Dynaudio Owner's Thread - Page 1267 - AVS Forum | Home Theater Discussions And Reviews
 8453Likes
post #37981 of 43578 Old 03-10-2018, 10:02 PM
Quoted: 47 Post(s)
Originally Posted by Otto J View Post
The Contour 20 has inserts in the bottom of the speaker designed for this purpose.
I have the C20 adapter plate, but mine plates didn't come with any screws.
Looking at the bottom of the C20, the inserts don't seem to be for a bolt or screw type that is obvious to me.
Do you know what type it uses? Are they custom, or a standard size / type I can buy elsewhere?
watchnerd is offline
post #37982 of 43578 Old 03-11-2018, 06:10 AM
callas01's Avatar
Quoted: 1325 Post(s)
Liked: 881
I haven’t seen it the plate but my guess would be M6-1.0 or M8-1.25 bolts. When I bought aftermarket outrigger feet for my Focus 260s to replace the spikes, the threads were metric, easy for me as I work for a fastener company. If I recall they were M6-1.0. In your situation I’d figure they’re the same but quite possibly counter sunk for a cleaner looking finish.
callas01 is online now
post #37983 of 43578 Old 03-11-2018, 06:18 AM
Quoted: 47 Post(s)
No, they're way bigger than that.
The stand does use M6-1 20mm to bolt the top plate to the column, and for the bottom spikes, but the holes in the bottom of the C20 are much larger, like the diameter of a pencil or more.
post #37984 of 43578 Old 03-11-2018, 07:41 AM
callas01's Avatar
Liked: 881
Honestly for what the screws are doing there’s no need for anything larger then an M6, so perhaps they’re using M8s, but that seems like overkill personally. I mean 1 or 2 #10-32 screws would be plenty.
post #37985 of 43578 Old 03-11-2018, 07:41 AM
Spurrier Sucks's Avatar
Quoted: 1086 Post(s)
Liked: 692
I looked at mine and there are "screws" in the bottom. I assume those come out and then are used for the top plate but I'm just guessing.
Spurrier Sucks is offline
post #37986 of 43578 Old 03-11-2018, 08:20 AM
Melting Blaze's Avatar
Originally Posted by Bluvette View Post
The problem is the master is loosing connection with the slave or the Dynaudio connect is loosing connection with the slave. Are you using a Connect??
i dont have a dynaudio connect. i only have a pair of zeo 2 on my desktop.
The slave one, even if it is far away form my pc, sometimes it "pops". the noise comes form the tweeter. the louder the volume the louder the "pop".
Describing the "pop": is an electrical noise, very short, it seems a little like a popping fireplace for this i am calling it "pop".
the wire are all cleaned and inserted well. the speakers are both powered by the same power strip.
i dunno what to do. the previous speakers setup i had here (a cheap logitech one) never "popped".
if i use bluethoot and it doesnt pop can it means that is my audio card?
tnx for help everyone! i am really worried!
Melting Blaze is offline
post #37987 of 43578 Old 03-11-2018, 08:47 AM
drewTT's Avatar
Quoted: 1956 Post(s)
Liked: 2098
I am going to fill my Stand 6 with this stuff. Anyone use this before?
https://www.musicdirect.com/accessor...Speaker-Stands
LG OLED65E8 | Plinius Hiato | Dynaudio Contour 20 | Dynaudio Stand 6 | REL T/9i | PS Audio DirectStream Junior | Furman IT-Reference 15i | Sony PS4 Pro | Synology DS916+ | Apple TV 4K | BDI Mirage | NEEO | Focal Shape 40 | iFi Pro iDSD | iFi Pro iRack | roon
drewTT is offline
post #37988 of 43578 Old 03-11-2018, 09:08 AM
Liked: 692
What's the difference in that and sand? Any benefits?
post #37989 of 43578 Old 03-11-2018, 09:21 AM
KenM10759's Avatar
Quoted: 3216 Post(s)
Liked: 1749
I have used stainless steel finishing (tumbling) media. Because it's a 430 series stainless, it can be picked up with a magnet. Heavier than sand, though that's a wash because sand compacts more. Spills are easier to clean up, and neater to repackage if you need to ship the stands later.
https://www.abbottball.com/steel-finishing-media/
I was quoted $1.00 per pound, minimum 10 lbs. Plus shipping.
KEF R500, R200C, R100, R50, SVS SB2000 sub, NAD T758v3 AVR, Pro-Ject RPM1 TT w/ Ortofon 2M Red, Bluesound Vault2, LG UP875 4K BlueRay, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer. Desktop: NAD M10, KEF LS50, KEF Kube 10b. Guest room: Hafler 200 L-R, KEF reference Model 100 center, KEF iQ10 surrounds, M&K V-90 sub.
KenM10759 is online now
post #37990 of 43578 Old 03-11-2018, 09:58 AM
drewTT's Avatar
Liked: 2098
Probably no benefit besides sand being a mess to work with.
drewTT is offline
post #37991 of 43578 Old 03-11-2018, 11:29 AM
drewTT's Avatar
Liked: 2098
Hurm....my C20 adapter plates didn't come with any screws, can't figure out what kind I need to get.
