Swan Owner's Thread - Page 134 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #3991 of 4006 Old 01-21-2018, 10:19 AM
Quoted: 1782 Post(s)
Liked: 1476
The thing that always confuses me a bit about Swan is that they seem to make a huge array of wildly differently designed speakers with no clear delineation on their website or in their model names for which ones are supposed to be better than others and why.
HT: Sony 940C, Oppo 203, Harman/Kardon DPR1001, Infinity Interlude IL40 x2, Infinity Interlude IL36C, Infinity MS-1 ii x2, Infinity MSW-1
Computer: Elac Uni-Fi UB5 x2, Elac Element EA101EQ integrated amp, SVS SB-12NSD
Dedicated 2-channel: Infinity Intermezzo 4.1t towers, Bluesound Node 2, Emotiva PT-100, Crown XLS 1502, Furman PL-8C
TuteTibiImperes is offline
post #3992 of 4006 Old 01-29-2018, 11:53 AM
Bachelor's Avatar
Quoted: 126 Post(s)
Liked: 130
I'm getting the itch to sell my 6.1's, C3, 2.1s and R3s in Rosewood and to switch over to Monitor Audio Silver 300's, C3150, and not sure on 50s, 100s, or the FXs for rears/backs. What are people moving to after Divas?
I should add that I tried the Power Sound Audio speakers, 110 and 210. I didn't like the sound of the horn tweeter and returned them.
Bachelor is offline
post #3993 of 4006 Old 01-29-2018, 02:13 PM
ggsantafe's Avatar
Quoted: 330 Post(s)
Liked: 262
I'm interested in your comments regarding the PSA speakers, as I've read lots of positive reviews, but have never listened to horn tweeters before. I have 4.2's paired with the C3 upfront and periodically think about making a change, but don't really know where to start, or if there is a significant improvement available without breaking the bank.
ggsantafe is offline
post #3994 of 4006 Old 01-29-2018, 02:29 PM
Bachelor's Avatar
Quoted: 126 Post(s)
Liked: 130
Here is my experience with PSA.
I initially bought a XV15 sub from them and then added a second one. Last year I was thinking what to do next for my setup and thought I would upgrade one of my subs. I contacted Tom as PSA and chatted and I mentioned I was happy with the subs and he brought up his speakers. I knew about them and had read all about them here which I continue to follow but only check off and on.
He had a pair of 110s and a 210C ready to ship and this is when they paid for return shipping so I had little risk on my side. The build quality matches their subs and they aren't necessarily "pretty". I have an Anthem MRX500 and use an external adcom amp for the fronts. I did turned of ARC on the Anthem and just did a plain A/B comaparison against the Diva's 6.1s. They had a more forward in your face sound and not harsh by any means. The highs had a different feel to them and I couldn't get quite the same detail as I do with the Divas. I can hear more dynamic range and separation with the highs with the Divas. I'm also in the pro audio business and to me they sounded like a powered Behringer speaker that is used for DJing. It's loud but just not as detailed as I like for the home. After about a week and listening to content, I decided to ship them back and to discuss a sub upgrade instead. I took the $ from the speakers and bought a S3600 which I'm happy with. I still have a XV15 in the rear to smooth out the bass. (I'm on the fence to swap it out to a sealed S1800 or something)
I've always liked Monitor Audio and my buddy has Silver 6s. I've liked their sound and think I may be ready for a speaker change. I've had them over 15 years.
Bachelor is offline
post #3995 of 4006 Old 01-29-2018, 04:44 PM
Fabricator's Avatar
Quoted: 237 Post(s)
Liked: 136
yeah, but the problem is "return on investment". resale is pretty bad on stuff like this. though some don't care about that.
BenQ HT1070 . Da-Lite HP 2.8 119"
ULTIMAX 18-22, 14cf ported, x2. 6000DSP.
XPA-3, PIONEER VSX-01TXH, SWANS 6.1 & C3
Fabricator is offline
post #3996 of 4006 Old 01-30-2018, 07:05 AM
ggsantafe's Avatar
Quoted: 330 Post(s)
Liked: 262
Thanks for sharing your observations, as it turns out, I also have PSA subs (XS-15 & XS-30) so I was naturally inclined to also consider the PSA speakers. It certainly helps that you have an opportunity to listen to the Monitors at your buddy's house - good luck with your audio quest!
post #3997 of 4006 Old 03-12-2018, 09:38 AM
Bachelor's Avatar
Quoted: 126 Post(s)
Liked: 130
Well here is my update, I upgraded to Revel speakers. It wasn't cheap and if I didn't have the desire to see what's out there, i'd be fine with the Diva's for many years to come.
