Triad Owner's Thread - Page 332 - AVS Forum | Home Theater Discussions And Reviews
 1290Likes
post #9931 of 10535 Old 11-18-2019, 09:30 AM
65Goat's Avatar
Quoted: 126 Post(s)
Liked: 76
Originally Posted by audioguy View Post
Craig, at what volume were you playing when you fried the tweeter in the Gold Monitors? I am trying to help someone and he is leaning toward the Gold Monitors though I was pushing him toward Gold LCRs since I have heard the and loved them (he heard my Plats) and I am worried that the Monitor tweeters won't hold up.
I'm very curious as well, as I have the Gold Monitors being pushed with an ATI6000 amp and a Marantz 8802A - I have had my monitors cranked and the monitors do so effortlessly.
Processor: Marantz 8802a Amplifiers: ATI Signature AT6007, Emotiva XPA5 Floor Speakers: (3) Triad Inroom Gold Monitors and (4) Gold Minimonitors ATMOS Speakers: (4) Atlantic Technology IC-6 OBA BR Players: Oppo BDP-95, Panasonic DMP UB9000 Streamers: Roku Ultra, nVidia Shield Screen: Panasonic 65" OLED GZ2000Subs: (2) Velodyne Optimums and (1) HSU ULS-15
65Goat is offline
post #9932 of 10535 Old 11-18-2019, 11:07 AM
batpig's Avatar
Quoted: 5241 Post(s)
Liked: 6109
Originally Posted by NickC View Post
What's the price difference between the INCEILING BRONZE/10 SUB and the INWALL BRONZE/6 SUB?
Trying to decide between the two(also considering using two subs), the specs seem almost identical minus the box size, which performs better?
With Triad, the same model in a different config will always have identical specs, just a different sized enclosure to fit the application while maintaining performance.
So for example an InWall Bronze/4 LCR vs an InWall Bronze/6 LCR will be the same speaker, just one will be 4" deep to fit a standard-sized stud depth (and as a consequence will be taller/wider to create more enclosure volume) whereas the other will be 6" deep which allows it to be shorter / less wide so the hole cut-out isn't as large.
Similarly, the in-ceiling models tend to be deeper (since there's usually more space in the ceiling joists than in wall stud bays) so the IC Bronze/10 requires 10" depth but the front baffle isn't as larger, whereas a 10" deep speaker would likely never work in a wall so the IW version is 6" deep (but that requires the baffle to be taller and wider to create the additional enclosure volume).
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #9933 of 10535 Old 11-19-2019, 12:28 PM
NickC's Avatar
Quoted: 28 Post(s)
Thanks. Is there a RackAmp 700 option? I asked my dealer for pricing regarding two subs 8ohm shared amp and they came back around $3300 including install/brackets, but for the 700 amp. Is there much performance difference vs the 300?
InWall Bronze Subs with RackAmp 300 (two 8-ohm woofer enclosures): $2260
InWall Bronze Sub with RackAmp 300 (4-ohm woofer enclosure): $1460 x 2 = $2920
NickC is offline
post #9934 of 10535 Old 11-19-2019, 02:02 PM
Dawn Gordon's Avatar
Quoted: 533 Post(s)
Liked: 384
InWall Bronze Subs with RackAmp 700 (two 8-ohm woofer enclosures): $2700 MSRP
InWall Bronze Sub with RackAmp 700 (4-ohm woofer enclosure): $1900 MSRP x2 = $3800
A7mad78 likes this.
________________________________________
[email protected]
Dawn Gordon is offline
post #9935 of 10535 Old 11-19-2019, 04:52 PM
NickC's Avatar
Quoted: 28 Post(s)
Thank you Dawn, how is the performance vs the 300 RackAmp? Which would you recommend?
NickC is offline
post #9936 of 10535 Old 11-20-2019, 05:29 AM
Quoted: 533 Post(s)
Liked: 384
I believe that you get an additional 3db of output with the RackAmp 700. I recommend it!
