Parasound Owners Thread - Page 210 - AVS Forum | Home Theater Discussions And Reviews
 709Likes
post #6271 of 6405 Old 02-15-2019, 06:04 AM
JodyV's Avatar
Liked: 4
Just ordered a Parasound 2250 to power a pair of Polk LSiM 705's.
Pretty solid amp?
vavan likes this.
JodyV is offline
post #6272 of 6405 Old 02-15-2019, 06:38 AM
Quoted: 125 Post(s)
Pretty solid amp?
Please report back your impressions!
I went the other way around and bought lsim 705 to mine hinto last weekend
Sent from my Mi Note 3 using Tapatalk
Parasound Halo Integrated, Pioneer SC-LX 901, Oppo-205, Polk Audio LSiM 705 + Heco Aurora Center 30 + Heco Victa Prime 202
vavan is offline
post #6273 of 6405 Old 02-15-2019, 07:05 AM
JodyV's Avatar
Liked: 4
So first of all, the LSiM's are freaking sick and you're gonna love them. Everything from sound to build quality was shockingly good.
The new amp lands Tuesday - looking forward to seeing how it sounds. Right now I have an Aventage 2080 AVR driving them... which is no slouch... but I have a feeling the new amp is really going to light these things up.
vavan and yanks1 like this.
JodyV is offline
post #6274 of 6405 Old 02-15-2019, 07:08 AM
Quoted: 125 Post(s)
I really hope I will, see my recent post in official polk thread
vavan is offline
post #6275 of 6405 Old 02-16-2019, 11:51 AM
stash64's Avatar
Quoted: 591 Post(s)
Liked: 219
To those with an A21, have you managed to get the amp to trigger on using the "audio sensing" option ? If so, what's the secret ?
It's never worked for me and I really need it to work now that I have both a HT pre-amp and a 2-channel pre-amp going thru the A21. My A21 is in the basement. On the plus side, I would get a little more exercise if I have to turn it on and off manually.
Sean
stash64 is offline
post #6276 of 6405 Old 02-16-2019, 01:28 PM
Delija's Avatar
Quoted: 396 Post(s)
Liked: 269
It works on my A21, but I don't like it - it goes to standby without input too fast.
I use 12V trigger.
Anthem MRX 720 | Parasound Halo A21
Dynaudio Contour 60 | Dynaudio Excite X28 | Dynaudio Emit M20 | 2x SVS SB16-Ultra
LG OLED65C7V
Delija is offline
post #6277 of 6405 Old 02-16-2019, 06:35 PM
stash64's Avatar
Quoted: 591 Post(s)
Liked: 219
Are you using RCA or XLR on the A21 ? I've only used XLR but can't get it to trigger even with the lowest setting (50 mV).
Sean
stash64 is offline
post #6278 of 6405 Old 02-17-2019, 02:45 AM
Delija's Avatar
Quoted: 396 Post(s)
Liked: 269
RCA. I haven't tried XLR.
LG OLED65C7V
Delija is offline
post #6279 of 6405 Old 02-17-2019, 04:54 AM
BillP's Avatar
Quoted: 488 Post(s)
Liked: 418
I use 12V trigger with XLR and it works perfectly. My A21 turns on and off automatically whenever I turn my JC2 preamp on and off.
BillP is offline
post #6280 of 6405 Old 02-17-2019, 09:58 AM
stash64's Avatar
Quoted: 591 Post(s)
Liked: 219
The 12V trigger works fine on my A21 as well. But given there is only one trigger input, the audio sensing turn on option is the better choice if using more than one pre-amp. I may have to purchase a couple of male to female mono cables, one for each pre-amp, and just swap the amp trigger cable back and forth.
Sean
stash64 is offline
post #6281 of 6405 Old 02-17-2019, 09:55 PM
jima4a's Avatar
Quoted: 430 Post(s)
Liked: 210
Assuming your 2 channel preamp has HT bypass? If so, does it have a trigger out? If not, how do you switch from Pre/pro to preamp?
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
post #6282 of 6405 Old 02-18-2019, 10:39 AM
stash64's Avatar
Quoted: 591 Post(s)
Liked: 219
I believe it does have HT bypass. It's a new NAD C658. However, I am not interested in using HT bypass if both pre-amps have to be ON at the same time for the bypass to work. I want to run one pre-amp at a time, though I suspect it might work with the NAD in standby. It also would require RCA connections and I am trying to maintain all XLR for the signal path. I am accomplishing the switch manually with two short pairs of XLR cables coming off each pre-amp and then "daisy chaining" to a longer XLR cable connected to the amp.
I was also considering using a second amp, but then there would have to be a amp/speaker switch in the mix somehow. I even briefly considered connecting the two stereo amps to my front speakers bi-amp terminals (in non bi-amp configuration) but I think this would be dangerous as the powered on amp would backfeed to the powered off amp, especially if the powered off amp was not actually powered off.
