Klipsch owner thread - Page 1965 - AVS Forum | Home Theater Discussions And Reviews
 24025Likes
post #58921 of 59291 Old 04-11-2020, 06:40 PM
joxr's Avatar
Quoted: 122 Post(s)
Liked: 41
Originally Posted by hotbeef View Post
Yup! RC-64III with RF-7III’s
How do you like it ?
hotbeef likes this.
5.2.4
joxr is offline
post #58922 of 59291 Old 04-11-2020, 06:47 PM
hotbeef's Avatar
Quoted: 44 Post(s)
Liked: 58
Excellent! Robust and dynamic, top notch clarity.
hotbeef is online now
post #58923 of 59291 Old 04-11-2020, 06:52 PM
joxr's Avatar
Quoted: 122 Post(s)
Liked: 41
Thanks trying to decide what speaker setup to go with after selling off my svs ultras and have been leaning towards the Klipsch rf7IIIs and the center.
hotbeef likes this.
5.2.4
joxr is offline
post #58924 of 59291 Old 04-11-2020, 07:20 PM
Norske's Avatar
Quoted: 18 Post(s)
[deleted post].
Norske is offline
post #58925 of 59291 Old 04-11-2020, 08:23 PM
Tom Riddle's Avatar
Quoted: 1103 Post(s)
Liked: 1357
Can the RF7-IIIs go to reference levels without distortion ?
Yes, but i would recommend running them off a separate amplifier. I run my RF-7 II’s at reference all the time and they sound quite pleasing.
Routh Family Theater - My Dedicated Home Theater Build - 7.2.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I & TV3612 Subwoofers
Marantz AV7705 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is online now
post #58926 of 59291 Old 04-11-2020, 08:31 PM
Tom Riddle's Avatar
Liked: 1357
Originally Posted by Kothoga View Post
Thanks, I had another VR PC in the rack but it's 1070 died so I went with this wall-mounted one while rebuilding in order to make space in the rack for more amps once I upgrade from the RZ1100 AVR. I routed everything through the wall, the only thing visible is the wireless transmitter cable for the Vive.
You got it, make your way over to the DIY section some time but careful, the rabbit hole is deep. The one from GSG is the V1 version, I'm building two of the 16Hz LFE versions with B&C 21" DS115-4 drivers: https://www.avsforum.com/forum/155-d...tor-index.html GSG also make some excellent 21" DIYs: https://shop.gsgad.com/collections/r...-21-flat-packs
I’m on my second 1070 - the first one just died for some reason. I need to invest in a VR system so I can play Half-Life Alyx. Maybe they will give me Half-Life 3 someday.
Thanks for all the info on the DIY subs! I’m sure I will get to it at some point.
post #58927 of 59291 Old 04-15-2020, 01:46 PM
Liked: 2
I'm another long-time Klipsch owner new to this forum. First Klipsch speakers were a pair of KG4s in the early 1980's. Always loved them. Then in 2002, bought my first 5.1 capable AV Receiver and a set of Klipsch Quintet speakers along with a KSW-12 subwoofer. Great sound there and meanwhile, the old system with the KG4s were in another room and saw less and less use.
Earlier this month, realizing that the 2002 AV Receiver which was not HDMI capable was now doing nothing but audio with a mess of cables directly into the TV to handle video switching, I bought a Yamaha RX-V685. And then it occurred to me with the new receiver 7.1 or 5.1.2 capable, the KG4s sitting doing nothing (but still in great shape), and the front pair of the Quintets in a good spot to be Presence speakers (as Yamaha calls them), to try making the KG4s front main speakers. I realize from what I've read that the KG4s are not a great match with the Quintet but so far, I like the sound but have not really challenged them but haven't watched anything with a more than 5.1 audio track yet). A little testing says the subwoofer is doing a better job with the low end than the KG4s so I have them set as "small" speakers on the AVR so the low-frequency sound goes to the sub.
I am a little concerned about my KG4s being marked as 4 ohm impedance (I've read that over their product life cycle, they were marked as 4, 6, and even 8 ohms - if some were marked as 8 ohm with no actual change, then there should be no issue at all). I never turn the volume way up so I don't think I'll have a problem there and the old receiver driving them (a Yamaha A-520 from the early 80s didn't even have an impedance setting).
