Parasound Owners Thread - Page 209 - AVS Forum | Home Theater Discussions And Reviews
 713Likes
post #6241 of 6436 Old 01-02-2019, 11:52 AM
WAFWarrior's Avatar
Quoted: 140 Post(s)
Liked: 79
Originally Posted by kirma View Post
Have the JC5 and bitterly disappointed with the binding posts! Unable to connect standard speaker wire with spades, do I have to use only bare wire? Posts look fancy but the opening is too small - I have mid-line Transparent cables with spades.
I suggest that you call our technical department for more information. These binding posts can certainly be used with spade lugs assuming they are of a relatively standard dimension.
Parasound Tech dept.
415-397-7100
Chris
Parasound Products Inc.
2250 Mckinnon Ave.
San Francisco CA 94124
415-397-7100
WAFWarrior is offline
post #6242 of 6436 Old 01-02-2019, 03:21 PM
bgbkt's Avatar
Quoted: 69 Post(s)
Liked: 25
Which one of this is better choice - HINT 6 or P6 + A21+?
Main: Ascend Acoustic Sierra 2 L/R | Rythmik E15HP | Marantz SR6010 | Oppo BDP-103
Headphones: Focal Clear | ZMF Atticus | Fostex THX00 | Senheiser HD 650 | Meze 99 Classics | Schiit Lyr3 (multi-bit DAC)
bgbkt is offline
post #6243 of 6436 Old 01-03-2019, 01:26 PM
TheMadMilkman's Avatar
Quoted: 22 Post(s)
I’m hoping you mean A23+, and I hope the answer is that the separates are better, since that’s the combo I’ll end up with ina few months.
TheMadMilkman is offline
post #6244 of 6436 Old 01-04-2019, 07:30 AM
bgbkt's Avatar
Quoted: 69 Post(s)
Liked: 25
I actually meant A21+. I know A21+ is much costlier but want to know if money is no objection is it worth going with A21+. Is there noticeable different between A21+ and amp inside Hint6.
bgbkt is offline
post #6245 of 6436 Old 01-04-2019, 08:30 PM
bgbkt's Avatar
Quoted: 69 Post(s)
Liked: 25
I got answer to my own question from man himself (John Curl) on one of other forum:
Serious listeners should get the A21 or the JC-1 monoblocks. That is where I put my best effort.
The A23 uses my design, but not my direct input. 2 means 2 ch, 3 means cheaper.
Spizz and Jive Turkey like this.
bgbkt is offline
post #6246 of 6436 Old 01-04-2019, 08:38 PM
stash64's Avatar
Quoted: 603 Post(s)
Liked: 225
I agree. The A21 is quite a bit more amp than the A23, and I am not just talking power. It is more refined. The A23 is not as quiet and is more susceptible to transformer noise.
Sean
stash64 is offline
post #6247 of 6436 Old 01-09-2019, 08:49 AM
Liked: 0
415-397-7100
Update on binding posts:
Parasound tech did walk me through the binding posts design and I was able to connect spades using (mid-line) Transparent cables.
A few points for others who may encounter similar challenges:
1. The narrow slit for inserting spades in on the bottom of binding post. Tolerance is tight, I had 1 spade with the prongs a bit bent, had to compress them to insert. Would help if opening was on both sides, vertical top and bottom.
2. If your cables are very stiff (close to the spades), then possible issues if your amp is the bottom component, as cable needs to bend in a tight curve (angle of 90 degrees between spade and cable).
3. Easiest way to connect spades is: (i) Stand amp (on soft carpet/surface) on its front face with the back panel up. (ii) Now easy to insert spades and tighten (size must be right). (iii) Then slowly lower amp on its feet taking care to allow the cable a gentle curve bend.
All in all, the Parasound folks were very helpful and the tech person worked with me through iPhone face time call to get this done - innovation is great!
And BTW, the amp sounds quite nice (only a few hours use yet), rich robust sound with a good heft/body. It also runs warm, much warmer than expected and maybe a tad more than the JC1s - anyone know if it operates in Class A and how many watts?
kirma is offline
post #6248 of 6436 Old 01-10-2019, 04:33 PM
WAFWarrior's Avatar
Quoted: 140 Post(s)
Liked: 79
For those of you who are interested in learning more about Parasound's Amplifiers and their designer, see the following link to a Parasound hosted evening with John Curl.
Spizz, WLGeter and audiofan1 like this.
Chris
2250 Mckinnon Ave.
415-397-7100
post #6249 of 6436 Old 01-10-2019, 06:46 PM
Quoted: 751 Post(s)
Liked: 299
Thanks. I use JC 1s for LCR in one setup. The link gave me a bit of insight about why they sound so good. Preamp is JC 2 BP, phonostage JC 3.
dbphd is offline
post #6250 of 6436 Old 01-13-2019, 05:57 PM
Simm's Avatar
Quoted: 23 Post(s)
Anyone know if the A51 and A31 are going to be updated soon? Would like to pick up one of them on closeout.
