The Official Salk Sound Owner's And Discussion Thread - Page 320 - AVS Forum | Home Theater Discussions And Reviews
 398Likes
post #9571 of 10060 Old 09-25-2015, 02:35 PM
Dennis Murphy's Avatar
Quoted: 957 Post(s)
Liked: 1490
Originally Posted by shawndo View Post
Wait, I think I'm missing something. I thought the SS8 was what you were referring to when you said "Silk tower". I must have read a review comparing the Silk bookshelves to the SoundScapes. I haven't seen/heard of anything called a "Silk tower". Can you point me to what you are referring?
Now I'm pretty much sold on SS8s if I can confirm they wouldn't need much open space around them if they are high-passed at @80Hz. I always thought those passive radiators needed a lot of open space.
I'll need to stew on this for a bit.
Unless Jim slipped one by me, I don't believe there is a tower version of the Silk. And I don't see any mention of one on the site.
Dennis Murphy is offline
post #9572 of 10060 Old 09-25-2015, 03:16 PM
justthinking's Avatar
Quoted: 389 Post(s)
Liked: 226
I am sorry to say this, but your problem is your room, not your speakers nor your preamp nor your subwoofer and unless you address the elephant in the room which is room acoustic, no amount of money will buy you the sound you are looking for
You can keep trying to swap out speakers, swap out amps, add subwoofer and play with cross-over settings, but it still won't sound good in your room with current placement..
What you really should do is take a look at this tutorial from GIK acoustics and take some measurement of your room, try to address the frequency response in your room to the best you can, then think about buying new equipments....
http://www.gikacoustics.com/room-eq-wizard-tutorial/
Nuance and beaveav like this.
5.2.4 HT - Sony XBR75X850C, Denon X4400H, Monitor Audio GS60, GSLCR, GSFX, C380LCR x4 and Martin Logan Descent I x2
2 Channel - Ascend Sierra Tower w/ RAAL, Sony HAP-Z1ES, Marantz SA-KI-Pearl, Primaluna Dialogue Three, Parasound Halo A21, JL Audio CR1, JL Audio E112 and ATS Acoustics room treatments
justthinking is offline
post #9573 of 10060 Old 09-25-2015, 04:10 PM
green giant's Avatar
Quoted: 114 Post(s)
Liked: 112
If you are set on crossing them at 80hz, have Jim build you the SS7 towers.
beaveav likes this.
green giant is offline
post #9574 of 10060 Old 09-25-2015, 04:41 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 673
+1. As much as I drool over the SS8s, I don't think they're at all an appropriate speaker for his room.
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #9575 of 10060 Old 09-25-2015, 04:42 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 673
+1. A much better idea.
Although I still wouldn't recommend he buy *any* new speakers without first addressing room acoustics.
beaveav is offline
post #9576 of 10060 Old 09-25-2015, 06:59 PM
laulau's Avatar
Quoted: 95 Post(s)
Liked: 168
There was this thread about a Silk Tower, but never saw it actually show up on the Salk site.
HT:: Salk SongTwr-Raal / SongCtr-Raal / SongSurr ; Rythmik F12 (x2) (my latest Dialing-in Guide); Denon 4520; ATI AT522NC; Oppo BDP93; Panny 65VT50; BJCables; CCast; Roku Ultra; Furman; Omnimic
CANS:: RPi>Soekris DAC1541 > LCD2C :: RPi>AGD DAC19 >Cavalli LC > MrSpeakers AFC & HE400i & HD569 :: RPi3 > Bifrost 4490 > Valhalla >HD600 & HD6XX :: RPi > Mimby >Schiit Vali 2 >Meze 99 Classics & Oppo PM3
laulau is offline
post #9577 of 10060 Old 09-25-2015, 09:01 PM
Quoted: 957 Post(s)
Liked: 1490
Hmmmm I have no recollection of that, but I do have a design file for it. It looks terrific on paper--I'm not sure why nothing came of it other than a one-off. Jim's younger than I am. Maybe he can explain what happened.
post #9578 of 10060 Old 09-26-2015, 02:01 PM
PAD
PAD's Avatar
Originally Posted by JonnyFive54950 View Post
Second, that copper front was done by Pete and I'm not sure it could be replicated. If it can, you're going to spend as much replicating it as the cost of the base speaker itself. Stringers, also going to cost money that could be put towards converting the bookshelves to towers.
