Triad Owner's Thread - Page 266 - AVS Forum | Home Theater Discussions And Reviews
 880Likes
post #7951 of 9868 Old 04-18-2016, 08:09 AM
ab325is's Avatar
Liked: 1
Originally Posted by Mike Garrett View Post
If you stay 10db below reference at your listening position, you should be okay. That is still pretty loud.
That's probably plenty loud, but would I be better off with the Silver/6 LCR for the fronts?
Did some measuring yesterday and I only have 10 1/2" in the wall for the rear right so thinking I may need to go with the Bronze/4 Sat for the rears. Would that work?
ab325is is offline
post #7952 of 9868 Old 04-18-2016, 10:42 AM
batpig's Avatar
Quoted: 4854 Post(s)
Liked: 5184
As always "it depends" -- do you really need to play at reference levels or not? Would you feel bad if you didn't have the potential for that in your back pocket? Or will you realistically not be playing that loud, ever, and are OK with buying what you actually need?
The room isn't that large and honestly you'd be fine with Bronze LCR if you are never going to play above -10 (again, which is loud). The difference between Bronze and Silver is the SPL capability (6.5" woofers instead of 5.25" and larger cabinets).
One question I have is about your surrounds -- it looks like a 5.1 system but due to the open floorplan is it accurate that both surrounds will be directly behind the couch and fairly narrowly spaced? That is basically the location for back surrounds and the primary surrounds, ideally, should be spaced to the sides and slightly behind in a 5.1, not directly behind.
Looks like you're planning to use the dipole/bipole style InWall Bronze Surrounds? That's probably the best choice for that location, but is ceiling mounting an option? If so you could theoretically even do a full 7.1 system and get the side surrounds spread out a bit wider (using something like the InCeiling Bronze Sat with the angled baffle, spread wider to either side of the primary couch and firing across).
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #7953 of 9868 Old 04-18-2016, 11:01 AM
ab325is's Avatar
Liked: 1
I doubt that I will ever watch a movie at reference levels. I want stereo music to sound great and movies to sound good, which is why I was leaning towards the Gold/4 Omni SEs for the fronts (they were recommended as being a great option for music).
That's correct. The only way for the right rear to get wider is to move up to 11-12ft high. I could go with the InCeiling option, but it's vaulted (so at an angle) and about 14-15ft high over the couch. Would that work?
I don't want to spend the money for 7.1 at this time, but I'm running speaker wire in the ceiling for it.
ab325is is offline
post #7954 of 9868 Old 04-19-2016, 05:13 AM
Dawn Gordon's Avatar
Quoted: 423 Post(s)
Liked: 255
With music as an important factor, and the fact that you aren't interested in playing movies that loud, Gold Omni SEs would work for your application.
jjcook likes this.
________________________________________
[email protected]
Dawn Gordon is online now
post #7955 of 9868 Old 04-19-2016, 06:15 PM
ShoutingMan's Avatar
Quoted: 345 Post(s)
Liked: 81
I'm considering in-wall speakers for a home theater. I'm considering Triad. I'm used to in-room SVS MTS 5.1 (full size LR, center, and satellite rears). My "simple" question: how to Triad in-walls compare to the (since discontinued) SVS MTS line? In particular, what I love about the SVS line is they reach down to 80Hz and crossover wonderfully with the sub. There's no 'hole' in that lower-mid range that I hear in so many smaller speakers. Thanks
ShoutingMan is offline
post #7956 of 9868 Old 04-19-2016, 07:21 PM
nathan_h's Avatar
Quoted: 2726 Post(s)
Liked: 1961
No problem at all, as long as you choose one of the inwalls with the extension you desire.
All the specs on the web site, and Triad is quite honest about their specs.
ShoutingMan likes this.
nathan_h is offline
post #7957 of 9868 Old 04-19-2016, 08:54 PM
Mike Garrett's Avatar
Quoted: 12541 Post(s)
Liked: 10154
Give us a call and we can discuss the options and pricing.
Mike Garrett is offline
post #7958 of 9868 Old 04-19-2016, 09:00 PM
Liked: 10154
Much of the Triad line have an f3 of 80hz and pair with a sub very well, leaving no hole in the frequency response. If we can help you, give us a call. The Triad speakers also have enclosures, not open baffle.
post #7959 of 9868 Old 04-26-2016, 04:15 PM
Tristan944's Avatar
Quoted: 77 Post(s)
Used Triad
I am buying them used off Craigslist. I called Triad and based upon the serial numbers, they are from around 2006. I am getting two Inroom Silver LCR's with stands and a Parasound 2125 amp for $450. Seller says everything is in perfect working condition.