Simm is offline
post #6251 of 6436 Old 01-14-2019, 03:06 PM
WAFWarrior's Avatar
Quoted: 140 Post(s)
Liked: 79
There are no immediate replacements under consideration with respect to the A31 and A51.
gordojones88 likes this.
Chris
2250 Mckinnon Ave.
415-397-7100
post #6252 of 6436 Old 01-14-2019, 03:20 PM
Simm's Avatar
Quoted: 23 Post(s)
Thanks for the update.
Simm is offline
post #6253 of 6436 Old 01-14-2019, 10:41 PM
jima4a's Avatar
Quoted: 457 Post(s)
Liked: 221
Is that marketing or technically constrained? Granted 300 watts x 5 would require a 20 amp circuit or dual 15s but heat management or other if technical?
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
post #6254 of 6436 Old 01-15-2019, 06:04 PM
Kraton's Avatar
Parasound P7
Configuration:
P7 preamp + A52 amp
TMA Subwoofer
Oppo 205 blu-ray player
Ticking sounds coming out of the P7. It sounds a bit like when you turn the device on/off.
Very irregularly, sometimes after 10 minutes, sometimes after an hour.
Searching the internet I found information that it could be a problem with a relay.
Any thoughts much appreciated.
Kraton is offline
post #6255 of 6436 Old 01-15-2019, 06:15 PM
Kal Rubinson's Avatar
Quoted: 1369 Post(s)
Liked: 1313
Fascinating. I use a P7 ocassionally. From time to time, I hear an intermittant but not subtle "tick" and had assumed that it was associated heating/cooling of the metal rack. Unfortunately, I have not made note of whether the P7 was in the system/rack at the time.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #6256 of 6436 Old 01-18-2019, 01:18 PM
WAFWarrior's Avatar
Quoted: 140 Post(s)
Liked: 79
Configuration:
P7 preamp + A52 amp
TMA Subwoofer
415-397-7100
Chris
2250 Mckinnon Ave.
415-397-7100
post #6257 of 6436 Old 01-20-2019, 04:01 PM
Quoted: 178 Post(s)
Liked: 32
To @WAFWarrior and others: I'm using the Halo Integrated DAC/preamp part and connect its analog out to a standalone power amp which connects to speakers. Will that cause any damage to the HINT as its amp part no longer has speakers connected? Thanks.
Setup #1: GoldenEar Triton Reference --> Parasound Halo Integrated --> Allo DigiOne Signature, LG OLED C7P 65
Setup #2: Elac Debut B6.2 --> Akitika GT-102 --> ??
tt.tennis-warehouse.com/index.php, www.dpreview.com/forums, www.bimmerfest.com/forums
Shangri-La is offline
post #6258 of 6436 Old 01-20-2019, 04:09 PM
Delija's Avatar
Quoted: 417 Post(s)
Liked: 287
Of course not.
Delija is offline
post #6259 of 6436 Old 01-20-2019, 07:51 PM
Quoted: 178 Post(s)
Liked: 32
Okay, I did some quick research and it seems no load damaging power amp is more of a tube amp thing. But if I put dummy speaker load like this or this to the HINT, what are the electrical/sonic affects?
post #6260 of 6436 Old 01-21-2019, 01:10 PM
WAFWarrior's Avatar
Quoted: 140 Post(s)
Liked: 79
This approach using a load resistor is not necessary. Having nothing connected to the amp section of this Integrated Amp will not affect it adversely.
Chris
2250 Mckinnon Ave.
415-397-7100
post #6261 of 6436 Old 01-21-2019, 02:42 PM
Quoted: 178 Post(s)
Liked: 32
Thank you for the confirmation.
post #6262 of 6436 Old 01-22-2019, 07:22 PM
Quoted: 158 Post(s)
Liked: 25
I wonder why you need external amp with Hint?
Sent from my Mi Note 3 using Tapatalk
Parasound Halo Integrated, Pioneer SC-LX 901, Oppo-205, Revel F208 + Heco Aurora Center 30 + Heco Victa Prime 202, Takstar HF 580
vavan is offline
post #6263 of 6436 Old 01-22-2019, 09:43 PM
Quoted: 178 Post(s)
Liked: 32
Just trying different amps. The Akitika GT-102 actually. Very impressed.
vavan likes this.
post #6264 of 6436 Old 01-22-2019, 10:27 PM
WestCoastD's Avatar
Quoted: 327 Post(s)
Liked: 134
looks like a very cool amp project, especially for the price (I'd love to build one of these)
Shangri-La likes this.
