Revel Owners Thread - Page 549 - AVS Forum | Home Theater Discussions And Reviews
 6087Likes
post #16441 of 16933 Old 11-15-2019, 10:06 PM
boblinds's Avatar
Quoted: 35 Post(s)
Liked: 84
Originally Posted by vavan View Post
Does your f208 serial look like sb0009-ag0001278?
I hope "12" doesn't mean that mine were produced 7 years ago
Yeah my numbers do look like that. However, you can probably pin the date down precisely by emailing your serial numbers to Revel customer support here in the US and they could tell you exactly when they were made.
And I don't think 7 years is anything to be concerned about. I've had 25-year-old speakers that have worked brilliantly when I sold them (to a friend) and they're still pumping out the beats.
Best,
Bob
vavan likes this.
boblinds is offline
post #16442 of 16933 Old 11-16-2019, 05:11 AM
youngho's Avatar
Quoted: 24 Post(s)
Liked: 42
Revel F228Be is Stereophile's Loudspeaker of 2019 (https://www.stereophile.com/content/...udspeaker-2019) and Joint 2019 Component of the Year (https://www.stereophile.com/content/...omponents-year)
youngho is offline
post #16443 of 16933 Old 11-16-2019, 08:56 AM
Kal Rubinson's Avatar
Quoted: 1399 Post(s)
Liked: 1354
Originally Posted by boblinds View Post
Hi vavan!!!
Finally getting back to you. My F208s serials are in the 00019XX range and the C208 is in the 00004xx range. The C208 was shipping directly from Revel just a couple weeks ago, so it is the newer speaker. I hope that helps you.
My Studio2s had the manufacture date printed on the shipping cartons.
vavan likes this.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #16444 of 16933 Old 11-17-2019, 12:31 AM
Tanquen's Avatar
Quoted: 149 Post(s)
Liked: 65
Frequency response, why doesn't Revel seem to list it on many of their speakers? I got some in ceiling speakers (C763L) and they don't list it and looking at some subs and even downloading the manual they don't list the frequency response which seems odd.
Tanquen is offline
post #16445 of 16933 Old 11-18-2019, 01:28 AM
Quoted: 179 Post(s)
Liked: 29
Originally Posted by SteveH View Post
Here is one of many examples: DALI's CD's https://www.dali-speakers.com/music/the-dali-cds/ . Click on the C-D and they show what songs are on the disk
https://www.dali-speakers.com/music/...dali-cd-vol-4/ has wrong tidal link pointing to vol.1
Parasound Halo Integrated, Pioneer SC-LX 901, Oppo-205, Revel F208 + Heco Aurora Center 30 + Heco Victa Prime 202, Takstar HF 580
vavan is offline
post #16446 of 16933 Old 11-18-2019, 03:23 AM
bear123's Avatar
Quoted: 2941 Post(s)
Liked: 4485
Originally Posted by Tanquen View Post
Frequency response, why doesn't Revel seem to listen on many of their speakers? I got some in ceiling speakers (C763L) and they don't list it and looking at some subs and even downloading the manual they don't list the frequency response which seems odd.
That does seem a bit odd. Luckily, there is a 3rd party site that lists Spinorama data for most Revel speakers although this is not provided directly by Revel. Seems like Revel needs one person capable of making such a decision to assign someone to adding links to the website with spins for each speaker. They have them, embrace the science wholeheartedly(almost), and wouldn't be that much work to do it.
Even if they "buried" the spins into a white paper for each speaker so that only those truly interested would get to them, rather than confuse the average consumer with TMI they don't understand.
bear123 is online now
post #16447 of 16933 Old 11-18-2019, 04:54 AM
blSwagger's Avatar
Quoted: 157 Post(s)
Liked: 90
I think someone posted the frequency response for the in-ceiling speakers several months ago. It's buried in hard-to-find pdf somewhere in cyber space. Rex has recommended crossing them over between 120-140hz, although the specs page lists 80hz +/- 3db.
blSwagger is offline
post #16448 of 16933 Old 11-18-2019, 07:43 AM
Tanquen's Avatar
Quoted: 149 Post(s)
Liked: 65
Even the powered subs make it look like you're just picking a size. Like there is no difference between them. ???
