Dynaudio Owner's Thread - Page 1562 - AVS Forum | Home Theater Discussions And Reviews
 10181Likes
post #46831 of 47366 Old 05-22-2020, 06:42 AM
yonson's Avatar
Quoted: 617 Post(s)
Liked: 435
Originally Posted by Garman View Post
DVDs? I sold most of those off once I saw the huge different in quality verses Blu-Ray, not as much of a difference from Blu-Ray to 4K... I use Atmos but it's a 5.1.2 system which is perfect for my size and the Dynaudio inwalls work great with this system. Love Arcam stuff, looks good and made well.
On the Aqua Dac note, definitely a keeper.. The KEF LS50's I am selling as a friend is going to let me try his Elac Vela 403 that have been getting rave reviews. Other than that most of my gear that is not being used is being sold.. Tinkering is a fun part of this hobby but with job situation uncertain not going to spend a ton of money in this hobby right now. Aqua Dac, Microrendu and Audirvana software... no need for a separate box (Streamer) or subscription when I have several high power computer(s) sitting around that I can use effectively to stream my music content. Although I think iTunes (Now Music) Apple screwed this software up royally as the last good copy of that was when they had 10.7... all newer versions are horrible.
I still have quite a few DVD's and the Oppo 205 actually does a really nice job of up-scaling them, however my main focus has always been about the sound and not the picture...
yonson is offline
post #46832 of 47366 Old 05-22-2020, 06:44 AM
yonson's Avatar
Quoted: 617 Post(s)
Liked: 435
Originally Posted by no quarter View Post
How loud do you guys listen to music at normally? I am listening at 65-70 DB’s with the new speakers and I am getting a nice DEEP, full bass...very satisfying at this volume. No subs required at all, best speakers I have ever owned by a mile. I have only used music off my Core so far, tomorrow I will attempt to get the TT running.
In the office with the F260's it's almost always under 75dB and I have to use subs for the bottom end, for the main system it just depends on my mood, last night I had it in the mid 90's for a while, no subs needed with the C4's although occasionally I will turn them on when I want to shake the house...
yonson is offline
post #46833 of 47366 Old 05-22-2020, 07:04 AM
yonson's Avatar
Quoted: 617 Post(s)
Liked: 435
I have the Rega up and running, hey Racetripper maybe you can help me. My phonostage has an adjustable MC resistive loading adjustment. Any idea what the Apheta 2 should be set to ? The options are 10,25,50,100,400,800,1k2,4.7k...
Anyway, it sounds lovely, currently listening to T-Rex and it is set at 400.
Phonostage is on top, power supply underneath.
400 is a bit high since it's rated at 100, I'd give 100 a try.
no quarter likes this.
yonson is offline
post #46834 of 47366 Old 05-22-2020, 07:08 AM
no quarter's Avatar
Quoted: 1930 Post(s)
Liked: 973
Thanks Yonson, yes the administrator on the Naim forum said 100 is a good place to start, that is where I now have it set. I will call the dealer later to see what he recommends.
Nagra,Chord,Naim,Rega RP-10,Peak Consult Incognito
no quarter is offline
post #46835 of 47366 Old 05-22-2020, 07:33 AM
Quoted: 179 Post(s)
Liked: 98
Originally Posted by alobar View Post
Hello
im considering a set of Contour 30s, note not the newer 30is, for a media room and interested in general feedback.
what are people powering them with?
here was my recommendation post in Speakers:[INDENT]
i have a paradigm HT setup with monitor 9s for LR and Monitor 3 Center and Monitor Surround 3s(Martin logan IC65s for the heights and HSU VTF-15H MK2 sub) currently powered by a Denon x3600h.
Personally, I would never buy a $7,500 MSRP speaker pair and drive them with a home audio receiver. The sound quality acheived will only ever be as good as your weakest link. Those speakers deserve proper amplification, and a proper source.
Make Em' Dance is offline
post #46836 of 47366 Old 05-22-2020, 07:37 AM
RaceTripper's Avatar
Quoted: 400 Post(s)
Liked: 374
100 or 400 are probably correct. Try both and see what sounds better. I believe Rega recommends 100 ohms so I would start there. There is no wrong answer that would do any damage. I know someone who maybe had that cartridge. I'll ask what he used.