Hey fellas!
Yeah, the copper is not cheap and it is a super PITA to assemble the speaker as it requires a somewhat backward process. And if it gets foobar'd you just can't sand it down and start over like a veneer.
And black was my first paint choice but I ultimately did not want an overall 'dark character' to the speaker so went with white to be a little more modern and hip looking. I have a mental image of what my next room will look like and white fit the scheme better. Black would still be sexy and manly. Also, for us petite folks white was a more logical choice.
What I am not sure of is how I will top these next time.
PAD is offline
post #9579 of 10060 Old 09-27-2015, 06:37 AM
irishluck73's Avatar
Quoted: 265 Post(s)
Liked: 157
I got home from work to find my 2 year old is very fond of my Salk center and surrounds! Thankfully he wasn't tall enough to get at the towers.
t1337Dude likes this.
irishluck73 is online now
post #9580 of 10060 Old 09-29-2015, 09:05 PM
funkmonkey's Avatar
ahhh looks like he got both mid-woofers.... If I am not mistaken its just a dust-cover that is dented there... shouldn't effect the sound. I think I may have read something a long time ago about using a straw to create suction to "grab" the cover, and then pull the dent out... or maybe I'm making it up... not sure. Either way, it should work if you are carefull.
Good luck,
Cheers
Speakerquest
funkmonkey is offline
post #9581 of 10060 Old 09-30-2015, 03:40 AM
PAD
PAD's Avatar
Masking tape will work. Be gentle and they should pop right back out.
PAD is offline
post #9582 of 10060 Old 09-30-2015, 03:42 AM
Quoted: 265 Post(s)
Liked: 157
Thanks for the tips guys. Saw a Youtube video with a vacuum hose too... Not sure I'd want to use that much suction.
post #9583 of 10060 Old 09-30-2015, 06:40 AM
Quoted: 90 Post(s)
Take a paper towel or toilet paper tube and place it over the pushed in dome. Suck gently and it will return to normal. I agree, vacuum cleaner may be entirely too much.
JonnyFive54950 is offline
post #9584 of 10060 Old 09-30-2015, 08:34 AM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 249
My solution...
iatacs19, screener and t1337Dude like this.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #9585 of 10060 Old 09-30-2015, 03:19 PM
PAD
PAD's Avatar
And there is the obligatory photo of you sucking on your speakers!!
funkmonkey likes this.
PAD is offline
post #9586 of 10060 Old 09-30-2015, 03:31 PM
Quoted: 265 Post(s)
Liked: 157
No go with the tube, the dust buster or the Dyson... Had to resort to using a pin! They're about 95% now. Only I know since they're covered by the grilles but I'm still taking it out of his allowance when he's older.
Nuance, madhuski and jjackkrash like this.
post #9587 of 10060 Old 10-02-2015, 03:33 PM
PAD
PAD's Avatar
Hey irish, where in central NY are you? Grew up in NY. RIT grad.
PAD is offline
post #9588 of 10060 Old 10-03-2015, 03:41 AM
Quoted: 265 Post(s)
Liked: 157
In the Cazenovia area, SE of Syracuse. Getting a lil chilly this time of year.
post #9589 of 10060 Old 10-03-2015, 06:24 AM
PAD
PAD's Avatar
Love that area. It's getting chilly in Michigan as well. Might be an early winter but last I heard El Nino was going to spare us some heavy snows. And I wanted to buy a bigger snowblower this year!