B112V2/B110V2
Type: Powered subwoofer
Low-frequency transducer: Coated paper/pulp cone (12" – B112V2; 10" – B110V2) with 50mm two-layer copper
voice coil, vented ceramic 5 magnet assembly and vented die-cast aluminum frame
Amplifier power: 1,000 watts (RMS), 2,000 watts (peak)
Input sensitivity/impedance: 400mV (full power)/20k ohms (balanced); 14k ohms (unbalanced)
Crossover frequency: 50Hz – 150Hz low-pass filter with LFE bypass
Enclosure type: Sealed
Inputs: Balanced (XLR); unbalanced (RCA)
Available finishes: High-gloss walnut, black and white
Dimensions (H x W x D):
B112V2:
B110V2:
18-7/16" x 15-15/16" x 16-9/16" (468mm x 404mm x 420mm), with grille
16-7/8" x 14-5/16" x 13-7/16" (428mm x 364mm x 342mm), with grille
Weight:
B112V2:
B110V2:
64.8 lb (29.4kg)
53.8 lb (24.4kg)
Tanquen is offline
post #16449 of 16933 Old 11-18-2019, 12:52 PM
Quoted: 179 Post(s)
Liked: 29
There is no mfd on my boxes but Harman support told me that mine were manufactured in 2016
Sent from my Mi Note 3 using Tapatalk
vavan is offline
post #16450 of 16933 Old 11-18-2019, 07:42 PM
LPMM's Avatar
My pair of F36 and matching C25 center channel arrived today. Piano gloss black.
Congrats! I know you received them recently, but have you had time to listen to them? My local dealer is having a buy one get one sale on Revel and I am thinking of picking up a pair of F36s for HT duties.
yanks1 likes this.
LPMM is offline
post #16451 of 16933 Old 11-18-2019, 08:39 PM
Bill-99's Avatar
Quoted: 940 Post(s)
Liked: 609
Is that for the entire revel line? That'd be a heck of a deal!
Sent from my Pixel 2 using Tapatalk
5.1.0 Main System: Anthem AVM 60 | Anthem Statement A5 | Revel F208s, C208, M106s | Velodyne FSR-12 | Samsung UN65KS800DF | Oppo UDP-203 | Roku Premiere+ | DIY HTPC | Logitech Harmony Companion | Amazon Echo Dot
Bill-99 is offline
post #16452 of 16933 Old 11-19-2019, 03:39 AM
bear123's Avatar
Liked: 4485
Early impressions are that I really like them so far, but, I like to take my time in making a definitive stance. I don't want to succumb to the "my shiny new toys are the bestest ever in the history of the world" syndrome. It's easy to be kind of excited about our new stuff, so I like to take my time, be objective as possible, listen to a large variety of music over time while really listening and paying attention. Also experimenting a lot with multi channel listening. In real world use(not sitting with my head in a vice in the perfect MLP), using the center channel certainly locks vocals and such down in the center better than stereo, and the ambiance and envelopment of using all 5 channels is certainly very different.
I haven't done movies extensively on them yet, so I can't report much here. I did watch The Elephant Queen(Apple TV documentary) and the sound was great....vocals through the center seemed very clear and natural.
As long as they will meet your output needs, if your getting F36 for half MSRP brand new, its a no brainer. If you are 12'+ away and want reference level playback, I don't think they are the right choice. I need more time with mine to determine if they fully meet my needs for home theater. However, I decided I was willing to give up a little bit of home theater capability to gain some benefits for music I was after.