Anything I should be concerned about?
Does that price seem okay?
Tristan944 is offline
post #7960 of 9868 Old 04-26-2016, 06:06 PM
nathan_h's Avatar
Liked: 1961
That's an awesome deal. You are essentially committing highway robbery! Well, not quite, but $450 for a pair of used Silver LCR in fine shape is a decent deal on their own.
Do a listening test before handing over your money, putting your ear up to each of the three drivers etc.
That setup should make some sweet music once paired with a sub to handle the 80z and below range. (If you are not using a receiver with bass management, or an outboard crossover like a miniDSP, you'll want to make sure your sub can do bass management for you.)
nathan_h is offline
post #7961 of 9868 Old 04-26-2016, 06:23 PM
Tristan944's Avatar
Quoted: 77 Post(s)
Here are some pictures. Can you take a look and see if there is anything you notice that I should be concerned about?
ID:	1407082   Click image for larger version
ID:	1407090   Click image for larger version
ID:	1407098   Click image for larger version
post #7962 of 9868 Old 04-26-2016, 06:41 PM
nathan_h's Avatar
Liked: 1961
If the condition looks fine to you, that's what matters. It's real hard to tell from the photos whether there are any issues.
With any speaker, I would NEVER buy it (new or used) without the option to hear it first or get a full refund if there is an audible problem.
But assuming it sounds fine, this is a very good deal you have found!
nathan_h is offline
post #7963 of 9868 Old 04-26-2016, 06:41 PM
Liked: 10154
Good deal.
post #7964 of 9868 Old 04-26-2016, 10:16 PM
Quoted: 345 Post(s)
Liked: 81
Another newb question: do Triads perform well (or rather, equally excellently) at low volume? Until I can get a demo, I'm googling triad reviews. One review from 2002 was positive, and yet it suggested Triads don't sound great until they're loud.
post #7965 of 9868 Old 04-27-2016, 05:29 AM
Quoted: 423 Post(s)
Liked: 255
That hasn't been my experience. Triad speakers sound great at all listening levels.
[email protected]
post #7966 of 9868 Old 04-27-2016, 06:00 AM
Quoted: 104 Post(s)
Liked: 112
I love my Triad speakers at all levels, very happy with my purchase.
Admittedly, sound is a very subjective thing though.
jjcook and ShoutingMan like this.
Sony 75" Z9D - Tivo Bolt+ - Roku Ultra - OPPO UDP-203 - Apple TV 4K
Datasat LS10 (w/ DIRAC - Atmos - DTS-X) - Two Emotiva XPA-7's (2nd Gen)
Seven Triad InWall Silver LCR's & Four KEF Ci200RR-THX Atmos speakers - Two Deep Sea Sound Mariana 24" subs - Vicoustic room treatment
grtuck is offline
post #7967 of 9868 Old 04-27-2016, 11:32 AM
batpig's Avatar
Liked: 5184
It's a great deal and I'm mad because I've been eyeing that ad for weeks and wanted to get it, but I'm in San Diego and haven't had any opportunity to get up to LA and grab them. Would have been a cheap upgrade from my Bronze LCR's to Silvers (at least for two speakers). Especially with the stands... the amp alone is probably worth $250-300. JUMP ON IT
(and if you buy them and change your mind I'd be happy to take them off your hands!!)
nathan_h and 65Goat like this.
Setup Guide and FAQ
batpig is offline
post #7968 of 9868 Old 04-27-2016, 02:39 PM
Tristan944's Avatar
Quoted: 77 Post(s)
I just picked them up. The seller ended up wanting to keep the amp so I bought the two Inroom Silver LCR's with stands at a further discount. I was able to listen to them briefly and they sound great. Can't wait to listen them at home. If they don't work out I'll let you know.
nathan_h likes this.
post #7969 of 9868 Old 04-27-2016, 09:24 PM
Tristan944's Avatar
Quoted: 77 Post(s)
Regarding the used Inroom Silver LCR's I just bought, the seller said he bought them new about a year ago. When I called Triad, they said based upon the serial numbers, they are from around 2006. The serial numbers on them are 170xxx, and he said the current Triad serial numbers are approximately 340xxx, that's how he got the approximate age. But the seller really doesn't understand how they could be that old as he bought them new, allegedly.