PAD is offline
post #9590 of 10060 Old 10-04-2015, 06:55 AM
Quoted: 265 Post(s)
Liked: 157
Due to the size of our living room, house was built in 1890, we have our L couch in the corner. It's not really feasible to have my SongSurrounds mounted in the corner over the couch and in the opposite corner just due to size. I'm going to use the surrounds in our kitchen and dining area for tunes out there but I need rear surrounds that will mate up with the SongTowers and center but in a much smaller format.
Would the Orbs work well with the Salks? Any other small speakers recommended for doing something like this?
post #9591 of 10060 Old 10-04-2015, 08:44 AM
R Swerdlow's Avatar
Quoted: 92 Post(s)
Liked: 209
Look into NHT SuperZeros as rear channel speakers. I use an older version of these speakers as rear speakers for my SongTowers and SongCenter, and they do well together.
http://www.nhthifi.com/Bookshelf-spe...&category=3772
They're small enough to easily mount on a wall.
R Swerdlow is offline
post #9592 of 10060 Old 10-04-2015, 08:53 AM
Saturn94's Avatar
Quoted: 158 Post(s)
Liked: 493
+1
I've also used NHTs with Salks with great results.
Saturn94 is offline
post #9593 of 10060 Old 10-04-2015, 09:14 AM
Quoted: 265 Post(s)
Liked: 157
Originally Posted by Saturn94 View Post
+1
Thank you. Those look like a good option. A little bigger than the Orbs but I think they'd be doable.
post #9594 of 10060 Old 10-07-2015, 12:35 PM
qwknuf6's Avatar
Quoted: 192 Post(s)
Liked: 199
Traded in My HT2-TL
Picked up Exotica 3s @ Jim shop !
Nuance, funkmonkey and t1337Dude like this.
qwknuf6 is offline
post #9595 of 10060 Old 10-08-2015, 10:13 PM
funkmonkey's Avatar
Oh yeah... looks like you nabbed some some of the finest looking speakers I have ever seen... I hope they sound as sweet as they look (I have no doubt that they do)... Congrats on the new acquisition. Cheers!
Speakerquest
post #9596 of 10060 Old 10-09-2015, 03:32 AM
Quoted: 265 Post(s)
Liked: 157
Awesome!
post #9597 of 10060 Old 10-12-2015, 04:51 PM - Thread Starter
Nuance's Avatar
Quoted: 29 Post(s)
Liked: 83
Congrats - those are stunning! Pau Ferro Rosewood?
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
post #9598 of 10060 Old 10-13-2015, 05:22 AM
jsalk's Avatar
Quoted: 82 Post(s)
Liked: 317
Not rosewood. We came across a really unique batch of curly (mild fiddleback) walnut with a "burly" grain pattern. We added orange dye to the topcoat. The result resembles the color of Mexican cocobolo, but the grain patterns were really unique.
- Jim
SalkSound.com
Custom-crafted Speakers
jsalk is offline
post #9599 of 10060 Old 10-13-2015, 05:50 AM - Thread Starter
Nuance's Avatar
Quoted: 29 Post(s)
Liked: 83
Originally Posted by jsalk View Post
Not rosewood. We came across a really unique batch of curly (mild fiddleback) walnut with a "burly" grain pattern. We added orange dye to the topcoat. The result resembles the color of Mexican cocobolo, but the grain patters were really unique.
- Jim
Thanks, Jim. You've created another work of art - very impressive! I look forward to hearing the Exotica's!
Nuance is offline
post #9600 of 10060 Old 10-13-2015, 06:17 AM
qwknuf6's Avatar
Quoted: 192 Post(s)
Liked: 199
A work of art and my dream speaker , the sound is great , and I came from HT2-TL speakers which are great speakers . The Exotica 3s are on another level .
Mark
Nuance and t1337Dude like this.
qwknuf6 is offline
Reply Speakers
