B&W Owner's Thread - Page 914 - AVS Forum | Home Theater Discussions And Reviews
 1395Likes
post #27391 of 27514 Old 08-28-2019, 11:32 AM
Liked: 0
Hi. I currently run a 3.0 setup with 804 D3's and HTM2 D3. I'm looking to upgrade into a 7.1. Does anyone have experience with M-1 compared to AM-1 as surround speaker?
I know proper bookshelf speakers would be better, but WAF demands smaller surrounds wall mounted near ceiling
Any advice would be appreciated.
Room is 244 x 516 x 679 (cm) or 8 x 16.9 x 11.3 (feet) and tv is setup on the long wall.
Jessens
Jessens is offline
post #27392 of 27514 Old 08-28-2019, 11:53 AM
SpeedDemon's Avatar
Quoted: 180 Post(s)
Liked: 97
Jessens
Can you do in-wall or on-wall instead mounted closer to ear height?
If in-wall, that'll get you the best performance.
If on-wall, then check out some of the older B&W on-wall speakers. I found some B&W FPM speakers on eBay and they're working great as surrounds in my case (I also own M-1 speakers and the larger FPMs are better quality).
I've never heard the AM-1s though.
Spoiler!
SpeedDemon is offline
post #27393 of 27514 Old 08-29-2019, 02:15 AM
Liked: 1
Originally Posted by SpeedDemon View Post
My personal opinion is that the CM1 S2 is more than up to the task of functioning as a surround speaker.
Thanks for the vote. +1 for the CM1.
Any chance there is something to gain with the CM5 S2 ? Figuring I'll be living with this set up for a long while so now's my chance.
markcus58 is offline
post #27394 of 27514 Old 08-29-2019, 08:15 AM
Liked: 0
Hi all,
I am looking at getting an in-wall Center, and was considering the CWM 8.3D or the CWM 7.3. My LR are 805D3. I am pretty much 50/50 music and video.
I’m wondering two things.
1. Is there any word about the 700 series tech becoming in wall (continuum et al)
2. How big a compromise is it to go with the CWM7.3? I know it doesn’t have the diamond tweeters, but considering the $ difference wondering how much I’m giving up going to a lower model.
I have a fairly small condo, where I’m simply projecting on a wall, so it’s not a dedicated home theatre or anything like that. I’d be upgrading from a small, old axiom Center so I’m sure anything will be a big move up, but I don’t want to completely sacrifice quality either. Your thoughts are appreciated. If a newer 700 series in wall is around the corner, I have no problem waiting for it.
Thanks in advance!
delray01 is offline
post #27395 of 27514 Old 08-29-2019, 10:30 AM
Guys, I need some answers to a couple of questions....
Right now, I have a 7.2 B&W CM S2 system. I would like to explore adding height channels for atmos. Are there in ceiling speakers that are a great tonal match to the CM S2 series? If not, how viable an option would it be to source used bookshelves from the series and find suitable ceiling brackets to mount them as height channels?
Also, if I make the jump to the 700 series, are there suitable in ceiling options for that series, and for those of you who have lived with them a while, are the new comtinuum speakers and carbon dome tweeters a dramatic upgrade?
Ryan the Gamer is offline
post #27396 of 27514 Old 08-29-2019, 12:12 PM
theozzfactor's Avatar
Quoted: 35 Post(s)
Hello people
I currently own B&W CM10s with matching CM 2 Center driven by Denon AVR4300H. I have been looking for matching surrounds (CM1s or CM5s) but not able to find them. I came across a pair of Martin Logan motion 15 speakers being sold by someone locally. Do you think I can buy them and use as surrounds? They come with B&W speaker stands and I remember the seller mentioning throwing in Audioquest 4 speaker cables as well. If it won't match the CM10s, do you still think they are good speakers that I can buy and keep them in my bedroom? He is asking for $400.
