"OFFICIAL" Pioneer MCACC thread - Page 231 - AVS Forum | Home Theater Discussions And Reviews
 175Likes
post #6901 of 6918 Old 05-04-2020, 08:45 PM
LastButNotLeast's Avatar
Quoted: 2976 Post(s)
Liked: 2743
It works the opposite as you may think. A smaller number means the effect is over a larger frequency range than a larger number.
The peak on the left is Q=5, the peak on the right is Q=2.
(obviously, this is not from your avr, but illustrates the example clearly, I think)
Michael
LastButNotLeast is offline
post #6902 of 6918 Old 05-04-2020, 09:05 PM
Prof.'s Avatar
Michael
That has not been my experience with MCACC..
I don't have any measurements to back it up, but purely from a listeners point of view, the sound to me sounded tighter..particularly the mid bass..
Home Theater...The never ending story..
Prof. is offline
post #6903 of 6918 Old 05-05-2020, 02:30 AM
Liked: 0
Originally Posted by Prof. View Post
It's very simple actually..
In the standing wave images you show..all you have to do is press the up button to highlight ":Main" or "Sub"..then press the right side button to highlight The "Q" factor and press the down button to reduce the number down..
so change the Q filter on all 3 areas within each of the options - MAIN, CENTRE, and SUB?
What does the change do? What shall I be listening out for in terms of sound, is it subtle or obvious? Its difficult for me as I dont have the sound engineering knowledge but trying to make the system sound as good as it can.
Really appreciate the comments and you taking the time to respond, thank you.
Martin Roberts is offline
post #6904 of 6918 Old 05-05-2020, 06:33 AM
Liked: 2743
Q is Q. It may sound "tighter" or whatever. That's why I rely on measurements. Then, of course, adjust to taste.
Michael
post #6905 of 6918 Old 05-05-2020, 06:39 AM
Liked: 2743
https://www.audiomasterclass.com/new...what-can-it-do
Then you really need measurements. See REW link in my sig.
Michael
Martin Roberts likes this.
post #6906 of 6918 Old 05-05-2020, 06:49 AM
Liked: 0
Thank you for this.
"so change the Q filter on all 3 areas within each of the options - MAIN, CENTRE, and SUB?"
regards the above change all of them to 5?
post #6907 of 6918 Old 05-05-2020, 07:42 AM
Liked: 2743
You can try 5. Since you're doing it randomly (without measurements), see what you think at 9, 5 and 2, then fine-tune accordingly.
Might want to do one channel at a time and just listen carefully to that speaker.
Michael
post #6908 of 6918 Old 05-05-2020, 12:06 PM
sk3ptic's Avatar
Liked: 0
MCACC defeatured since last firmware update?
I have an SC-LX502 for a couple of years and when I recently ran Full Auto MCACC, one of the speaker distances was way off. I know that previously I had manually adjusted these, now however there is no way to adjust them. The only thing that has changed is that I have updated the firmware 1 or 2 times. I am at the current firmware (1081-2020-3070-0011). Can anyone else confirm this feature going away?
Similarly I swear there were more advanced room alignment features as well. All I have now is their "basic" MCACC. This may not be a change for the 502 as I have had several Elite receivers over the years and I may be remembering the previous one. Does anyone have time alignment features in their SC-LX502 MCACC?
sk3ptic is offline
post #6909 of 6918 Old 05-05-2020, 05:36 PM
Prof.'s Avatar
Generally the changes are subtle...You may have to repeat the tests several times to get a good feel about it..
It does help to have a good audio ear!
Prof. is offline
post #6910 of 6918 Old 05-08-2020, 11:15 AM
Liked: 0
Hi,
I did it all again with the only difference being complete silence and it finished with Q numbers of 3/5.6 and 6.8. Lower than the previous efforts.
post #6911 of 6918 Old 05-13-2020, 11:48 AM
Liked: 0
Import MCACC?
I had to reset my SC-32 in hopes of setting up the network settings. For some reason I cannot get an IP address when I connect the receiver to my router... I saved my preset MCACC #1 to a USB stick and reset the receiver. Can I import the MCACC back into the receiver?? I am also not sure why I cant get an IP address, I go to the setting on IP address and it sits there and blinks. any advice??
Ben Levy is offline
post #6912 of 6918 Old 05-13-2020, 11:53 AM
Liked: 0
I have a SC-37, NOT a SC-32...
Ben Levy is offline
post #6913 of 6918 Old 05-13-2020, 01:53 PM
Liked: 2743
See if the receiver shows up on the router's Client Table.
Michael
post #6914 of 6918 Old 05-13-2020, 05:15 PM
Liked: 0
Michael
It doesnt.. I cant even get any info on the receivers Mac or anything either via settings on the Receiver.. dang!
Ben Levy is offline
post #6915 of 6918 Old 05-13-2020, 08:38 PM
Liked: 2743
Any chance it's just a bad cable?
Michael
post #6916 of 6918 Old 05-14-2020, 07:47 AM
Liked: 0
Michael
Tried a couple cables... Thought maybe I used a bad one and or a crossover cable but no luck still. its really bugging me!
Ben Levy is offline
post #6917 of 6918 Old 05-23-2020, 04:55 AM
Osamede's Avatar
Quoted: 76 Post(s)
Liked: 57
After running MCACC Advanced on my VSX-83, this what what I got back (see image):
https://imgur.com/a/VXbj2wG
How can I interpret these results from MCACC - and what actions can I take?
Osamede is offline
post #6918 of 6918 Old 05-23-2020, 05:13 AM
pmeintel's Avatar
Quoted: 164 Post(s)
Liked: 94
Originally Posted by pmeintel View Post
I've read the newer manuals yet nothing specific is stated regarding running Auto MCACC Pro while keeping the speaker settings in the Elite recievers. Can anyone answer this for me?
Bump..
Bueller.....Bueller anyone Bueller
"These go to eleven." - Great words from Nigel Tufnel.
pmeintel is online now