I do think they sound very good with music so far.
post #16453 of 16933 Old 11-19-2019, 07:10 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 2008 Post(s)
Liked: 2482
Hmm, that could motivate me to buy another pair of Salon 2's. LOL
gsr is offline
post #16454 of 16933 Old 11-19-2019, 07:49 AM
LPMM's Avatar
They have one big sale a year and this year has me tempted to pick up a pair of speakers. I am perfectly happy with my B&W 805S for music listening but now that I have just turned a room into a more HT based room, I feel that “better” speakers for movie viewing may be in order. So far, the announced deal is for the F12, F35, F36, F206, or Studio2.
Thanks for the feedback. My sitting position is about 12’ and I am willing to give up some music capability for more HT benefits. My local dealer has the F35s setup in a listening room and I liked them, I can only assume that the F36 would be better.
LPMM is offline
post #16455 of 16933 Old 11-19-2019, 09:55 AM
Oppo Beta Group
RichB's Avatar
Quoted: 2052 Post(s)
Liked: 1483
If you need to buy a set of pairs, I'll take one pair
- Rich
Oppo UPD-205 x 2 | UPD-203 | Sonica DAC | Emotiva RMC-1 | Revel Salon2s, Voice2, Studio2s | Benchmark AHB2 x 5 | ATI AT522NC | Velodyne HGS-15 | LG 77C9 | Lumagen 2020 | HDFury Vertex2 x 2
RichB is offline
post #16456 of 16933 Old 11-19-2019, 03:10 PM
Super Moderator
teachsac's Avatar
Quoted: 1310 Post(s)
Liked: 2139
Posts removed. Please stick to discussion of speakers.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #16457 of 16933 Old 11-20-2019, 12:27 AM
mmiles's Avatar
Quoted: 1064 Post(s)
Liked: 551
That certainly is interesting. Is this for new orders or just existing stock and floor demos?
Do you have to buy other associate items at MSRP in order to get the BOGO?
How long is the sale last?
Most importantly where are you located?
Mike Miles
[email protected]
mmiles is offline
post #16458 of 16933 Old 11-20-2019, 12:31 AM
mmiles's Avatar
Liked: 551
When was the F208 and C208 released?
Mike Miles
[email protected]
mmiles is offline
post #16459 of 16933 Old 11-20-2019, 12:39 AM
Quoted: 179 Post(s)
Liked: 29
here's what harman cs told me: "The Performa3 F208 was introduced in 2013 and is still our current speaker models"
vavan is offline
post #16460 of 16933 Old 11-20-2019, 01:03 AM
Liked: 0
Help me identify these home audio, i dont have any other pictures or any other information
Cuttsa01 is offline
post #16461 of 16933 Old 11-20-2019, 06:15 AM
Quoted: 179 Post(s)
Liked: 29
and they responded with "Thank you for bringing it to our attention – our webmaster will fix the link"
vavan is offline
post #16462 of 16933 Old 11-23-2019, 07:25 AM
steven59's Avatar
Quoted: 240 Post(s)
Liked: 117
$25. Goodwill write off
Meetloaf13 likes this.
Meridian dsp8000se upgrade, Vienna acoustics Beethoven's, Hegel H360, Roon Nucleus, Rega jupiter cd, Revox s26 tuner,
steven59 is offline
post #16463 of 16933 Old 11-24-2019, 12:00 PM
mmiles's Avatar
Liked: 551
Look on the back where the speaker connectors are located.
Mike Miles
[email protected]
mmiles is offline
post #16464 of 16933 Old 11-24-2019, 06:25 PM
Molon_Labe's Avatar
Quoted: 3544 Post(s)
Liked: 4294
Damn! You have two separate speakers that match your flooring perfectly - well done! Call me nostalgic, but I so dig retro speakers and their looks.
