The OFFICIAL JBL Owners Thread - Page 580 - AVS Forum | Home Theater Discussions And Reviews
 445Likes
post #17371 of 17575 Old 06-06-2018, 01:33 PM
filecat13's Avatar
Quoted: 94 Post(s)
Liked: 190
Originally Posted by Eduardo Almeida Costa View Post
Hello everyone.
I got a JBL Pulse 3, 4 months ago. Two weeks ago I used it normally and turned it off normally.
After that, some hours later, I noticed that the JBL Pulse 3 turns on and off by itself, and was not charging the battery normally, the LED would flash red while charging.
I tried to use the JBL Pulse but it turned off without reason, and it came at a time that did not care anymore.
I did not take it immediately to the shop to fix it, because there is not one in my city.
I was scheduled to go to another city now in the month of June.
But last night the JBL Pulse 3 turn on of nowhere, and the noise woke me up. I was scared when I heard the box and saw a purple light in the room, I thought it was some lost soul. Anyway, now the JBL Pulse 3 works normally.
I connected via Bluetooth, I tested all styles of light through the JBL Connect app. I used the battery until exhausted, charged normally and JBL Pulse 3 is working normally.
Can anyone tell me what happened?
Will JBL Pulse 3 again have a malfunction?
Or was JBL Pulse 3 possessed by some spirit?
Thanks, Eduardo.
It could be a demon, but look at possible reasons for its demon-like behavior.
Read the 254 comments in this iFixit thread. (Scroll down to get to them.)
https://www.ifixit.com/Wiki/JBL_Charge_Troublshooting
What I can afford, when I can afford it...
filecat13 is offline
post #17372 of 17575 Old 06-08-2018, 10:25 PM
Liked: 2
I was wondering if anyone knows a bit about the HTPS400. I have 2 that I bought used and they have both needed fixing but I've got one working great now and the 2nd one should be repairable.
The one that doesn't work seems to have a loose lead wire. From the terminal side everything looks fine so I assume it's the solder point to the voice coil that has come loose. I believe to access that I would need to remove the dust cap.
I've been trying to prepare for the worst and find a dust cap before I attempt the repair but I can't find a suitable one anywhere. No one seems to sell parts for this woofer and I'm not even sure what materials it's made of.
According to JBL's literature it is a "metal alloy driver" and owner's manual says "aluminum cone". By tapping on the dust cap I would guess it's black painted aluminum and it's about 5.25" with a lip on it. I haven't seen anything for sale that is similar.
Any info or suggestions would be greatly appreciated.
ckwaters is offline
post #17373 of 17575 Old 06-09-2018, 05:24 AM
rdgrimes's Avatar
Quoted: 3889 Post(s)
Liked: 3137
Its a one of a kind driver. Any dust cap should do fine, but yes its aluminum.
rdgrimes is offline
post #17374 of 17575 Old 06-09-2018, 09:15 AM
EZ-Rhino's Avatar
Quoted: 20 Post(s)
Liked: 32
Definitely worth fixing. I have six of them, five working. The driver was over $700 when available. I bought a spare driver from ebay but it is a rare find.
EZ-Rhino is offline
post #17375 of 17575 Old 06-12-2018, 08:32 AM
Liked: 2
I took the speaker apart again yesterday to have a look and the bad solder point was on the connector side....yeah! So you desoldered it, cleaned the solder point which looked discolored from heat and stuff, then resoldered the lead wire. All is good now! I can't wait to watch my first movie with 2 of these subs. Thanks
skypop and JosephTonyStark like this.
ckwaters is offline
post #17376 of 17575 Old 06-15-2018, 10:43 PM
stopdrpnro's Avatar
Quoted: 53 Post(s)
Does anyone have any experience with the JBL Studio or Arena series in-ceiling speakers? Looking to possibly upgrade my Atmos speakers which are Yamaha ic600s. Both the studio and Arena have lower sensitivity than the Yamahas, but they would match my studio LCR speakers. Any thoughts? Thanks in advance
stopdrpnro is offline
post #17377 of 17575 Old 06-16-2018, 07:45 AM
dapakattack's Avatar
Quoted: 40 Post(s)
Hello All,
I need some advice for a couple of speakers to use for Atmos 5.2.1. I have recently upgraded my system from the AJ Pioneer setup to JBL Studio 230s up front, 235 center, and 220s in the rear. I am using the AJ Pioneer Bookshelves as near ceiling-on wall Atmos speakers.
I would like to go with another set of JBLs. I've been waiting for the 220s to go back on sale, but should I consider another JBL speaker?
Maybe the JBL C1Pro or the Arena B15?
Thank you for the help,
Daniel
dapakattack is offline
post #17378 of 17575 Old 06-16-2018, 08:09 AM
tom703's Avatar
Quoted: 92 Post(s)
Liked: 93
Originally Posted by dapakattack View Post
Hello All,
Daniel
I have one pair of Studio 230s for overheads, and love them, so plan on adding a second pair when I get some other stuff paid off. If you use 230s for all your peripherals, you wont be disappointed.