BTW in case I set up the motion 15 speakers in my bedroom, will Marantz 7008 be a good choice to drive them?
theozzfactor is offline
post #27397 of 27514 Old 08-30-2019, 06:00 PM
Liked: 1
Originally Posted by theozzfactor View Post
Hello people
There are a couple sets of CM5's on eBay at the moment. And there are plenty of CM1 S2's also.
theozzfactor likes this.
post #27398 of 27514 Old 09-03-2019, 01:29 PM
Quoted: 294 Post(s)
Liked: 35
Guys needs some Help
I am wall mounting my M-1 speakers & i got the wall mount to the wall easily. I am struggling to get the speaker wire in the terminals as the screws on the speaker terminals is super hard to unscrew as it just makes the screw driver slip. Don't want to brake anything like the terminals as will have to replace the whole wall mount then :-(
Any tips on how to get that screw unscrewed in the speaker terminals? anyone who have their M-1s wall mounted can help me?
Thanks in advance.
Pic of what the wall bracket for the M1 looks like-
blackspider is offline
post #27399 of 27514 Old 09-03-2019, 04:17 PM
Berland's Avatar
Quoted: 418 Post(s)
Liked: 252
Thanks in advance.
Use the right tool, and not something that almost fits.
HT: Trinnov Altitude32 (AL32-1632)/Amplitude8/8M - BRYSTON 4B SST2 - B&W 802D3, 803D2, 2*DB1, HTM2D2, 804D2, SCMS, Nautilus SCM1, 805D2 - NORDOST Heimdall2/Frey2 - ISOTEK EVO3 Titan,Sigmas - LG OLED65B7V - GIK ACOUSTICS
HP: 2*MOON 430HA D, 2*MiND2 Network Player - 2*Yggdrasil - 2*Hydra Z/ZPM - ISOTEK EVO3 Sigmas, Aquarius - NORDOST Heimdall 2 - AUDEZE LCD-4 rev2, 2*LCD-XC - SHURE SE846
Berland is offline
post #27400 of 27514 Old 09-04-2019, 07:03 AM
clnconcpts's Avatar
Quoted: 27 Post(s)
Hi all,
I'm going to be listing my B&W's up for sale , but, I'm trying to figure out a good listing price . I don't want to over price nor do I want to under price them .
My speakers are from the 2006 era and are
804's
805's with B&W stands filled with silica sand to prevent and vibrations.
SCM's which are considered 805's but squish with wall mounting brackets
All of these are cherry rosewood
Htm1 center channel black ash
Thanks in advance for any advice
B&K Ref 50
Gemstone Audio Amp 7 channel
Denon 5900
Dwin TV 3+
Stewart 92"
B&W 803's
B&W htm1
B&W 805's
B&W scm1's
Spl 1200
https://www.avsforum.com/avs-vb/showthread.php?t=1043310
clnconcpts is offline
post #27401 of 27514 Old 09-04-2019, 08:25 AM
Quoted: 201 Post(s)
Liked: 153
Same here, actually! I'm selling my like-new B&W 702 S2's, but I'm not entirely sure what a fair price would be.
Ascend Sierra Towers (RAAL) + Ascend Horizon (RAAL) + 2x Rythmik F18 | Ascend Sierra 2EX + JL Audio E112 | [Selling:] Bowers and Wilkins 702 S2
echopraxia is offline
post #27402 of 27514 Old 09-04-2019, 06:17 PM
scanido's Avatar
Quoted: 158 Post(s)
Liked: 51
Originally Posted by delray01 View Post
Hi all,
Thanks in advance!
I can highly recommend the CWM8.3D. These in-walls are beasts and blend seamlessly with my 802D3's! They can surprisingly keep up with them as well.
See Profile
scanido is offline
post #27403 of 27514 Old 09-05-2019, 05:25 PM
Quoted: 66 Post(s)
Liked: 62
Hey folks!
I have 704s2 mains, HTM71s2 center, CM6s2 surrounds. This is all powered by an Anthem MRX520 receiver. This is what I'd call a very, very nice setup, but I'd like to take it to the next level, and I'm trying to decide what that move should be. I'm considering upgrading my mains to the 703s2 (maybe 702s2 if I can find a deal on a used pair), or alternatively adding a solid amp to pair with the 704s2.
Specifically I'm looking for more effortless dynamics - in my mind upgrading to the larger drivers is the no-brainer solution, but is my power source going to be just as much of a constraint as the relatively small drivers in the 704s2? Along those lines - would the 704s2 be capable of better dynamics if driven by a more capable amp? I did try out one of the Monolith amps by Monoprice, but honestly it didn't add much to my ears so I sent it back.
