Rear or Side Speakers + more.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-21-2000, 02:38 PM - Thread Starter
controlit's Avatar
I'm completely redoing my HT and will finally have a 'real' rear wall instead of a opening and a staircase.
The HT is located in the basement and will be about 13' wide by 16' long. Ceiling height is only 6' 10" before sheetrocking.
The seating areas will be 12 feet from the screen and about 16' from the screen. Should I prewire for rear speakers, side speakers or both?
Also, I'd like to prewire for sub woofers (1 or 2) and anything else I can think of while the walls and ceilings are open.Where should I figure on the subs placement??
Any comments or suggestions would be appreciated.
Mark
PS I tried the program for figuring out seating placement and room sizes and can't make much out of it. I can still change the room sizes slightly but don't know how to figure out what will work best.
Mark
controlit is offline
Closed Thread Speakers
