Aerial Acoustics Owners Thread - Page 79 - AVS Forum | Home Theater Discussions And Reviews
 134Likes
post #2341 of 2345 Old 11-24-2019, 08:38 PM
Mudslide's Avatar
Quoted: 158 Post(s)
Liked: 217
Originally Posted by jdlynch View Post
Thanks Class A
So, at ear level, are they high enough to clear the backs of your seating?
JD, it doesn't work for me...but it depends upon the back height of your chairs, as well as the distance from speakers to LPs. I have mine on top of cabinets, so about 7' up. (We have high backed recliners.) The LP to rear speaker distance in almost equidistant to the LCR to LP distance. Direct is the only way to go for rears, IMO. The delivered ambience is terrific for most sounds (video/audio sources). The SR3s might be okay for side surrounds, but I have never enjoyed bipoles/dipoles for rears.
Cheers.
MARGARITAS,
they're not just for breakfast anymore.
Mudslide is offline
post #2342 of 2345 Old 11-24-2019, 10:10 PM
jdlynch's Avatar
Quoted: 367 Post(s)
Liked: 139
Cheers.
Hey Mudslide.
Thanks for sharing your comments. I think I’ll experiment with raising the height of my lr3’s Instead of downsizing to 5’s. They are to heavy for wall mounting; think I’ll build 12” tall pedestals to stand them on. They will just clear my seat backs at that elevation.
Mudslide likes this.
Current Equipment: Datasat LS10 w/ Atmos and DIRAC. ATI 6005, AT527NC, Aerial Acoustics LR5's (LCR), SR3's sides, LR3's (rears), Seaton Submersive HP, Marantz VP15s1, 123" diag 16:9 Stewart Cima Neve screen, Oppo BDP-103, Palliser Flicks Theater Seating AC Power: Eaton whole-house surge protector at main panel, three dedicated 20 amp circuits, Surgex XR315 surge protector at equipment rack, Cyberpower 1400VA/900 watt, true sine wave UPS.
jdlynch is offline
post #2343 of 2345 Old 12-03-2019, 04:25 AM
mj13young's Avatar
Quoted: 21 Post(s)
Bi Amping 10Ts and CC3
Hi,
Does anyone have experience bi amping 10Ts and CC3?
My questions is it better to go with a more powerful amp driving the whole 10T or bi amping it with a less powerful amp?
I am considering the following LCR options:
3 each PS Audio Stellar M700 mono block (350/700 watts into 8/4 ohms)
or
3 each Bel Canto Ref 600m mono block (300/600 watts into 8/4 ohms)
or
1 each Gato DPA-4004 using only 3 of the 4 channels (400/800 watts into 8/4 ohms)
or
3 each Lyngdorf Audio SDA2400 stereo amps - bi amping each speaker (200/400 watts into 8/4 ohms)
Any thoughts?
Thanks in advance.
mj13young is offline
post #2344 of 2345 Old 12-03-2019, 07:38 AM
Class A's Avatar
Quoted: 765 Post(s)
Liked: 5074
Thumbs up
Originally Posted by mj13young View Post
Hi,
or
or
or
Any thoughts?
Thanks in advance.
My local dealer has the Gato amps. They should be no problem running 10T's and a CC-3 center. I use a 200wpc Forte 6 to run the CC-3 center. The store I go to was the first store to sell Aerials. 250wpc on up should be sufficient.
Class A is offline
post #2345 of 2345 Old 12-03-2019, 06:09 PM
jdlynch's Avatar
Quoted: 367 Post(s)
Liked: 139
Hi,
or
or
or
Any thoughts?
Thanks in advance.
I once bi-amped my center channel (LR5) when I had a lower powered Parasound HCA1206 amplifier. I had an extra channel I wasn’t using and thought it wouldn’t hurt to try. Honestly, I couldn’t tell a difference.
Later, during a conversation with Michael Kelly, he explained that bi-amping does not benefit with the extra watts. He said the only way to give them more power is with a more powerful amplifier. He loves the Gato/Aerial combo, but they are priced WAY above my current HT budget.
jdlynch is offline
Reply Speakers
Energy Cc 5 Center Channel Speaker Black