Appreciate any thoughts and feedback.
swartzy.baby is online now
post #27404 of 27514 Old 09-05-2019, 10:18 PM
SpeedDemon's Avatar
Quoted: 180 Post(s)
Liked: 97
Originally Posted by swartzy.baby View Post
Hey folks!
Are you using ARC?
How many cubic feet is your room?
The 704 S2 is a great, but surprisingly power hungry speaker. The size of the drivers doesn't play a role in this as much as the sensitivity of the speaker and the fact that it regularly dips below 4 ohms.
I have B&W CM8s (early predecessor to the 704 S2) and I've always found that it sounded best if bi-amped and driven with plenty of power (>100W continuously at 8 ohms).
The 702 S2 is a great speaker and would be an impressive upgrade unless you have a smaller room that the 704 S2 is better suited for.
Spoiler!
post #27405 of 27514 Old 09-06-2019, 05:39 AM
Quoted: 66 Post(s)
Liked: 62
Are you using ARC?
My room's about 2,000 cubic feet - 12x24x7 carpeted, finished basement. I have mostly used ARC, but I've been going back-and-forth the past week, trying to determine if I prefer it without. It's difficult to judge, as overall levels are a lot louder just by turning ARC off so it gives an impression of being more dynamic right away, but I think that's just a matter of needing to adjust volume levels.
I know the 702s2 would be an improvement, I listened to them alongside the 704s2 when auditioning, but they were then and still are very much beyond my budget. Even the 703s2 are beyond budget, I just happen to have found a used example for a price I can probably swing. I'm just not sure if I'm just going to be in the same boat as I am now, just with less money to spend on an amp.
When I auditioned, everything was powered by some massive McIntosh, and sounded sublime. At that point comparing speakers had very little to do with dynamics or volume, and more to do with actual differences in how they reproduce sound instead, and given that context I came out absolutely gobsmacked by how good the 704s2 can be, and again by how awesome the 702s2 are. I'm afraid I don't have McIntosh money, but if a used 702s2 pair were to suddenly show up for a price I can swing, I would pick those up without hesitation.
So I guess my question is really: should I get the bigger speakers (in this case referring to the 703s2), or should I instead get a nice amp (thinking - used Parasound Halo A21, or maybe Rotel RMB-1582). I don't always listen at reference level, but when I do I want to be "wow"ed each time.
post #27406 of 27514 Old 09-06-2019, 06:24 AM
markmon1's Avatar
Quoted: 5231 Post(s)
Liked: 3400
Is your use mostly music or mostly theater? I don't think the amp will make much impact. If you're use is theater, I'd suggest trying to get that center upgraded to at least an HTM2D3. That probably makes the most difference for you over anything. If your use is mostly music, then I'd say the 704S2-->702S2 is a huge upgrade.
rovingardener likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #27407 of 27514 Old 09-06-2019, 06:27 AM
markmon1's Avatar
Liked: 3400
Jessens
My suggestion here is to pass on the M1's or similar. Quantity is always worse than quality. You have a great front stage. M1's will bring ambiance to the rear, but the quality is so poor compared to what you have I'd suggest just sticking to 3.1. Can you do 5.1 with 2 decent speakers instead? Perhaps a couple 706S2's mounted on the rear walls either via speaker mounts or shelves?
markmon1 is offline
post #27408 of 27514 Old 09-06-2019, 06:43 AM
Quoted: 66 Post(s)
Liked: 62
Thanks for the feedback - I think you're probably correct and I'd get less out of an amp than I would get out of the 702s2 upgrade. My use is probably more like 50/50 music/theater, but I'm much more interested in getting the best 2-channel music listening setup than I am upping my home theater game. I'm guessing general opinion here would be that 704s2--->703s2 is not enough gain to warrant the extra investment?