On my Dynavector rule of thumb says 100 would be correct setting, but on my SuperLine phonostage I'm running 500. I am having a custom Naim load made for 453, which has been recommended by Peter Swain, who did extensive testing of many cartridges on the SuperLine.
Clearaudio Ovation/Universal Dynavector XV-1s
Naim Audio SuperLine/NDX2/XPS DR/NAC-252/SuperCap DR/NAP-300 DR/Fraim
Dynaudio Confidence C2 Platinum (Piano Black) REL R-328 x 2
Naim Audio Uniti Atom, Mu-so Qb2; Dynaudio Audience 52SE (Cherry)
RaceTripper is offline
post #46837 of 47366 Old 05-22-2020, 10:18 AM
drewTT's Avatar
Quoted: 2403 Post(s)
Liked: 2729
Anyone leaving their amps on 24/7? I left mine on for a day and I could swear it sounds a little bit purer. Not a huge difference by any means but interesting. So I looked into my manual and they do recommend leaving it on all the time for best performance. It does pull about 140 watts at idle though. Gets pretty toasty too. Not sure if it is worth the wear.
drewTT is offline
post #46838 of 47366 Old 05-22-2020, 10:28 AM
Quoted: 400 Post(s)
Liked: 374
I leave mine on, but I have Naim and that's the recommendation. If I'm not going to be using it for a while (vacation, etc) or there is a nasty electrical storm I will power it down and unplug everything from the wall.
The Naim aficiandos will say it takes days or weeks for it to fully warm up after powering on, but I think it sounds full on within a record side or two.
Akp2123 likes this.
post #46839 of 47366 Old 05-22-2020, 10:31 AM
drewTT's Avatar
Liked: 2729
Interesting. I can understand a day but days or weeks? That sounds like nonsense.
drewTT is offline
post #46840 of 47366 Old 05-22-2020, 10:32 AM
Quoted: 400 Post(s)
Liked: 374
Is anyone using a Bluesound Powernode 2i with Dyn speakers. It's rated 60 WPC @ 8Ω and I don't see anything said about performance (or stability) at 4Ω. I am thinking about matching one with a pair of Audience 52SE for an office system. It doesn't have to be loud but I would like it to sound pretty good (mostly classical music via Roon). I would love to just get a Naim Atom, but even a used one would be out of my budget.
post #46841 of 47366 Old 05-22-2020, 10:34 AM
Quoted: 400 Post(s)
Liked: 374
If you hang out on the Naim forums long enough, you'll hear stuff that's even more nonsensical. But it's no different from other forums.
My favorite amusement nowadays is to see all the threads about "audiophile" ethernet cables, switches and other networking woo.
post #46842 of 47366 Old 05-22-2020, 10:45 AM
Quoted: 70 Post(s)
Liked: 4
Originally Posted by Make Em' Dance View Post
Originally Posted by ToddDavid View Post
Speaking of volume, how difficult are the X18’️s to blow? If the bass is set to 0 [neutral] and the crossover is at 80, can they play to -5 dB on my older Yamaha HTR 6090 that’️s allegedly rated at 840 total watts?
For one, your receiver is rated at 120 wrms per channel with 2 channels driven (best case scenario). You are probably getting 100 wrms per channel with all channels driven. The more channels you run, the more saturated the power supply gets. That would be at max signal input with the volume knob at max. Don't turn the volume knob past clipping/distortion, and you'll be fine. Your speakers can handle way more CLEAN power than that receiver can deliver.
On another note, don't be fooled by numbers. All power is not created equally.
I believe this Yamaha is allegedly 120 x 7 [840 total watts], not 120 x 2, hence its 40 pound weight. It drives speakers in 5 channel stereo well beyond the clipping point of a newer Marantz 110 x 2 and a high end Onkyo THX of the same age.
ToddDavid is offline
post #46843 of 47366 Old 05-22-2020, 10:46 AM
Spurrier Sucks's Avatar
Quoted: 1162 Post(s)
Liked: 749
Also coming from Naim I leave mine on all the time too.
RaceTripper and Akp2123 like this.