[email protected]
post #9937 of 10535 Old 11-20-2019, 07:55 AM
NickC's Avatar
Quoted: 28 Post(s)
Thanks, I think I'm going to go with two subs (8ohm) and the RackAmp 700, is it possible to add a second RackAmp later with the 8ohm woofer? or does it not make sense to do that?
NickC is offline
post #9938 of 10535 Old 11-20-2019, 10:27 AM
Quoted: 533 Post(s)
Liked: 384
Hi Nick,
I don't think you'll need to do that. You'll see..... :-)
NickC likes this.
[email protected]
post #9939 of 10535 Old 11-20-2019, 10:35 AM
batpig's Avatar
Liked: 6109
There's not much point to that because you'll get 1/2 the power running the amp on a single 8ohm sub. The two 8ohm subs connected in parallel to the amp present a 4ohm load, which allows the amp to put out the 700 watts specified. With two RackAmp 700's running independent 8ohm wired subs, they'll basically act as 350wpc each, so you'll gain essentially nothing but a lighter wallet and less space in the rack.
Dawn Gordon and NickC like this.
Setup Guide and FAQ
batpig is offline
post #9940 of 10535 Old 11-20-2019, 10:39 AM
A7mad78's Avatar
Quoted: 279 Post(s)
Liked: 158
I am plan to order this month inwall bronz with rack amp700 2 sub in each corner for the rear sub to handle the 2 front gold based on triad recommendation coz I stuck with hidden placement in the room
A7mad78 is online now
post #9941 of 10535 Old 11-20-2019, 04:40 PM
NickC's Avatar
Quoted: 28 Post(s)
Hi Nick,
What should I expect to pay for this setup?
ONWALL MINI LCR 1.0 SE
INCEILING SILVER/8 LCR
INWALL SILVER/4 SURROUND
InWall Bronze 6 Subs with RackAmp 700 (two 8-ohm woofer enclosures): $2700 MSRP
NickC is offline
post #9942 of 10535 Old 11-21-2019, 06:16 AM
Quoted: 533 Post(s)
Liked: 384
That's going to depend on your Triad dealer. Do you need help finding one?
[email protected]
post #9943 of 10535 Old 11-21-2019, 06:36 AM
NickC's Avatar
Quoted: 28 Post(s)
Nope, just looking for MSRP numbers.
NickC is offline
post #9944 of 10535 Old 11-21-2019, 06:42 AM
Quoted: 533 Post(s)
Liked: 384
MSRP pricing below:
Onwall mini lcr 1.0 se: $550
inceiling silver/8 lcr: $1000
inwall silver/4 surround: $750
[email protected]
post #9945 of 10535 Old 11-21-2019, 06:56 AM
NickC's Avatar
Quoted: 28 Post(s)
MSRP pricing below:
Thank you! I was expecting the Onwall mini lcr 1.0 se to be over $1000 as the 3.0 is was $3300 for 66" custom size.
NickC is offline
post #9946 of 10535 Old 11-21-2019, 10:49 AM
Quoted: 533 Post(s)
Liked: 384
My bad. I didn't see the SE because we generally capitalize it, so I completely missed that.
The SE verison is: $1000 MSRP.
My apologies.
[email protected]
post #9947 of 10535 Old 11-21-2019, 11:28 AM
Quoted: 36 Post(s)
Liked: 94
There are differences -- audible differences. The Gold Monitors won't play as loud as Gold LCRs, but what you lose in volume you gain in soundstage, airiness, and an overall smoother sound that most audiophiles will happily appreciate.
Out of all the Triad speakers I could have chosen for my showroom, I specifically selected Gold Monitors.
This intrigues me greatly. Better separation in the soundstage and airiness are things I'd rather have over volume. Smoother sound that has less chance to fatigue my ears are another possible benefit.
