B&W Owner's Thread - Page 937 - AVS Forum | Home Theater Discussions And Reviews
 1581Likes
post #28081 of 28126 Old 06-27-2020, 02:41 PM
Liked: 0
Originally Posted by JL1RP View Post
I have a 700 S2 set-up and my room is 22 x 14. My 7.2 surrounds are 707's work fine. I did try some 706's after living with the 707's for a year. Found the 706 a little better, but not enough to change. Plus the bigger speaker made moving by the couch and speaker a pain. So I stayed with the 707.
Yep that´s true , 707s2 its works fine with 805D3, HTM2D3 and JL F113.
Now I have tested a lot of B&W models.
M-1 = Different sound, and sound not have enough body.
AM-1 = Different sound.
607 = Good, but the treble does not match the front end.
606 = Good, but the treble does not match the front end.
706s2 = Good match treble and midbass, but placement is a little trickier.
707s2 = Good match treble and enough midbass (80hz crossover), easier to find a suitable place.
Staafe100 is online now
post #28082 of 28126 Old 06-29-2020, 12:17 PM
peacefulcargo's Avatar
Liked: 0
Hi B&W UK said that for the 800D3 you need min 16feet x 24feet room. What room sizes do you have for this speaker and does it work well? Thanks
peacefulcargo is offline
post #28083 of 28126 Old 06-29-2020, 06:47 PM
Liked: 2
B&W 702 S2 Midrange driver repair help
Somebody knows how to remove the midrange speaker on the 700 series? One of my speakers midrange is not reproducing any sound.
Thank you
Diego Latorre is offline
post #28084 of 28126 Old 06-30-2020, 06:12 AM
techtvman's Avatar
Quoted: 91 Post(s)
Liked: 31
Thank you
If it’s the new 700 series with the decoupled midrange you’ll need to pull the dust cap off, then use a special tool to unscrew it and it comes right out. I had an issue with mine a few months after I bought and turned out this little blue resistor thing for which I’m forgetting the name was damaged. Those go first to protect the driver in the event of overdriving.
7.1.4 system:
JVC NX7 / 120" Seymour Screen | Marantz SR7011 | Emotiva XPA 3 Gen 3 | Nvidia Shield | OPPO BDP 203 UHD | Tivo Roamio OTA | Roomie Remote | 4x B&W 600 series surrounds | 4x Definitive Technology AW 6500 Atmos | B&W 700 Series Front LCR | Rythmik FV15 | Insteon Automation | Philips Hue accent lighting
techtvman is online now
post #28085 of 28126 Old 06-30-2020, 12:18 PM
Liked: 0
Did you have this "special tool", can you take a picture of that tool?.
post #28086 of 28126 Old 06-30-2020, 12:28 PM
techtvman's Avatar
Quoted: 91 Post(s)
Liked: 31
Nope my dealer did. I was covered under warranty.
7.1.4 system:
post #28087 of 28126 Old 06-30-2020, 08:21 PM
rick216's Avatar
Hello all! I currently have audioquest rocket 44 standard cable, would exchanging for rocket 44 biwire cable make a difference?
rick216 is offline
post #28088 of 28126 Old 06-30-2020, 08:43 PM
tommarra's Avatar
Quoted: 1023 Post(s)
Liked: 599
Cables unless the gauge is different and the run is long don’t matter.
Also unless you are using external active crossover, and have decent amps, bi-wiring doesn’t have any proven benefit. I would not waste money on upgrading cables and spend that on room treatments
markmon1 and blackspider like this.
Gear: Fronts: B&W 804D3 | Center: B&W HTM2D3 | Surrounds: B&W 684S2 | Backs: B&W 684S2 | Heights: B&W DM601S3 | Subs: 3x PSA S1500 Receiver & Amps: Arcam AV40 + Monoprice Monolith 7x200 + Outlaw 7000x | Projector: JVC NX7 | Screen: 126 inch 16:9 Stewart Studiotek 130 G4 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
post #28089 of 28126 Old 07-01-2020, 12:47 AM
RebelMan's Avatar
Quoted: 51 Post(s)
Bi-wiring does have a proven benefit, albeit minor. If someone has to choose between room treatments and cable upgrades then the former would be the better investment. The reality is you don't have to spend a lot on cables to reap the benefits of bi-wiring. People that think you do is the true misnomer.
hery19 likes this.
"Dream as if you'll live forever. Live as if you'll die today."
RebelMan is offline
post #28090 of 28126 Old 07-01-2020, 01:19 AM
markmon1's Avatar
Quoted: 6846 Post(s)
Liked: 4968
Doubt biwiring has any benefits. A huge thick gold plated bridge does plenty. The only benefit provided by biwiring is doubling the thickness of the wires by having 2 runs.