Anyway, any comments welcome - either about mixing the KG4s with the Quintet or any possible issues with the KG4s and impedance or anything else.
SanchoPanza likes this.
lstone19 is offline
post #58928 of 59291 Old 04-15-2020, 04:37 PM
altpensacola's Avatar
Quoted: 331 Post(s)
Liked: 201
Once you get into this league the only distortion you have to watch out for is from a (poor) source.
Tom Riddle likes this.
Music, more music.
altpensacola is offline
post #58929 of 59291 Old 04-16-2020, 03:13 PM
Joe879's Avatar
Quoted: 240 Post(s)
Liked: 29
I'm using an rc-7 center channel, but I feel like it doesn't sound like it should for dialogue sometimes I have to rewind a scene due to not understanding what is being said in the film. I've been messing around the my yamaha peq for it but not sure what frequencies to cut or boost, I do also have some room treatments placed in my room. Just looking for some help if possible thanks in advance.
Sent from my SM-N960U using Tapatalk
Joe879 is offline
post #58930 of 59291 Old 04-16-2020, 03:46 PM
nexus99's Avatar
Quoted: 191 Post(s)
Liked: 91
Podcast from a prolific Klipsch fan:
JDM World: https://www.youtube.com/jdmworld
GSG Devastator Build Eminence 21" https://youtu.be/DgtVxjg06to
GSG Full Marty Build: https://youtu.be/-U1deD_0j9c
UM18-22 Sealed Subwoofer Build: https://youtu.be/7ifac8Rh8gk
nexus99 is offline
post #58931 of 59291 Old 04-16-2020, 05:33 PM
Tom Riddle's Avatar
Liked: 1357
Try putting it on top of one of your panels to reduce cabinet resonance from the speaker to the stand. My RC-64 II had a lot of resonance transferring to my stand and I put it on a 2” thick 24”x48” panel and it sounded so crisp and clear after. Also, make sure the tweeter is angled directly at your ear level of MLP and you have plenty of space between it and your wall.
post #58932 of 59291 Old 04-16-2020, 08:35 PM
DCM88's Avatar
Quoted: 49 Post(s)
Liked: 36
Just got my RP-400M speakers today they look amazing and sound amazing I can’t believe how much bass is coming from them with such small drivers can’t wait for the RP-4000F and RP-400C to come also got some R-41M for my atmos speakers
Scars and drh3b like this.
DCM88 is offline
post #58933 of 59291 Old 04-17-2020, 06:50 AM
schwock5's Avatar
Quoted: 240 Post(s)
Liked: 84
I use an RC-7 as well but have never had issues.
What is it paired with? also any sub / what is the cutoff frequency?
My RC-7 is on a media stand, however, since the stand is low and since i wanted the speaker straight on ear level i stacked some furniture pads under it to lift it up and reduce resonance.
kind of like these below, stacked like 4-5 in each corner attached to under the speaker to create resonance reducing "feet" and also you can angle the speaker this way by putting more or less on the front or back to angle as you need it. i've never had any clarity issue.
https://www.amazon.com/Furniture-Sli...131131&sr=8-32
also the speaker sits so the front is flush / right in front of the media stand so there's no refection or bounce off of it.
still researching / looking into cutoff frequency of vocals since ideally i'd like vocals to not be cutoff from the speaker to a sub to see if that makes any issue, but so far i haven't had any issues in my current setup with the standard 80hz cutoff or even slightly lower at 60 or 70hz (the speaker is rated down to 45).
Remember for 2 channel the center isn't being used so the cutoff in a home theater using this speaker also needs to take into account not just vocals from it, so it's a trade-off / fine line, but i think 60-80hz should be fine.
