Canton owner's 'club' - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 295Likes
post #1351 of 1389 Old 06-18-2020, 06:19 AM
Quoted: 58 Post(s)
Liked: 108
Originally Posted by mike030987 View Post
Fair enough, I just do not want to get something on the lower power side (70w per) if it isn't going to push them appropriately. I also don't want to spend the money for a 100w per one if all I can find are things with too many bells and whistles that cost 600 or so. Just trying to find a good balance and hope someone can guide me in the right direction.
AVR’s are pretty much all about bells and whistles so that is going to be part of the Avr package no matter what.
I would probably er on the side of more watts as a power supply that doesn’t struggle is going to perform better and last longer.
As the saying goes, buy once cry once. I’d pay a little more now so you aren’t paying even more down the road.
gbus is offline
post #1352 of 1389 Old 06-18-2020, 06:29 AM
Quoted: 628 Post(s)
Liked: 560
Keep an eye on the Receiver deals thread and the general everything deals thread here on AVS.
Costco has some Denon's available for members
https://www.avsforum.com/forum/90-re...l#post59811970
https://www.avsforum.com/forum/122-great-found-deals/
cocrh is online now
post #1353 of 1389 Old 06-18-2020, 07:08 AM
Quoted: 26 Post(s)
Liked: 0
I never thought about Costco as I am not member. My significant other is though so I may have to look into that ty. What are your thoughts on a used reciever?
mike030987 is offline
post #1354 of 1389 Old 06-18-2020, 08:55 AM
Quoted: 628 Post(s)
Liked: 560
Used is hit or miss. If price is good and somewhat newer it might be a workable idea. It is a risk.
cocrh is online now
post #1355 of 1389 Old 06-18-2020, 06:07 PM
RickD1225's Avatar
Quoted: 380 Post(s)
Liked: 3462
Mike,
What are you using for input? Turntable, streamer, etc? What volume do you use in the small room? That certainly helps with suggestions.
Spoiler!
RickD1225 is online now
post #1356 of 1389 Old 06-18-2020, 08:55 PM
Quoted: 26 Post(s)
Liked: 0
Input will be game systems and just the smaller TV in the room. Loudness is all dependent on who is in there. With me then louder but not ear screeching. The significant other, more mellow.im sure.
post #1357 of 1389 Old 06-18-2020, 09:10 PM
RickD1225's Avatar
Quoted: 380 Post(s)
Liked: 3462
Literally, any AVR will fit that bill.
Spoiler!
post #1358 of 1389 Old 06-18-2020, 11:46 PM
Quoted: 26 Post(s)
Liked: 0
I understand for what I am connecting to it anything will work. That's actually why I don't need much of anything when it comes to fanciness. What I need is a properly powered and fitted ave for the speakers I will be running. I do not want the Chrono sl to be underpowered if that means they will not sound as well. Thats all
post #1359 of 1389 Old 06-19-2020, 04:04 AM
Liked: 0
Hi Peeps, I have been spending a few months researching brands for 100% home theatre use and I have come across Canton. The CANTON: CHRONO SL 586 DC fronts, CANTON: CHRONO SL 526 rears, CANTON: CHRONO SL 556 centre, not sure on the sub yet and probs a set of CANTON: AR-400 for front heights. Has any of you guys experienced Canton from more of a movie point of view?
Cheers
ryekar is offline
post #1360 of 1389 Old 06-19-2020, 04:58 AM
Quoted: 58 Post(s)
Liked: 108
Cheers
I use Canton Vento 876 towers for my L/R, Vento 826 at center and a pair of Chrono 502.2 for surrounds and love it for both movies and music.
gbus is offline
post #1361 of 1389 Old 06-19-2020, 07:25 AM
RickD1225's Avatar
Quoted: 380 Post(s)
Liked: 3462
I don't know about the Chrono SL series, but the Vento series I have has an impedance curve that dips below 4 ohms. The requires an amp section that can deliver a lot of current. I have an outboard power amp with dual 1.2 kVa toroidal transformers that fits that requirement nicely. I do have a large room to fill which it does at concert levels if desired (think Led Zeppelin). I never tried them with the AVR amps.