When we say they won't play as loud, are we talking at above reference levels? If that's the case I don't plan on listening that loud on a regular basis. I may make the Gold Monitors my LCR of choice for the time being.
David Wong is offline
post #9948 of 10535 Old 11-21-2019, 11:40 AM
Quoted: 533 Post(s)
Liked: 384
Then you should be in great shape. You can get things pretty darn loud with Gold Monitors -- especially if you assist with enough subs and cross them over at 100 Hz.
David Wong likes this.
[email protected]
post #9949 of 10535 Old 11-28-2019, 11:28 PM
A7mad78's Avatar
Quoted: 279 Post(s)
Liked: 158
I have a problem in my C Gold speaker the vocals become like one speaks in water is that mean the speakers damage or there are a problem in the amps or losing in the connection ?
any help in diagnostic the problem and if the speakers damage how can I change the parts and I am far from US
post #9950 of 10535 Old 11-29-2019, 05:24 AM
A7mad78's Avatar
Quoted: 279 Post(s)
Liked: 158
I think after test both L&R tweeters are damage
post #9951 of 10535 Old 11-29-2019, 05:39 AM
Quoted: 533 Post(s)
Liked: 384
What amplifier have you been using? How old are the speakers?
[email protected]
post #9952 of 10535 Old 11-29-2019, 06:13 AM
A7mad78's Avatar
Quoted: 279 Post(s)
Liked: 158
QSC DCA and the speakers just 2 years late 2016 I buy install in Feb 2017
post #9953 of 10535 Old 11-29-2019, 06:19 AM
A7mad78's Avatar
Quoted: 279 Post(s)
Liked: 158
post #9954 of 10535 Old 11-29-2019, 06:28 AM
A7mad78's Avatar
Quoted: 279 Post(s)
Liked: 158
post #9955 of 10535 Old 11-29-2019, 06:37 AM
A7mad78's Avatar
Quoted: 279 Post(s)
Liked: 158
Dose I need to send them back (international shipment) or triad will send the tweeter and fix it here through the dealer
Very sad day for me
post #9956 of 10535 Old 11-29-2019, 07:04 AM
Quoted: 533 Post(s)
Liked: 384
Work with your local dealer. Triad can send the tweeters to your dealer who can then install them for you.
nathan_h likes this.
[email protected]
post #9957 of 10535 Old 12-03-2019, 06:20 AM
AnnapolisSony's Avatar
Quoted: 155 Post(s)
Liked: 220
Received my OW Bronze Surrounds yesterday. Triad was lighting fast filling the order. Grilles are color-matched to SW Iron Ore. They look beautiful. Thanks @Dawn Gordon for all of your help and guidance. Much appreciated. Now to get the room built so I can enjoy them!
AnnapolisSony is offline
post #9958 of 10535 Old 12-03-2019, 06:34 AM
tigerhonaker's Avatar
Quoted: 1079 Post(s)
Liked: 1323
Thumbs up
Looking forward to seeing them UN-Boxed.
Terry
tigerhonaker is online now
post #9959 of 10535 Old 12-04-2019, 05:16 AM
Quoted: 533 Post(s)
Liked: 384
Me too!
[email protected]
post #9960 of 10535 Old 12-04-2019, 09:12 AM
craig john's Avatar
Quoted: 1691 Post(s)
Liked: 2008
Great news!
About two weeks ago, I sent an email to Triad asking about measurements. I recently heard back from Steve Colburn, System Designer at Control4 who tells me that Triad has begun the process of updating their speaker specifications and measurements! New information should be available soon. This is a great first step! I look forward to seeing the measurements!
Steve sends his best regards to everyone on the forum! This is another example of Triad's excellent customer service!
Craig
PS. Dawn was instrumental in getting this initiated as well! Thanks Dawn!
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence.
My System (Edited Feb. 2020 to add 4K and Atmos updates)
craig john is offline
Reply Speakers
Triad
