AVS Forum | Home Theater Discussions And Reviews
(https://www.avsforum.com/forum/)
- Speakers
(https://www.avsforum.com/forum/89-speakers/)
- - Ouch, Speaker Ding
(https://www.avsforum.com/forum/89-speakers/83548-ouch-speaker-ding.html)
My 3 year old grand-daughter pulled the grill off my Infinity Overature 2 and poped inward the center dome on one of the speakers.Sounds OK but am I gettind degredation of sound and how in the heck can I get it to pop back out??? Comments much appreciated
------------------ Paul |
Ttriff, you are a genius. It was a woofer and the vacuum cleaner hose did the trick. The dome popped right back to its original position. I REALLY thank you! https://www.avsforum.com/ubb/biggrin.gif
Paul |
I used some chewing-gum once on a 6" mid-range. I only made it worse and wound up throwing the thing out.
Vaccume, very smart. jdb. |
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by
vBSecurity (Pro) -
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by
vB Optimise (Pro) -
User Alert System provided by
Advanced User Tagging (Pro) -