EYES: Sony 75z9d
EARS: Klipsch: Front - RF7 | Center - RC7 | Side Surround - RF35 | Rear Surround - RS35
BRAIN: Marantz 8012
FOOD: Oppo BDP 103D: HD and 3D, SACD/CD | Sony UBP‑X700: 4K | Marantz 1975 6300 Turntable (Grado Blue Cartridge)
schwock5 is online now
post #58934 of 59291 Old 04-18-2020, 06:17 AM
DCM88's Avatar
Quoted: 49 Post(s)
Liked: 36
Anyone have the RP-404C ? I’m thinking of returning my 400C and getting this instead will it be worth the extra 240 or so it would cost over the 400C ?? I have the RP4000f as my left and right channels
DCM88 is offline
post #58935 of 59291 Old 04-19-2020, 11:04 AM
Joe879's Avatar
Quoted: 240 Post(s)
Liked: 29
Its paired with RF-7s, I'm running 4 subs tow monoprice 8inch and two ultimax 15s. I have my rf-7 crossed at 80hz, and my rc-7 at 60hz. My center level is at 0.0db. I might just reset my receiver and re run the auto calibration to see what frequency it tries to apply to the peq for it
Joe879 is offline
post #58936 of 59291 Old 04-19-2020, 11:08 AM
Joe879's Avatar
Quoted: 240 Post(s)
Liked: 29
I have the rc-7 on the floor vertical with a door stopper having it angled towards my ears. Maybe it's just me or maybe it's the content I watch.
Joe879 is offline
post #58937 of 59291 Old 04-19-2020, 05:42 PM
Quoted: 315 Post(s)
Liked: 132
Originally Posted by asabrag View Post
LOL..it seems Im not the only one with Spare time.
I bought a pair of 8000F. I already had a couple of 280F.
I cant tell you how different these sound!
I can not make sense of the difference.
At the beggining I said: it the break inn missing..
Then: I said, thankfully I own an Onkyo that lets me select the Stereo Assign to different speakers.
They sound soo different that I ended up thinking I should have left some crossover or Accu EQ bad...
I finally exchanged the cables (as if no Stereo Assig available).
The difference is still there ...
Bass and Dynamic Sound is non existence in the 8000F compared with the 280F.
Voice clarity is better on the 8000F.
Anyone noted the same??
Originally Posted by DjFreddyD View Post
I recently moved from the 280F's to the RF7III's. The biggest difference I noticed was how the highs/tweeters on the RF7III's are subtle and not harsh, ofcourse the bass response on the RF7's are better as well.
Originally Posted by MrKyle View Post
You mean you like the 280F more than the 8000Fs?
I’ve read that elsewhere and am very interested if that is true as I was looking to either get 280Fs 8000F or maybe save a bit and get RF7 iiis
Yes, that's what I meant
I had the 280F published to sell, but after I received the 8000F I stopped the publication.
I would really like to hear somebody else with the two of them thoug.
I come to clarify things up a little or a lot since Ive made quiet a lot of mistakes comparing the 280F against the 8000F that today's a month since I've got them.
Until today, the difference was still so notorious, I kept thinking: theres something wrong with them.
Last week I exchange the ampa and the cables from one to the other: same result...
I kept comparing since then ising Onkyo's Stereo Assign feature.
Today, at 8pm I couldnt support it anymore: I exchanged the place of the 280s by the place of the 8000F. That was the whole deal. Now the 280Fs are crap and the 8000F are amazing
Tom Riddle and drh3b like this.
asabrag is online now
post #58938 of 59291 Old 04-20-2020, 05:28 AM
Tom Riddle's Avatar
Liked: 1357
Can you set it on a stand? Leaving it on the floor, not matter what you do, will yield the same results. It’s too far away from ear level to put out good sound.
post #58939 of 59291 Old 04-20-2020, 12:42 PM
teetertotter's Avatar
Quoted: 64 Post(s)
Liked: 45
Originally Posted by Jim McC View Post
What do you guys think of the R-51M speakers ? How would you describe the treble ? Would they work well for home theater and music ?
This past FALL, I bought my first Klipsch speakers to replace 8 year old JBL's. I bought the Klipsch R-15M 's and the center R-25C for my small 12 X 8 room. The R-51M has the same specs as the R-15M. The tech at Klipsch said the R-51M is a little better sounding, whatever that meant. I left it at that. The R-15M's were 1/2 price at Best Buy, at the time. The R-25C dialog hearing has been outstanding at all levels, with more help from AVR adjustments, too.
Yes, I use for both OTA, internet, and Directv music. I have no issues and put the AVR on Multichannel mode. Then for HD TV, it is DD surround mode.
That said, I decided to buy the discontinued R-15M and the R-25C and is tied into their 10" subwoofer via AVR. I have been extremely happy with these Klipsch fronts with adjustments via the AVR.