Other than the serial number, is there anything else that can used to help determine the age of the speakers? Any physical characteristics? I'm just curious. I listened to them at home and they sound great!
post #7970 of 9868 Old 04-27-2016, 10:30 PM
BllDo's Avatar
Quoted: 667 Post(s)
Liked: 477
He may have purchased them as new-old stock. If a reseller or CI had them left over from a job and sitting on shelf in a warehouse for 10 years, they are still technical in the box and new. Just really old.
Or, he was just trying to pull a fast on one you and didn't think someone would call up Triad with the serial.
Congrats, that's a heck of a deal.
BllDo is offline
post #7971 of 9868 Old 04-28-2016, 05:40 AM
Liked: 10154
Not a problem at lower levels.
post #7972 of 9868 Old 04-28-2016, 05:44 AM
Liked: 10154
Triad will be correct on the age. No if's ands or butts. Either he did not buy them new or a dealer had them on the shelf a long time. I really find it hard to believe a dealer had them on the shelf for 8 to 9 years.
post #7973 of 9868 Old 04-28-2016, 10:11 PM
batpig's Avatar
Liked: 5184
I looked at the photos of this guy's stuff and he's full of shmmt if he says they're a year old. Besides the serial number (which is unequivocal) they are obviously the older generation. They have cloth grills not the newer metal Acoustimesh which makes them at least 8-9 years old or so.
I have Bronze LCR from 2010ish and they are the metal grill. I have a third as center that is 2005 or so and it has the same drivers but cloth grill like those Silvers.
And it's also obvious from the photo that they are the older Peerless woofers. That alone makes them no more recent than 2010 or so because Peerless went out of business and Triad had to redo the line with new drivers.
batpig is offline
post #7974 of 9868 Old 04-28-2016, 10:31 PM
nathan_h's Avatar
Liked: 1961
What is it about the drivers that gives them away? I thought the ones with flat edges were the newer ones?
nathan_h is offline
post #7975 of 9868 Old 05-02-2016, 04:56 PM
batpig's Avatar
Liked: 5184
Someone correct me if I'm wrong, but the older Peerless drivers has a flat (or slightly concave) dust cap in the center of the woofer, whereas the newer drivers have a convex dustcap.
Setup Guide and FAQ
batpig is offline
post #7976 of 9868 Old 05-03-2016, 12:26 PM
voodoo1694's Avatar
Quoted: 37 Post(s)
I have a relatively small theater (19'x12') and have Gold LCR's as my fronts (found an insane deal on them locally). I've been told I should get bipole surrounds and am contemplating the silver or bronze's. Would the silvers be overkill for surrounds? Would I honestly notice an appreciable difference between the two? I'd rather save where I can, unless there's a very compelling reason to get the silvers. Thoughts anyone?
voodoo1694 is offline
post #7977 of 9868 Old 05-03-2016, 03:18 PM
batpig's Avatar
Liked: 5184
Everything I've read or been told is that there is no sound quality difference between Silver and Bronze, rather there is simply a room size / SPL capability distinction. They are the same design except the Silver uses larger drivers and larger cabinets so they can play a few dB louder.
Setup Guide and FAQ
batpig is offline
post #7978 of 9868 Old 05-04-2016, 12:30 AM
voodoo1694's Avatar
Quoted: 37 Post(s)
Thank you batpig, I appreciate it. That makes my decision a bit easier. In a small room (where I rarely listen at reference levels), I think the bronze's will do just fine.
post #7979 of 9868 Old 05-07-2016, 01:05 PM
hatlesschimp's Avatar
Quoted: 505 Post(s)
Liked: 541
With my new house/theater build I decided to go a 130" AT screen with a baffle wall with speakers behind the screen. I was dead against this type of setup because I didnt want to loose length on my room but after chatting to a few people I think 3 to 4 seats in one row is going to be fine. So now just trying to work out what speakers suit me best for a baffled screen wall setup. I demoed the Krix SX range and loved the horn sound and big 10" drivers. I believe that Triad have similar speakers and may even be better and thought Id drop by and ask you all. Do you think my room big enough for these speakers? What speakers would you recomend? These speakers are for movies only. Thanks
hatlesschimp is online now
post #7980 of 9868 Old 05-07-2016, 02:07 PM
nathan_h's Avatar
Liked: 1961
Is that 17' by 14'?
What is your budget?
Gold LCR would be nice. Silver LCR might work fine.
nathan_h is offline
Reply Speakers
Triad
