KEF Owners Thread - Page 665 - AVS Forum | Home Theater Discussions And Reviews
 6151Likes
post #19921 of 19977 Old 03-20-2020, 08:09 PM
Quoted: 33 Post(s)
Liked: 0
I'm finding my kef r3's to be too bright. Anything I can do? Denon 4500 is the receiver.
500352474 is offline
post #19922 of 19977 Old 03-20-2020, 08:16 PM
macgallant's Avatar
Quoted: 797 Post(s)
Liked: 516
Is it bright when you play in pure direct ?
Speakers: KEF Q100, Q300, Q750, Q650C, Q50a / Fluance Signature Series/ DCM TP160S-CH Subwoofers: Outlaw Ultra X12 (x2) / BIC H100-IIReceiver: Denon AVR-X4500H, AVR-X1400H Integrated Amplifier: Yamaha A-S501/ Fosi Audio TPA3116 mini amp Extras: MiniDSP Umik-1 Amplifier: Emotiva BasX-A300 Next Speakers: Triangle BR03, Revel Concerta2 M16, Dynaudio Emit M20, Buchardt S400, Triangle Comet ez, KEF R3
macgallant is offline
post #19923 of 19977 Old 03-20-2020, 08:25 PM
Quoted: 1047 Post(s)
Liked: 336
Originally Posted by rocksarkar View Post
that link is for mini ls50.. i was looking regular ones...someone near my area is selling for cheap so thinking of grabbing them... will that big for my system....
There is nothing like mini LS50. It is the same speakers.
Sent from my SAMSUNG-SM-G930A using Tapatalk
SouthernCA is offline
post #19924 of 19977 Old 03-20-2020, 10:05 PM
aarons915's Avatar
Quoted: 1162 Post(s)
Liked: 933
When I brought the R3 home they sounded good but they were a bit fatiguing to me as well. If you check this review you'll see that the direct on-axis has a bit more energy in the highs than the listening window so you might have luck pointing them straight ahead without any toe-in. If that doesn't work you need to EQ them a bit, you can see they don't need much but just very low levels in the 2-8k range. Audyssey is hit or miss, it sounds like it's not doing the trick but see how pointing them straight ahead does.
https://www.audiosciencereview.com/f...-review.12021/
Ryan Statz likes this.
aarons915 is offline
post #19925 of 19977 Old 03-20-2020, 10:27 PM
Quoted: 41 Post(s)
Liked: 30
Thanks for all the information provided... i went with sb-4000 and will get one more in couple of months to make it dual.. in meanwhile i want to see if it makes sense to upgrade my rear channels(deftech bp-2x) or they are fine fro my system.
how would be ls50 as rear channels
my current setup..
R11 front, r2c center, svs sb-4000, deftech bp2x rear,
marantz 8805, xpa-5 gen 2..
still have room treatment pending
The new SB-4000 is a good choice. Compact and powerful. Duals would be great!
I'd love to have LS50s. Huge upgrade and they are at a good price right now. @pase22 is right about upgrading to the second sub first. If you want something to hold you over till you get the second sub, go for the Q150s as surrounds. They work well for me, and they're on sale right now.
Anthem MRX1120, AC Infinity Aircom T8, Panamax 5300-PM
Speakers: KEF R700, R200C, SR/SL - Q150
Subs: Rythmik E15HP2 (x2) w/ miniDSP 2x4 HD
TV: Vizio E50-C1, Devices: Apple TV 4K, StreamSmart Pro, Xbox One, and Xbox 360
pn56Matt is offline
post #19926 of 19977 Old 03-21-2020, 05:45 AM
pase22's Avatar
Quoted: 3713 Post(s)
Liked: 3159
Actually Q150's would be great as surrounds and would save you a few hundred. They will be timbre matched and you'd likely not be able to tell the difference unless you listen to multi channel music. The aesthetics would need to be taken into consideration.
pn56Matt likes this.
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #19927 of 19977 Old 03-21-2020, 11:48 AM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 617
It seems to me that most, if not all of KEFs speakers with Uni-Q are designed in such a way that there's no toe-in required. I think they even recommend their Q series to be pointed straight ahead, and I suspect that it'd be sort of the same with their R series or LS50s, etc...
Home Theatre: Marantz SR6014 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R
Ryan Statz is offline
post #19928 of 19977 Old 03-21-2020, 12:07 PM
pase22's Avatar
Liked: 3159
That's the beauty of the uni-q driver. Kef is arguably one of the best know speakers for off axis performance. I have mine very slightly toed in which is more for aesthetics than anything else. I find them a little brighter fully toed-in, though it could just be in my head.