Spurrier Sucks is offline
post #46844 of 47366 Old 05-22-2020, 11:10 AM
Quoted: 179 Post(s)
Liked: 98
You are not understanding. All receiver manufacturers pull these tricks. There are many ways to get higher power numbers on paper. During power testing, they normally run the receiver with only two channels being driven to get a higher power number, and then rate it at that. Therefore, with all 7 channels being driven, the power supply is more saturated, and you get less power. So, just as I said, you are probably getting around 100 watts a channel if you are using all 7 channels of the receiver simultaneously. Nonetheless, you don't have enough power to damage your speakers, and you will never use all the power from the receiver anyways. You also would never hear an audible difference between 100 and 120 watts. In general, doubling your power will only give you a 3db increase with all else being equal. The circuit design, quality, and build of an amplifier means a lot more than the power numbers on a spec sheet.
post #46845 of 47366 Old 05-22-2020, 11:24 AM
Quoted: 70 Post(s)
Liked: 4
i get all that. My point wasn’t to enter a discussion about semantics, respectfully. It was to make sure that an older powerful AVR wouldn’t damage a pair of Dyn bookshelfs at high volume since its not the same clean power of a quality amp.
post #46846 of 47366 Old 05-22-2020, 11:44 AM
Red MC's Avatar
Quoted: 371 Post(s)
Liked: 300
I keep my Simaudio amps on 24/7. They sound better that way. If they've been off for a while, it takes a couple hours for them to sound normal, and sometimes I hear a further improvement the next day. The 2-channel W-5LE idles at 48W and the 5-channel Titan idles at 75W. Neither gets beyond a little warm.
When I put my Class A Luxman in the system, it takes about 20-30 minutes of warmup to sound its best, but I can't leave that on 24/7.
HT: Dynaudio C2, Contour S CX, 2x BM14S, Aperion surrounds, Simaudio Titan, Marantz AV8801, Oppo 103, Linn Majik DS, and a Pioneer Kuro
Stereo: Dynaudio Focus 160, Simaudio W-5 LE or Luxman M-600A, Linn Akurate DSM, 2x Rythmik F12G
Other interests: motorcycling, skiing, being active
Red MC is offline
post #46847 of 47366 Old 05-22-2020, 11:54 AM
Quoted: 349 Post(s)
Liked: 350
I rarely ever turn stereo equipment off, even my pre which is tube. The tubes still last a few years. I've been wasting electricity this way for 25 years or so I guess.
aschen is offline
post #46848 of 47366 Old 05-22-2020, 11:56 AM
drewTT's Avatar
Liked: 2729
Why not the class A Luxman? Heat, power draw?
drewTT is offline
post #46849 of 47366 Old 05-22-2020, 11:59 AM
Garman's Avatar
Quoted: 2111 Post(s)
Liked: 1029
I have used the powernode 2i and the NAD M10, both sounded decent and one is a lot less, if it's an office system the Powernode 2i might do the trick.. I am using a Teac Int. through my computer system so I really didn't need the other 2 units, as the NAD M10 was overkill for my office.
Dynaudio Confidence C2 Platinums (Mocca), Dynaudio Contour 20's (Grey Oak) KEF LS50 (Black), Magnepan 1.7i, Belles VT-01/MB-200s, NAD M10, Hegel, Musical Fidelity and various other good brands.. HT system: Dynaudio SCX Center, Dynaudio In-Walls for Surrounds and Sony VPL-295ES possibly a new Monitor in the future.
Kanso Audio Stand's http://kansoaudiofurniture.com/
Garman is offline
post #46850 of 47366 Old 05-22-2020, 12:03 PM
Quoted: 400 Post(s)
Liked: 374
My dealer is going to loan me their demo Powernode 2i next weekend, so I'll have that Monday to try it out while I work all day in the office.
What speakers have you used with the Powernode?
I could potentially just get a small integrated amp and continue to use my Squeezebox Touch and Arcam rDAC as a Roon endpoint, but I am planning to move that to the living room with the AVR system.
post #46851 of 47366 Old 05-22-2020, 12:18 PM
Red MC's Avatar
Quoted: 371 Post(s)
Liked: 300
Both. It idles at 290W. It's not quite in Pass Labs territory, but it's a space heater.
