Changing Bi-poles into Di-poles?.............. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-01-2000, 01:32 PM - Thread Starter
Dave Harper's Avatar
Quoted: 3159 Post(s)
Liked: 1723
As the subject line states, what is needed to convert my current bi-pole surround speakers into di-poles? I know the difference is that one of the drivers of a dipole is 180 degrees out of phase with the other driver (duh) as a bipole, they are both in phase. The question is, can I just open up the speaker cabinet and change the + and - leads of one of the drivers to make it fire out of phase with the other? Is there more involved, say a small circuit of some kind used with the out of phase one? Also, which driver should be the one out of phase, the one facing the front or the one facing the rear?
Thanks in advance for any help you can give!!! i tried a search for this subject and didn't seem to find anything.
Dave Harper
"Harper Home Theater Systems"
A TAWOW Network Member Company
www.TAWOW.com
Dave Harper is offline
Closed Thread Speakers
