Help! How to hook up Bass Shakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-23-2000, 09:54 PM - Thread Starter
nickbuol's Avatar
Quoted: 831 Post(s)
Liked: 856
OK. I have 8 Bass Shakers (4ohms each), that I need to hook up to a second receiver that I have. I also want to hook up a passive sub that I have that has 2 8ohm woofers in it (each with their own terminals to hook up the wires). How can this be done so that I get the right ohms? The receiver is an older Pioneer Pro-Logic receiver.
nickbuol is offline
post #2 of 2 Old 03-25-2000, 06:03 AM
David Bott's Avatar
Liked: 45
For all the bass shakers to have one load of 8 ohms...
You need to hook up 4 of them in seies and the same for the other 4. Then hook both groups of four in paraell. That will make your eight 4 ohm speakers look like one speaker with 8 ohms at 2oo watts.
4 + 4 + 4 + 4 = 16 ohms (series)
16 ohms / 2 = 8 ohms (paraell)
Not sure what to do with your other speaker.
David Bott
It's A World Of Entertainment...Experience It!
AV Science Admin
http://www.avscience.com
https://www.avsforum.com
David Bott
Founder - AVSForum
DISCLAIMER: All spelling and grammatical errors done on purpose for the proofreadingly challenged...:)
David Bott is offline
Closed Thread Speakers