A4-70 hex bolt cone shaped head.
drewTT is offline
post #37992 of 43578 Old 03-11-2018, 12:56 PM
Quoted: 47 Post(s)
Hopefully this picture will help give some useful info.
1. On the sheet of paper is one of the M6-1.00 20mm screws used to screw the top plate to the column. However, I was wrong -- the spikes are not the same diameter, they're thicker.
2. Although the spikes are meant to go into the bottom plate of the speaker stand, the spike fits properly into the threaded insert on the bottom of the Contour 20, as seen in the photo. However, the instruction sheet doesn't say what the diameter or length of the spike is....
So whatever diameter the spike is, that's the correct diameter for the threaded insert. Maybe M8? Does that look about right for those of you who can eyeball these things?
As for length, shorter than the spike is...
post #37993 of 43578 Old 03-11-2018, 12:58 PM
callas01's Avatar
Liked: 881
Or more commonly called a metric flat head socket cap screw
post #37994 of 43578 Old 03-11-2018, 01:01 PM
Quoted: 47 Post(s)
Awesome!
Do you know what length?
post #37995 of 43578 Old 03-11-2018, 01:08 PM
Quoted: 47 Post(s)
Like this?
https://www.amazon.com/M4-0-70-Butto...4-70+hex&psc=1
post #37996 of 43578 Old 03-11-2018, 01:13 PM
drewTT's Avatar
Liked: 2098
That does not look like my C20 adapter plate.
drewTT is offline
post #37997 of 43578 Old 03-11-2018, 01:13 PM
callas01's Avatar
Liked: 881
https://www.fastenal.com/products/details/M42580025A20000
post #37998 of 43578 Old 03-11-2018, 01:14 PM
Quoted: 47 Post(s)
It's not. That's the bottom of the Contour 20 that the adapter plate screws to.
post #37999 of 43578 Old 03-11-2018, 01:14 PM
drewTT's Avatar
Liked: 2098
Lol, nope. I'll try to take a pic.
drewTT is offline
post #38000 of 43578 Old 03-11-2018, 01:16 PM
Quoted: 47 Post(s)
They don't come out; those are threaded insert to stick screws in.
post #38001 of 43578 Old 03-11-2018, 01:20 PM
Quoted: 47 Post(s)
Pardon my ignorance of fasteners, but is the length also implied by the spec number?
I noticed that one is 25mm.
post #38002 of 43578 Old 03-11-2018, 01:21 PM
Quoted: 47 Post(s)
Do they look like the link callas01 posted? This one:
https://www.fastenal.com/products/de...42580025A20000
post #38003 of 43578 Old 03-11-2018, 01:23 PM
drewTT's Avatar
Liked: 2098
You owe me a beer.
drewTT is offline
post #38004 of 43578 Old 03-11-2018, 01:29 PM
Quoted: 47 Post(s)
You owe me a beer.
Thank you so much!
So it looks like 20 mm in length...
post #38005 of 43578 Old 03-11-2018, 01:42 PM
callas01's Avatar
Liked: 881
You owe me a beer.
Can you confirm the diameter
post #38006 of 43578 Old 03-11-2018, 01:44 PM
drewTT's Avatar
Liked: 2098
Looks to be 7mm, my best nonscientific measurement possible lol.
drewTT is offline
post #38007 of 43578 Old 03-11-2018, 01:47 PM
Quoted: 47 Post(s)
I can confirm that, whatever it is, it's >M6, as the M6 screws will just fall into the threaded insert on the bottom of the Contour 20 because the screw hole is too wide for them.
post #38008 of 43578 Old 03-11-2018, 02:02 PM
callas01's Avatar
Liked: 881
M7 is only popular in India, it’s probably M8 based on what watchnerd just said.
post #38009 of 43578 Old 03-11-2018, 02:53 PM
no quarter's Avatar
Quoted: 1534 Post(s)
Liked: 809
If M6 actually goes in the hole,it will be M8...M7 does not allow enough material for the thread.M6 is the tap drill size for an M8 screw.
5.0-Cary audio cinema 12 , confidence centre, XD 600's,excite 12's, Cary 500.1 monoblock, anthem mca-50,, 65 inch Panasonic 3d plasma, marantz-blueray/sacd/dvd audio,Nordost Heimdall 2 cables
2 channel-Naim Core/NDS/XPSDR/Cary Cinema 12/Anthem MCA 50,power lines,Focal Sopra 1,Teac pd-501 DSD player,Nordost QB-8.Superlumina cables,DC 1. Full Naim Fraim.NDS/XD 600.
no quarter is online now
post #38010 of 43578 Old 03-11-2018, 03:52 PM
Quoted: 47 Post(s)
Originally Posted by no quarter View Post
If M6 actually goes in the hole,it will be M8...M7 does not allow enough material for the thread.M6 is the tap drill sixe for an M8 screw.
Yep, falls right in, stopped only by the width of the head.
How do you guys now this stuff? Are you machinists?
Reply Speakers
Dynaudio , dynaudio confidence , dynaudio contours , Dynaudio Focus Powered Monitor Speakers , Speaker Systems , thereore
