Active Subwoofer connected to Passive ONKYO HT-R340 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 11-04-2008, 02:56 PM - Thread Starter
blazingazn's Avatar
Will this be possible? Also is there any danger to the sub or receiver?
I want to connect the Jamo SUB200 Active Subwoofer to the passive SUBwoofer speaker terminals on the HT-R340.
It will be connected via x2 Speaker Line Level Inputs on the Sub to the Clip-on Subwoofer Output Terminals of the Receiver via 16 gauge speaker wire.
To clarify this R340 receiver does not have any "pre output" subwoofer options.
Thanks in advance.
P.S. The Receiver out terminals output 120W of power.
The Sub supplies itself with 200W of power.
blazingazn is offline
post #2 of 15 Old 11-04-2008, 04:28 PM - Thread Starter
blazingazn's Avatar
Nothing really solid found via Google.
Would appreciate help.
post #3 of 15 Old 11-04-2008, 04:38 PM
afrogt's Avatar
Quoted: 2051 Post(s)
Liked: 1376
That's exactly what those speaker level inputs are there for on your sub, to use with a receiver that doesn't have a dedicated line level sub output.
You'll be fine.
Afro GT
afrogt is offline
post #4 of 15 Old 11-04-2008, 04:39 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 481
As long as you connect to your speaker level input on sub, not line input, you should be fine.
Foxbat121 is online now
post #5 of 15 Old 11-05-2008, 12:16 AM - Thread Starter
blazingazn's Avatar
Took some pics. Please let me know if I did it right.
Terminals on the Sub itself
Close up
Receiver's Subwoofer Speaker Wire Output
Another picture of the subwoofers speaker wire output.
Basically I doubled up the Negative and Positive Terminals on the receiver for the L and R Channel Line Levels.
The wires are exposed so I'm a little worried.
Let me know.
post #6 of 15 Old 11-05-2008, 09:07 AM - Thread Starter
blazingazn's Avatar
Let me know.
post #7 of 15 Old 11-05-2008, 11:01 PM - Thread Starter
blazingazn's Avatar
Any more tips?
Is it okay that the Speaker Wire output from the receiver is sending power and also I am plugging into the wall for power?
post #8 of 15 Old 11-06-2008, 11:52 AM - Thread Starter
blazingazn's Avatar
Bump for help.
post #9 of 15 Old 11-06-2008, 12:08 PM
batpig's Avatar
Quoted: 4667 Post(s)
Liked: 4851
You'll be fine.
you're fine, just like hooking up a speaker, black-to-black, red-to-red. again, that is what those inputs are for....
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #10 of 15 Old 11-06-2008, 12:28 PM - Thread Starter
blazingazn's Avatar
Thanks for the reassurance!
Mostly wondering now if I can double up the Sub L/R inputs like that onto the Receiver output.
post #11 of 15 Old 11-07-2008, 10:07 AM - Thread Starter
blazingazn's Avatar
Bump for help with the inputs to outputs.
Can I double the 2 inputs going into the single output?
The manual tells me not to do it...
I'll leave you all alone after this
post #12 of 15 Old 11-07-2008, 11:08 AM
robfive's Avatar
You are fine. Yes you can double up because you are not connecting directly to a speaker. It won't hurt anything as long as you connect the reds to reds and blacks to blacks. I can see that you have it all wired but have you tried running it yet?
robfive is offline
post #13 of 15 Old 11-07-2008, 03:19 PM - Thread Starter
blazingazn's Avatar
Yep it's running great so far (cross fingers)
It's a much cleaner punch then my old HTIB subwoofer, that was so muddy.
Thanks all, any other suggestions would be appreciated.
Also for my next receiver upgrade I want to get the SR606 ($350 CDN through my employee discount).
Is that 606 a good receiver, value and quality wise?
post #14 of 15 Old 11-09-2008, 01:35 AM - Thread Starter
blazingazn's Avatar
BUMP for interest.
post #15 of 15 Old 11-10-2008, 06:06 AM
robfive's Avatar
The Onkyo 606 is a good receiver and will be a big step up from your htib receiver in terms of power output, input and output flexibility, audio codec support, etc. You won't be disappointed as long as you don't put it in an enclosed cabinet. It needs room to breath.
robfive is offline