Not to throw another wrench in the mix, but if I were to decide to up the budget (okay, if my wife decides to let me up the budget) - I could potentially grab a used pair of 805d3 for the price of 702s2 new. I think I understand that there are a myriad of things the 805d3 would do better (or, *should* do better) than the 702s2, but I also have to imagine dynamics and bass extension are not on that list of things, correct? And how awful would my HTM71s2 sound as part of that front soundstage?
post #27409 of 27514 Old 09-06-2019, 07:01 AM
markmon1's Avatar
Liked: 3400
I own both 702S2's and 805D3's. To be honest, I prefer the 702S2's to the 805D3's for music by a large margin. I also have 802D3's. I have had 803D3's and 804D3's in my room to test. My preference for music ran like this:
802D3-->702S2-->805D3-->803D3-->804D3.
The 805D3's have a close tonal match to the 802D3's and have similar staging but just lack some sort of oomph. The 702S2's have all that oomph but lack the staging of the 800 series. Tonally, I love the 702S2's. They're so warm sounding and not at all harsh. The 702S2s are a big upgrade to 703S2's. The 703S2's in my opinion are a small upgrade to 704S2's. I'd hold off and save your money until you can go from 704 to 702. I'd pass on 805D3's but that's just my personal preference.
The center I have is the HTM1D3 and it's super musical. The HTM71 is not a good center in my opinion. The drivers are just too small. B&W blew it with the 700 series center. The HTM1D3 is basically an 802D3 in a center sized box. The HTM2D3 is basically an 803D3 in a center sized box. The HTM71 is not a 702S2 in a center sized box Whether or not it will add anything for music I"d say with 702S2's you'll probably want it turned off during 2 channel music. My HTM1D3 definitely adds to the sound stage for 2 channel music. I have it enabled at -3DB here.
Prior to my 802D3's, I had 803D2's then I bought the HTM1D3 center and the center was more musical and nicer sounding than my 803D2's which is why I ended up upgrading to 802D3's.
markmon1 is offline
post #27410 of 27514 Old 09-06-2019, 01:33 PM
Quoted: 66 Post(s)
Liked: 62
I just did a short A/B comparison between my CM6s2 and 704s2. The 704s2 definitely has more + punchier bass, slightly thinner but crisper mids, and treble that I like better but can't put a finger on why. The CM6s2 then has less bass punch, but fuller mids that seem a bit mellowed out in comparison. Again - I preferred the highs on the 704 but couldn't tell you why.
The assumption I'm making based on this very unprofessional comparison is that the continuum cone is allowing for the crisper/more detailed mids, and that the larger driver on the CM6s2 is what's giving those same mids their fullness. And if that assumption is correct (I know making assumptions is second-rate to actually experiencing things, but it's all I've got right now), would the 705s2 then offer the crips and detailed mids from the 704 alongside the full mids of the CM6? Or does the driver material have more to do with it? I guess it's also possible the smaller driver is what's allowing for a crisper sound instead of the driver material.
ps - I think by "crisper" I actually mean "more detailed". To me that presents itself most obviously in distorted guitars from the likes of Highly Suspect, where the added detail makes them sound much more crisp.
post #27411 of 27514 Old 09-06-2019, 04:12 PM
ProKarter's Avatar
Quoted: 13 Post(s)
I am currently running two CCM663 speakers in my Atmos home theater and will be adding two more this weekend for a 5.1.4 system. I have a Denon x4200W doing the processing. My question is, should I pivot the tweeter the full 30 degrees and point them at the main listening position? This is what I currently do. I am not sure if this is the recommended way or not.
thanks
Troy
ProKarter is offline
post #27412 of 27514 Old 09-06-2019, 11:08 PM
SpeedDemon's Avatar
Quoted: 180 Post(s)
Liked: 97
thanks
Troy
I have my CCM663 at a 45 deg angle and the tweeters at 30 deg. I didn't want the Atmos channels directly on top of me because I didn't want to be able to pick out their location... I wonder a little though if I should have put the speakers at 30 deg and their tweeters at 30 deg as well...