Red MC is offline
post #46852 of 47366 Old 05-22-2020, 12:20 PM
CDLehner's Avatar
Quoted: 1209 Post(s)
Liked: 3316
what about a used Rega Elex R for under a grand?
EXELLENT Choice. I'm just going to put it out there; so the forum can honestly give you a thumbs up or down.
I might have an MF M2si I'm moving.
No forum debate needed; it'll beat the hell, out of these AVRs.
1 - All The Music In The World > PS Audio Stellar Gain DAC > Dynaudio X14As
2 - All The Music In The World > > Dynaudio EMIT M10s
FS: ARCAM A29 IA
CDLehner is offline
post #46853 of 47366 Old 05-22-2020, 12:29 PM
yonson's Avatar
Quoted: 617 Post(s)
Liked: 435
I leave mine on and playing at a low volume 24/7...
yonson is offline
post #46854 of 47366 Old 05-22-2020, 12:31 PM
CDLehner's Avatar
Liked: 3316
Dane freaks; anyone given Jamo the time of day?
FS: ARCAM A29 IA
CDLehner is offline
post #46855 of 47366 Old 05-22-2020, 01:26 PM
Quoted: 70 Post(s)
Liked: 4
Thanks. Here’s my dilemma: if I’m doing a full 5.1 with Excites [plus Atmos and maybe Auro eventually], will I be wanting to do as much as if not more all channel music listening than 2 channel? ....bc if that’s the case, the money for the integrated amp would be better spent on a 3-5 channel power amp, no?
post #46856 of 47366 Old 05-22-2020, 01:43 PM
CDLehner's Avatar
Liked: 3316
Sure. Your AVR, have pre-outs?
FS: ARCAM A29 IA
CDLehner is offline
post #46857 of 47366 Old 05-22-2020, 01:55 PM
Red MC's Avatar
Quoted: 371 Post(s)
Liked: 300
It's kind of a preference question. Do you like listening to stereo music processed through a surround encoder? Some do, some don't. I don't. Even when I was big into the SACD and DVD-A craze, I usually preferred to listen to the stereo mix than the discrete multichannel mix. So I always put my money into the front L&R channels first and compromise on the rest. But if you like surround processing and prefer to listen to music and watch shows in surround, then it makes sense to invest more equally on all the channels.
Red MC is offline
post #46858 of 47366 Old 05-22-2020, 02:07 PM
Quoted: 70 Post(s)
Liked: 4
Thanks. Here’️s my dilemma: if I’️m doing a full 5.1 with Excites [plus Atmos and maybe Auro eventually], will I be wanting to do as much as if not more all channel music listening than 2 channel? ....bc if that’️s the case, the money for the integrated amp would be better spent on a 3-5 channel power amp, no?
the two that I’m looking at both do. Marantz 6013 or Integra DRX 4.2.
I would just need to know then which 3 or 5 channel amp pairs well in the $800 range.
Would a 3 x 200 for LCR [letting the AVR power the rest] be better than going with a 5 x 120 and letting the AVR power the rears and heights?
post #46859 of 47366 Old 05-22-2020, 02:22 PM
Quoted: 349 Post(s)
Liked: 350
Sounds absurd but the monoprice Monolith multi channel amps are repackaged ATI amps made in California and very high quality for a decent price.
200 watts in a quality amp with earnest ratings is quite a lot for most applications.
aschen is offline
post #46860 of 47366 Old 05-22-2020, 02:29 PM
Quoted: 179 Post(s)
Liked: 98
Let me save you some time and money. If you don't listen to music the way it was intended (2 channel stereo), then just power everything by your receiver.
The reason it is being suggested to power your two main speakers with a quality amplifier is because 2 channel music listening can be highly improved with a quality 2 channel integrated. If you are just listening in surround sound, then adding an additional amp will have limited benefits. All these "home theater" 3 and 5 channel amps are barely better than a quality receiver to begin with.
Garman likes this.
Reply Speakers
Dynaudio , dynaudio confidence , dynaudio contours , Dynaudio Focus Powered Monitor Speakers , Speaker Systems , thereore