Samsung UN55HU8550/SEK-3500U 4K TV, and UBD-K8500 BR Player. Receivers: Denon AVR-X4300H - 5.1.4., JBL Spearkers: Center Studio 235C, 2 - Studio 590 - L&R, ES250PBK Sub, 2 - ES90 Towers - L&R surround, 2 - Studio 230 - front height, 2 - ES20 - rear height. Video production: Resolve Studio 15, Windows 10 Pro, CPU i9 9940X, MSI X299 Carbon MB, EVGA RTX 2080, 128GB (4x16)Corsair Vengeance LPX DDR4 3200, GH5 camera, Zhiyun Crane 2 Gimble
tom703 is offline
post #17379 of 17575 Old 06-17-2018, 09:57 AM
Quoted: 52 Post(s)
Liked: 7
JBL Studio 590
These seem like awesome home theater speakers- technology, design, sensitivity, clarity , dispersion , disruption, etc; does anyone have them or do they fail to impress “audio addicts” ?
deucevantage is offline
post #17380 of 17575 Old 06-17-2018, 03:53 PM
tom703's Avatar
Quoted: 92 Post(s)
Liked: 93
I have a pair of 590s for left and right fronts, and they are awesome!
JosephTonyStark likes this.
tom703 is offline
post #17381 of 17575 Old 06-19-2018, 04:16 PM
JosephTonyStark's Avatar
Quoted: 251 Post(s)
Liked: 160
Do you not like the sound of your Yamaha overheads?
Sent from my GT-N5110 using Tapatalk
TV: Samsung 65" UHD LED | Sources: PS4; Panasonic DMP-BT460; LG UB870; Dell 7010 SFF; Roku Ultra | AVP: Marantz AV8802A | Amps: Emotiva XPA-1L\100 (LR\C); Outlaw Audio 7125 | Front LR\C: JBL Studio 590\Studio 520C | Surrounds: JBL P520WS | Subs: PSA S1801 | Heights: JBL Pro Control CRV (2)
JosephTonyStark is offline
post #17382 of 17575 Old 06-20-2018, 07:19 AM
stopdrpnro's Avatar
Quoted: 53 Post(s)
I find i have to crank the Atmos channels to +12db to hear the effects. I'm feeding them 60w/channel from an audio control amp. Not sure if the efficiency on the Yamahas is overstated or if it's my programming
post #17383 of 17575 Old 07-02-2018, 01:33 PM
tcramer's Avatar
Quoted: 414 Post(s)
Liked: 196
Fairly new to the JBL front, but I have a couple questions. I purchased 3 590's when they were 50% off a couple weeks ago for a buddy's theater space, but now I need to get a set of bookshelves for myself. The usage is primarily movies and TV with fairly minimal music.
With the current sales, what are considered the best options? I was leaning towards the 235C with the 230 bookshelves. That the best combo?
Centers
- Studio 520C
- Studio 235C
L and Rs
- Studio 230s
- Studio 220s
tcramer is offline
post #17384 of 17575 Old 07-02-2018, 01:41 PM
tom703's Avatar
Quoted: 92 Post(s)
Liked: 93
I would recommend the 235C and the 230s.
tom703 is offline
post #17385 of 17575 Old 07-03-2018, 01:17 PM
LNEWoLF's Avatar
Quoted: 477 Post(s)
Liked: 293
The bestest most goodest option would be JBL 590’s
ALL the way around. Left, center, right, surround and surround back
Twin Pioneer AVR Locomotives-Elite SC 97, SC 1222 7.2.4, DOLBY Atmos and DTS X, (Front Pre Out,) JBL Pro Synthesis LS Series Speakers, F L R-LS80, Cen-LS, S L R-LS60, SB L R-LS60, 4 Dolby Atmos Enabled Klipsch R41SA, Twin Klipsch R120SW. Mitz 73740 DLP, Sony UBP-X800, ATV G4, Yamaha ATS 1060 Sound Bar, True Depth Firestorm 2.0 3D Glasses, Harmony Hub with Utlimate 1 Remote, Broadlink RM Pro2, EYE Pad Air, Winegard FL6550A
LNEWoLF is offline
post #17386 of 17575 Old 07-03-2018, 02:54 PM
Quoted: 251 Post(s)
Liked: 160
Sounds dreamy....
post #17387 of 17575 Old 07-03-2018, 03:12 PM
tcramer's Avatar
Quoted: 414 Post(s)
Liked: 196
Sounds dreamy....
Can you run that option by the wife and see what she thinks of it?
tcramer is offline
post #17388 of 17575 Old 07-03-2018, 08:21 PM
Quoted: 251 Post(s)
Liked: 160
No need, my present place couldn't handle all that and I dont have a projector/AT screen to allow for an identical tower LCR.
post #17389 of 17575 Old 07-04-2018, 11:42 AM
skypop's Avatar
Quoted: 387 Post(s)
Liked: 266
No problem,next time you're in NY get in touch for a demo,you and your wife will be leaving with your faces in a permanent smile!
tcramer likes this.
