Martin Logan Owners Thread - Page 36 - AVS Forum | Home Theater Discussions And Reviews
 282Likes
post #1051 of 2404 Old 11-01-2014, 01:36 PM
DrMichael's Avatar
Quoted: 484 Post(s)
Liked: 275
Originally Posted by Slickman View Post
I wanted to get the 50XT center and 2 35XT's for my front soundstage but it looks like the new XT speakers are junkers. What should I get then, 2 Motion 40s and a C2 for the front?
I can honestly say the new XT line is a large improvement over last generation. I have owned every motion speaker other than the 2's. I kept the 40s for the rears while having the 60's in the front and 50 for the center. The new line shows a large improvement in the overall bass and midrange. They have incredible staging in 2 channel and a very wide stage for movies. Everything I have read agrees with my assessment. Not sure where you are getting the assumption that they are junkers....
|Tch0rT| likes this.
DrMichael is offline
post #1052 of 2404 Old 11-04-2014, 01:17 PM
Craig Peer's Avatar
Quoted: 7195 Post(s)
Liked: 8592
The XT's sounded excellent at Cedia. That said, I don't plan on replacing my Motion 40's with XT's as my theater isn't big enough to need larger L / R front tower speakers. The 40's are more than adequate in my room.
TomC1315 likes this.
Craig Peer is offline
post #1053 of 2404 Old 11-05-2014, 08:52 AM
TL24's Avatar
Quoted: 14 Post(s)
What gauge wires are you guys running with the Motion 40's? My current setup consists of a Pioneer Elite SC-71 and the Motion 40's will be bi-amped.
Martin Logan specifically states the following:
"Use the best speaker cables you can. The length and type of speaker cable used in your system will have an audible effect. Under no circumstance should a wire of gauge higher (thinner) than #16 be used. In general, the longer the length used, the greater the necessity of a lower gauge, and the lower the gauge, the better the sound, with diminishing returns setting in around #8 to #12.
A variety of cables are available whose manufacturers claim better performance than standard heavy gauge wire. We have verified this in many cases, and the improvements available are often more noticeable than the differences between wires of different gauge. The effects of cables may be masked if equipment is not of the highest quality.
So I guess I'm a bit confused as to what's best for me? The max length will be around 5-6 feet as the speakers will not be far away from the receiver at all so 5-6 feet should be all I need. Any assistance in this matter would be greatly appreciated!
TV: Panasonic Viera VT50 55 | A/V Receiver: Pioneer Elite SC-71 | Speakers: Martin Logan Motion 40's (Bi-Amped) | Cables: AudioQuest Cinnamon HDMI Cables + AudioQuest Rocket 33's (split)
TL24 is offline
post #1054 of 2404 Old 11-05-2014, 09:00 AM
SubSolar's Avatar
Quoted: 119 Post(s)
Liked: 40
Don't waste your money, they all sound the same. Check this chart:
http://en.wikipedia.org/wiki/Speaker_wire#Wire_gauge
I run 12 gauge but it's cause I have electrostats which go below 1 ohm. I've used Blue Jeans Cable and recently got these:
http://sewelldirect.com/Silverback-S...Terminated.asp
|Tch0rT| likes this.
Samsung 85" 4K, Dolby Atmos 7.1.4 with MartinLogan Theos, Stage, Motion 15, EM-R, Seaton Submersive F2, Denon AVR-X5200W
SubSolar is offline
post #1055 of 2404 Old 11-05-2014, 09:17 AM
Quoted: 62 Post(s)
Liked: 2
i have a question on wires...
i have montis and went with straight wire that has 4 strands of 18 gauge OFC bound together what would that be equivalent to ? is that enough?
Larryfl is offline
post #1056 of 2404 Old 11-05-2014, 09:33 AM
SubSolar's Avatar
Quoted: 119 Post(s)
Liked: 40
Not sure, maybe 12?
http://home.hiwaay.net/~rgs/awgcalculator.html
SubSolar is offline
post #1057 of 2404 Old 11-05-2014, 09:48 AM
Slickman's Avatar
Quoted: 512 Post(s)
Liked: 464
I didn't think the XT line was any good because no one talks about them. I was thinking of getting 2 35XT and a 50XT for my front soundstage. I heard bookshelves are no good for home theater and can't play very loud though, is this true?