Spoiler!
post #1362 of 1389 Old 06-19-2020, 08:58 AM
tomd51's Avatar
Quoted: 25 Post(s)
If you're running the Canon SL-516.2s with a sub as you noted earlier and have them crossed over at 80Hz or higher, any Yamaha or Denon AV receiver rated at 75-80w or more will do just fine. I've had better success with Yamaha, but unless you're chasing bells and whistles, which you aren't in this case, there should be minimal difference.
Good luck!
Yamaha CX-A5200 | Emotiva XPA-5, UPA-7 | Mitsubishi WD-73742 | Epson 5040UB
Canton Chrono SL-536.2s, Vento 866.2, Emotiva ERD-1s (x2) | 15" TC-2000 DIY Sub
Dish Hopper with Sling | Oppo BDP-93 | AppleTV 4k
tomd51 is offline
post #1363 of 1389 Old 06-20-2020, 03:18 AM
Quoted: 26 Post(s)
Liked: 0
Thanks everyone, I have the opportunity to get a Denon x2100w for 200 so I may jump on that. If not I will prolly go with a Yamaha v485 or 585. I appreciate everything.
post #1364 of 1389 Old 06-27-2020, 01:01 AM
Liked: 3
Hello, just sharing my experiences with my new Canton Vento 826.0. After saving up a reasonable amount to spend on good speakers, I was researching everything in the $600-800 usd range. Due to the pandemic, I had to rely on online reviews/information. My final list had Q Acoustics 3030i, Elac reference, b&w 607, Triangle BR03, and Kef LS50. I was looking for warm speakers with good low end. And then someone on reddit recommended the canton vento 826.0 which were being sold for $600 on A4L, and was an older model, a couple years old, with a $1500 msrp. Information on these speakers were nigh impossible to find in english save for the occasional post on avsforums and a couple google translated reviews. But hell they used to be $1500 speakers and looked amazing in white, so I pulled the trigger. How to describe these speakers. They sounded just dead and flat out of the box. But after half an hour or so, they started warming up. They have amazing bass, which I loved instantly, but they also had this forward sound signature like Klipsch horn tweeters (but not as pronounced), which I thought I would really dislike but I forgot about it after a day. I initially thought the speakers were on the bright side (which I really hate, and the main reason why I passed on the Kefs) but after several days of really listening, I came to the conclusion that the speakers were not bright (bright speakers like my sony cs5 hurt my ears) but the ceramic tweeter on the speakers were just incredibly accurate. These speakers are quite exceptional speakers, and the fact that I got them for $600 is just a steal. Very happy with this purchase.
Though I do always wonder how these compare to the buchardt s300 (since they have similar msrp).
Darvis, cocrh and gbus like this.
Ganked By Life is offline
post #1365 of 1389 Old 06-27-2020, 08:09 AM
Liked: 2
Originally Posted by qirex View Post
Apologies for the double post but I heard back from Canton support and the bolt holes on the bottom of the standmount speakers are standardized across ranges, so my existing stands will work with Vento speakers.
What are the dimensions of the mounting holes? Are there any other generic stands with holes that fit? I was hoping to find a cheaper alternative to the Canton brant stands.
Hudson777 is offline
post #1366 of 1389 Old 06-29-2020, 08:59 PM
RickD1225's Avatar
Quoted: 380 Post(s)
Liked: 3462
My wife bought a new entertainment center for a smoking deal at Costco, last one, $400. If you can’t tell she is into Farmhouse decorating. Got it all disassembled and reassembled without a hitch, yahoo. Canton Vento 890.2 DC Towers and 866.2 Center. Other equipment in Sig. One sub behind the electric fireplace the other in the opposite corner.
vavan, cocrh and gbus like this.