JVC Control - my software for controlling JVC projector via IP control.
Smart Masking - See my automatic smart screen masking system.
JVC IR Codes - free online pronto code converter for JVC IR codes.
markmon1 is offline
post #28091 of 28126 Old 07-01-2020, 05:18 AM
jima4a's Avatar
Quoted: 500 Post(s)
Liked: 248
Just for clarification, you are mixing bi-wiring and bi-amping in the same discussion- two different things.
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Parasound Halo A31, ATI AT528nc. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
post #28092 of 28126 Old 07-01-2020, 02:51 PM
blackspider's Avatar
Quoted: 440 Post(s)
Liked: 55
Hello everyone,
Been enjoying my new 702 s2 for a few days :-) upgraded from the S684 s2.
I have them powered by an Anthem MCA225 power amp which is connected to the pre outs of my NAD T758 v3 avr.
I m still using my older 600 series for surrounds & center. Thing is i want to upgrade my center speaker & confused between the HTM71 or 72.
The HTM 72 will slide in my Tv cabinet easily where my previous 600 series center is, if i go for the HTM71 then i have to put it on a center speaker stand infront of the Tv cabinet.(wife doesn't like that idea)
Is the HTM71 a big jump from the HTM72 & worth all the drama for me which is get the center stand & convince the wife? Also the center speaker will be power by the NAD avr itself. Will that be enough for the HTM71?
Inputs would be great.
55" LG B6 - Nad T758 V3- Anthem MCA 225- B&W 600 s2 speaker series - Stereo Rel S2
blackspider is online now
post #28093 of 28126 Old 07-01-2020, 05:55 PM
Captdave's Avatar
Quoted: 38 Post(s)
Liked: 32
Originally Posted by blackspider View Post
Hello everyone,
Hi, how you like your 702? I power them with the new model MC257 and 8805 they sound great
BrianPK likes this.
SONY-A9G 77" OLED | Apple TV 4K | Power Amp-Mcintosh MC257 | Blu-ray-Oppo udp-205 | Preamp-Marantz AV8805 | 2 Subwoofers- REL-212/SE and PSB Subseries 450 | Front--B&W 702 S2 | Surround CM9 S2 | Surround Back--CM5 S2 | Center HTM71 S2 | KEF R8a atmos speakers | Panamax M5400-PM Conditioner
Captdave is offline
post #28094 of 28126 Old 07-01-2020, 11:38 PM
Quoted: 440 Post(s)
Liked: 55
They are lovely :-) How's the HTM71 s2 center speaker? Do they blend well with the 702s?
post #28095 of 28126 Old 07-02-2020, 06:14 AM
hery19's Avatar
Quoted: 88 Post(s)
Liked: 44
I’ve had them around two weeks now and they get better each day. Very happy with my purchase!Click image for larger version
TV: Sony XBR-85X850G, Receiver: Anthem MRX 720, Amplifier: Monolith 7X Bluray: Panasonic DP-UB820, OPPO BDP-93 Conditioner: Panamax M4300-PM, Speakers: B&W 702 S2 Fronts, HTM71 S2 center, 706 S2 Surrounds, Sub: SVS PB 3000 & Remote: Harmony One
hery19 is online now
post #28096 of 28126 Old 07-02-2020, 06:16 AM
hery19's Avatar
Quoted: 88 Post(s)
Liked: 44
706 S2 sorrounds
post #28097 of 28126 Old 07-02-2020, 11:12 AM
Captdave's Avatar
Quoted: 38 Post(s)
Liked: 32
[QUOTE=blackspider;59891180]They are lovely :-) How's the HTM71 s2 center speaker? Do they blend well with the 702s?
[/QUOTE
The center is doing a great job with the 702s
Captdave is offline
post #28098 of 28126 Old 07-02-2020, 11:15 AM
Captdave's Avatar
Quoted: 38 Post(s)
Liked: 32
Originally Posted by hery19 View Post
Attachment 2751964
706 S2 sorrounds
They Nice!!! I have the CM5 s2 they sound super
hery19 likes this.
Captdave is offline
post #28099 of 28126 Old 07-02-2020, 11:17 AM
hery19's Avatar
Quoted: 88 Post(s)
Liked: 44
Thanks! Very happy with them, much fuller and detailed sound than the CM2s they replaced.
post #28100 of 28126 Old 07-02-2020, 11:38 AM
Captdave's Avatar
Quoted: 38 Post(s)
Liked: 32
CM5 S2
Captdave is offline
post #28101 of 28126 Old 07-03-2020, 12:12 AM
Quoted: 114 Post(s)
Liked: 48
I would go for the 71 S2 with the 702 S2
I have the 72 S2, it does sound great, but i wished i'd gone with the 71.
i'll be looking at changing it over to a HTM71 once we get around to renovating our new place.
hery19 likes this.