Slickman is offline
post #1058 of 2404 Old 11-05-2014, 10:34 AM
mogrub's Avatar
Quoted: 270 Post(s)
Liked: 260
... I run 12 gauge but it's cause I have electrostats which go below 1 ohm.
Sub, how long are those runs?
"Get me a scotch. I'm starving." JVC DLA RS-540U, Stewart ST 130 G3, Yamaha RX-A3080, Emotiva XPA-3, Panasonic UB820, Oppo 103D, Xfinity X1, Roku, ATV, Harmony 900.  Atmos 7.2.4 via Martin Logan Stage-X, Martin Logan Theos x2, Martin Logan FX x2, Sonance VP69 x2, Sonance VP66 x4, SVS PC12-NSD x2. Viewer's choice between Palliser recliners x7 or Great Dane beds x2.
mogrub is offline
post #1059 of 2404 Old 11-05-2014, 12:56 PM
SubSolar's Avatar
Quoted: 119 Post(s)
Liked: 40
Six to 10 feet. I actually had some 8 gauge but they were too bulky and overkill for that length. For my Atmos speakers, I ran 12 gauge too. Longest runs were probably 30-40 feet.
SubSolar is offline
post #1060 of 2404 Old 11-05-2014, 02:15 PM
DrMichael's Avatar
Quoted: 484 Post(s)
Liked: 275
I don't understand your logic on the lack of people talking about a speaker meaning a speaker is bad. They are so new that not many people have them yet. The local Magnolia does not even have the demo speakers yet. There are no reviews because they are so new. As far as the bookshelf speakers....you can use them in a HT but it depends what you want to get out of them.....You can play them loud as long as the crossover is set correctly in your AVR.
|Tch0rT| likes this.
post #1061 of 2404 Old 11-05-2014, 04:09 PM
Slickman's Avatar
Quoted: 512 Post(s)
Liked: 464
I cross all my speakers at 80hz and let my SB13 Ultra do the low bass.
Slickman is offline
post #1062 of 2404 Old 11-05-2014, 07:08 PM
Tampa Jeff's Avatar
What would be your opinion on Martin Logan's Motion C center. I currently have a 5.1 setup with a pair of ML Motion 15's up front with a Motion C center, and 2 Motion 4's in the rear. Sub is a ML Dynamo. Speakers are being driven by a Yamaha RX-A2000. Do you think their would be a noticeable difference switching to a Motion 30 or even the new Motion 50 XT center?
Tampa Jeff is offline
post #1063 of 2404 Old 11-05-2014, 10:06 PM
mogrub's Avatar
Quoted: 270 Post(s)
Liked: 260
I hear ya. The 8's are crazy bulky. Kinda like pipe that bends a little bit. But the 10's are a piece of work too. I ran long 10's for stats last year, with wall drops. It was the right thing to do, but zero fun. It gets much easier to work with starting at 12. ✌️
mogrub is offline
post #1064 of 2404 Old 11-06-2014, 10:59 AM
simp1yamazn's Avatar
Quoted: 112 Post(s)
Liked: 88
I ran a paid of Montis for about a year with 14 gauge wire, about 6 ft runs to each without any trouble. When asking questions about speaker wire typically you will get 2 answers:
1. Quality of the wire makes a very noticeable and tangible improvement to sound so buy as heavy and high quality as you can find/afford
2. Quality of the wire makes no difference at all so buy as inexpensive correct gauge speaker wire you can find.
I am in camp #2 . Here's what I would buy: http://www.monoprice.com/Category?c_id=102&cp_id=10239
probably the 12 awg, CL2 rated if you are going in-wall.
simp1yamazn is offline
post #1065 of 2404 Old 11-06-2014, 11:27 AM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 116
I use the same cable, its great for the price, just need a 25 footer for my rears.
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #1066 of 2404 Old 11-06-2014, 12:59 PM
DonH50's Avatar
Quoted: 3311 Post(s)
Liked: 3421
A hair smaller than a single 12 AWG wire.
Yes.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #1067 of 2404 Old 11-13-2014, 03:18 AM
tritiumglo's Avatar
Quoted: 376 Post(s)
Liked: 167
The NEOLITH is coming.