WestCoastD is offline
post #6265 of 6436 Old 01-25-2019, 10:58 AM
Craig Peer's Avatar
Quoted: 7113 Post(s)
Liked: 8466
I recently got a new Parasound A 52+ , and have been testing it out in my home theater. I have a Denon X8500 running 13 Martin Logan 4 ohm Motion speakers ( 2 Motion 40’s, 1 Motion SLM XL center speaker, 4 Motion FX surrounds, 2 Motion LX16 wide channel speakers, 4 Motion 4 height speakers, and 4 SVS subwoofers ). I have been running my Motion 40's with an Emotiva XPA 200 I've had since the Denon 4520 days. Now I'm using the A 52+ to run the L / C / R and wide channel speakers, and letting the X8500 run the heights and surrounds. The difference last night watching the Mission: Impossible – Fallout 4K Blu-ray ( excellent Atmos sound track by the way ) was noticed by all my guests. The extra headroom just seems to give a cleaner, less fatiguing sound. Even cranked to 78 on my Denon ( which is pretty loud in my theater ). So far I think the A 52+ is the perfect compliment for my receiver. I also installed AC Infinity Aircom T10 cooling fans, and the amp and X8500 never got much over 80 degrees, even after 2 1/2 hours of " Fallout " 13 channels of Atmos audio hammerfest !
This is a great amp !
ID:	2515982   Click image for larger version
Spizz, David Ortiz, MNSACD and 3 others like this.
[email protected] JVC RS4500, Lumagen Radiance Pro, Panamorph Paladin DCR lens, Stewart Luxus Model A ElectriScreens - 128" diagonal 2.35:1 ST130 & 122" diagonal 16:9 Cima Neve, Denon X8500, Parasound A 52+ amp, Martin Logan Motion series 9.4 speakers, four SVS subs, Panasonic UB820, Oppo 203, PFP M1500 UPS
Craig Peer is offline
post #6266 of 6436 Old 01-25-2019, 02:01 PM
stash64's Avatar
Quoted: 603 Post(s)
Liked: 225
And there are so many on AVS Forum that continue to say an amplifier does not make a difference and the amps in an AVR are "just as good". I find most of these people have never even tried an external amplifier.
Sean
stash64 is offline
post #6267 of 6436 Old 01-25-2019, 02:36 PM
Craig Peer's Avatar
Liked: 8466
I like to play action / war / sci-fi movies pretty loud ( when the wife isn't watching anyway ). And my theater is around 3550 cubic feet, best as I can measure ( with a 12' tall peaked ceiling ).
Two of my guests last night had already watched " Fallout " in my theater prior to my installing the A 52+. They commented that the sound was yet again better in my room ! The same guests commented on a sound improvement when I installed acoustic panels - without my mentioning I made any changes ! So there is an improvement !
audiofan1 likes this.
post #6268 of 6436 Old 01-28-2019, 07:37 AM
dmarcink's Avatar
Quoted: 189 Post(s)
Liked: 126
Everything matters as you have found out. Some to a lesser degree than others. Acoustic treatments and better amplification certainly do provide great improvements.
High Performance Audio and HT is not a hobby.... but a lifestyle choice.
Craig Peer and audiofan1 like this.
"Every time I put the line in the water I said a Hail Mary and every time I said a Hail Mary I caught a fish." - Fredo
Sony XBR65A1E-Marantz AV8802a-Oppo BDP-203-Parasound Halo A21 & A31-ZoneMaster 1250 -Zamp v.3 (x2) -Paradigm Studio Sub-15 -Vandersteen Signature 2ce Mk II -Vandersteen VCC-2 center -Energy RVSS Surrounds -Yamaha NS-IC800 ceiling Atmos(x4)- Furman Elite 15i
dmarcink is offline
post #6269 of 6436 Old 02-01-2019, 06:56 PM
Jarrod2750's Avatar
Quoted: 41 Post(s)
Liked: 29
I took the upgrade plunge and went from two 2125 bi-amping each of my Klispch Epic CF 3s to a Halo a21 and all I can say is wow! The sound is more dynamic and I could swear the detail is much better. It took me a couple of years for this upgrade but well worth the wait.
Marantz AV8805, Parasound Halo a21, (2)Parasound 2250, Parasound 275, Panamax 5400PM
Klipsch Epic CF3 V1, KV 4, (4) RP250S,(2)RP140S (2)CDT5650
LG Oled 65C8,Oppo 205, Pro-ject 2xperience Classic w/Music Hall speed Control
Cambridge Audio Azur 851N, Harmony Ultimate,(2) SVS SB 3000
Jarrod2750 is offline
post #6270 of 6436 Old 02-05-2019, 04:44 AM
cccoltsicehockey's Avatar
Looking for a replacement for an old 1205A my father has that has all the overload lights on. There is not an authorized repair place in any reasonable amount of distance and shipping would probably not make sense for a unit this old. Would the A52+ be a newer replacement for this? It seems to have a little more power 180 vs 140 per channel but otherwise seems to be very similar.
cccoltsicehockey is offline
Parasound , Parasound Products Inc , Parasound Classic 2100 Stereo Pre Amp
