Originally Posted by
Steve Dodds
I know I'm a lone voice harping on about this, but a blind test does not tell you which is a better speaker. It's a nifty way of seeing if you can reliably differentiate between speakers, and if you can, which of those speakers you prefer.
But preferring one speaker over another does not make that speaker 'better'.
The poster wanted to know how much better, if any the Ref 1 are to the LS50, so if he were to see which he "preferred" in a blind comparison, the winner would be the "better" speaker to him. Generally the objectively better speaker is preferred in blind tests, so they should conclude the same thing.
Steve Dodds
People forget a couple of things about the 'scientific' Harman methodology.
Firstly, that it is predicated on Trained listeners.
And secondly that it is not trying to choose the most objectively accurate speakers, but rather the most subjectively preferred speakers.
You need to read up a bit on the Harman research, first they use trained listeners because they get results faster but they come to the identical conclusions as untrained listeners, it's about efficiency.
Again, the subjectively preferred speaker is the same as the objectively accurate speaker most of the time, in their well controlled study with bookshelf speakers there was a .995 correlation with measurements and listening tests.
Steve Dodds
The Harman 'house curve' is liked by most, but is wilfully inaccurate.
No it's not willfully innacurate, it's the naturally occurring room curve that neutral speakers exhibit, most KEFs follow a similar curve in-room.
Steve Dodds
All that said, I agree about doing a blind test. Objectively the Ref 1 is a better speaker than the LS50. But subjectively you may prefer the sound of the LS50 and thus can save thousands.
Objectively, the $1000 Neumann KH80 is better than either. Short of a Kii or D&D I've not seen a speaker that measures better.
I expect the Ref 1 to win as well.
The KH80 measures well on-axis but they have very limited directivity, so the early reflections curve would probably not be that great, which plays an important part in overall preference.