Spoiler!
post #27413 of 27514 Old 09-06-2019, 11:33 PM
markmon1's Avatar
Liked: 3400
thanks
Troy
I think it should point towards main listening position. You want the sounds from above to be as directional as possible as that's the entire point of those speakers.
markmon1 is offline
post #27414 of 27514 Old 09-06-2019, 11:35 PM
markmon1's Avatar
Liked: 3400
How does 704s2 + cm6s2 together sound compared to just 704s2 alone? When we were messing around here, a front speaker set consisting of 805D3+702S2 per side actually sounded fantastic.
markmon1 is offline
post #27415 of 27514 Old 09-07-2019, 06:59 AM
ProKarter's Avatar
Quoted: 13 Post(s)
This is exactly what I am doing now and have been debating changing it if there is a good reason or theory for a different setup.
SpeedDemon likes this.
post #27416 of 27514 Old 09-07-2019, 08:56 AM
nadfan's Avatar
Quoted: 37 Post(s)
Liked: 4
Does anyone on here, who owns B&W 706 S2 or 707 S2 speakers, use the FS-700 S2 speaker stands with them?
If so, what do you think of them? Are they worth the money? I like the fact that you can bolt the speakers to the top plate, it avoids using spikes or blue-tack and protects the finish of the cabinets.
I'm looking to get a pair of 706 S2s to replace my old 602 S3s and I'm keen to get opinions on these stands, which have been designed specifically for the 706/707 S2 speakers. I realise they are expensive stands and cheaper alternatives exist.
Please don't reply with "buy a used pair of ... " or similar!!!
I'm interested in what owners of these stands think of them, not suggestions for alternatives...
Not am employee of NAD, not affiliated with the company in any way...just a fan of their products...and lover of good hi-fi sound
nadfan is offline
post #27417 of 27514 Old 09-07-2019, 04:51 PM
Quoted: 66 Post(s)
Liked: 62
Honestly the combo is pretty great - feels like I'm getting the detail from the 704s2 with the fullness of the cm6s2. I started my B&W journey with the cm6s2 pair, then decided to add a center. Got the HTM71s2 and immediately noticed that same detail - so for a long time when listening to music I'd use "all channel stereo" on my receiver to have it all in the mix, and that's what ultimately led me to start looking at 700-series mains. This is basically the same effect.
I've been watching audiogon the past week, and finally noticed a pair of 702s2 for a price I could feel good about. Pulled the trigger this morning, cannot wait.
When I initially moved the cm6s2 in back for surround duty, I noticed a much better sense of rear channel effects than what I'd been getting from the Emotiva T-Zero I had there - I've been attributing that to the top-mounted tweeter, or maybe it has more to do with the height of that tweeter vs the previous pair, so I'm planning on keeping them back there. The 704s2 will eventually end up listed for sale.
post #27418 of 27514 Old 09-07-2019, 04:57 PM
markmon1's Avatar
Liked: 3400
When I initially moved the cm6s2 in back for surround duty, I noticed a much better sense of rear channel effects than what I'd been getting from the Emotiva T-Zero I had there - I've been attributing that to the top-mounted tweeter, or maybe it has more to do with the height of that tweeter vs the previous pair, so I'm planning on keeping them back there and will probably put up the 704s2 pair for sale in the classifieds in the next couple of weeks.
Nice I think you'll love the 702S2. What about putting the 704S2 in rear channels and selling the CM6? Maybe when the 702S2's show you should play with that before selling them
jima4a likes this.
markmon1 is offline
post #27419 of 27514 Old 09-07-2019, 05:23 PM
NMG
NMG's Avatar
Quoted: 37 Post(s)
Liked: 39
I haven't heard the CMs, so take this for what it's worth, but I just added Atmos to my setup which consists of first version 703s, the matching HTM7 for the centre and DS6 S3s for the surrounds. I didn't want to invest a pile of money into the height channels given that they're mainly for effects, so I went with a pair of CCM362s. I installed them last weekend, re-ran the room correction on my receiver and have watched to a few movies since then.
I'm very happy with how it turned out. I wasn't sure how much more 5.1.2 would give me over 5.1, but it's a very worthwhile upgrade IMHO.
NMG is offline
post #27420 of 27514 Old 09-07-2019, 09:17 PM
Liked: 1
Unfortunately, nobody responded to my first - long - questing.
So, short questing... Would you buy 804 D3 now or wait for coming D4?
mhasman is offline
Reply Speakers
802D , atmos , B W , b&w dm1400 , Bowers And Wilkings 685 Speakers , carver cm-1090