Sean
stash64 is offline
post #6283 of 6405 Old 02-18-2019, 10:54 AM
Quoted: 712 Post(s)
Liked: 284
It's been a while since I've owned an A 21, but I have three JC 1 monoblocks and two A 23s, all used with the audio sensing option. The JC 1s have two trigger controls, one for trigger level and the other for duration of silence before shut-down; the A 23 has only trigger level. Have you tried adjusting that? The A 21 is fine amp.
dbphd is offline
post #6284 of 6405 Old 02-18-2019, 11:06 AM
stash64's Avatar
Quoted: 591 Post(s)
Liked: 219
Agreed. A21 is a great amp, but I did notice that the trigger circuitry has been improved on the A21+... which led me to believe that my issue is not unique. It did not bother me too much that audio sensing did not work because the 12V trigger worked fine. But now I realize that the audio sensing trigger is more versatile... if it works. I did try the lowest sensitivity setting (50 mV) but still would not trigger. I suspect it works fine with RCA but not so much with XLR.
Sean
stash64 is offline
post #6285 of 6405 Old 02-18-2019, 11:51 AM
Craig Peer's Avatar
Quoted: 6613 Post(s)
Liked: 7687
Originally Posted by cccoltsicehockey View Post
Looking for a replacement for an old 1205A my father has that has all the overload lights on. There is not an authorized repair place in any reasonable amount of distance and shipping would probably not make sense for a unit this old. Would the A52+ be a newer replacement for this? It seems to have a little more power 180 vs 140 per channel but otherwise seems to be very similar.
I'm not familiar with the 1205A, but it sure looks like the A 52 + would be a great replacement. I've been enjoying experimenting watching all sorts of movies with mine. My surround sound has never sounded cleaner/ better, and both the A 52+ and my Denon X8500 barely break out of the 70 degree temperature range even when pushed pretty hard ( ear bleed levels ). And I can easily run the sound beyond reference levels if I want ( and my wife isn't in the room ).
Craig Peer is offline
post #6286 of 6405 Old 02-19-2019, 01:17 PM
WAFWarrior's Avatar
Quoted: 140 Post(s)
Liked: 78
There is a chance there is something that is damaged or faulty on the auto turn on circuit of your amplifier. I suggest that you call Parasound's Tech department for more info.
415-397-7100
or alternatively you can email [email protected]
Chris
Parasound Products Inc.
2250 Mckinnon Ave.
San Francisco CA 94124
415-397-7100
WAFWarrior is offline
post #6287 of 6405 Old 02-19-2019, 05:34 PM
stash64's Avatar
Quoted: 591 Post(s)
Liked: 219
415-397-7100
Thanks... I found a mono splitter (dual male to single female) and plan to hook up one male end to each of the pre-amps and then the female end to the trigger cable. I think this should work.
Sean
stash64 is offline
post #6288 of 6405 Old 02-20-2019, 10:41 AM
stash64's Avatar
Quoted: 591 Post(s)
Liked: 219
415-397-7100
Chris,
I realized last night that my idea to use a splitter will not work (or might be dangerous) if I use the mono trigger cable. I would need to use a stereo cable to ensure that the trigger signal from each pre-amp is kept separate. Would you know if using a stereo cable would work to trigger the A21 ? In my past experience, it works on some equipment but not others.
Sean
stash64 is offline
post #6289 of 6405 Old 02-20-2019, 04:17 PM
WAFWarrior's Avatar
Quoted: 140 Post(s)
Liked: 78
Chris,
Thanks for the question. I would avoid using this approach with a TRS stereo trigger into your A21. There are a few aspects that could cause issues .
Chris
2250 Mckinnon Ave.
415-397-7100
post #6290 of 6405 Old 02-20-2019, 10:31 PM
jima4a's Avatar
Quoted: 430 Post(s)
Liked: 210
Chris,
There is no way short of using diodes to split 12V DC signal into unique paths that I am aware. However, you could use a powered trigger expander such as Emotiva’s ET-3.
Edit: Not sure how you are feeding one amp with two different preamps/ prepro without HT bypass but my suggestion above may not help. You just want to turn on your A-21 remotely, correct? So you just need to supply a 12 V DC signal to the amp, does not need to be from a preamp. I remember someone had found a remote power strip and had a 12 V power supply plugged in giving them the ability to operate an amp remotely.
I would still run any plans by Parasound Technical before employing.
WAFWarrior likes this.
jima4a is offline
post #6291 of 6405 Old 02-21-2019, 11:00 AM
stash64's Avatar
Quoted: 591 Post(s)
Liked: 219
Jim,
You got me all excited with the mention of the Emo trigger module, but alas it does the opposite of what I need. It looks like it can be manually triggered and thus would work for one of the source components. I will stay away from my original plan (using a splitter) based on Chris' comment above. I think it would work right up to the A21 but, given the A21 was designed to be triggered with a mono cable, I believe the 12V would find it's way back from the A21 to the unpowered source device.
My new strategy is to stick with the mono cable from the amp and then use a male to female mono cable on each source component and simply swap the connections before powering on. I'm already swapping XLR cables.
The ultimate solution would be to trade in the A21 for the A21+.