I've really had a chance to enjoy them this past week. Listening to stuff I haven't heard in years.
pase22 is offline
post #19929 of 19977 Old 03-25-2020, 07:52 AM
Liked: 0
I am re-furbishing a pair of KEF Reference 201 I have just bought and have a question. Anyone know how to get the bass driver out? I have removed the three bolts for the bezel, then the three screws for the drive chassis but both speakers have the assembly stuck to the speaker case. I am holding back on the brute force, any suggestions please?
Oktoberfester is offline
post #19930 of 19977 Old 03-26-2020, 08:14 AM
Liked: 0
Solved partly, I could get a spanner behind and tapped it until it finally came out. The gasket had merged with the paper thin veneer on the particle board to form a glue. I now discover the bass unit has a frozen coil and corroded back and just attempted to get an opinion from KEF Support, but no-one is manning the line, understandably.
post #19931 of 19977 Old 03-26-2020, 08:57 AM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 617
Do you toe them in at all? If so, try just aiming them straight forward.
KenM10759 likes this.
post #19932 of 19977 Old 03-26-2020, 02:25 PM
KenM10759's Avatar
Quoted: 3601 Post(s)
Liked: 2040
They won't be of much help, unfortunately. They only handle things from one to two generations back.
There's a technician in New York metro area that can save the bass driver, I'll see if I can find the name of the company.
KEF R500, R200C, R100, R50, SVS SB2000 sub, NAD T758v3 AVR, LG UP875 4K BlueRay, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer. Office: NAD M10, KEF LS50, KEF Kube 10b, E.A.T. C-Major TT w/Ortofon Quintet Blue cart.
KenM10759 is online now
post #19933 of 19977 Old 03-26-2020, 05:41 PM
jmbgator's Avatar
Quoted: 89 Post(s)
Liked: 54
With the Denon 4500, if you download the MULTEQ app on your phone, and run Audyssey then you can adjust the curve to bring down the brightness if it's too bright.
Main Room: 65'' Samsung Q90R; AVR: Denon AVR X-4500H; AMP: Monolith 3-Channel Amp; Center Channel: KEF R2C; L/R Channels: KEF R3; Atmos: KEF R8A; LFE: SVS-PB3000; UHD Blu-Ray Player: Sony UBP-X800; Gaming: PS4 Pro; Streaming Device: Apple TV 4K Secondary Room: 49'' Samsung MU7000; AVR: Denon AVR S-720W; Center Channel: Polk Signature S-35; L/R Channels: Polk Signature S-20; IEMs: Shure 846, Shure 535; DAC/Amp: Dragonfly Cobalt, JDS Labs C5D
jmbgator is offline
post #19934 of 19977 Old 03-26-2020, 11:54 PM
pase22's Avatar
Liked: 3159
As previously mentioned, the audyssey editor app is well worth the 20$ asking price. You can adjust settings, subwoofer output and select how much eq you want. Many of us only eq below 300hz where the bulk of the issues reside.
pase22 is offline
post #19935 of 19977 Old 03-27-2020, 08:29 AM
aarons915's Avatar
Liked: 933
This could help but the problem is Audyssey could be taking a sledge hammer to something that really requires a scalpel. The measurements on ASR show that they really only need a slight cut in the 2-8k region, if that's easy to do in the Audyssey app it could work but I think PEQ would be much better to not affect areas that don't need correcting.
post #19936 of 19977 Old 03-30-2020, 09:45 PM
SodomySquirrel's Avatar
Quoted: 54 Post(s)
Liked: 30
Suggestions on a receiver to power a pair of R11s. Would like to use something better than a Sonos amp to power them.
Would be used as a 2ch with a sub for a listening room.
SodomySquirrel is offline
post #19937 of 19977 Old 03-30-2020, 09:50 PM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 617
budget?
post #19938 of 19977 Old 03-30-2020, 09:54 PM
Quoted: 54 Post(s)
Liked: 30
budget?
3k max.
post #19939 of 19977 Old 03-31-2020, 08:49 AM
pase22's Avatar
Liked: 3159
3k max.
