Music 96/24 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-28-2000, 05:58 PM - Thread Starter
ChuckTraywick's Avatar
Is there any 96/24 music out? If so where and how do you find it?
Chuck
ChuckTraywick is offline
post #2 of 2 Old 05-28-2000, 10:31 PM
PF
PF's Avatar
Quoted: 26 Post(s)
Liked: 35
Of course there is. And all you need to play it is a $225 Pioneer DV525 DVD player (some of the other Pioneer DVD players will work too), a $10 digital interconnect (Toslink on the Pioneer, if I recall correctly) and a 24/96 capable DAC. MSB makes an inexpensive one and you can go all the way up to a Levinson, Wadia or Accuphase if you want to spend the price of a decent motorcycle. By the way, be sure to select 24/96 output on the Pioneer. You'll know you've got it right when the DAC's 24/96 icon lights.
For music, try www.chesky.com or www.acousticsounds.com or www.elusivedisc.com. I particularly recommend the Patricia Barber CD and most definitely the Rebecca Pidgeon DVD entitled "Four Marys." But I tend to favor female vocalists.
A couple of the Chesky 24/96 disks even have video to go with the audio.
Good luck.
Paul
PF is offline
Closed Thread Speakers