2 Channel: Fi 2A3 mono's,Hovland HP100,Technics SP10MK2/SME/Benz....HT:126" Seymour AT Screen,JBL Studio 590's for LCR, Side and Rear Surrounds. Jbl SCS8'S for Fr Heights, and Rear Heights,2 Epik Empire Subs,2 Behringer B1200D Midbass Subs,Marantz 7702MK2,Proceed Amp-5,Outlaw 7125,Panasonic UB820 ,Toshiba HD35,JVC RS600. Black Velvet.
skypop is online now
post #17390 of 17575 Old 07-04-2018, 02:26 PM
bommai's Avatar
Quoted: 624 Post(s)
Liked: 203
I am running the 590 rotated as center for the past year and love it. Way better than the 520.
Sent from my iPhone using Tapatalk Pro
wassup likes this.
bommai is offline
post #17391 of 17575 Old 07-05-2018, 01:59 AM
Rick88's Avatar
Quoted: 20 Post(s)
Liked: 58
I've had the 4306 monitors for a few months now, and I am in love with them!!
Pardon the photos posting sideways, don't know why they do that...
ID:	2424576   Click image for larger version
ID:	2424578   Click image for larger version
ID:	2424580   Click image for larger version
ID:	2424582   Click image for larger version
ID:	2424586   Click image for larger version
Rick88 is offline
post #17392 of 17575 Old 07-05-2018, 08:58 AM
LNEWoLF's Avatar
Quoted: 477 Post(s)
Liked: 293
Da WAF
[img][/img]
LNEWoLF is offline
post #17393 of 17575 Old 07-05-2018, 01:16 PM
tcramer's Avatar
Quoted: 414 Post(s)
Liked: 196
Centers
- Studio 520C
- Studio 235C
L and Rs
- Studio 230s
- Studio 220s
Well I have the 230's and both of the centers coming tomorrow. Figured with 30 days free returns, I may as well try them both.
tcramer is offline
post #17394 of 17575 Old 07-05-2018, 02:36 PM
tom703's Avatar
Quoted: 92 Post(s)
Liked: 93
I will be interested in your center comparison thoughts after testing.
tom703 is offline
post #17395 of 17575 Old 07-05-2018, 07:22 PM
Quoted: 251 Post(s)
Liked: 160
Those look cool
post #17396 of 17575 Old 07-06-2018, 06:12 AM
ack_bk's Avatar
Quoted: 1345 Post(s)
Liked: 1503
Look what's behind the screen
I friggin love these speakers.
dholmes54, jacbri and skypop like this.
ack_bk is offline
post #17397 of 17575 Old 07-06-2018, 09:43 PM
Quoted: 251 Post(s)
Liked: 160
Nice. What sub is that?
post #17398 of 17575 Old 07-07-2018, 06:02 AM
ack_bk's Avatar
Liked: 1503
Monolith 15. One in front, one in back. One day I would like 2 more.
ack_bk is offline
post #17399 of 17575 Old 07-09-2018, 09:15 PM
JackOften's Avatar
Quoted: 37 Post(s)
Liked: 25
Help with mounting JBL Studio 220's vertical (normal) or horizontal as front height speakers!!
I've purchased a couple of JBL Studio 220's as height speakers, but I can't get more than a 10 degree tilt on them when my main listening position is about 40 degrees down. Now I can drill some holes in those 220's and get the tilt I want, but I don't feel great about that.
It looks like the off-axis response is better horizontally than vertically on the 220's... anyone know what's the downside of positioning them horizontally would be? My seating positions are are within 10 degrees of center horizontally (3-seat couch 12-feet away), so I'm not too concerned about the smaller off axis range when the speaker is positioned horizontally.
Video: Epson 5040ub, 120" Seymour AT screen
Audio:Onkyo TX-RZ730, 3x Outlaw 2200, Outlaw 5000, Monoprice Unity 200w, miniDSP
Speakers: 2x JBL Studio 230, JBL Studio 235c, 8x JBL Studio 220. Subs: 2x HSU ULS-15 MK I
JackOften is offline
post #17400 of 17575 Old 07-09-2018, 10:25 PM
tom703's Avatar
Quoted: 92 Post(s)
Liked: 93
I have a pair of Studio 230s as front Heights at about 15 degrees tilt. The bracket does that without any drilling. Like you, I don't want to drill into my speaker enclosures. My MLP is about 9 feet back. I have no problem getting a good Audyssey calibration that sounds great to me. From ear level to speaker, you may not be off axis all that much. The ear level to the speaker is much different than floor to speaker. You might want to give it a try and see how it sounds.
tom703 is offline
Reply Speakers
520c , Athena , Center Channel Speaker Sku Pas749099 , Center Channel Speakers , Jbl , Jbl Balboa Sub 10 Inch Powered Subwoofer , Jbl G200 Bookshelf Speakers , Jbl Harman Kardon , Jbl Lc1 3 Way High Performance Dual 5 1 4 Inch Center Channel Loudspeaker Black , Jbl Lc2 4 Way High Performance 6 Inch Dual Wall Mountable Center Channel Loudspeaker Black , Jbl Northridge E30 2 Way 6 Inch Bookshelf Speakers Pair Black Ash , Jbl Professional , Jbl S Center Center Channel Speaker , jbl studio 5 series
