***The Official Ascend Acoustics Sierra Thread*** - Page 200 - AVS Forum | Home Theater Discussions And Reviews
 1258Likes
post #5971 of 6039 Old 02-09-2020, 12:03 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1963
Originally Posted by raistlin65 View Post
Bright implies that a speaker has emphasized treble over other frequencies. The particular generic tweeter type is not a good indicator of that. Both the specific tweeter and the way that the crossover is designed affects how the tweeter is attenuated relative to the driver.
Yeah. Any speaker can be bright with any tweeter - just turn up the tweeter. It's all relative.
Vikram Iyengar and raistlin65 like this.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is offline
post #5972 of 6039 Old 02-10-2020, 05:08 PM
rysher's Avatar
Quoted: 131 Post(s)
Liked: 68
my wife is playing Ed Sheeran's "How would you feel", the voice and instruments are so clear.
gonna miss my S2's.
rysher is offline
post #5973 of 6039 Old 02-12-2020, 08:10 PM
rysher's Avatar
Quoted: 131 Post(s)
Liked: 68
got the towers, moving the s2's to the back.
thanks to dina and the ascend team.
rysher is offline
post #5974 of 6039 Old 02-13-2020, 05:32 AM
madrac's Avatar
Quoted: 110 Post(s)
Liked: 73
thanks to din and the ascend team.
Nice, Rysher. Those pics look familiar ;-)
LG OLED65E6P, Anthem MRX720, Rogue Atlas Magnum II, UPA7, Ascend Acoustics Sierra Towers with RAAL, Luna Duo center, Sierra 2 surrounds, and HTM200SE front & rear heights, Rythmik E15HP (1, but plan on adding a 2nd), VPI Classic 1+ (VTA Tower, 3D arm), VAS NOVA and Soundsmith Paua cartridges, Manley Chinook, Oppo 103D, Oppo 203. Audio Sensibility and Blue Jeans cabling, Symposium & Isoacoustics isolation products
madrac is offline
post #5975 of 6039 Old 02-13-2020, 05:54 AM
psuKinger's Avatar
Quoted: 1655 Post(s)
Liked: 735
Originally Posted by Vikram Iyengar View Post
Appreciate your thoughts. For my HT room, I plan 4 Lunas, a Luna Duo, and an L12. But the other setup I'm discussing above is my small home office for only critical music listening. Here, the bookshelves will be close to wall behind them and only 4' apart. I'll be 2' from each. Sub can go in at most 3 locations: to left of desk, below desk next to my feet, and to right of desk. I'm concerned about bass management. As you noted its easy just 80 and 120 settings. more concerned about gain tweaking, position tweaking and integrating. Have listened to many badly integrated subs at my friend's apartments and at every big box store that sells subs. Clutter is also a concern in small room.
As others have indicated, I think you're going to want a receiver (or other method) to apply either Audyssey XT32 or Dirac. I don't think it's coincidental that the most commonly recommended ones around here often come with one or the other (or something like a miniDSP that will let you do the same thing without the receiver).
I have owned several Onkyo's, back when Onkyo came with Audyssey, but pre-XT32 (or I didn't buy high enough up on the food chain). The HDMI board went bad on the first one. I still use it via Optical In in my bedroom, but it forced me to upgrade/rebuy much earlier than I planned. The other has been a real tank in terms of a big clean power bank (NR809; 135 wpc into 2 channel) that has run well and driven hard for almost a decade now. But "XT" falls far short of "XT32" for bass management, and that NR809 only came with "XT". My main room now has a Denon x4400h, and XT32 has made a significant improvement for my base management, and I definitely recommend it or some other similar solution.
Some subs, like Rythmik I use in my main room, also have extra knobs that can be turned. Most of those knobs are disabled when applying bass management at an AVR, and particularly if using "LFE In" input, but per their guidance docs if you use "Line In" instead they'll support a 24 dB/octave slope roll off, rather tha 12 db/octave via LFE In, which I've been led to believe is not particularly common...
I stayed "on a safe and well traveled path" with this last round of upgrades. Denon Receiver (with XT32), Ascend Sierra's with RAAL Ribbon, and Rythmik sub, was a recommendation I saw on here over and over again for years before I bought... and FWIW, it's been a significant improvement over the gear it replaced. TIFWIW.
Living Room: Sony x940E; Denon x4400h; Ascend Sierra RAAL Tower L/R's and 2EX center, Ascend HTM-200SE Rears, Rythmik F25 sub. NVidia Shield, ATV4k, OPPO UDP-203, CCA.