Sean
stash64 is offline
post #6292 of 6405 Old 02-21-2019, 03:28 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1876 Post(s)
Liked: 2275
^ The ultimate solution might be to reconsider your approach. Swapping the cables around frequently really isn't a great long term solution. If nothing else, it's tedious. For the amp trigger, it might just be easier to turn the amp on and off manually than to keep swapping the cables. IMHO a better approach might be to replace the current 2 channel preamp and surround preamp with a single, but better, surround preamp and simplify the system significantly in the process.
gsr is offline
post #6293 of 6405 Old 03-01-2019, 06:02 AM
Delija's Avatar
Quoted: 396 Post(s)
Liked: 269
Has anyone compared P6 vs higher class AVR (Anthem MRX 720/1120, Arcam AVR 550/850...) or pre/pro (Anthem AVM 60, Arcam AV860...) as stereo DAC + preamp + bass management or preamp + bass management?
LG OLED65C7V
Delija is offline
post #6294 of 6405 Old 03-04-2019, 03:12 AM
Yveke's Avatar
Quoted: 18 Post(s)
Liked: 3
Hi,
With the risk of getting an answer that is "just buy only Parasound"
I am very satisfied with my ATI amps for HT use, however I use a Parasound JC2-BP preamp for 2 channel listening and find the JC2 with ATI AT4002 a bit harsh and fatigueing to listen to at low to medium volume. I am thinking of changing either the amp or the pre, what are your thoughts? Changing to JC5 amp cos parasound and ATI just don't mate well?...
Thanks in advance,
Yves
Arendal Subwoofer 3 - KEF R900 front R600c center R700 surround R700 rear surround -Kef R8a Atmos front- Kef R50 back- ATI 4002 signature - ATI 2005 - Parasound JC2BP - IOTAVX AVXP1 - Cambridge Audio 851N - Marantz AV7702 - Dune HD Solo 4K - xbox one x - Asset UPnP from QNap NAS - Pioneer LX5090 - Epson TW3600EW
Yveke is offline
post #6295 of 6405 Old 03-04-2019, 04:17 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 2275
Originally Posted by Yveke View Post
Hi,
The ATI Signature amps are excellent amps, as are the Parasound amps and I've heard only good things about the JC2-BP. I'd be more inclined to believe that your speakers are responsible for your dissatisfaction than the amps or preamp as they're by far the most important factor here.
RichB likes this.
gsr is offline
post #6296 of 6405 Old 03-04-2019, 04:48 AM
BillP's Avatar
Quoted: 488 Post(s)
Liked: 418
Yes, it could be your speakers. But it could also be a bad match between your amp and preamp. I have the JC2-BP matched with the Parasound Halo A21 for 2-channel, and it is incredible. I would switch out either the amp or preamp to match the brand (Parasound or ATI) from a local place that lets you try it out at home.
BillP is offline
post #6297 of 6405 Old 03-04-2019, 11:24 AM
Quoted: 712 Post(s)
Liked: 284
I've used my JC 2 BP with A 21s and agree the sound is excellent. I now use the JC 2 BP with JC 1 monoblocks that really make my KEF Ref 107/2s sing down to a usable 20 Hz to portray that subtle vibration you feel at a live organ recital when a large pipe is invoked.
dbphd is offline
post #6298 of 6405 Old 03-05-2019, 11:54 AM
Yveke's Avatar
Quoted: 18 Post(s)
Liked: 3
Thanks guys! Not too many options to try different preamps/amp combinations in my heck of the woods. ATI does not yet have a (HT)preamp, so that combo is not really an option. Was hoping someone would have had some input on ATI ammps with Parasound preamp experiences. Maybe it is the source...Cambridge Audio 851N, cos even with the AV7702 in pure direct and cambridge audio streamer it is pretty "harsh", but not as clear in imaging and soundstage as the JC2.
Thanks again and enjoy the music.
Y.
Yveke is offline
post #6299 of 6405 Old 03-05-2019, 08:43 PM
TheMadMilkman's Avatar
Quoted: 20 Post(s)
Oh hey, my P6 finally arrived! That only took... a long time. Apparently it has sold really, really well.
I won’t make any sound quality comments, but the ergonomics are great. Controls feel good, and the volume display isn’t overly bright, at least when it’s dimmed. I really like the silver color, which has a bit of a gold tint to it. Very classy. So far I’ve just been casually listening to some new stuff, since I havent had a working system for the last few months. I’ll do some more serious listening this weekend.
Oh, and make sure you don’t accidentally misread “rec out” as “ pre out.” Thankfully I pulled up a stream on my phone to play and had the phone’s volume down. Oops.
TheMadMilkman is offline
post #6300 of 6405 Old 03-12-2019, 05:55 PM
mzs22's Avatar
Quoted: 225 Post(s)
Liked: 91
The A52+ seems to be a very nice amp, after adding two more atmos speakers two my system I was thinking about adding the 52+ to my system to take some of the load off my receiver but not sure if I can configure the amp with my receiver.
mzs22 is offline
Parasound , Parasound Products Inc , Parasound Classic 2100 Stereo Pre Amp