Denon X3200W
Bower & Wilkins HTM72 Centre, M1 & PV1 Sub
Samsung 2014 75 inch and Samsung 2018 NU8000 82 inch 4K
QED Speaker Cables and HDMI
Bryn23 is offline
post #28102 of 28126 Old 07-03-2020, 02:08 AM
markmon1's Avatar
Liked: 4968
Save up for an HTM1D3. No joke.
tommarra likes this.
markmon1 is offline
post #28103 of 28126 Old 07-03-2020, 07:41 AM
Captdave's Avatar
Quoted: 38 Post(s)
Liked: 32
Cool
wow HTM1D3 will be a killer center NICE!!
Captdave is offline
post #28104 of 28126 Old 07-03-2020, 07:51 PM
Quoted: 114 Post(s)
Liked: 48
I have not doubt that these would be amazing, but
I'd be wasting my money spending $8900 AUD on the HTM1D3 compared to $1999 AUD HTM71 as i don't have a dedicated soundproofed Home Theatre to really crank those up at this present time and honestly my ears aren't as good as they use to be.
I'm currently designing our apartment remodelling, with better acoustic and sound isolation properties than what we have, at least i can put my Drafting qualifications and Cabinetmaking qualifications to use.
Decoupled/Isolated ceiling mounts, acoustic batts, dual layers of dampened green glued plasterboard, laminated hush glass and acoustic curtains for external noise will provide a better bang for buck than better HTM1D3 speakers at this point in time.
bmcleod likes this.
Denon X3200W
Bryn23 is offline
post #28105 of 28126 Old 07-04-2020, 12:58 AM
markmon1's Avatar
Liked: 4968
Honestly, those AU prices are just ridiculous. I can see your perspective at those prices.
Bryn23 and Staafe100 like this.
markmon1 is offline
post #28106 of 28126 Old 07-06-2020, 10:04 AM
Quoted: 133 Post(s)
Liked: 65
Hello everyone,
I had the exact same problem. Wanted the 71 but only had room for the 72. I was able to cut out part of the inside of cabinet to slide Oppo 203 over and make room for 71. I have about 1/4 inch of clearance now on each side of 71. I also placed felt tape running down the side of Oppo, 778, and bottom of cabinet shelf above 71 to ensure 71 does not get scratch when sliding in and out in case I make contact. The 71 has felt pads on bottom. Not sure if you have that option but I was going to make the 71 fit somehow. Sounds amazing!! I put on stands for when I want to rock out and watch movies for better dispersion. My new NAD 778 powers everything really really awesome; sounds so crisp and clear even when play super loud (a 5.1.2 system with sub being powered but it's own amp). My previous Denon x4200W couldn't power sufficiently; would cut out at reference volumes.
Good luck!!
Name:	BW on Bookshelf.jpg
ID:	2753842   Click image for larger version
Name:	BWs 805 D3s.jpg
ID:	2753844   Click image for larger version
Name:	Cutout for BW HTM71 S2.jpg
hery19 likes this.
tigerljj1 is offline
post #28107 of 28126 Old 07-06-2020, 12:19 PM
hery19's Avatar
Quoted: 88 Post(s)
Liked: 44
I was wondering what crossover are you guys using with your 702s, HTM71?
post #28108 of 28126 Old 07-06-2020, 01:37 PM
Quoted: 440 Post(s)
Liked: 55
Good luck!!
Nice alteration you did, so you put the HTM71 also on a stand for movies? i have no option but to put it on a separate center speaker stand as can't do any alteration to the tv stand.
Mostly will get the HTM71 & put it on a dedicated stand infront of the Tv console, lets see.
post #28109 of 28126 Old 07-06-2020, 02:57 PM
Quoted: 133 Post(s)
Liked: 65
I can but I leave center in place where it is. I'll let Dirac distance/levels make necessary adjustment. Will have two Dirac slots: 1) one for when in bookshelf and 2) when on stands. I know it's not the best setup but man does it sound great!! Post a pic of your setup; people are creative. Who knows, someone may find a solution.
post #28110 of 28126 Old 07-07-2020, 11:57 PM
Quoted: 440 Post(s)
Liked: 55
Well here is the pic of my setup, got a new power amp & front speakers which aren't in the pic but you get the basic point of my issue to fit the HTM71. No other solution except put a center speaker stand in the front of the unit
https://ibb.co/Mfh5zMQ
BrianPK likes this.
Reply Speakers
606 , 802D , atmos , B W , b&w dm1400 , Bowers And Wilkings 685 Speakers , carver cm-1090