Molon_Labe is offline
post #16465 of 16933 Old 11-25-2019, 11:23 AM
Quoted: 1179 Post(s)
Liked: 1401
F208/F206 comparison
Just got in a pair of F206's for rear surrounds to go with my F208's and C208. I thought it might help folks to see the size comparison. I used my Lexicon MC-10 to play stereo music to the rear channels only and kept cranking up the volume expecting to see clip lights on my Bryston 3B SST2. I couldn't get it to happen before it was way too loud and didn't want to put in ear plugs just to see clip lights flash. The F206s are small but mighty, amazingly powerful speakers for their size. Mine have to be close to the rear wall but that makes them sound huge. When I get subs and run Dirac I expect the low end in my room to be very powerful and extended.
ID:	2645516   Click image for larger version
ID:	2645518   Click image for larger version
ID:	2645520   Click image for larger version
ID:	2645534   Click image for larger version
DS-21, DonH50, jima4a and 3 others like this.
Rex Anderson is offline
post #16466 of 16933 Old 11-25-2019, 12:33 PM
Quoted: 179 Post(s)
Liked: 29
Originally Posted by Rex Anderson View Post
Just got in a pair of F206's for rear surrounds to go with my F208's and C208. I thought it might help folks to see the size comparison. I used my Lexicon MC-10 to play stereo music to the rear channels only and kept cranking up the volume expecting to see clip lights on my Bryston 3B SST2. I couldn't get it to happen before it was way too loud and didn't want to put in ear plugs just to see clip lights flash. The F206s are small but mighty, amazingly powerful speakers for their size. They have to be close to the rear wall, that makes them sound huge. When I get subs and run Dirac I expect the low end in my room to be very powerful and extended.
Rex, don't you have your stock spikes attached? Yesterday I tried but was unable to screw those in and am really confused. It looked like the spikes couldn't fit into their places deep enough so I've had to discard the idea. I don't like these spikes anyway as unlike to Polk lsim it's really inconvenient to adjust their height and think whether third-party outriggers worth their money
vavan is offline
post #16467 of 16933 Old 11-25-2019, 01:18 PM
Liked: 1401
I have used the spikes in the past but am not using them now. Not sure why you would be having a problem screwing them in. I didn't have any problems when I used them in a previous house.
post #16468 of 16933 Old 11-25-2019, 02:54 PM
Bill-99's Avatar
Quoted: 940 Post(s)
Liked: 609
It's probably worth checking the screw hole for construction adhesive / debris. That happened with my speakers. I wound up using an allen wrench to work it out.
vavan likes this.
Bill-99 is offline
post #16469 of 16933 Old 11-25-2019, 02:54 PM
SteveH's Avatar
Quoted: 1297 Post(s)
Liked: 1967
I finally took delivery on a pair of F206's (pictured below). I've been traveling a ton and just got back to AZ late last night. An hour ago, the F206's were delivered (see below). I'll give an update on the speaker comparison experiment in the next few days.
Since I didn't have time to re-package up the F228's, I might as well give them another A-B-C comparison. The Salon2's that were pictured earlier are now at their new home. I should mention that my customer is liking his new Salon2's even more than his Magico A3's ($12,300).
Based off of sound quality 1st and size 2nd, my prebias is that the F226Be's will be staying and they have more bottom end and control. We shall see. I needed another pair of speakers in my loft area so I figured I might as well compare them in the same room before I drag them up to the loft. As I mentioned in an earlier post, I've already decided that the F228Be's won't be staying. More to follow in the next several days.
Name:	20191125_122328 (002).jpg
Varejao17 likes this.
Steve (Owner) Sound Video
SteveH is offline
post #16470 of 16933 Old 11-25-2019, 04:17 PM
Liked: 1354
I've had a fair number of Revels shipped to me in the past year and I have had this issue with a few. For those, I purchased an appropriate thread flat-bottom tap to clean out the threads in the speaker.
vavan likes this.
Kal Rubinson
Reply Speakers
c426be , F206 , F208 , f228be , Revel