Basement: Samsung PN58B650 & LN-T4065F (x2); Onkyo TX-NR809; JBL Studio 530 L/R's, SVS PB-1000 sub. NVidia Shield (x2), Windows Desktop, CCA, Pi running Ropieee.
psuKinger is offline
post #5976 of 6039 Old 02-13-2020, 06:46 AM
Quoted: 861 Post(s)
Liked: 136
Thanks, appreciate it.
Vikram Iyengar is online now
post #5977 of 6039 Old 02-13-2020, 10:15 PM
sdg4vfx's Avatar
Quoted: 255 Post(s)
Liked: 207
thanks to dina and the ascend team...
What sub's are those in the pics?
My neighbors all listen to great music. Whether they like it or not.
sdg4vfx is online now
post #5978 of 6039 Old 02-14-2020, 04:31 AM
rysher's Avatar
Quoted: 131 Post(s)
Liked: 68
outlaw ultra x12's
sdg4vfx likes this.
rysher is offline
post #5979 of 6039 Old 02-14-2020, 10:52 AM
ahender's Avatar
Quoted: 132 Post(s)
Liked: 44
Sierra-1 vs Sierra-2EX
If the Sierra-2EX is a 10, what is the Sierra-1 on a scale of 1-10?
Thanks...Alan
Lp85253 likes this.
ahender is online now
post #5980 of 6039 Old 02-16-2020, 08:37 AM
MrGuru's Avatar
Quoted: 145 Post(s)
Hi again, Ascend thread.
I currently run Sierra 2's for my L/R/C in my home theater setup. Has anyone upgraded their 2's to the 2 EX's? If so, what were your impressions? I'm toying around with the upgrade but am not quite sure it'll be worth ~$1100 over my 2's.
Edit: just typing that out makes me realize it's probably not worth it for the price/performance ratio, but nevertheless, opinions welcome.
Lp85253 likes this.
TV: LG OLED65C8PUA
Front L & R/Center: Sierra-2/Sierra-2 center
Surrounds/Atmos: Polk RTi A3's/RSL C34E's
Receiver/Blu-ray: Marantz SR6012/Oppo 203-D
Subwoofer: Rythmik FV15HP w/ miniDSP 2x4 HD
MrGuru is offline
post #5981 of 6039 Old 02-16-2020, 08:50 AM
Quoted: 32 Post(s)
Liked: 54
Be wary of the upgrade kits. My experience trying to upgrade from the Sierra 1 to the 2EX was that it was not a drop in replacement (one of the driver holes in the enclosure was a hair too small and would not fit the driver). Apparently the upgrade does not go well for a small percentage of people. I ended up keeping my Sierra 1s for surrounds and bought the 2EX.
Given that, if you are happy with what you have, I'd say stay with it. I doubt that the differences would be significant for HT usage.
Lp85253 likes this.
raistlin65 is online now
post #5982 of 6039 Old 02-16-2020, 08:58 AM
Quoted: 2292 Post(s)
Liked: 1968
i too was going to suggest that $1100 is a big chunk of change to gain a moderate amount of improvement.. it may well be worth it to many though.. my suggestion sell the 2's and order the 2ex...you should get enough from the 2's to come out "ahead"..
YAMAHA TSR 5790.. front l/r Dennis Murphy modded emotiva b1's ..BIC v1220.....Emotiva basx10.... infinity alpha 20 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. ascend cbm 170 se... kef q100 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is online now
post #5983 of 6039 Old 02-16-2020, 09:12 PM
Quoted: 134 Post(s)
Liked: 136
If you are upgrading from Sierra-2's to EX's the upgrade will go without a hitch. The issue mentioned happens if you have an early batch of Sierra-1 cabinets from the first few runs when they were released in 2007 or thereabouts. I ran into it when I upgraded to Sierra-2's, where I had to open up the woofer cutouts to make the Sierra-2 woofer fit. When I did the EX upgrade everything was drop-in.
I am very happy with the EX improvements, but mine are for a music only system. For HT I don't know if they will have as big an impact on the sound. They can play louder and have greater dynamics, and are clearer with more detail in the mids.
If you can sell your 2's for more than half the difference of buying new EX's it will be cheaper than the upgrade kits, but I've seen a lot of 2's flood the used market.
Eddy_Z is offline
post #5984 of 6039 Old 02-16-2020, 09:19 PM
aarons915's Avatar
Quoted: 1124 Post(s)
Liked: 901
As others have mentioned, selling your Sierra 2 and buying the EX is probably economically the best move and even better is you can order the EX and A/B them so you know you're making the right decision without any risk.
