" created by Atmos as they are usually positioned 3-4 ft or so in front of and behind MLP and are truly coming from above you. (a lot of the in ceiling speakers also have tweeters/woofers you can aim at the MLP)
Front/Rear Heights reproduce the height aspect but they are usually significantly farther in front of and behind the MLP and have to be tilted/aimed at the MLP as well.
Typically of the three types of Atmos speakers here is the preference/best sound
#1 - In ceiling
#2 - Front/Rear Heights
#3 - Up-firing Atmos speakers/Modules on your speakers (reflects off the ceiling to simulate Atmos effect)
hope this helps!
Bedroom - 65VT30
MrKyle is offline
post #58858 of 59115 Old 04-02-2020, 08:30 AM
DAG6371's Avatar
Liked: 0
#1 - In ceiling
hope this helps!
Yes, thank you. I have extra speakers to use as front and rear height, but not the cash to invest in in-ceiling and installation right now. So, I'll settle for second best for now. Thanks again.
DAG6371 is offline
post #58859 of 59115 Old 04-03-2020, 05:40 AM
psuKinger's Avatar
Quoted: 1702 Post(s)
Liked: 782
I just joined the club yesterday! Got a pair of RP-600M's delivered last yesterday afternoon. Have them up on monoprice monolith stands, and being driven by an old Onkyo TX-NR809 receiver (135 wpc into 8 ohms; Audyssey XT) down in my secondary (basement) setup.
I'm A-Bing them against the pair of JBL Studio 530's I currently have down there. Audyssey currently has the JBL's room-corrected and crossed into my SVS PB-1000, and I plan to rerun with the Klipsch's sometime this weekend, but for now just trying to A-B them in Pure Direct with no sub and no EQ for a somewhat level playing field...
I've mostly stayed away from Klipsch over the years after having had one or two not-so-great "shouty" experiences at other folks places/setups, but after all the positive reviews and hype online, and the substantial discounted price (25%) on what was already not a particularly expensive piece of gear, and while under quarantine with a lot of time at home, I finally decided to jump in and give them a try... I didn't get much time with them last night (they arrived while I was playing some ball with my son in the backyard, after which I was on Grill duties for dinner, and then bathtime/bedtime routine for my youngest... #DadLife ), but the 20-30 minutes I did get left me *very* impressed and pleased with what I got for the price.
Should make for a very fun weekend of listening and A-B comparing...
Tom Riddle, drh3b and MrKyle like this.
Living Room: Sony x940E; Denon x4400h w/ Marantz MM7055; Ascend Sierra RAAL Tower L/R's and 2EX center, Polk Monitor 35B Rears, Rythmik F25 sub. NVidia Shield, ATV4k, OPPO UDP-203, CCA.
Basement: Samsung PN58B650 & LN-T4065F (x2); Onkyo TX-NR809; Kplisch RP-600m L/R's, SVS PB-1000 sub. NVidia Shield (x2), Windows Desktop, CCA, Pi running Ropieee.
psuKinger is offline
post #58860 of 59115 Old 04-03-2020, 03:07 PM
Quoted: 293 Post(s)
Liked: 206
Crazy Idea For Center Channel Speaker
I have always liked experimenting with my speakers to get that "special sound", at least to me. With things as they are now, I have plenty of time to try different combos.
What I would like to know is if it would make any sense to use 2 RP-600M's as my center channel speaker? What I would do is lay them horizontally with their tops abutting each other. I would connect them using a bi-wire cable. One pair to one speaker and the other pair to the other. Does something like this actually make any sense? I have the speakers on hand and plenty of time to waste so thought I would ask what others thought about doing something like this.
Appreciate any and all input.
As an aside, I like my current speaker set-up but always looking for something that might sound better.
Spoiler!
RetiredandLovingIt is online now
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