Spoiler!
post #1367 of 1389 Old 06-30-2020, 06:38 AM
Quoted: 628 Post(s)
Liked: 560
I don't think you will find any speaker stands with holes in the same position as the Canton's. Most all speaker stands I have seen do not have any mounting holes at all. A lot of folks use blu- tack to hold them on pretty securely.
https://www.amazon.com/Tack-Original.../dp/B01JRZQLX8
cocrh is online now
post #1368 of 1389 Old 06-30-2020, 11:46 AM
Liked: 2
Thanks for getting back to me, I will try Blu-tack. Does anyone have the expensive canton stands, do they seem worth the extra $$?
post #1369 of 1389 Old 06-30-2020, 12:19 PM
Quoted: 58 Post(s)
Liked: 108
If I’m paying around $500 for stands for my Cantons I’m just buying Solidsteel SS-6 stands not canton branded ones.
I’m actually using $300 Focal stands from my 906 Aria’s with my Canton Ref 9.2’s and even those are over priced for what they are, no way I’m paying even more for Canton stands that don’t look any better built.
You could easily make a template of the holes on the speakers and drill two holes on the top plates of whatever stands you come up with. I’ve got a couple metal Wharfdale stands that would work perfectly for this if I felt it necessary to secure speakers to them.
Could do the same thing with the all wood stands.
gbus is offline
post #1370 of 1389 Old 06-30-2020, 08:30 PM
Liked: 2
If I’️m paying around $500 for stands for my Cantons I’️m just buying Solidsteel SS-6 stands not canton branded ones.
I’️m actually using $300 Focal stands from my 906 Aria’️s with my Canton Ref 9.2’️s and even those are over priced for what they are, no way I’️m paying even more for Canton stands that don’️t look any better built.
You could easily make a template of the holes on the speakers and drill two holes on the top plates of whatever stands you come up with. I’️ve got a couple metal Wharfdale stands that would work perfectly for this if I felt it necessary to secure speakers to them.
I like the template idea, I am going to try that. The solidsteel stands you mentioned look excellent as well, still pricey but better value than the Canton.
gbus likes this.
post #1371 of 1389 Old 06-30-2020, 08:42 PM
Quoted: 628 Post(s)
Liked: 560
Which Canton speakers do you have? What other speakers have you had and how do you like them compared to the others?
cocrh is online now
post #1372 of 1389 Old 06-30-2020, 08:52 PM
Quoted: 58 Post(s)
Liked: 108
I have seen open box deals on the Solidsteel SS stands for around $300 and you never know what you can find on the various audio classifieds on the cheap.
I have a couple pairs of these Wharfdale ST-1 stands that I found on sale new for $199 pr. Like most stands they still seems over priced for what you get but they aren’t a bad metal stand in form and function.
gbus is offline
post #1373 of 1389 Old 07-01-2020, 08:08 PM
Liked: 1
Joining the club
It’s still early on but these new Canton 9.2’s could very well displace my Focal Aria 906’s from main stage in my current 2.2 setup.
I am contemplating pulling a trigger on the same Reference 9.2s you have. I've done some research, but it is still a difficult decision knowing that I can't audition those and Canton does not even have dealership network in the U.S. if something goes wrong.
Do you have any updates on your listening experience since last time you shared it?
Any other happy owners here who would like to share a few thoughts?
NazzoGood is offline
post #1374 of 1389 Old 07-01-2020, 10:50 PM
Quoted: 58 Post(s)
Liked: 108
I’m still enjoying them and have no plans to upgrade, but I also have 5 other pairs of Cantons besides the 9.2’s so I’m already pretty well invested in the canton sound. I’m also not the most critical listener and don’t have a lot of experience with a bunch of different speaker brands like a lot of folks here do, so I’m probably not the best of speaker judges.
NazzoGood likes this.
gbus is offline
post #1375 of 1389 Old 07-03-2020, 05:56 AM
Liked: 2
Which Canton speakers do you have? What other speakers have you had and how do you like them compared to the others?[/QUOTE]
I have the Canton Chrono SL 536.2 downstairs in my basement. I am running them through an Arcam avr380, those are the only speakers I have hooked up to that reciever at the moment. I may decide to get a sub at some point but honestly the system sounds great for now.
Upstairs in my home theater I have a yamaha 3050 with Martin Logan motion 40 front r/l with a motion 30 center. I have motion 4's on the wall for surround. A svs-sb1000 finishes out that system.