On the high end and slightly over budget, Naim unity one.
https://www.amazon.com/Naim-Uniti-Co...s%2C145&sr=8-2
The Yamaha A-S1100 or Nad M10 are within budget and both are well reviewed.
https://www.crutchfield.com/p_745M10...rs-Series.html
On the lower end, Marantz PM8006
https://www.crutchfield.com/p_642PM8...tz-PM8006.html
pase22 is offline
post #19940 of 19977 Old 03-31-2020, 10:05 AM
macgallant's Avatar
Quoted: 797 Post(s)
Liked: 516
http://www.outlawaudio.com/products/rr2160.html
often overlooked but you won't find anything better under $1000 period.
has analogue bass management as well!
High/Low pass filters
this feature would be incredibly valuable to you for blending your subwoofer.
Can be use as a pre-amp/dac if you have the desire to add external power amps.
It also pushes way more power than it's rated:
Two channels driven continuously into 8-ohm loads:
0.1% distortion at 144.7 watts
1% distortion at 165.1 watts
Two channels driven continuously into 4-ohm loads:
0.1% distortion at 188.5 watts
1% distortion at 235.3 watts
https://www.soundandvision.com/conte...iew-test-bench
KenM10759, pase22 and pn56Matt like this.
post #19941 of 19977 Old 03-31-2020, 10:23 PM
Liked: 336
Naim is primarily a streamer with a small 40W amplifier. It may not be enough power for a speaker like R11.
post #19942 of 19977 Old 03-31-2020, 10:33 PM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 617
3k max.
maybe this: https://www.crutchfield.com/S-K8Ldnq...cam-PA240.html ?
post #19943 of 19977 Old 04-01-2020, 05:16 AM
pase22's Avatar
Liked: 3159
That is an excellent amp, but he would need to get a pre-amp as well which would likely put him over budget.
pase22 is offline
post #19944 of 19977 Old 04-01-2020, 09:31 PM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 617
You're right. I guess if this person can find one on US audio mart or something like that for less than full retail, a pre-amp might still be in budget?
post #19945 of 19977 Old 04-01-2020, 10:43 PM
Quoted: 41 Post(s)
Liked: 30
If you're planning to stick with 2-channel only and are willing to put out $3k for the receiver, I would recommend stretching your budget and going for this:
https://www.anthemav.com/products-cu.../page=overview
If you’re looking at something that can be used later for multi-channel, but still want ample amount of power now, I’d go with this:
Both would be excellent choices with plenty of power. These are great prices, and I believe Crutchfield would honor the discount being an authorized Online dealer.
Happy Hunting,
pn56Matt is offline
post #19946 of 19977 Old 04-02-2020, 08:03 AM
Liked: 1
3k max.
At $3k the Parasound Halo Hint 6 is right at the limit. This is a very nice unit and would do the R11 justice plus allowing a lot of connectivity. If you wanted separates, the P6 & A23+ are the same unit just not integrated.
parasound.com/hint6.php
SouthernCA likes this.
Willyspu is offline
post #19947 of 19977 Old 04-02-2020, 03:05 PM
jima4a's Avatar
Quoted: 478 Post(s)
Liked: 239
3k max.
Suggest contacting JDSmoothie or Mike Garrett for a price on HINT6 (Parasound Integrated). [email protected] or [email protected]. Got my A31 from JD.
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Parasound Halo A31, ATI AT528nc. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is online now
post #19948 of 19977 Old 04-02-2020, 10:33 PM
Quoted: 54 Post(s)
Liked: 30
The NAD M10 looks great! even with HDMI ARC (dont really matter since its a 2ch)
Any other alternatives similar to this?
post #19949 of 19977 Old 04-03-2020, 02:24 AM
KenM10759's Avatar
Liked: 2040
I have one with my LS50's and love it. I just don't think it's enough to power a pair of R11 to their full potential.
The "big brother" to it will be the M33 with 250w/ch and all the same features. It'll be the more standard size, but still have the big front screen. The biggest advantage is the power and even cleaner sound with the "PuriFi" amp technology. It's almost twice the price though.
post #19950 of 19977 Old 04-03-2020, 10:11 AM
pase22's Avatar
Liked: 3159
The NAD C 388 w/bluos pumps out 150x/channel which should be plenty to do those R11's justice.
https://www.crutchfield.com/p_745C38...-BluOS-2i.html
pase22 is offline
Reply Speakers
Kef , Kef Audio , kef blade 2 , Kef Bookshelf Speaker , Kef C4 Subwoofer Black , Kef Center Channel Speaker , Kef Ls50 2 Way Speaker System , Kef Q100bl Bookshelf Speaker , Kef Q700wa Floorstanding Speaker , kef r series , kef reference 3 , Kef T Series Floor Stand Pair