The L/R's tweeters are at ear level angle in towards center listening. The Center Speaker is below the TV screen and angled down at my ears....in my case. The side surrounds are a bit behind my ears with the tweeters 20" above my ears and angled towards my head. I have perfect DD surround and Multichannel, when used.
Tom Riddle, drh3b and asabrag like this.
TV: TCL 55" 4K UHD HDR w ROKU
DENON AVR-S910W, 7.2, HDMI 2.0a, 4K UHD HDR, Upscaling, Atmos, Wi-Fi, etc. [2016]
KLIPSCH: L/R: R-51M - Ctr: RP-400C - Sub: R-100SW - POLK S-20 Surround
SPKR Wire:Windy City Wire - 16ga, 2 Cond, Twisted Pair, Shielded, Jacketed [USA]
HDMI: VANCO - 4K, 18Gbps, 2.0b, Certified --- [AT&T - Directv Sat. & DSL 100Mbps]
teetertotter is offline
post #58940 of 59291 Old 04-22-2020, 12:52 PM
Quoted: 401 Post(s)
Liked: 115
Just got my black ash rf7 iii, I love klipsch so far everything great but they have a lot of
Strong like paint or varnish smell , lots of gassing off
Manoj Mohan is offline
post #58941 of 59291 Old 04-22-2020, 02:26 PM
Quoted: 64 Post(s)
Liked: 45
So, did contact their technical support via their website????
post #58942 of 59291 Old 04-22-2020, 03:01 PM
Quoted: 315 Post(s)
Liked: 132
Hi guys, I just included a pair of RS52II to my set up. I am not very satisfied with its sound.
Does any of you have BOTH the RS52II and RP250S? How would you compare them?
post #58943 of 59291 Old 04-22-2020, 06:31 PM
Quoted: 401 Post(s)
Liked: 115
Can someone mention which center best matches these speakers ? Model number ?
Thanks !
post #58944 of 59291 Old 04-22-2020, 06:52 PM
Tom Riddle's Avatar
Liked: 1357
Thanks !
The RC-64 III is the only acceptable center channel to match with the RF-7 III’s. The center is by and large the most important speaker in your front sound stage (for movies) and it needs to be in the same realm of speakers you are matching it to.
post #58945 of 59291 Old 04-22-2020, 06:52 PM
Quoted: 401 Post(s)
Liked: 115
Awesome thanks I’ll Order that
Btw these speakers rock ! Wow ! Amazing
post #58946 of 59291 Old 04-22-2020, 09:08 PM
DCM88's Avatar
Quoted: 49 Post(s)
Liked: 36
The new RP line is absolutely amazing got all my speakers finally in and I couldn’t be happier everything sounds so good
Tom Riddle, drh3b and MrKyle like this.
DCM88 is offline
post #58947 of 59291 Old 04-22-2020, 09:20 PM
cbatc's Avatar
Quoted: 137 Post(s)
Liked: 60
You might like direct firing or monopolies better. I've got a pair of rs52ii in the closet. I used them for years until I got rb61iis.
cbatc is offline
post #58948 of 59291 Old 04-22-2020, 09:34 PM
Quoted: 315 Post(s)
Liked: 132
I reaaallyyy liked the WDST and the sound from the RP250S. I bought the RS52II blindly believing the sound would be very similar...
I will continue to test them.
post #58949 of 59291 Old 04-22-2020, 10:39 PM
drh3b's Avatar
Quoted: 2477 Post(s)
Liked: 5529
Older Klipsch products will have a brighter sound than the RP series, that's probably what you aren't liking. If you like RP line stuff, I'd probably stay away from other Klipsch speakers with the possible exception of the latest R series, not sure how those sound.
asabrag likes this.
My Stuff.
Spoiler!
drh3b is offline
post #58950 of 59291 Old 04-23-2020, 09:44 AM
whiteboy714's Avatar
Quoted: 1908 Post(s)
Liked: 826
Curious here. If you guys could do one or the other.
5.2 or 3.2.2
I am moving into a new home and don't think I will bother with 5.1 this time, I like it but not sure its worth the effort.
So I am panning to do 3.2, L,C,R and two subs. But I could easily add two height speakers. Anyone ever tried this?
TCL 65R625 -- Denon X3500h -- Klipsch RP600m -- RP450C -- Ascend HTM 200 SE -- Dual Klipsch RW-10
whiteboy714 is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