I got a pair of F206s, a big C208 for the center and I decided to do 4 W763 in walls for the rears. This allowed better placement in the room and they blend well with the fronts.
I liked the sound of Revel and the off axis sound is great for more coverage than just the sweet spot. The center speaker is a beast and I decided not to settle for the C205 which is a smaller and about 1/2 the price.
I've had them for about a month and am enjoying them. Now I need to sell off my Divas......
Bachelor is offline
post #3998 of 4006 Old 06-02-2018, 09:51 AM
Liked: 1
Just reviving a VERY old very dead thread.
Looking for any information anyone might have on this pair of Swans I just picked up. They're old enough that they don't even use HiVi drivers, pre-merger. It's a 6.5" Audax woofer and a 1" Morel tweeter. Rosewood veneer, bi-wireable, separate high and low freq crossovers in a sealed enclosure on the bottom of the tower. There doesn't seem to be a model name, just a serial number.
Any info that anyone might have would be greatly appreciated. They sound great and look great.
ID:	2410762   Click image for larger version
ID:	2410766   Click image for larger version
zeagan is offline
post #3999 of 4006 Old 06-12-2018, 11:40 PM
audiostar88's Avatar
Quoted: 23 Post(s)
Liked: 30
Looks like one of the earliest models when it still was canada based before Hivi bought it.
Sent from my SM-G955F using Tapatalk
audiostar88 is offline
post #4000 of 4006 Old 07-05-2018, 09:22 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6409 Post(s)
Liked: 6404
Originally Posted by Ka7niq View Post
LOL, Cleveland Plasma sounds like a blood bank or something
We have gotten those calls.....lol
Originally Posted by goodtimes View Post
I hope someone like Audio Insider comes into play to bring Swans back to life on the entry to mid level. Cleveland Plasma has been a great asset in the HiVi/Swan community from everything I have read. Thanks CP!
Ya, this thread does need some life......selling off our M806, M808, and M6.
Cleveland Plasma is offline
post #4001 of 4006 Old 07-05-2018, 09:48 AM
Jon Lane's Avatar
Quoted: 311 Post(s)
Liked: 1035
A couple of years ago I went into the HiVi/Swans room at THE S.H.O.W. Newport Beach. They had a pair of huge high end Swans (I forget the model) set up and a few smaller models in another room. The representative had no music playing and was talking quite a bit about swans presence in the US. He commented on needing brick and mortar dealers and the fact that Swans were getting a reputation for being cheap Chinese speakers and they needed to bring up their image. Long story...the guy rubbed me the wrong way and I was just sitting in on the conversation. I remember thinking if this guy was to become a major proponent of HiVi/Swans in the US things aren't looking good for them
For better or worse things change. There's more to a line than good product, and brand missteps can hurt.
We're also liquidating our remaining few desktop models.
Jon Lane is offline
post #4002 of 4006 Old 10-18-2018, 09:33 PM
mkiv808's Avatar
Quoted: 36 Post(s)
I still use 6.1’s as mains. I wonder how much I would have to spend to do better?
mkiv808 is online now
post #4003 of 4006 Old 10-18-2018, 09:44 PM
Bachelor's Avatar
Quoted: 126 Post(s)
Liked: 130
I replaced my 6.1s with Revel f206's. They have a neutral sound and I'm enjoying them. I still have my 6.1s in another room trying to decide what to do with them...
Bachelor is offline
post #4004 of 4006 Old 11-26-2018, 06:52 PM
Liked: 1
Hi everyone--I'm a bit late to the party but just picked up some Swans! I upgraded from my old Fluance XL7F and XL7C 3.1 to a full Swans M6 5.1--the difference is incredible. Listening in stereo is a completely different experience, and the enormous center channel really keeps up with the towers.
I'm still holding on to my Denon AVR-S510BT for now, but will soon upgrade to an X series, mostly for improved room correction. Here's to hoping I'll avoid the upgrade bug for a few years!
Alcapa is offline
post #4005 of 4006 Old 11-30-2018, 10:24 AM
ggsantafe's Avatar
Quoted: 330 Post(s)
Liked: 262
Swan Diva C3
If anyone is interested in a Diva C3 Center speaker - I just posted an ad in the classified section.
post #4006 of 4006 Old 07-10-2019, 02:31 PM
Liked: 1
Hello, I would like to get a set of Swan M20-5.1 MKII, but I can't find any review about them. From what I understand they are the 5.1 version of the M20W? You folks seem pretty with your Swan, do you recommend them?
Robertoso is offline
Reply Speakers
Oppo Dv 981hd Universal Dvd Player With Hdmi 1080p Up Converting Divx Sacd , Samsung Lns4096d 40 Inch Lcd Hdtv