The Canton/Martin Logan sound comparison is a tough one. They both sound excellent when I compare them in stereo direct. I have never run the ML speakers with the Arcam reciever so I am not sure if they would sound that much different then they do currently with the Yamaha. The suprising thing to me was how much sound came out of the small Canton bookshelf size and how much detail. Since the Canton speakers are only a few weeks old, I need a little more time listening to them to see which speaker becomes my favorite.
cocrh likes this.
post #1376 of 1389 Old 07-03-2020, 05:59 AM
Liked: 2
I have seen open box deals on the Solidsteel S stands for around $300 and you never know what you can find on the various audio classifieds on the cheap.
I have a couple pairs of these Wharfdale ST-1 stands that I found on sale new for $199 pr. Like most stands they still seems over priced for what you get but they aren’️t a bad metal stand in form and function.
[/QUOTE]
Those Wharfdale look nice, I am trying to see if I can find anything used local or ebay. If not I might just see if I can get something like those.
post #1377 of 1389 Old 07-03-2020, 11:03 PM
Darvis's Avatar
Quoted: 25 Post(s)
Liked: 29
Originally Posted by Daybg View Post
Hello. I was originally ignoring the Canton because it seemed like a gimmick. I only ever saw it on A4l, and it always had those ridiculous price strick throughs so it seemed to be on absurd sell, so I just skipped it.
However, after ordering a Kef r5 set from best buy that will be coming in Tuesday, and then also ordering a set of Focal 926 I will compare the two, I started looking into European made, which of course led me to the Sonos (could only even consider used Chinese made apparently) and then back around to the Canton.
Of course its a crazy thing with A4l's apparently horrible return policy, so that combined with towers shipping cost and returning would pretty much not be an option.
However, I am super confused, the two units that are most interesting to me at the moment are the Reference 5 if it ever comes back in stock, though a bit expensive. Or, the really nicely priced 876.2
Of course, there are also some nice looking JBL speakers for like 200 dollars out and around so...obviously things can be cheaped out on in ways that I do not understand. All the specs seem to be great, but the pricing is just really confusing me and I feel I must be missing something. Combined with no way to test them out and it's a real brick wall. (of course, if they were MSRP I wouldn't even have looked back at them again, given the no testing and very very few English reviews)
Anybody have some information I should consider, or links to some good reviews etc? Even in German, Japanese etc with some Google translation would be great...
I'm interested in reading your impressions of the kef against the focal
Darvis is offline
post #1378 of 1389 Old 07-04-2020, 05:05 PM
Quoted: 143 Post(s)
Hey guys! I've got $2,500 to spend on a pair of floorstanding speakers and a receiver. I see a pretty solid deal on the Chrono SL-596.2, $999 each and a free center channel. While a 50% discount sounds like an amazing deal, I need a basis for comparison. Can someone tell me how the Chrono SL-596.2's compare to other floorstanding speakers that are priced at $999, such as the KEF Q950s?
I really want to love and buy these speakers, I just need a bit of convincing because I've never heard of the brand lol.
Thanks to anyone who responds!
Crusher21 is online now
post #1379 of 1389 Old 07-04-2020, 05:43 PM
RickD1225's Avatar
Quoted: 380 Post(s)
Liked: 3462
Crusher, all I can tell you is Canton makes great speakers. Not that well known in the USA, but very popular in the EU. I love mine.
Spoiler!
post #1380 of 1389 Old 07-04-2020, 05:48 PM
Norris Kasey's Avatar
Quoted: 195 Post(s)
Liked: 94
Not sure on how they compare but I have that setup. They sound great. I got the same deal about a month ago
Sent from my Pixel 3 XL using Tapatalk
Norris Kasey is offline
Reply Speakers
Canton , Canton Center Channel Speaker , Canton Chrono 505 2 Speaker , Canton Chrono 507 2 Standing Speaker , Canton Gle 490 2 Speaker Single Silver , Canton Ls 105 Stand Pair Silver , Canton Ls 80 1 Stand Pair Black , Canton Ls 90 1 Stand Pair Black , Canton Ls 90 1 Stand Pair Silver , Canton Ls 95 Stand Pair Silver , chrono sl-536.2
