Recommendations of $400-$500 Subwoofers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-07-2000, 03:17 PM - Thread Starter
WynsWrld98's Avatar
Quoted: 573 Post(s)
Liked: 217
I'm looking for a powered subwoofer in the price range of $400-$500. Would like to hear from anyone who has bought one in that price range if they like it, where they got it, etc. Thanks in advance!
WynsWrld98 is offline
post #2 of 11 Old 03-08-2000, 08:34 AM
DaveN's Avatar
Quoted: 219 Post(s)
Liked: 92
Try the MTX PS-15 for $470 delivered from Soundpros.com. It got a great write-up in Widescreen Review and IMO is the best sub $1000 powered sub.
Dave
DaveN is offline
post #3 of 11 Old 03-08-2000, 08:50 AM
migliore's Avatar
paradigm ps1200, $600 list, paid $500 at a local dealer. moves mucho air.
rob
Migliore Theater
migliore is offline
post #4 of 11 Old 03-09-2000, 04:27 AM
avdoc's Avatar
Quoted: 222 Post(s)
Liked: 129
I drove an hour to demo the MTX PS-15 and was extremely unimpressed. I would recommend the HSU TN825 (www.hsuresearch.com) or the ACI Quake (www.audioc.com).
Pioneer Elite SC-LX901 Receiver, Magnepan MG2.5/R x4 and CC3 center channel speakers with Sound Anchor stands, Power Sound Audio S3000i subwoofer, Sony UBP-X800 4K Blu-ray player, Sony XBR-75X940E TV, Monoprice Premium HDMI and DH Labs Silver Sonic T-14 speaker cables
avdoc is offline
post #5 of 11 Old 03-09-2000, 05:27 AM
DaveN's Avatar
Quoted: 219 Post(s)
Liked: 92
AVDoc,
What didn't you like about the MTX unit?
Dave
DaveN is offline
post #6 of 11 Old 03-09-2000, 11:42 AM
Lex
Lex's Avatar
A Shiva or equivilent DIY sub will smoke most sub 1000 subs-
The bass output from my 2 DIY subs driven by 315 watts each @ 4 ohms, can't be matched by a pair of MK MX-125s, IMO. What does this tell you, since the drivers appear to be the same? It takes a helluva lot of power to generate powerful bass. Fact is, most commercial subs are underpowered.
It would probably take the equivilent of at least a pair of 18" velos to get the kind of output I get- Thats according to TV.
~125 for the driver, 100 for the sonotube enclosure, and 250 for a decent 2 channel amp, or mono amp (you only need 1 channel).
Lex
My subs- Also a sonotube sub plan- http://www.hometheatertalk.com/DIY_S...ore_plans.html
Lex is offline
post #7 of 11 Old 03-09-2000, 03:23 PM
Rachael Bellomy's Avatar
Location: Knocksville TN, capitol por republica de Polezannia
To WW98, take a look at Paradigm
PDR-10 and PDR-12.They come without
crossover so your processor can dump
de base straight in.Crossover is an option if you need it.The other
Paradigm sub that was recomended is
a bandpass sub and a good one,I used
to have the 8 inch/125 watt little
brother,PBM-800.I like the sound of
the PDR series better and PDR's are
much easier to set-up and adjust.PDR's
are front firing subs.
Ms. Bitchlist
In real life I am Dot Mongur champion of the International Pacman Federation. I don't play the game, I operate it.....no dot is safe from me....
Rachael Bellomy is offline
post #8 of 11 Old 03-09-2000, 10:15 PM
MikeSRC's Avatar
The Definitive Technology Pro Sub 100 at $450 list will kick the butt of any subwoofer in it's price range. Not only on movies, but has great tight, well-defined bass on music as well! Highly recommended! Give it a listen!
Enjoy!
Mike
Surf Remote Control
MikeSRC is offline
post #9 of 11 Old 03-10-2000, 02:03 AM
dave c's Avatar
Just goes to show what a bunch of opinionated people we are here doesn't it?
Good luck deciding!
dave c is offline
post #10 of 11 Old 03-10-2000, 04:15 AM
avdoc's Avatar
Quoted: 222 Post(s)
Liked: 129
DaveN,
The widescreen review article really had me excited about the MTX. But when I measured it at the store with my SPL it didn't have the extension I hoped for. Also, no matter what I seemed to do there were higher frequencies coming out of it and it was just too boomy for my tastes. However, if you are pleased with its performance bully for you. I have an ACI Titan which I am very happy with and few other people like so, se la vi.
Also, I just wanted to remark on the Acoustic Research subs. I had the 12HO (or whatever) in my house and what a piece of crap! Measuring the response with a SPL meter showed it had extension only down to about 45 Hz. Then nothing at all until you got down around 30 and then it was just buzzing and distortion. While it's possible I got a bad unit, it was nowhere near the specifications said it should be.
avdoc is offline
post #11 of 11 Old 03-10-2000, 06:49 AM
DaveN's Avatar
Quoted: 219 Post(s)
Liked: 92
avdoc,
I had to play around with the crossover frequency and room placement to get the sub sounding good. Unfortunately, subs are very dependant on room acoustics.
Dave
DaveN is offline
Closed Thread Speakers