Lp85253 and Mark6088 like this.
aarons915 is online now
post #5985 of 6039 Old 02-19-2020, 05:12 PM
Mark6088's Avatar
Quoted: 41 Post(s)
Outlaw 2200 Monoblocks with Towers and Horizon Center
I am seriously considering purchasing a pair of Sierra Towers w/Raal and a Horizon center. I already have two Outlaw Audio 2200 monoblocks that power my fronts. I contacted Yamaha about powering the Horizon center (4 ohm) with my Yamaha RX-A2060 and they emphatically told me "No." So, I guess I will purchase an additional Outlaw Monoblock to power the Horizon Center. Just wanted to check with Ascend owners who use Outlaw 2200s to power their LCR and if you have had any issues with this arrangement. I am assuming not, but wanted to double-check before shelling out the $ for another monoblock.
Yamaha Aventage RX-A2060 AVR, 2 X Outlaw Audio Model 2200 Amps (fronts), Klipsch: RP-280F, RP-250F (surrounds), RP-250C, R-14S (F. Presence); SVS SB-3000 SWs X 2, Bluesound Node 2i, Samsung BD-F5900 BP, Roku Ultra, LG OLED 55C6P UHD.
Mark6088 is online now
post #5986 of 6039 Old 02-19-2020, 06:00 PM
Quoted: 45 Post(s)
Liked: 29
My Ascends are powered by Denon 4300 receiver. My basement is large and have openings on both sides and never had any issue. When listening at loud volume the Infinity fan powers up and that's about it. Doubt if you really need these as Ascends are easy to drive.
Ascend Sierra Tower and Horizon with RAAL. HSU VTF-15H MK2. Sony 40ES and Silver Ticket 135.
FIQBAL is offline
post #5987 of 6039 Old 02-19-2020, 06:11 PM
Mark6088's Avatar
Quoted: 41 Post(s)
From my reading through the Ascend Acoustics website forum on the Towers, I got the general sense that the Towers are easy to drive. Since I already own the Outlaw monoblocks for the fronts, that is a moot point. Yamaha says not to run any center under 6 ohms or the RX-A2060 could shut down. That is why I am concerned....
post #5988 of 6039 Old 02-19-2020, 06:14 PM
Ascend's Avatar
Quoted: 228 Post(s)
Liked: 648
Our Horizon, like our towers, has a nominal impedance of 8 ohms. Minimum impedance is not nominal impedance. Most 8 ohm nominal speakers will have a minimum impedance between 4-5 ohms, most 4 ohm nominal speakers will have a minimum impedance of 3.2 ohms or lower.
Our Horizon and Towers are an extremely easy load to drive for basically any decent amp or receiver. Your Yamaha can run the towers and horizons 24/7 without issue.
defmoot, bear123, Lp85253 and 2 others like this.
David Fabrikant
audio professional and soft spoken representative of www.AscendAcoustics.com
Ascend is offline
post #5989 of 6039 Old 02-19-2020, 06:28 PM
Liked: 1968
yamaha is covering their "butt" .. avoiding having to replace your avr should you blow it up,,listen to the advice here and forget you ever talked to cs at yamaha..jmo..ymmv
Mark6088 likes this.
post #5990 of 6039 Old 02-19-2020, 06:38 PM
Mark6088's Avatar
Quoted: 41 Post(s)
Thank you very much David! Just what I needed and wanted to hear. Guess I was not clear on minimal vs nominal impedance. I will press ahead without worrying about purchasing another monoblock!
post #5991 of 6039 Old 02-19-2020, 06:43 PM
Mark6088's Avatar
Quoted: 41 Post(s)
Thanks Lp85253. In Yamaha's defense, when I mentioned 4 ohm, they probably took that to mean nominal impedance. Anyway, I am thankful to all of you on this forum and other AVS forums...I have learned a great deal of valuable information!
Lp85253 likes this.
post #5992 of 6039 Old 02-19-2020, 07:24 PM
Quoted: 45 Post(s)
Liked: 29
Red face
Be careful with these forums!! Soon after you buy your Ascends and other stuff you will hear next "shiny" and "best ever" gears that will make you itching to buy.
FIQBAL is offline
post #5993 of 6039 Old 02-19-2020, 11:51 PM
BrianNLS's Avatar
Quoted: 33 Post(s)
Liked: 32
Can confirm. I ran my Sierra-2 L&R plus Horizon C (and other channels) with my Yamaha RX-A3060 for months with zero issues. None. I've since reconfigured to run my front 3 with my Outlaw 5000, but I did not really need to switch. You will LOVE the Yamaha receiver + Sierra LCR fronts combo.
Yamaha RX-A3060 AV receiver | Outlaw Model 5000 amp
LG 75UH8500 tv | Samsung UBD-K8500 4K BD player
Ascend Acoustics Sierra-2 (L & R), Horizon (C)
Rhythmik LVX12 sub | Atlantic Tech. IC-6 OBA (4x, in ceiling)
Paradigm Mini Monitor surrounds (4x)
BrianNLS is online now
post #5994 of 6039 Old 02-20-2020, 05:23 AM
Mark6088's Avatar
Quoted: 41 Post(s)
If you ran your entire front (LCR) with vitually the same AVR I own (3060 is just 10 wpc more), then I should have zero problem running just the Horizon center with the RX-A2060. Thanks so much for sharing your experience!