NAD M15 /NAD M25 / PSB STRATUS GOLD / PSB STRATUS 6C /DENON AVR 3300/CARVER TFM 45/35 - ANTHEM MCA3 / NAD T163
IMAGE DYNAMICS / INFINITY RS3 / POLK MONITOR 10/ALTEC 501 / INTEGRA 50.3/PARADIGM DSP 3400 / GOLDENEAR AON3 / HK AVI 200
An Observer of many philosophies, a slave to none.
tritiumglo is offline
post #1068 of 2404 Old 11-13-2014, 04:23 AM
TomC1315's Avatar
Quoted: 136 Post(s)
Liked: 149
Booyah !!!
MartinLogan Motion 40s / 30 / LX16s
Marantz SR5007 / UD5007
Emotiva XPA-3
SVS SB13ultra
exercise room: MartinLogan LX16s / SVS SB2000
TomC1315 is offline
post #1069 of 2404 Old 11-13-2014, 04:34 AM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 159
That just looks like something I would never be able to afford
Holiday121 is offline
post #1070 of 2404 Old 11-13-2014, 08:38 AM
brenro's Avatar
Originally Posted by akm3 View Post
Panel replacements used to be reasonably priced, but then ML said they weren't going to do them anymore, then they relented but increased the price 3x effectively not doing them anymore.
Not disagreeing but the difference is once upon a time you could buy new old stock replacement panels. Now that those are sold out you have to pay for them to make you new panels which understandably doesn't make it any cheaper. On the plus side their new panels are made better than the originals. Still, it makes considering used ML's a little harder.
brenro is offline
post #1071 of 2404 Old 11-13-2014, 12:55 PM
tritiumglo's Avatar
Quoted: 376 Post(s)
Liked: 167
The ML dealer where I listened to Theos said the panels should never go bad!!!! So this is not true? Are these going bad over time or are they being damaged from clipping/overpowering etc?????
post #1072 of 2404 Old 11-14-2014, 12:50 AM
RayDunzl's Avatar
Quoted: 1231 Post(s)
Liked: 1437
Mine are 16 years old and work fine.
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #1073 of 2404 Old 11-17-2014, 06:17 AM
Quoted: 112 Post(s)
Liked: 88
Not an ML owner any more, but your dealer is wrong. They do degrade and wear out over time. That being said, they are much more robust than they used to be. The amount of direct sunlight, heat, humidity, how much dust they accumulate, all those things will factor into how long the panels last. That being said, we are talking well over 10 years of usable life, just maybe not the 30 years certain cone speakers will give you.
post #1074 of 2404 Old 11-17-2014, 07:30 AM
DonH50's Avatar
Liked: 3421
And don't forget that cone speakers are also sensitive to their environment. Some may last thirty years, many may not, depends upon their environment. Few speakers stand up well to sunlight, smoke, heavy dust, high humidity, etc. Nothing lasts forever.
DonH50 is offline
post #1075 of 2404 Old 11-17-2014, 08:29 AM
Mike Garrett's Avatar
Quoted: 12798 Post(s)
Liked: 10430
You really need a person standing next to them to really understand the size of those things.
Mike Garrett is offline
post #1076 of 2404 Old 11-17-2014, 10:10 AM
InfinityBob's Avatar
I do not knowwhy you are asking me? Mine were damaged is shipping. I wish I never purchased them.
InfinityBob is offline
post #1077 of 2404 Old 11-17-2014, 10:22 AM
Craig Peer's Avatar
Liked: 8592
post #1078 of 2404 Old 11-17-2014, 12:27 PM
DonH50's Avatar
Liked: 3421
Take it again, Craig, but stand on the table with it or put it on the ground first! BTW, how tall are you?
I haven't seen a spec sheet yet, just the press release saying 22" x 48" ESL panel, 12" front-firing and 15" rear-firing woofers. Claimed response down to 23 Hz. So yeah, it's big. Entering SoundLabs territory...
DonH50 is offline
post #1079 of 2404 Old 11-17-2014, 04:30 PM
Craig Peer's Avatar
Liked: 8592
That's Mike at CEDIA in Sept. - Mike isn't short by any means.
post #1080 of 2404 Old 11-17-2014, 08:29 PM
DonH50's Avatar
Liked: 3421
Sorry, I've never been good with names...
DonH50 is offline
Reply Speakers
Polk Audio Monitor 50 2 Way Floorstanding Speaker Single Cherry
