Simple (dumb) Woofer Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-25-2000, 09:16 PM - Thread Starter
Scotty's Avatar
I am connecting a Polk woofer in series with the Front Speakers, per the Instructions. My Kenwood Receiver Manual only shows a subwoofer port and under setup the setup asks: Woofer ..Yes or No.. If No the Front Speakers automically default to "Large". Then if Yes you specify whether the Front Speakers are "Large" or "Normal".I said it was a simple question. Thanks.
Scotty is offline
Closed Thread Speakers