BrianNLS likes this.
post #5995 of 6039 Old 02-20-2020, 05:52 AM
Quoted: 101 Post(s)
Liked: 34
I'm not sure about the 2060 but the newer RX-A2080 lists ratings for dynamic power into 8/6/4/2 ohms which implies that they test their amps under those conditions. I've been looking at an upgrade from the RX-A660 for exactly that reason. I may just contact Yamaha and state the question a bit differently, "I'll buy the 2080 if it has the ability of running speakers with Ascend specs, OK ?" I'll bet that they say "yes".
daddyora is online now
post #5996 of 6039 Old 02-20-2020, 07:17 AM
rysher's Avatar
Quoted: 131 Post(s)
Liked: 68
if you already have 2 monoblocks to power the L/R your yamaha can power the center with no problem. you can even power all L/C/R no problem.
i have a denon 4200w which has lower power rating than your yamaha and it powered my Sierra raal towers L/R and sierra raal horizon center no problem, the amp ( ati2005 ) makes it louder at the same volume level though.
rysher is offline
post #5997 of 6039 Old 02-20-2020, 09:09 AM
jsc79's Avatar
Quoted: 494 Post(s)
Liked: 679
I might be misunderstanding your post.
If the system is calibrated correctly it should be the same output volume at the same volume level on the avr would it not? Just as an example, -10 mv on a receiver or pre pro should be 75db avg/95db peaks whether or not you have an amp or not.
derekmoore likes this.
jsc79 is online now
post #5998 of 6039 Old 02-20-2020, 10:02 AM
rysher's Avatar
Quoted: 131 Post(s)
Liked: 68
this is what i know,
with the s2's i can go as low as -10 on movies, sometimes even 5.
with the towers the lowest i've gone is 19 and went back to 24.
rysher is offline
post #5999 of 6039 Old 02-20-2020, 10:16 AM
Quoted: 134 Post(s)
Liked: 136
You are talking about the difference in efficiency, the tower being quite a bit higher so it will play louder with the same wattage vs the S2.
I think what jsc79 is saying is that if calibrated in the AVR they should have similar output at a given volume setting.
So, did you rerun the Audyssey calibration after you swapped the S2's & Towers?
jsc79 and Mark6088 like this.
HT - 5.2.2 ATMOS With: Klipsch DS Series In-wall/In-ceiling Speakers|2x Rythmik LV12F|Denon AVR-X3300W|Sony UBP-X800|Sony XBR-85X900F|AppleTV 4K
Music - 2.1: Ascend Acoustics Sierra-2EX|Rythmik 12" Sealed Direct Servo Sub|Adcom GFA-5500 With LX-Elite mod by Musical Concepts|Parasound Halo P5|Cambridge Audio ID100 Digital Dock|Audio by Van Alstine Humdinger
Eddy_Z is offline
post #6000 of 6039 Old 02-20-2020, 11:19 AM
s2000's Avatar
Quoted: 98 Post(s)
Liked: 79
I also have the Denon 4200...
I had a similar experience before when I had my pioneer elite sc 27. I ran the pre out to a Parasound 5 channel...also NAD 2 channel and currently have a Harmon Kardon Citation 5.1 Bridged. I don't have the parasound or Nad any longer as I was testing which dedicated amp i wanted to keep.
I noticed the volume difference running a higher watt dedicated amplifier compared to the AVR. Definitely have more headroom with the extra power. I did run the room correction on the pioneer and audysey with denon to correct the higher volumes in the front and center channels.
However if you wanted more power to go towards the Center you can also control the DB level manually since most of the dialogue is coming from the Center channel. now if you did want an even output the audysey would measure the distance for you so the Center wouldn't overwhelm the left , right and rears.
Sent from my SM-G950U using Tapatalk
[I]Video: Sony XBR-75X850C 75 inch 4k - Samsung 55inch 4k -58 PANASONIC PZ850u plasma
4k-Blu Ray: Sony UBP x800 - PS3 - oppo 103 Amp and power : Pioneer elite SC - 27 - Monster Power AVS 2000 Reference - DT BP 30s- 10s - citation 5.1
Speakers and Sub : Kef Model reference 1 - DT CLR 2000 - DT UIW BP/A in ceiling rears - DT BPX Rears - JTR Captivator 118HT
s2000 is online now
Reply Speakers
Ascend Acoustics , Acoustics
